#1 2020-01-03 06:47:56
farmatito
[Solved]Mailing list problems
I've tried a few times to post to the DNG mailing list, but the mails just
silently don't make it through. Is there somebody to contact who can
fix this?
Best regards.
#2 2020-01-03 07:24:09
Re: [Solved]Mailing list problems
Yes.  Me.  OK, the messages are in moderation because they are over the 40  KB size limit.  Can you trim them a bit?
#3 2020-01-03 08:48:27
farmatito
Ok, will try in the afternoon.
Best regards,
farmatito
#4 2020-01-03 16:34:51
Looks like your email finally got through to the list.  There are 3 failed over-sized instances in moderation.  I will delete unless you give me a reason not to.
#5 2020-01-14 14:00:07
farmatito
Delete them. Thanks
