#1 2019-12-20 16:07:05
roluan17
USB Multiboot
searching a way to install more than one ISO on one  flash-drive (multiboot?).
Any kind hints  out there?
Tried unetbootin and got some strange (I don't understand them) errors:
add apt-repository ppa:gezakovacs/ppa  ==> bash: add: Kommando nicht gefunden (command not found)
I installed beforehand:
python-software-properties,
software-properties-common,
multisystem  (can not be found)
apt-add-repository 'deb http://liveusb.info/multisystem/depot all main'
  File "/usr/bin/apt-add-repository", line 95, in <module>
    sp = SoftwareProperties(options=options)
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
    self.reload_sourceslist()
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
    self.distro.get_sources(self.sourceslist)
  File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
    (self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Devuan/ascii
apt-get install cryptsetup grub-pc hal syslinux zenity imagemagick squashfs-tools fatresize fuseiso wmctrl xdotool qemu gtkdialog
Paketlisten werden gelesen... Fertig (package lists are read ...ready)
Abhängigkeitsbaum wird aufgebaut.       (dependancy-tree is built)
Statusinformationen werden eingelesen.... Fertig (status quo is read ... ready)
Paket hal ist nicht verfügbar, wird aber von einem anderen Paket (package hal is not available,
but is referenced to an other package
referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
wurde oder nur aus einer anderen Quelle verfügbar ist.
(package hal is not available, but is referenced to an other package.
 This can mean, package is missing, relieved or only available from an other source)
E: Für Paket »hal« existiert kein Installationskandidat.
                                           (for package "hal" there is no installation candidate)
E: Paket gtkdialog kann nicht gefunden werden.
                                          (package gtkdialog can not be found)
Pardon my english translation, may be funny.
#2 2019-12-20 16:53:58
Re: USB Multiboot
Please look at the multi-boot iso that fsmithred made for the Devuan conference in April.  That may give you some hints.
#3 2019-12-20 17:54:40
roluan17
Re: USB Multiboot
Thank you! That was quick.
Will test it tomorrow.
greetings
#4 2019-12-20 19:34:00
Re: USB Multiboot
My recommendation is not impartial, and I won't try to debug unetbootin. Use my software to make a multi-boot usb.
refracta2usb download - https://sourceforge.net/projects/refrac … b/download
Instructions (at least read the Quick Start!) - https://refracta.org/docs/readme.refracta2usb.txt
It uses isolinux/syslinux. If you want grub bootloader on it, we can change it to that later.
#5 2019-12-20 20:15:51
ilargi
Re: USB Multiboot
You may be interested in trying multibootusb http://multibootusb.org/. You can just download the tar.gz file and use it from a local folder. No need to install it.
#6 2019-12-21 13:43:16
Re: USB Multiboot
To make a "multiboot" USB simply copy the images to a partition on the USB stick then install both types of GRUB:
# mount /dev/sdXY /mnt
# mkdir -p /mnt/boot/efi
# mount /dev/sdXZ /mnt/boot/efi
# grub-install --target=i386-pc --boot-directory=/mnt/boot /dev/sdX
# grub-install --target=x86_64-efi --boot-directory=/mnt/boot --efi-directory=/mnt/boot/efi --removable
The stick will need both the main root partition (/dev/sdXY) and an EFI system partition (/dev/sdXZ) with a GUID partition table and a BIOS boot partition. For both UEFI and non-UEFI grub-install commands use the grub-pc-bin & grub-efi-amd64-bin packages. For multibitness UEFI systems there is also a grub-efi-ia32-bin package (--target=i386-efi).
Then write (/mnt)/boot/grub/grub.cfg with menu entries for each image, here is an example stanza for a Devuan ISO image:
menuentry 'Devuan (live)' {
   isofile=usr/share/iso/devuan.iso
   search.fs_uuid $uuid_stick root
   loopback loop $root/$isofile
   linux (loop)/live/vmlinuz boot=live config fromiso=$root/$isofile toram
   initrd (loop)/live/initrd.img
In this example the ISO image is stored on the root partition under /usr/share/iso/devuan.iso (because FHS) but you can put it wherever you want. Replace $uuid_stick with the actual UUID of the root partition.
#7 2019-12-23 21:44:16
Micronaut
Re: USB Multiboot
Unetbootin is not the only bootable USB creator. As far as I know, Rufus can install multiple environments on a single USB stick. But I've never used it that way myself.
https://rufus.ie/
#8 2019-12-28 16:25:16
roluan17
Re: USB Multiboot
rufus? Isn't that for "He Who Cannot Be Named"?
#9 2019-12-28 17:18:32
roluan17
Re: USB Multiboot
@golinux
well, dev1usb seems to run. But I can't get further than login:
Please give me a hint, the readme is quite frugal.
#10 2019-12-28 17:51:29
Re: USB Multiboot
I forget exactly how I arranged the boot menu, but there should be four different systems you can boot: minimal-live and desktop-live both in i386 and amd64. Which one did you boot and what happened after you logged in?
If you want to make your own live-usb, you're in the wrong place. Use one of the usb creators or do it manually as mentioned in posts above.
#11 2019-12-28 18:07:01
Re: USB Multiboot
@fsmithred . . . I suggested he look at that to confirm that multiboot can be done.  I thought if he poked at it a bit he might be able to figure out how to put one together.
#12 2019-12-29 10:13:21
roluan17
Re: USB Multiboot
Well I put that img (dev1usb_2019-03-28.img) to a stick and it runs ok until  I have a black screen leaving the prompt blinking after
"login:"
I thought there might be a hint in any READme, but couldn't find one.
This was no try to create a multiboot system though it definitely has several different Devuan distros on board which can be selected during the boot process.
#13 2019-12-29 11:04:54
Re: USB Multiboot
I'd imagine that if you don't select one of the choices at the boot menu, you are being dropped into a terminal session, possibly for recovery purposes. If you do select a distro at boot time, does it then load to a desktop?
#14 2019-12-29 12:07:08
Re: USB Multiboot
If you do nothing at the boot menu, you will get the first item, which is desktop-live i386. The system is set for automatic login, so if you got a login screen, something is wrong.
What kind of instructions would you like? There's not much to say. Just dd the image to a usb stick, boot the stick and choose a system. If you want to install one of those systems, it's probably better to download one of the 2.1 isos, because they are newer.
#15 2019-12-29 16:05:36
roluan17
Re: USB Multiboot
Thank you for the reply!
I thought, it would be something similar to STAR,  Login: starlive Pwd: live.
I'll by me a new stick, tomorrow. Then I will go on again.
greetings
#16 2019-12-29 21:31:24
Re: USB Multiboot
If you do get a login screen (maybe after you log out) the username/password combination is devuan/devuan (or root/toor).
Check the sha256sum on the .img file to make sure it downloaded correctly.
#17 2023-03-18 22:06:55
bai4Iej2need
Re: USB Multiboot
404 Not Found
broken by design :
#18 2023-03-19 02:22:30
Trev Brownen
Re: USB Multiboot
refind a program that lets yoy boot many operating systems I have 30 on a large usb stick.
http://www.rodsbooks.com/refind/
#19 2023-03-19 18:49:32
Devarch
#20 2023-04-10 17:30:02
bai4Iej2need
Re: USB Multiboot
rEFInd is UEFI only and does not work with some older HW of mine
Ventoy was the solution for me.
ls -hl
insgesamt 7,8G
-rwxr-xr-x 1 md md 2,6G  8. Apr 22:57 debian-live-11.6.0-amd64-xfce.iso
-rwxr-xr-x 1 md md 372M 16. Jun 2022  devuan_chimaera_4.0.0_amd64_netinstall.iso
-rwxr-xr-x 1 md md 642M 13. Jun 2022  devuan_chimaera_4.0.0_amd64_server.iso
-rwxr-xr-x 1 md md 405M 16. Jun 2022  devuan_chimaera_4.0.0_i386_netinstall.iso
-rwxr-xr-x 1 md md 1,2G  8. Apr 23:22 devuan_chimaera_4.0.2_amd64_desktop-live.iso
-rwxr-xr-x 1 md md 586M 10. Apr 23:48 devuan_chimaera_4.0.2_amd64_minimal-live.iso
-rwxr-xr-x 1 md md 856M  8. Apr 22:55 grml64-full_2022.11.iso
-rwxr-xr-x 1 md md 874K 29. Sep 2014  Memtest86-4.3.7.iso
-rwxr-xr-x 1 md md 6,0M 11. Apr 01:22 mt86plus_6.10_64.iso
-rwxr-xr-x 1 md md  816 11. Apr 00:59 SHA256SUMS_ventoy_sorted
-rwxr-xr-x 1 md md 1,3G 10. Apr 12:35 tails-amd64-5.11.img
broken by design :
