#1 2019-12-09 02:56:09
defunctlizard
Is any work planned for devuan on the raspberry pi 4?
I plan on buying a raspberry pi 4, but I want to check if my favorite distribution will be able to potentially run on this thing. I realize that not many distributions support the raspberry pi 4 as of now, but is it planned as of now?I would really like if my favorite distribution would run on it smile
#2 2019-12-09 04:03:21
freemedia2018
Re: Is any work planned for devuan on the raspberry pi 4?
i would be surprised if debian supported raspberry pi 4 and devuan didnt sooner or later-- unless the person in charge of raspberry pi in devuan left recently.
i would also be very surprised if debian didnt support raspberry pi 4 but devuan did. so, im assuming that debian either does, or will soon.
monopolies are able to change free software so it better serves their freedom than ours.
why is that so difficult to prove to many free software advocates, and what is it that stops them from caring?
#3 2019-12-09 04:21:42
From the ASCII 2.1 point release announcement
What about ARM and virtual images?
Going forward, ARM and also virtual images will be provided by the greater Devuan community rather than as part of official releases. Users are being encouraged to build and contribute ARM images for their particular hardware. This will increase the variety of images available and allow the release schedule of the installer ISOs to move forward more quickly.
Images can be built using using arm-sdk and vm-sdk: https://devuan.org/os/distro-kit
Arm-related discussion happens at #devuan-arm (Freenode) and https://dev1galaxy.org/viewforum.php?id=24
Images will eventually be available via p2p torrent(s).
https://devuan.org/os/debian-fork/ascii … nce-112119
#4 2019-12-09 05:16:32
yeti
Debian will... if I remember a not sooo old talk by GWolf correctly...
#5 2019-12-09 16:14:48
tuxd3v
Hello,
I would make a Image of RPi4, but I don't own one.. sad
If you agree in be a beta tester, sure I will do!! smile
Best Regards,
tux
#6 2020-01-11 16:03:14
uther
tuxd3v, if you are still looking for a beta tester for RPi4 builds than I volounteer.
Want to use it as a small NAS in the future, so having Devuan on it would be great!
soystemd-free diet
#7 2020-01-13 07:33:40
tuxd3v
Yup smile
What is the memory size of the version you have?
Best Regards,
tux
#8 2020-01-13 11:50:56
uther
I have 4GB model.
soystemd-free diet
#9 2020-01-15 00:10:10
tuxd3v
uther wrote:
I have 4GB model.
Ok, can you please issue on the Oficial raspbian image, as root:
zcat /proc/config.gz
And post the result?
I have checked, uboot has support for it..
ArmTrustedFirmware has also some support at least..
I compiled uboot with stage 'bl31' without issues..
For the kernel, I would need that output to start with( config.gz above.. ).. smile
Kernel 5.4.11 doesn't support this board yet, but kernel 5.5 is were I believe support was added smile
Best Regards,
tux
#10 2020-01-15 22:08:49
uther
We have some progress. I've extracted two configs. Default 4.19.75-v7l+ (just in case) and 5.5.0-rc6-v7l+ They're pretty lenghy, so do you prefer them pasted here directly or on some pastebin?
During compilation 5.5.0 kernel there was couple of warnings about soundcard and Realtek network card. No errors thou.
soystemd-free diet
#11 2020-01-16 05:24:49
kramer
Hello uther, thanks for your work, feel free to paste them here, I'll use them to create new images. BTW did you ran the 5.x Kernel succesfully or are there any errors or issues so far?
#12 2020-01-16 07:55:14
uther
Hi, no problem. So far I didn't noticed any instabilities on 5.5, didn't try with 5.4. Considering aforementioned compile warnings there could be some audio or networking issues. I'll try to check it today. As of now - networking works, didn't check audio yet. If you want I can run specific tests, so feel free to give me the details.
Pasting 4.19 config:
# Automatically generated file; DO NOT EDIT.
# Linux/arm 4.19.75 Kernel Configuration
# Compiler: arm-linux-gnueabihf-gcc (crosstool-NG crosstool-ng-1.22.0-88-g8460611) 4.9.3
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=40903
CONFIG_CLANG_VERSION=0
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="-v7l"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_SIM=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_GENERIC_MSI_IRQ=y
CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
CONFIG_GENERIC_IRQ_DEBUGFS=y
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# CONFIG_PREEMPT_NONE is not set
CONFIG_PREEMPT_VOLUNTARY=y
# CONFIG_PREEMPT is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_CPU_ISOLATION=y
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
CONFIG_BUILD_BIN2C=y
CONFIG_IKCONFIG=m
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
# CONFIG_MEMCG_SWAP is not set
CONFIG_MEMCG_KMEM=y
CONFIG_BLK_CGROUP=y
# CONFIG_DEBUG_BLK_CGROUP is not set
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
# CONFIG_CFS_BANDWIDTH is not set
# CONFIG_RT_GROUP_SCHED is not set
CONFIG_CGROUP_PIDS=y
# CONFIG_CGROUP_RDMA is not set
CONFIG_CGROUP_FREEZER=y
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
# CONFIG_CGROUP_PERF is not set
# CONFIG_CGROUP_DEBUG is not set
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_CHECKPOINT_RESTORE is not set
CONFIG_SCHED_AUTOGROUP=y
# CONFIG_SYSFS_DEPRECATED is not set
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
CONFIG_EXPERT=y
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_KALLSYMS_BASE_RELATIVE=y
# CONFIG_BPF_SYSCALL is not set
# CONFIG_USERFAULTFD is not set
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_RSEQ=y
# CONFIG_DEBUG_RSEQ is not set
CONFIG_EMBEDDED=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
# CONFIG_SLUB_MEMCG_SYSFS_ON is not set
# CONFIG_COMPAT_BRK is not set
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
CONFIG_SLUB_CPU_PARTIAL=y
CONFIG_SYSTEM_DATA_VERIFICATION=y
CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_MIGHT_HAVE_PCI=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ZONE_DMA=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_FIQ=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=3
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_AXXIA is not set
CONFIG_ARCH_BCM=y
# IPROC architected SoCs
# CONFIG_ARCH_BCM_CYGNUS is not set
# CONFIG_ARCH_BCM_HR2 is not set
# CONFIG_ARCH_BCM_NSP is not set
# CONFIG_ARCH_BCM_5301X is not set
# KONA architected SoCs
# CONFIG_ARCH_BCM_281XX is not set
# CONFIG_ARCH_BCM_21664 is not set
# CONFIG_ARCH_BCM_23550 is not set
# Other Architectures
CONFIG_ARCH_BCM2835=y
# CONFIG_ARCH_BCM_53573 is not set
# CONFIG_ARCH_BCM_63XX is not set
# CONFIG_ARCH_BRCMSTB is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_NPCM is not set
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
# CONFIG_SOC_AM33XX is not set
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
# CONFIG_ARCH_SIRF is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32 is not set
# CONFIG_ARCH_SUNXI is not set
# CONFIG_ARCH_TANGO is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZX is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
CONFIG_ARM_LPAE=y
CONFIG_ARM_THUMB=y
# CONFIG_ARM_THUMBEE is not set
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_CPU_SPECTRE=y
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
# CONFIG_CACHE_L2X0 is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_DEBUG_ALIGN_RODATA=y
# CONFIG_ARM_ERRATA_430973 is not set
CONFIG_ARM_ERRATA_643719=y
# CONFIG_ARM_ERRATA_720789 is not set
# CONFIG_ARM_ERRATA_754322 is not set
# CONFIG_ARM_ERRATA_754327 is not set
# CONFIG_ARM_ERRATA_764369 is not set
# CONFIG_ARM_ERRATA_775420 is not set
# CONFIG_ARM_ERRATA_798181 is not set
# CONFIG_ARM_ERRATA_773022 is not set
# CONFIG_ARM_ERRATA_818325_852422 is not set
# CONFIG_ARM_ERRATA_821420 is not set
# CONFIG_ARM_ERRATA_825619 is not set
# CONFIG_ARM_ERRATA_852421 is not set
# CONFIG_ARM_ERRATA_852423 is not set
# Bus support
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCI_DOMAINS_GENERIC=y
CONFIG_PCI_SYSCALL=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCIEAER=y
# CONFIG_PCIEAER_INJECT is not set
# CONFIG_PCIE_ECRC is not set
# CONFIG_PCIEASPM is not set
CONFIG_PCIE_PME=y
# CONFIG_PCIE_DPC is not set
# CONFIG_PCIE_PTM is not set
CONFIG_PCI_MSI=y
CONFIG_PCI_MSI_IRQ_DOMAIN=y
CONFIG_PCI_QUIRKS=y
# CONFIG_PCI_DEBUG is not set
# CONFIG_PCI_STUB is not set
# CONFIG_PCI_IOV is not set
# CONFIG_PCI_PRI is not set
# CONFIG_PCI_PASID is not set
# CONFIG_HOTPLUG_PCI is not set
# PCI controller drivers
# Cadence PCIe controllers support
# CONFIG_PCIE_CADENCE_HOST is not set
# CONFIG_PCI_FTPCI100 is not set
# CONFIG_PCI_HOST_GENERIC is not set
# CONFIG_PCIE_XILINX is not set
# CONFIG_PCI_V3_SEMI is not set
# CONFIG_PCIE_ALTERA is not set
CONFIG_PCIE_BRCMSTB=y
# DesignWare PCI Core Support
# CONFIG_PCIE_DW_PLAT_HOST is not set
# CONFIG_PCI_LAYERSCAPE is not set
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# PCI switch controller drivers
# CONFIG_PCI_SW_SWITCHTEC is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_HAVE_SMP=y
CONFIG_SMP=y
CONFIG_SMP_ON_UP=y
CONFIG_ARM_CPU_TOPOLOGY=y
# CONFIG_SCHED_MC is not set
# CONFIG_SCHED_SMT is not set
CONFIG_HAVE_ARM_ARCH_TIMER=y
# CONFIG_MCPM is not set
# CONFIG_BIG_LITTLE is not set
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_NR_CPUS=4
# CONFIG_HOTPLUG_CPU is not set
# CONFIG_ARM_PSCI is not set
CONFIG_ARCH_NR_GPIO=0
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
# CONFIG_THUMB2_KERNEL is not set
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HAVE_GENERIC_GUP=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_SYS_SUPPORTS_HUGETLBFS=y
CONFIG_HAVE_ARCH_TRANSPARENT_HUGEPAGE=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_ARM_MODULE_PLTS=y
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
CONFIG_UACCESS_WITH_MEMCPY=y
CONFIG_SECCOMP=y
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# CONFIG_XEN is not set
# Boot options
CONFIG_USE_OF=y
# CONFIG_ATAGS is not set
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
# CONFIG_ARM_APPENDED_DTB is not set
CONFIG_CMDLINE="console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait"
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
# CONFIG_CPUFREQ_DT is not set
# CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set
CONFIG_ARM_BCM2835_CPUFREQ=y
# CONFIG_QORIQ_CPUFREQ is not set
# CPU Idle
# CONFIG_CPU_IDLE is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
CONFIG_KERNEL_MODE_NEON=y
# Power management options
# CONFIG_SUSPEND is not set
# CONFIG_HIBERNATION is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_PM_GENERIC_DOMAINS_OF=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# Firmware Drivers
# CONFIG_ARM_SCMI_PROTOCOL is not set
# CONFIG_ARM_SCPI_PROTOCOL is not set
# CONFIG_FIRMWARE_MEMMAP is not set
CONFIG_RASPBERRYPI_FIRMWARE=y
# CONFIG_FW_CFG_SYSFS is not set
CONFIG_HAVE_ARM_SMCCC=y
# CONFIG_GOOGLE_FIRMWARE is not set
# Tegra firmware driver
CONFIG_ARM_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM=m
CONFIG_CRYPTO_SHA1_ARM_NEON=m
# CONFIG_CRYPTO_SHA1_ARM_CE is not set
# CONFIG_CRYPTO_SHA2_ARM_CE is not set
# CONFIG_CRYPTO_SHA256_ARM is not set
# CONFIG_CRYPTO_SHA512_ARM is not set
CONFIG_CRYPTO_AES_ARM=m
CONFIG_CRYPTO_AES_ARM_BS=m
# CONFIG_CRYPTO_AES_ARM_CE is not set
# CONFIG_CRYPTO_GHASH_ARM_CE is not set
# CONFIG_CRYPTO_CRC32_ARM_CE is not set
# CONFIG_CRYPTO_CHACHA20_NEON is not set
# CONFIG_VIRTUALIZATION is not set
# General architecture-dependent options
CONFIG_OPROFILE=m
CONFIG_HAVE_OPROFILE=y
CONFIG_KPROBES=y
CONFIG_JUMP_LABEL=y
# CONFIG_STATIC_KEYS_SELFTEST is not set
CONFIG_OPTPROBES=y
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_KRETPROBES=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_HAVE_RCU_TABLE_FREE=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP_FILTER=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS=8
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_ARCH_HAS_PHYS_TO_DMA=y
CONFIG_REFCOUNT_FULL=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
CONFIG_PLUGIN_HOSTCC="g++"
CONFIG_HAVE_GCC_PLUGINS=y
# CONFIG_GCC_PLUGINS is not set
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
CONFIG_BLK_DEV_BSGLIB=y
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
CONFIG_BLK_DEV_THROTTLING=y
# CONFIG_BLK_DEV_THROTTLING_LOW is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# CONFIG_BLK_WBT is not set
# CONFIG_BLK_CGROUP_IOLATENCY is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_AIX_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
CONFIG_MAC_PARTITION=y
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
# CONFIG_CMDLINE_PARTITION is not set
CONFIG_BLK_MQ_PCI=y
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
CONFIG_CFQ_GROUP_IOSCHED=y
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
CONFIG_ASN1=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
# CONFIG_BINFMT_FLAT is not set
CONFIG_BINFMT_MISC=m
CONFIG_COREDUMP=y
# Memory Management options
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_NO_BOOTMEM=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
CONFIG_PHYS_ADDR_T_64BIT=y
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_TRANSPARENT_HUGEPAGE is not set
CONFIG_CLEANCACHE=y
CONFIG_FRONTSWAP=y
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
# CONFIG_CMA_DEBUGFS is not set
CONFIG_CMA_AREAS=7
# CONFIG_ZSWAP is not set
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
CONFIG_ZSMALLOC=m
CONFIG_PGTABLE_MAPPING=y
# CONFIG_ZSMALLOC_STAT is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_FRAME_VECTOR=y
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
CONFIG_ARCH_HAS_PTE_SPECIAL=y
CONFIG_NET=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=y
CONFIG_XFRM_USER=y
# CONFIG_XFRM_INTERFACE is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
CONFIG_XFRM_IPCOMP=m
CONFIG_NET_KEY=m
# CONFIG_NET_KEY_MIGRATE is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
# CONFIG_IP_FIB_TRIE_STATS is not set
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_CLASSID=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
# CONFIG_IP_PNP_BOOTP is not set
CONFIG_IP_PNP_RARP=y
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_NET_IP_TUNNEL=m
CONFIG_NET_IPGRE=m
# CONFIG_NET_IPGRE_BROADCAST is not set
CONFIG_IP_MROUTE_COMMON=y
CONFIG_IP_MROUTE=y
CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
CONFIG_SYN_COOKIES=y
CONFIG_NET_IPVTI=m
CONFIG_NET_UDP_TUNNEL=m
# CONFIG_NET_FOU is not set
# CONFIG_NET_FOU_IP_TUNNELS is not set
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
# CONFIG_INET_ESP_OFFLOAD is not set
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_XFRM_MODE_TRANSPORT=m
CONFIG_INET_XFRM_MODE_TUNNEL=m
CONFIG_INET_XFRM_MODE_BEET=m
CONFIG_INET_DIAG=m
CONFIG_INET_TCP_DIAG=m
# CONFIG_INET_UDP_DIAG is not set
# CONFIG_INET_RAW_DIAG is not set
# CONFIG_INET_DIAG_DESTROY is not set
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
# CONFIG_TCP_CONG_HSTCP is not set
# CONFIG_TCP_CONG_HYBLA is not set
# CONFIG_TCP_CONG_VEGAS is not set
# CONFIG_TCP_CONG_NV is not set
# CONFIG_TCP_CONG_SCALABLE is not set
# CONFIG_TCP_CONG_LP is not set
# CONFIG_TCP_CONG_VENO is not set
# CONFIG_TCP_CONG_YEAH is not set
# CONFIG_TCP_CONG_ILLINOIS is not set
# CONFIG_TCP_CONG_DCTCP is not set
# CONFIG_TCP_CONG_CDG is not set
CONFIG_TCP_CONG_BBR=m
CONFIG_DEFAULT_CUBIC=y
# CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=m
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
# CONFIG_INET6_ESP_OFFLOAD is not set
CONFIG_INET6_IPCOMP=m
# CONFIG_IPV6_MIP6 is not set
# CONFIG_IPV6_ILA is not set
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
CONFIG_INET6_XFRM_MODE_TRANSPORT=m
CONFIG_INET6_XFRM_MODE_TUNNEL=m
CONFIG_INET6_XFRM_MODE_BEET=m
# CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
# CONFIG_IPV6_VTI is not set
CONFIG_IPV6_SIT=m
CONFIG_IPV6_SIT_6RD=y
CONFIG_IPV6_NDISC_NODETYPE=y
CONFIG_IPV6_TUNNEL=m
# CONFIG_IPV6_GRE is not set
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_IPV6_MROUTE=y
CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y
CONFIG_IPV6_PIMSM_V2=y
# CONFIG_IPV6_SEG6_LWTUNNEL is not set
# CONFIG_IPV6_SEG6_HMAC is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
# Core Netfilter Configuration
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_FAMILY_BRIDGE=y
CONFIG_NETFILTER_FAMILY_ARP=y
CONFIG_NETFILTER_NETLINK_ACCT=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NETFILTER_NETLINK_OSF=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_LOG_COMMON=m
# CONFIG_NF_LOG_NETDEV is not set
CONFIG_NETFILTER_CONNCOUNT=m
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_ZONES=y
CONFIG_NF_CONNTRACK_PROCFS=y
CONFIG_NF_CONNTRACK_EVENTS=y
# CONFIG_NF_CONNTRACK_TIMEOUT is not set
CONFIG_NF_CONNTRACK_TIMESTAMP=y
CONFIG_NF_CONNTRACK_LABELS=y
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_GRE=m
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_BROADCAST=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
CONFIG_NF_CONNTRACK_SNMP=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SANE=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
# CONFIG_NETFILTER_NETLINK_GLUE_CT is not set
CONFIG_NF_NAT=m
CONFIG_NF_NAT_NEEDED=y
CONFIG_NF_NAT_PROTO_DCCP=y
CONFIG_NF_NAT_PROTO_UDPLITE=y
CONFIG_NF_NAT_PROTO_SCTP=y
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_SIP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_REDIRECT=y
CONFIG_NF_TABLES=m
CONFIG_NF_TABLES_SET=m
CONFIG_NF_TABLES_INET=y
CONFIG_NF_TABLES_NETDEV=y
CONFIG_NFT_NUMGEN=m
CONFIG_NFT_CT=m
CONFIG_NFT_FLOW_OFFLOAD=m
CONFIG_NFT_COUNTER=m
CONFIG_NFT_CONNLIMIT=m
CONFIG_NFT_LOG=m
CONFIG_NFT_LIMIT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_REDIR=m
CONFIG_NFT_NAT=m
CONFIG_NFT_TUNNEL=m
CONFIG_NFT_OBJREF=m
CONFIG_NFT_QUEUE=m
CONFIG_NFT_QUOTA=m
CONFIG_NFT_REJECT=m
CONFIG_NFT_REJECT_INET=m
CONFIG_NFT_COMPAT=m
CONFIG_NFT_HASH=m
CONFIG_NFT_FIB=m
CONFIG_NFT_FIB_INET=m
CONFIG_NFT_SOCKET=m
CONFIG_NFT_OSF=m
CONFIG_NFT_TPROXY=m
CONFIG_NF_DUP_NETDEV=m
CONFIG_NFT_DUP_NETDEV=m
CONFIG_NFT_FWD_NETDEV=m
CONFIG_NFT_FIB_NETDEV=m
CONFIG_NF_FLOW_TABLE_INET=m
CONFIG_NF_FLOW_TABLE=m
CONFIG_NETFILTER_XTABLES=m
# Xtables combined modules
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_CONNMARK=m
CONFIG_NETFILTER_XT_SET=m
# Xtables targets
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_CT=m
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
CONFIG_NETFILTER_XT_TARGET_HMARK=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_NAT=m
CONFIG_NETFILTER_XT_TARGET_NETMAP=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_NOTRACK=m
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m
# Xtables matches
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_BPF=m
# CONFIG_NETFILTER_XT_MATCH_CGROUP is not set
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_CPU=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DEVGROUP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ECN=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
# CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_L2TP=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_NFACCT=m
CONFIG_NETFILTER_XT_MATCH_OSF=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_SOCKET=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
CONFIG_IP_SET=m
CONFIG_IP_SET_MAX=256
CONFIG_IP_SET_BITMAP_IP=m
CONFIG_IP_SET_BITMAP_IPMAC=m
CONFIG_IP_SET_BITMAP_PORT=m
CONFIG_IP_SET_HASH_IP=m
# CONFIG_IP_SET_HASH_IPMARK is not set
CONFIG_IP_SET_HASH_IPPORT=m
CONFIG_IP_SET_HASH_IPPORTIP=m
CONFIG_IP_SET_HASH_IPPORTNET=m
# CONFIG_IP_SET_HASH_IPMAC is not set
# CONFIG_IP_SET_HASH_MAC is not set
# CONFIG_IP_SET_HASH_NETPORTNET is not set
CONFIG_IP_SET_HASH_NET=m
# CONFIG_IP_SET_HASH_NETNET is not set
CONFIG_IP_SET_HASH_NETPORT=m
CONFIG_IP_SET_HASH_NETIFACE=m
CONFIG_IP_SET_LIST_SET=m
CONFIG_IP_VS=m
# CONFIG_IP_VS_IPV6 is not set
# CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_AH_ESP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
CONFIG_IP_VS_PROTO_SCTP=y
# IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
# CONFIG_IP_VS_FO is not set
# CONFIG_IP_VS_OVF is not set
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
# CONFIG_IP_VS_MH is not set
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
# IPVS SH scheduler
CONFIG_IP_VS_SH_TAB_BITS=8
# IPVS MH scheduler
CONFIG_IP_VS_MH_TAB_INDEX=12
# IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IP_VS_NFCT=y
CONFIG_IP_VS_PE_SIP=m
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m
CONFIG_NF_SOCKET_IPV4=m
CONFIG_NF_TPROXY_IPV4=m
CONFIG_NF_TABLES_IPV4=y
CONFIG_NFT_CHAIN_ROUTE_IPV4=m
CONFIG_NFT_REJECT_IPV4=m
CONFIG_NFT_DUP_IPV4=m
CONFIG_NFT_FIB_IPV4=m
CONFIG_NF_TABLES_ARP=y
CONFIG_NF_FLOW_TABLE_IPV4=m
CONFIG_NF_DUP_IPV4=m
# CONFIG_NF_LOG_ARP is not set
CONFIG_NF_LOG_IPV4=m
CONFIG_NF_REJECT_IPV4=m
CONFIG_NF_NAT_IPV4=m
CONFIG_NF_NAT_MASQUERADE_IPV4=y
CONFIG_NFT_CHAIN_NAT_IPV4=m
CONFIG_NFT_MASQ_IPV4=m
CONFIG_NFT_REDIR_IPV4=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PROTO_GRE=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_RPFILTER=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
# CONFIG_IP_NF_TARGET_SYNPROXY is not set
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_CLUSTERIP=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# IPv6: Netfilter Configuration
CONFIG_NF_SOCKET_IPV6=m
CONFIG_NF_TPROXY_IPV6=m
CONFIG_NF_TABLES_IPV6=y
CONFIG_NFT_CHAIN_ROUTE_IPV6=m
CONFIG_NFT_CHAIN_NAT_IPV6=m
CONFIG_NFT_MASQ_IPV6=m
CONFIG_NFT_REDIR_IPV6=m
CONFIG_NFT_REJECT_IPV6=m
CONFIG_NFT_DUP_IPV6=m
CONFIG_NFT_FIB_IPV6=m
CONFIG_NF_FLOW_TABLE_IPV6=m
CONFIG_NF_DUP_IPV6=m
CONFIG_NF_REJECT_IPV6=m
CONFIG_NF_LOG_IPV6=m
CONFIG_NF_NAT_IPV6=m
CONFIG_NF_NAT_MASQUERADE_IPV6=y
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RPFILTER=m
CONFIG_IP6_NF_MATCH_RT=m
# CONFIG_IP6_NF_MATCH_SRH is not set
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
# CONFIG_IP6_NF_TARGET_SYNPROXY is not set
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_RAW=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_IP6_NF_TARGET_NPT=m
CONFIG_NF_DEFRAG_IPV6=m
CONFIG_NF_TABLES_BRIDGE=y
CONFIG_NFT_BRIDGE_REJECT=m
CONFIG_NF_LOG_BRIDGE=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_IP6=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_OBJCNT is not set
CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
CONFIG_SCTP_COOKIE_HMAC_MD5=y
CONFIG_SCTP_COOKIE_HMAC_SHA1=y
CONFIG_INET_SCTP_DIAG=m
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
CONFIG_ATM=m
# CONFIG_ATM_CLIP is not set
# CONFIG_ATM_LANE is not set
# CONFIG_ATM_BR2684 is not set
CONFIG_L2TP=m
# CONFIG_L2TP_DEBUGFS is not set
CONFIG_L2TP_V3=y
CONFIG_L2TP_IP=m
CONFIG_L2TP_ETH=m
CONFIG_STP=m
CONFIG_GARP=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_IGMP_SNOOPING=y
# CONFIG_BRIDGE_VLAN_FILTERING is not set
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
# CONFIG_VLAN_8021Q_MVRP is not set
# CONFIG_DECNET is not set
CONFIG_LLC=m
# CONFIG_LLC2 is not set
CONFIG_ATALK=m
# CONFIG_DEV_APPLETALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
CONFIG_6LOWPAN=m
# CONFIG_6LOWPAN_DEBUGFS is not set
CONFIG_6LOWPAN_NHC=m
CONFIG_6LOWPAN_NHC_DEST=m
CONFIG_6LOWPAN_NHC_FRAGMENT=m
CONFIG_6LOWPAN_NHC_HOP=m
CONFIG_6LOWPAN_NHC_IPV6=m
CONFIG_6LOWPAN_NHC_MOBILITY=m
CONFIG_6LOWPAN_NHC_ROUTING=m
CONFIG_6LOWPAN_NHC_UDP=m
# CONFIG_6LOWPAN_GHC_EXT_HDR_HOP is not set
# CONFIG_6LOWPAN_GHC_UDP is not set
# CONFIG_6LOWPAN_GHC_ICMPV6 is not set
# CONFIG_6LOWPAN_GHC_EXT_HDR_DEST is not set
# CONFIG_6LOWPAN_GHC_EXT_HDR_FRAG is not set
# CONFIG_6LOWPAN_GHC_EXT_HDR_ROUTE is not set
CONFIG_IEEE802154=m
# CONFIG_IEEE802154_NL802154_EXPERIMENTAL is not set
CONFIG_IEEE802154_SOCKET=m
CONFIG_IEEE802154_6LOWPAN=m
CONFIG_MAC802154=m
CONFIG_NET_SCHED=y
# Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFB=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
# CONFIG_NET_SCH_CBS is not set
# CONFIG_NET_SCH_ETF is not set
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_DRR=m
CONFIG_NET_SCH_MQPRIO=m
# CONFIG_NET_SCH_SKBPRIO is not set
CONFIG_NET_SCH_CHOKE=m
CONFIG_NET_SCH_QFQ=m
CONFIG_NET_SCH_CODEL=m
CONFIG_NET_SCH_FQ_CODEL=m
# CONFIG_NET_SCH_CAKE is not set
CONFIG_NET_SCH_FQ=m
CONFIG_NET_SCH_HHF=m
CONFIG_NET_SCH_PIE=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_SCH_PLUG=m
# CONFIG_NET_SCH_DEFAULT is not set
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
# CONFIG_CLS_U32_PERF is not set
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_CLS_CGROUP=m
# CONFIG_NET_CLS_BPF is not set
# CONFIG_NET_CLS_FLOWER is not set
# CONFIG_NET_CLS_MATCHALL is not set
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
# CONFIG_NET_EMATCH_CANID is not set
CONFIG_NET_EMATCH_IPSET=m
# CONFIG_NET_EMATCH_IPT is not set
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
# CONFIG_NET_ACT_SAMPLE is not set
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
# CONFIG_NET_ACT_VLAN is not set
# CONFIG_NET_ACT_BPF is not set
# CONFIG_NET_ACT_CONNMARK is not set
# CONFIG_NET_ACT_SKBMOD is not set
# CONFIG_NET_ACT_IFE is not set
# CONFIG_NET_ACT_TUNNEL_KEY is not set
# CONFIG_NET_CLS_IND is not set
CONFIG_NET_SCH_FIFO=y
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
CONFIG_BATMAN_ADV=m
CONFIG_BATMAN_ADV_BATMAN_V=y
CONFIG_BATMAN_ADV_BLA=y
CONFIG_BATMAN_ADV_DAT=y
# CONFIG_BATMAN_ADV_NC is not set
# CONFIG_BATMAN_ADV_MCAST is not set
# CONFIG_BATMAN_ADV_DEBUGFS is not set
CONFIG_OPENVSWITCH=m
CONFIG_OPENVSWITCH_GRE=m
CONFIG_OPENVSWITCH_VXLAN=m
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=m
# CONFIG_MPLS_ROUTING is not set
CONFIG_NET_NSH=m
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
CONFIG_NET_L3_MASTER_DEV=y
# CONFIG_NET_NCSI is not set
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_XPS=y
# CONFIG_CGROUP_NET_PRIO is not set
CONFIG_CGROUP_NET_CLASSID=y
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
CONFIG_NET_FLOW_LIMIT=y
# Network testing
CONFIG_NET_PKTGEN=m
# CONFIG_NET_DROP_MONITOR is not set
CONFIG_HAMRADIO=y
# Packet Radio protocols
CONFIG_AX25=m
CONFIG_AX25_DAMA_SLAVE=y
CONFIG_NETROM=m
CONFIG_ROSE=m
# AX.25 network device drivers
CONFIG_MKISS=m
CONFIG_6PACK=m
CONFIG_BPQETHER=m
CONFIG_BAYCOM_SER_FDX=m
CONFIG_BAYCOM_SER_HDX=m
CONFIG_YAM=m
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_BCM=m
CONFIG_CAN_GW=m
# CAN Device Drivers
CONFIG_CAN_VCAN=m
# CONFIG_CAN_VXCAN is not set
CONFIG_CAN_SLCAN=m
CONFIG_CAN_DEV=m
CONFIG_CAN_CALC_BITTIMING=y
# CONFIG_CAN_FLEXCAN is not set
# CONFIG_CAN_GRCAN is not set
# CONFIG_CAN_TI_HECC is not set
# CONFIG_CAN_C_CAN is not set
# CONFIG_CAN_CC770 is not set
# CONFIG_CAN_IFI_CANFD is not set
# CONFIG_CAN_M_CAN is not set
# CONFIG_CAN_PEAK_PCIEFD is not set
# CONFIG_CAN_RCAR is not set
# CONFIG_CAN_RCAR_CANFD is not set
# CONFIG_CAN_SJA1000 is not set
# CONFIG_CAN_SOFTING is not set
# CAN SPI interfaces
# CONFIG_CAN_HI311X is not set
CONFIG_CAN_MCP251X=m
# CAN USB interfaces
# CONFIG_CAN_8DEV_USB is not set
# CONFIG_CAN_EMS_USB is not set
# CONFIG_CAN_ESD_USB2 is not set
CONFIG_CAN_GS_USB=m
# CONFIG_CAN_KVASER_USB is not set
# CONFIG_CAN_MCBA_USB is not set
# CONFIG_CAN_PEAK_USB is not set
# CONFIG_CAN_UCAN is not set
# CONFIG_CAN_DEBUG_DEVICES is not set
CONFIG_BT=m
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=m
CONFIG_BT_HS=y
CONFIG_BT_LE=y
CONFIG_BT_6LOWPAN=m
# CONFIG_BT_LEDS is not set
# CONFIG_BT_SELFTEST is not set
CONFIG_BT_DEBUGFS=y
# Bluetooth device drivers
CONFIG_BT_INTEL=m
CONFIG_BT_BCM=m
CONFIG_BT_RTL=m
CONFIG_BT_HCIBTUSB=m
# CONFIG_BT_HCIBTUSB_AUTOSUSPEND is not set
CONFIG_BT_HCIBTUSB_BCM=y
CONFIG_BT_HCIBTUSB_RTL=y
# CONFIG_BT_HCIBTSDIO is not set
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_SERDEV=y
CONFIG_BT_HCIUART_H4=y
# CONFIG_BT_HCIUART_NOKIA is not set
# CONFIG_BT_HCIUART_BCSP is not set
# CONFIG_BT_HCIUART_ATH3K is not set
# CONFIG_BT_HCIUART_LL is not set
CONFIG_BT_HCIUART_3WIRE=y
# CONFIG_BT_HCIUART_INTEL is not set
CONFIG_BT_HCIUART_BCM=y
# CONFIG_BT_HCIUART_QCA is not set
# CONFIG_BT_HCIUART_AG6XX is not set
# CONFIG_BT_HCIUART_MRVL is not set
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBPA10X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIVHCI=m
CONFIG_BT_MRVL=m
CONFIG_BT_MRVL_SDIO=m
CONFIG_BT_ATH3K=m
CONFIG_BT_WILINK=m
# CONFIG_BT_MTKUART is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=m
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_CERTIFICATION_ONUS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
CONFIG_LIB80211=m
CONFIG_LIB80211_CRYPT_WEP=m
CONFIG_LIB80211_CRYPT_CCMP=m
CONFIG_LIB80211_CRYPT_TKIP=m
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_MINSTREL_HT=y
# CONFIG_MAC80211_RC_MINSTREL_VHT is not set
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
CONFIG_MAC80211_MESH=y
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
CONFIG_WIMAX=m
CONFIG_WIMAX_DEBUG_LEVEL=8
CONFIG_RFKILL=m
CONFIG_RFKILL_LEDS=y
CONFIG_RFKILL_INPUT=y
# CONFIG_RFKILL_GPIO is not set
CONFIG_NET_9P=m
# CONFIG_NET_9P_DEBUG is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
CONFIG_NFC=m
# CONFIG_NFC_DIGITAL is not set
# CONFIG_NFC_NCI is not set
# CONFIG_NFC_HCI is not set
# Near Field Communication (NFC) devices
# CONFIG_NFC_PN533_USB is not set
# CONFIG_NFC_PN533_I2C is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
# CONFIG_NET_DEVLINK is not set
CONFIG_MAY_USE_DEVLINK=y
# CONFIG_FAILOVER is not set
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_ARM_AMBA=y
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER is not set
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_DMA_CMA=y
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=5
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# Bus devices
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_SIMPLE_PM_BUS is not set
# CONFIG_VEXPRESS_CONFIG is not set
CONFIG_CONNECTOR=m
# CONFIG_GNSS is not set
CONFIG_MTD=m
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
# CONFIG_MTD_AFS_PARTS is not set
CONFIG_MTD_OF_PARTS=m
# CONFIG_MTD_AR7_PARTS is not set
# Partition parsers
# User Modules And Translation Layers
CONFIG_MTD_BLKDEVS=m
CONFIG_MTD_BLOCK=m
# CONFIG_MTD_BLOCK_RO is not set
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_INTEL_VR_NOR is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
# CONFIG_MTD_DATAFLASH is not set
CONFIG_MTD_M25P80=m
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
CONFIG_MTD_BLOCK2MTD=m
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# CONFIG_MTD_ONENAND is not set
CONFIG_MTD_NAND_ECC=m
# CONFIG_MTD_NAND_ECC_SMC is not set
CONFIG_MTD_NAND=m
# CONFIG_MTD_NAND_ECC_BCH is not set
CONFIG_MTD_NAND_BCM2835_SMI=m
# CONFIG_MTD_NAND_DENALI_PCI is not set
# CONFIG_MTD_NAND_DENALI_DT is not set
# CONFIG_MTD_NAND_GPIO is not set
# CONFIG_MTD_NAND_RICOH is not set
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_DOCG4 is not set
# CONFIG_MTD_NAND_CAFE is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_BRCMNAND is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_SPI_NAND is not set
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
CONFIG_MTD_SPI_NOR=m
# CONFIG_MTD_MT81xx_NOR is not set
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_SPI_CADENCE_QUADSPI is not set
CONFIG_MTD_UBI=m
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
# CONFIG_MTD_UBI_BLOCK is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_DYNAMIC=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_RESERVED_MEM=y
CONFIG_OF_RESOLVE=y
CONFIG_OF_OVERLAY=y
CONFIG_OF_CONFIGFS=y
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
CONFIG_CDROM=m
# CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
CONFIG_ZRAM=m
# CONFIG_ZRAM_WRITEBACK is not set
# CONFIG_ZRAM_MEMORY_TRACKING is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_UMEM is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_DRBD=m
# CONFIG_DRBD_FAULT_INJECTION is not set
CONFIG_BLK_DEV_NBD=m
# CONFIG_BLK_DEV_SX8 is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
CONFIG_CDROM_PKTCDVD=m
CONFIG_CDROM_PKTCDVD_BUFFERS=8
# CONFIG_CDROM_PKTCDVD_WCACHE is not set
CONFIG_ATA_OVER_ETH=m
# CONFIG_BLK_DEV_RBD is not set
# CONFIG_BLK_DEV_RSXX is not set
# NVME Support
# CONFIG_BLK_DEV_NVME is not set
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# Misc devices
CONFIG_BCM2835_SMI=m
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_PHANTOM is not set
# CONFIG_SGI_IOC4 is not set
# CONFIG_TIFM_CORE is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_HP_ILO is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_USB_SWITCH_FSA9480 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_PCI_ENDPOINT_TEST is not set
# CONFIG_C2PORT is not set
# EEPROM support
CONFIG_EEPROM_AT24=m
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
CONFIG_EEPROM_93CX6=m
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_CB710_CORE is not set
# Texas Instruments shared transport line discipline
CONFIG_TI_ST=m
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# Intel MIC & related support
# Intel MIC Bus Driver
# SCIF Bus Driver
# VOP Bus Driver
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# VOP Driver
# CONFIG_ECHO is not set
# CONFIG_MISC_RTSX_PCI is not set
# CONFIG_MISC_RTSX_USB is not set
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_MQ_DEFAULT=y
# CONFIG_SCSI_PROC_FS is not set
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
CONFIG_CHR_DEV_ST=m
CONFIG_CHR_DEV_OSST=m
CONFIG_BLK_DEV_SR=m
# CONFIG_BLK_DEV_SR_VENDOR is not set
CONFIG_CHR_DEV_SG=m
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
CONFIG_SCSI_ISCSI_ATTRS=y
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=m
CONFIG_ISCSI_BOOT_SYSFS=m
# CONFIG_SCSI_CXGB3_ISCSI is not set
# CONFIG_SCSI_CXGB4_ISCSI is not set
# CONFIG_SCSI_BNX2_ISCSI is not set
# CONFIG_BE2ISCSI is not set
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_HPSA is not set
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_3W_SAS is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_AIC94XX is not set
# CONFIG_SCSI_MVSAS is not set
# CONFIG_SCSI_MVUMI is not set
# CONFIG_SCSI_ADVANSYS is not set
# CONFIG_SCSI_ARCMSR is not set
# CONFIG_SCSI_ESAS2R is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
# CONFIG_MEGARAID_SAS is not set
# CONFIG_SCSI_MPT3SAS is not set
# CONFIG_SCSI_MPT2SAS is not set
# CONFIG_SCSI_SMARTPQI is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_HPTIOP is not set
# CONFIG_SCSI_SNIC is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_STEX is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
# CONFIG_SCSI_QLA_ISCSI is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_AM53C974 is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_WD719X is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_PMCRAID is not set
# CONFIG_SCSI_PM8001 is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID10=m
CONFIG_MD_RAID456=m
# CONFIG_MD_MULTIPATH is not set
# CONFIG_MD_FAULTY is not set
# CONFIG_MD_CLUSTER is not set
# CONFIG_BCACHE is not set
CONFIG_BLK_DEV_DM_BUILTIN=y
CONFIG_BLK_DEV_DM=m
# CONFIG_DM_MQ_DEFAULT is not set
# CONFIG_DM_DEBUG is not set
CONFIG_DM_BUFIO=m
# CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set
CONFIG_DM_BIO_PRISON=m
CONFIG_DM_PERSISTENT_DATA=m
# CONFIG_DM_UNSTRIPED is not set
CONFIG_DM_CRYPT=m
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_THIN_PROVISIONING=m
CONFIG_DM_CACHE=m
CONFIG_DM_CACHE_SMQ=m
# CONFIG_DM_WRITECACHE is not set
# CONFIG_DM_ERA is not set
CONFIG_DM_MIRROR=m
CONFIG_DM_LOG_USERSPACE=m
CONFIG_DM_RAID=m
CONFIG_DM_ZERO=m
# CONFIG_DM_MULTIPATH is not set
CONFIG_DM_DELAY=m
# CONFIG_DM_UEVENT is not set
# CONFIG_DM_FLAKEY is not set
# CONFIG_DM_VERITY is not set
# CONFIG_DM_SWITCH is not set
# CONFIG_DM_LOG_WRITES is not set
# CONFIG_DM_INTEGRITY is not set
# CONFIG_TARGET_CORE is not set
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# CONFIG_FIREWIRE is not set
# CONFIG_FIREWIRE_NOSY is not set
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
CONFIG_BONDING=m
CONFIG_DUMMY=m
# CONFIG_EQUALIZER is not set
# CONFIG_NET_FC is not set
CONFIG_IFB=m
# CONFIG_NET_TEAM is not set
CONFIG_MACVLAN=m
# CONFIG_MACVTAP is not set
CONFIG_IPVLAN=m
# CONFIG_IPVTAP is not set
CONFIG_VXLAN=m
# CONFIG_GENEVE is not set
# CONFIG_GTP is not set
# CONFIG_MACSEC is not set
CONFIG_NETCONSOLE=m
# CONFIG_NETCONSOLE_DYNAMIC is not set
CONFIG_NETPOLL=y
CONFIG_NET_POLL_CONTROLLER=y
CONFIG_TUN=m
# CONFIG_TUN_VNET_CROSS_LE is not set
CONFIG_VETH=m
# CONFIG_NLMON is not set
CONFIG_NET_VRF=m
# CONFIG_ARCNET is not set
CONFIG_ATM_DRIVERS=y
# CONFIG_ATM_DUMMY is not set
# CONFIG_ATM_TCP is not set
# CONFIG_ATM_LANAI is not set
# CONFIG_ATM_ENI is not set
# CONFIG_ATM_NICSTAR is not set
# CONFIG_ATM_IDT77252 is not set
# CONFIG_ATM_IA is not set
# CONFIG_ATM_FORE200E is not set
# CONFIG_ATM_HE is not set
# CONFIG_ATM_SOLOS is not set
# CAIF transport drivers
# Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_3COM=y
# CONFIG_VORTEX is not set
# CONFIG_TYPHOON is not set
CONFIG_NET_VENDOR_ADAPTEC=y
# CONFIG_ADAPTEC_STARFIRE is not set
CONFIG_NET_VENDOR_AGERE=y
# CONFIG_ET131X is not set
CONFIG_NET_VENDOR_ALACRITECH=y
# CONFIG_SLICOSS is not set
CONFIG_NET_VENDOR_ALTEON=y
# CONFIG_ACENIC is not set
# CONFIG_ALTERA_TSE is not set
CONFIG_NET_VENDOR_AMAZON=y
CONFIG_NET_VENDOR_AMD=y
# CONFIG_AMD8111_ETH is not set
# CONFIG_PCNET32 is not set
CONFIG_NET_VENDOR_AQUANTIA=y
CONFIG_NET_VENDOR_ARC=y
CONFIG_NET_VENDOR_ATHEROS=y
# CONFIG_ATL2 is not set
# CONFIG_ATL1 is not set
# CONFIG_ATL1E is not set
# CONFIG_ATL1C is not set
# CONFIG_ALX is not set
CONFIG_NET_VENDOR_AURORA=y
# CONFIG_AURORA_NB8800 is not set
CONFIG_NET_VENDOR_BROADCOM=y
# CONFIG_B44 is not set
CONFIG_BCMGENET=y
# CONFIG_BNX2 is not set
# CONFIG_CNIC is not set
# CONFIG_TIGON3 is not set
# CONFIG_BNX2X is not set
# CONFIG_SYSTEMPORT is not set
# CONFIG_BNXT is not set
CONFIG_NET_VENDOR_BROCADE=y
# CONFIG_BNA is not set
CONFIG_NET_VENDOR_CADENCE=y
# CONFIG_MACB is not set
CONFIG_NET_VENDOR_CAVIUM=y
CONFIG_NET_VENDOR_CHELSIO=y
# CONFIG_CHELSIO_T1 is not set
# CONFIG_CHELSIO_T3 is not set
# CONFIG_CHELSIO_T4 is not set
# CONFIG_CHELSIO_T4VF is not set
CONFIG_NET_VENDOR_CIRRUS=y
# CONFIG_CS89x0 is not set
CONFIG_NET_VENDOR_CISCO=y
# CONFIG_ENIC is not set
CONFIG_NET_VENDOR_CORTINA=y
# CONFIG_GEMINI_ETHERNET is not set
# CONFIG_DM9000 is not set
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_DEC=y
# CONFIG_NET_TULIP is not set
CONFIG_NET_VENDOR_DLINK=y
# CONFIG_DL2K is not set
# CONFIG_SUNDANCE is not set
CONFIG_NET_VENDOR_EMULEX=y
# CONFIG_BE2NET is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_FARADAY=y
# CONFIG_FTMAC100 is not set
# CONFIG_FTGMAC100 is not set
CONFIG_NET_VENDOR_HISILICON=y
# CONFIG_HIX5HD2_GMAC is not set
# CONFIG_HISI_FEMAC is not set
# CONFIG_HIP04_ETH is not set
# CONFIG_HNS is not set
# CONFIG_HNS_DSAF is not set
# CONFIG_HNS_ENET is not set
# CONFIG_HNS3 is not set
CONFIG_NET_VENDOR_HP=y
# CONFIG_HP100 is not set
CONFIG_NET_VENDOR_HUAWEI=y
CONFIG_NET_VENDOR_I825XX=y
CONFIG_NET_VENDOR_INTEL=y
# CONFIG_E100 is not set
# CONFIG_E1000 is not set
# CONFIG_E1000E is not set
# CONFIG_IGB is not set
# CONFIG_IGBVF is not set
# CONFIG_IXGB is not set
# CONFIG_IXGBE is not set
# CONFIG_IXGBEVF is not set
# CONFIG_I40E is not set
# CONFIG_I40EVF is not set
# CONFIG_ICE is not set
# CONFIG_FM10K is not set
# CONFIG_JME is not set
CONFIG_NET_VENDOR_MARVELL=y
# CONFIG_MVMDIO is not set
# CONFIG_SKGE is not set
# CONFIG_SKY2 is not set
CONFIG_NET_VENDOR_MELLANOX=y
# CONFIG_MLX4_EN is not set
# CONFIG_MLX5_CORE is not set
# CONFIG_MLXSW_CORE is not set
# CONFIG_MLXFW is not set
CONFIG_NET_VENDOR_MICREL=y
# CONFIG_KS8842 is not set
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_KSZ884X_PCI is not set
CONFIG_NET_VENDOR_MICROCHIP=y
CONFIG_ENC28J60=m
# CONFIG_ENC28J60_WRITEVERIFY is not set
# CONFIG_ENCX24J600 is not set
# CONFIG_LAN743X is not set
CONFIG_NET_VENDOR_MICROSEMI=y
CONFIG_NET_VENDOR_MYRI=y
# CONFIG_MYRI10GE is not set
# CONFIG_FEALNX is not set
CONFIG_NET_VENDOR_NATSEMI=y
# CONFIG_NATSEMI is not set
# CONFIG_NS83820 is not set
CONFIG_NET_VENDOR_NETERION=y
# CONFIG_S2IO is not set
# CONFIG_VXGE is not set
CONFIG_NET_VENDOR_NETRONOME=y
# CONFIG_NFP is not set
CONFIG_NET_VENDOR_NI=y
CONFIG_NET_VENDOR_8390=y
# CONFIG_AX88796 is not set
# CONFIG_NE2K_PCI is not set
CONFIG_NET_VENDOR_NVIDIA=y
# CONFIG_FORCEDETH is not set
CONFIG_NET_VENDOR_OKI=y
# CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_PACKET_ENGINES=y
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
CONFIG_NET_VENDOR_QLOGIC=y
# CONFIG_QLA3XXX is not set
# CONFIG_QLCNIC is not set
# CONFIG_QLGE is not set
# CONFIG_NETXEN_NIC is not set
# CONFIG_QED is not set
CONFIG_NET_VENDOR_QUALCOMM=y
CONFIG_QCA7000=m
CONFIG_QCA7000_SPI=m
# CONFIG_QCA7000_UART is not set
# CONFIG_QCOM_EMAC is not set
# CONFIG_RMNET is not set
CONFIG_NET_VENDOR_RDC=y
# CONFIG_R6040 is not set
CONFIG_NET_VENDOR_REALTEK=y
# CONFIG_8139CP is not set
# CONFIG_8139TOO is not set
# CONFIG_R8169 is not set
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
CONFIG_NET_VENDOR_SAMSUNG=y
# CONFIG_SXGBE_ETH is not set
CONFIG_NET_VENDOR_SEEQ=y
CONFIG_NET_VENDOR_SOLARFLARE=y
# CONFIG_SFC is not set
# CONFIG_SFC_FALCON is not set
CONFIG_NET_VENDOR_SILAN=y
# CONFIG_SC92031 is not set
CONFIG_NET_VENDOR_SIS=y
# CONFIG_SIS900 is not set
# CONFIG_SIS190 is not set
CONFIG_NET_VENDOR_SMSC=y
# CONFIG_SMC91X is not set
# CONFIG_EPIC100 is not set
# CONFIG_SMC911X is not set
# CONFIG_SMSC911X is not set
# CONFIG_SMSC9420 is not set
CONFIG_NET_VENDOR_SOCIONEXT=y
CONFIG_NET_VENDOR_STMICRO=y
# CONFIG_STMMAC_ETH is not set
CONFIG_NET_VENDOR_SUN=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NIU is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
CONFIG_NET_VENDOR_TEHUTI=y
# CONFIG_TEHUTI is not set
CONFIG_NET_VENDOR_TI=y
# CONFIG_TI_CPSW_ALE is not set
# CONFIG_TLAN is not set
CONFIG_NET_VENDOR_VIA=y
# CONFIG_VIA_RHINE is not set
# CONFIG_VIA_VELOCITY is not set
CONFIG_NET_VENDOR_WIZNET=y
# CONFIG_WIZNET_W5100 is not set
# CONFIG_WIZNET_W5300 is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
CONFIG_MDIO_BCM_UNIMAC=y
CONFIG_MDIO_BITBANG=m
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_GPIO is not set
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_MSCC_MIIM is not set
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
# MII PHY device drivers
# CONFIG_AMD_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AX88796B_PHY is not set
# CONFIG_AT803X_PHY is not set
CONFIG_BCM7XXX_PHY=y
# CONFIG_BCM87XX_PHY is not set
CONFIG_BCM_NET_PHYLIB=y
CONFIG_BROADCOM_PHY=y
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_DP83822_PHY is not set
# CONFIG_DP83TC811_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_ICPLUS_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MICREL_PHY is not set
CONFIG_MICROCHIP_PHY=y
# CONFIG_MICROCHIP_T1_PHY is not set
# CONFIG_MICROSEMI_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_RENESAS_PHY is not set
# CONFIG_ROCKCHIP_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
CONFIG_PPP=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOATM=m
CONFIG_PPPOE=m
# CONFIG_PPTP is not set
CONFIG_PPPOL2TP=m
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_SLIP=m
CONFIG_SLHC=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
# CONFIG_SLIP_MODE_SLIP6 is not set
CONFIG_USB_NET_DRIVERS=y
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=y
CONFIG_USB_LAN78XX=y
CONFIG_USB_USBNET=y
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_CDC_EEM=m
CONFIG_USB_NET_CDC_NCM=m
CONFIG_USB_NET_HUAWEI_CDC_NCM=m
CONFIG_USB_NET_CDC_MBIM=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9700=m
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=y
CONFIG_USB_NET_GL620A=m
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_NET_CDC_SUBSET_ENABLE=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_ZAURUS=m
CONFIG_USB_NET_CX82310_ETH=m
CONFIG_USB_NET_KALMIA=m
CONFIG_USB_NET_QMI_WWAN=m
CONFIG_USB_HSO=m
CONFIG_USB_NET_INT51X1=m
CONFIG_USB_IPHETH=m
CONFIG_USB_SIERRA_NET=m
CONFIG_USB_VL600=m
# CONFIG_USB_NET_CH9200 is not set
CONFIG_WLAN=y
# CONFIG_WIRELESS_WDS is not set
CONFIG_WLAN_VENDOR_ADMTEK=y
# CONFIG_ADM8211 is not set
CONFIG_ATH_COMMON=m
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
# CONFIG_ATH5K is not set
# CONFIG_ATH5K_PCI is not set
CONFIG_ATH9K_HW=m
CONFIG_ATH9K_COMMON=m
CONFIG_ATH9K_BTCOEX_SUPPORT=y
CONFIG_ATH9K=m
CONFIG_ATH9K_PCI=y
# CONFIG_ATH9K_AHB is not set
# CONFIG_ATH9K_DEBUGFS is not set
# CONFIG_ATH9K_DYNACK is not set
# CONFIG_ATH9K_WOW is not set
CONFIG_ATH9K_RFKILL=y
# CONFIG_ATH9K_CHANNEL_CONTEXT is not set
CONFIG_ATH9K_PCOEM=y
CONFIG_ATH9K_HTC=m
# CONFIG_ATH9K_HTC_DEBUGFS is not set
# CONFIG_ATH9K_HWRNG is not set
CONFIG_CARL9170=m
CONFIG_CARL9170_LEDS=y
CONFIG_CARL9170_WPC=y
# CONFIG_CARL9170_HWRNG is not set
CONFIG_ATH6KL=m
# CONFIG_ATH6KL_SDIO is not set
CONFIG_ATH6KL_USB=m
# CONFIG_ATH6KL_DEBUG is not set
# CONFIG_ATH6KL_TRACING is not set
CONFIG_AR5523=m
# CONFIG_WIL6210 is not set
# CONFIG_ATH10K is not set
# CONFIG_WCN36XX is not set
CONFIG_WLAN_VENDOR_ATMEL=y
# CONFIG_ATMEL is not set
CONFIG_AT76C50X_USB=m
CONFIG_WLAN_VENDOR_BROADCOM=y
CONFIG_B43=m
CONFIG_B43_BCMA=y
CONFIG_B43_SSB=y
CONFIG_B43_BUSES_BCMA_AND_SSB=y
# CONFIG_B43_BUSES_BCMA is not set
# CONFIG_B43_BUSES_SSB is not set
CONFIG_B43_PCI_AUTOSELECT=y
CONFIG_B43_PCICORE_AUTOSELECT=y
# CONFIG_B43_SDIO is not set
CONFIG_B43_BCMA_PIO=y
CONFIG_B43_PIO=y
CONFIG_B43_PHY_G=y
# CONFIG_B43_PHY_N is not set
CONFIG_B43_PHY_LP=y
CONFIG_B43_PHY_HT=y
CONFIG_B43_LEDS=y
CONFIG_B43_HWRNG=y
# CONFIG_B43_DEBUG is not set
CONFIG_B43LEGACY=m
CONFIG_B43LEGACY_PCI_AUTOSELECT=y
CONFIG_B43LEGACY_PCICORE_AUTOSELECT=y
CONFIG_B43LEGACY_LEDS=y
CONFIG_B43LEGACY_HWRNG=y
CONFIG_B43LEGACY_DEBUG=y
CONFIG_B43LEGACY_DMA=y
CONFIG_B43LEGACY_PIO=y
CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y
# CONFIG_B43LEGACY_DMA_MODE is not set
# CONFIG_B43LEGACY_PIO_MODE is not set
CONFIG_BRCMUTIL=m
# CONFIG_BRCMSMAC is not set
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
CONFIG_BRCMFMAC_SDIO=y
CONFIG_BRCMFMAC_USB=y
# CONFIG_BRCMFMAC_PCIE is not set
# CONFIG_BRCM_TRACING is not set
CONFIG_BRCMDBG=y
CONFIG_WLAN_VENDOR_CISCO=y
CONFIG_WLAN_VENDOR_INTEL=y
# CONFIG_IPW2100 is not set
# CONFIG_IPW2200 is not set
# CONFIG_IWL4965 is not set
# CONFIG_IWL3945 is not set
# CONFIG_IWLWIFI is not set
CONFIG_WLAN_VENDOR_INTERSIL=y
CONFIG_HOSTAP=m
# CONFIG_HOSTAP_FIRMWARE is not set
# CONFIG_HOSTAP_PLX is not set
# CONFIG_HOSTAP_PCI is not set
# CONFIG_HERMES is not set
CONFIG_P54_COMMON=m
CONFIG_P54_USB=m
# CONFIG_P54_PCI is not set
# CONFIG_P54_SPI is not set
CONFIG_P54_LEDS=y
# CONFIG_PRISM54 is not set
CONFIG_WLAN_VENDOR_MARVELL=y
CONFIG_LIBERTAS=m
CONFIG_LIBERTAS_USB=m
CONFIG_LIBERTAS_SDIO=m
# CONFIG_LIBERTAS_SPI is not set
# CONFIG_LIBERTAS_DEBUG is not set
# CONFIG_LIBERTAS_MESH is not set
CONFIG_LIBERTAS_THINFIRM=m
# CONFIG_LIBERTAS_THINFIRM_DEBUG is not set
CONFIG_LIBERTAS_THINFIRM_USB=m
CONFIG_MWIFIEX=m
CONFIG_MWIFIEX_SDIO=m
# CONFIG_MWIFIEX_PCIE is not set
# CONFIG_MWIFIEX_USB is not set
# CONFIG_MWL8K is not set
CONFIG_WLAN_VENDOR_MEDIATEK=y
CONFIG_MT7601U=m
CONFIG_MT76_CORE=m
CONFIG_MT76_LEDS=y
CONFIG_MT76_USB=m
CONFIG_MT76x2_COMMON=m
CONFIG_MT76x0U=m
# CONFIG_MT76x2E is not set
CONFIG_MT76x2U=m
CONFIG_WLAN_VENDOR_RALINK=y
CONFIG_RT2X00=m
# CONFIG_RT2400PCI is not set
# CONFIG_RT2500PCI is not set
# CONFIG_RT61PCI is not set
# CONFIG_RT2800PCI is not set
CONFIG_RT2500USB=m
CONFIG_RT73USB=m
CONFIG_RT2800USB=m
CONFIG_RT2800USB_RT33XX=y
CONFIG_RT2800USB_RT35XX=y
CONFIG_RT2800USB_RT3573=y
CONFIG_RT2800USB_RT53XX=y
CONFIG_RT2800USB_RT55XX=y
CONFIG_RT2800USB_UNKNOWN=y
CONFIG_RT2800_LIB=m
CONFIG_RT2X00_LIB_USB=m
CONFIG_RT2X00_LIB=m
CONFIG_RT2X00_LIB_FIRMWARE=y
CONFIG_RT2X00_LIB_CRYPTO=y
CONFIG_RT2X00_LIB_LEDS=y
# CONFIG_RT2X00_DEBUG is not set
CONFIG_WLAN_VENDOR_REALTEK=y
# CONFIG_RTL8180 is not set
CONFIG_RTL8187=m
CONFIG_RTL8187_LEDS=y
CONFIG_RTL_CARDS=m
# CONFIG_RTL8192CE is not set
# CONFIG_RTL8192SE is not set
# CONFIG_RTL8192DE is not set
# CONFIG_RTL8723AE is not set
# CONFIG_RTL8723BE is not set
# CONFIG_RTL8188EE is not set
# CONFIG_RTL8192EE is not set
# CONFIG_RTL8821AE is not set
CONFIG_RTL8192CU=m
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_USB=m
CONFIG_RTLWIFI_DEBUG=y
CONFIG_RTL8192C_COMMON=m
CONFIG_RTL8XXXU=m
# CONFIG_RTL8XXXU_UNTESTED is not set
CONFIG_WLAN_VENDOR_RSI=y
# CONFIG_RSI_91X is not set
CONFIG_WLAN_VENDOR_ST=y
# CONFIG_CW1200 is not set
CONFIG_WLAN_VENDOR_TI=y
# CONFIG_WL1251 is not set
# CONFIG_WL12XX is not set
# CONFIG_WL18XX is not set
# CONFIG_WLCORE is not set
CONFIG_WLAN_VENDOR_ZYDAS=y
CONFIG_USB_ZD1201=m
CONFIG_ZD1211RW=m
# CONFIG_ZD1211RW_DEBUG is not set
CONFIG_WLAN_VENDOR_QUANTENNA=y
# CONFIG_QTNFMAC_PEARL_PCIE is not set
CONFIG_MAC80211_HWSIM=m
CONFIG_USB_NET_RNDIS_WLAN=m
# WiMAX Wireless Broadband devices
CONFIG_WIMAX_I2400M=m
CONFIG_WIMAX_I2400M_USB=m
CONFIG_WIMAX_I2400M_DEBUG_LEVEL=8
# CONFIG_WAN is not set
CONFIG_IEEE802154_DRIVERS=m
# CONFIG_IEEE802154_FAKELB is not set
CONFIG_IEEE802154_AT86RF230=m
# CONFIG_IEEE802154_AT86RF230_DEBUGFS is not set
CONFIG_IEEE802154_MRF24J40=m
CONFIG_IEEE802154_CC2520=m
# CONFIG_IEEE802154_ATUSB is not set
# CONFIG_IEEE802154_ADF7242 is not set
# CONFIG_IEEE802154_CA8210 is not set
# CONFIG_IEEE802154_MCR20A is not set
# CONFIG_IEEE802154_HWSIM is not set
# CONFIG_VMXNET3 is not set
# CONFIG_NETDEVSIM is not set
# CONFIG_NET_FAILOVER is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
CONFIG_INPUT_FF_MEMLESS=m
CONFIG_INPUT_POLLDEV=m
# CONFIG_INPUT_SPARSEKMAP is not set
CONFIG_INPUT_MATRIXKMAP=m
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
# CONFIG_INPUT_MOUSEDEV_PSAUX is not set
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_EVDEV=m
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADC is not set
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=m
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
CONFIG_KEYBOARD_MATRIX=m
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_STMPE is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
CONFIG_INPUT_JOYSTICK=y
# CONFIG_JOYSTICK_ANALOG is not set
# CONFIG_JOYSTICK_A3D is not set
# CONFIG_JOYSTICK_ADI is not set
# CONFIG_JOYSTICK_COBRA is not set
# CONFIG_JOYSTICK_GF2K is not set
# CONFIG_JOYSTICK_GRIP is not set
# CONFIG_JOYSTICK_GRIP_MP is not set
# CONFIG_JOYSTICK_GUILLEMOT is not set
# CONFIG_JOYSTICK_INTERACT is not set
# CONFIG_JOYSTICK_SIDEWINDER is not set
# CONFIG_JOYSTICK_TMDC is not set
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_USB=y
# CONFIG_JOYSTICK_IFORCE_232 is not set
# CONFIG_JOYSTICK_WARRIOR is not set
# CONFIG_JOYSTICK_MAGELLAN is not set
# CONFIG_JOYSTICK_SPACEORB is not set
# CONFIG_JOYSTICK_SPACEBALL is not set
# CONFIG_JOYSTICK_STINGER is not set
# CONFIG_JOYSTICK_TWIDJOY is not set
# CONFIG_JOYSTICK_ZHENHUA is not set
# CONFIG_JOYSTICK_AS5011 is not set
# CONFIG_JOYSTICK_JOYDUMP is not set
CONFIG_JOYSTICK_XPAD=m
CONFIG_JOYSTICK_XPAD_FF=y
CONFIG_JOYSTICK_XPAD_LEDS=y
CONFIG_JOYSTICK_PSXPAD_SPI=m
CONFIG_JOYSTICK_PSXPAD_SPI_FF=y
# CONFIG_JOYSTICK_PXRC is not set
CONFIG_JOYSTICK_RPISENSE=m
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
CONFIG_TOUCHSCREEN_ADS7846=m
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_ADC is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
# CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
CONFIG_TOUCHSCREEN_EGALAX=m
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
CONFIG_TOUCHSCREEN_EXC3000=m
# CONFIG_TOUCHSCREEN_FUJITSU is not set
CONFIG_TOUCHSCREEN_GOODIX=m
# CONFIG_TOUCHSCREEN_HIDEEP is not set
CONFIG_TOUCHSCREEN_ILI210X=m
# CONFIG_TOUCHSCREEN_S6SY761 is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
CONFIG_TOUCHSCREEN_EDT_FT5X06=m
CONFIG_TOUCHSCREEN_RPI_FT5406=m
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
CONFIG_TOUCHSCREEN_USB_COMPOSITE=m
CONFIG_TOUCHSCREEN_USB_EGALAX=y
CONFIG_TOUCHSCREEN_USB_PANJIT=y
CONFIG_TOUCHSCREEN_USB_3M=y
CONFIG_TOUCHSCREEN_USB_ITM=y
CONFIG_TOUCHSCREEN_USB_ETURBO=y
CONFIG_TOUCHSCREEN_USB_GUNZE=y
CONFIG_TOUCHSCREEN_USB_DMC_TSC10=y
CONFIG_TOUCHSCREEN_USB_IRTOUCH=y
CONFIG_TOUCHSCREEN_USB_IDEALTEK=y
CONFIG_TOUCHSCREEN_USB_GENERAL_TOUCH=y
CONFIG_TOUCHSCREEN_USB_GOTOP=y
CONFIG_TOUCHSCREEN_USB_JASTEC=y
CONFIG_TOUCHSCREEN_USB_ELO=y
CONFIG_TOUCHSCREEN_USB_E2I=y
CONFIG_TOUCHSCREEN_USB_ZYTRONIC=y
CONFIG_TOUCHSCREEN_USB_ETT_TC45USB=y
CONFIG_TOUCHSCREEN_USB_NEXIO=y
CONFIG_TOUCHSCREEN_USB_EASYTOUCH=y
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
CONFIG_TOUCHSCREEN_STMPE=m
# CONFIG_TOUCHSCREEN_SUR40 is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
CONFIG_INPUT_MISC=y
CONFIG_INPUT_AD714X=m
CONFIG_INPUT_AD714X_I2C=m
CONFIG_INPUT_AD714X_SPI=m
# CONFIG_INPUT_ARIZONA_HAPTICS is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
CONFIG_INPUT_ATI_REMOTE2=m
CONFIG_INPUT_KEYSPAN_REMOTE=m
# CONFIG_INPUT_KXTJ9 is not set
CONFIG_INPUT_POWERMATE=m
CONFIG_INPUT_YEALINK=m
CONFIG_INPUT_CM109=m
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
CONFIG_INPUT_UINPUT=m
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_PWM_VIBRA is not set
CONFIG_INPUT_GPIO_ROTARY_ENCODER=m
CONFIG_INPUT_ADXL34X=m
CONFIG_INPUT_ADXL34X_I2C=m
CONFIG_INPUT_ADXL34X_SPI=m
# CONFIG_INPUT_IMS_PCU is not set
CONFIG_INPUT_CMA3000=m
# CONFIG_INPUT_CMA3000_I2C is not set
# CONFIG_INPUT_SOC_BUTTON_ARRAY is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=m
CONFIG_SERIO_SERPORT=m
# CONFIG_SERIO_AMBAKMI is not set
# CONFIG_SERIO_PCIPS2 is not set
# CONFIG_SERIO_LIBPS2 is not set
CONFIG_SERIO_RAW=m
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
CONFIG_GAMEPORT=m
CONFIG_GAMEPORT_NS558=m
CONFIG_GAMEPORT_L4=m
# CONFIG_GAMEPORT_EMU10K1 is not set
# CONFIG_GAMEPORT_FM801 is not set
# Character devices
CONFIG_BRCM_CHAR_DRIVERS=y
CONFIG_BCM2708_VCMEM=y
CONFIG_BCM_VCIO=y
CONFIG_BCM_VC_SM=y
CONFIG_BCM2835_DEVGPIOMEM=y
CONFIG_BCM2835_SMI_DEV=m
CONFIG_RPIVID_MEM=m
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
# CONFIG_LEGACY_PTYS is not set
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_NOZOMI is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_LDISC_AUTOLOAD=y
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
# CONFIG_SERIAL_8250_DMA is not set
CONFIG_SERIAL_8250_PCI=y
CONFIG_SERIAL_8250_EXAR=y
CONFIG_SERIAL_8250_NR_UARTS=1
CONFIG_SERIAL_8250_RUNTIME_UARTS=0
CONFIG_SERIAL_8250_EXTENDED=y
# CONFIG_SERIAL_8250_MANY_PORTS is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_SHARE_IRQ=y
# CONFIG_SERIAL_8250_DETECT_IRQ is not set
# CONFIG_SERIAL_8250_RSA is not set
CONFIG_SERIAL_8250_BCM2835AUX=y
CONFIG_SERIAL_8250_FSL=y
# CONFIG_SERIAL_8250_DW is not set
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
# CONFIG_SERIAL_8250_MOXA is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_AMBA_PL010 is not set
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_KGDB_NMI is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_CONSOLE_POLL=y
# CONFIG_SERIAL_JSM is not set
# CONFIG_SERIAL_SCCNXP is not set
CONFIG_SERIAL_SC16IS7XX_CORE=m
CONFIG_SERIAL_SC16IS7XX=m
CONFIG_SERIAL_SC16IS7XX_I2C=y
CONFIG_SERIAL_SC16IS7XX_SPI=y
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_RP2 is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
CONFIG_SERIAL_DEV_BUS=m
CONFIG_TTY_PRINTK=y
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
CONFIG_HW_RANDOM_BCM2835=y
CONFIG_HW_RANDOM_IPROC_RNG200=y
# CONFIG_APPLICOM is not set
CONFIG_RAW_DRIVER=y
CONFIG_MAX_RAW_DEVS=256
CONFIG_TCG_TPM=m
CONFIG_HW_RANDOM_TPM=y
CONFIG_TCG_TIS_CORE=m
# CONFIG_TCG_TIS is not set
CONFIG_TCG_TIS_SPI=m
# CONFIG_TCG_TIS_I2C_ATMEL is not set
# CONFIG_TCG_TIS_I2C_INFINEON is not set
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_ATMEL is not set
# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
CONFIG_DEVPORT=y
# CONFIG_XILLYBUS is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=m
CONFIG_I2C_MUX=m
# Multiplexer I2C Chip support
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
# CONFIG_I2C_MUX_GPIO is not set
CONFIG_I2C_MUX_GPMUX=m
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
CONFIG_I2C_MUX_PCA954x=m
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=m
# I2C Hardware Bus support
# PC SMBus host controller drivers
CONFIG_I2C_BCM2708=m
CONFIG_I2C_BCM2708_BAUDRATE=100000
# CONFIG_I2C_ALI1535 is not set
# CONFIG_I2C_ALI1563 is not set
# CONFIG_I2C_ALI15X3 is not set
# CONFIG_I2C_AMD756 is not set
# CONFIG_I2C_AMD8111 is not set
# CONFIG_I2C_I801 is not set
# CONFIG_I2C_ISCH is not set
# CONFIG_I2C_PIIX4 is not set
# CONFIG_I2C_NFORCE2 is not set
# CONFIG_I2C_SIS5595 is not set
# CONFIG_I2C_SIS630 is not set
# CONFIG_I2C_SIS96X is not set
# CONFIG_I2C_VIA is not set
# CONFIG_I2C_VIAPRO is not set
# I2C system bus drivers (mostly embedded / system-on-chip)
CONFIG_I2C_BCM2835=m
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_DESIGNWARE_PCI is not set
# CONFIG_I2C_EMEV2 is not set
CONFIG_I2C_GPIO=m
# CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
# CONFIG_I2C_NOMADIK is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
CONFIG_I2C_ROBOTFUZZ_OSIF=m
# CONFIG_I2C_TAOS_EVM is not set
CONFIG_I2C_TINY_USB=m
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BCM2835=m
CONFIG_SPI_BCM2835AUX=m
# CONFIG_SPI_BCM_QSPI is not set
CONFIG_SPI_BITBANG=m
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
CONFIG_SPI_GPIO=m
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_PL022 is not set
# CONFIG_SPI_PXA2XX is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=m
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
CONFIG_SPI_SLAVE=y
# CONFIG_SPI_SLAVE_TIME is not set
# CONFIG_SPI_SLAVE_SYSTEM_CONTROL is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=m
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
CONFIG_PPS_CLIENT_LDISC=m
CONFIG_PPS_CLIENT_GPIO=m
# PPS generators support
# PTP clock support
# CONFIG_PTP_1588_CLOCK is not set
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AMD is not set
CONFIG_PINCTRL_MCP23S08=m
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
CONFIG_PINCTRL_BCM2835=y
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
CONFIG_GPIO_RASPBERRYPI_EXP=y
CONFIG_GPIO_BCM_VIRT=y
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_EXAR is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_MB86S7X is not set
CONFIG_GPIO_MOCKUP=m
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_PL061 is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
CONFIG_GPIO_PCA953X=m
CONFIG_GPIO_PCF857X=m
# CONFIG_GPIO_TPIC2810 is not set
# MFD GPIO expanders
CONFIG_GPIO_ARIZONA=m
# CONFIG_HTC_EGPIO is not set
CONFIG_GPIO_STMPE=y
# PCI GPIO expanders
# CONFIG_GPIO_BT8XX is not set
# CONFIG_GPIO_PCI_IDIO_16 is not set
# CONFIG_GPIO_PCIE_IDIO_24 is not set
# CONFIG_GPIO_RDC321X is not set
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# USB GPIO expanders
CONFIG_W1=m
CONFIG_W1_CON=y
# 1-wire Bus Masters
# CONFIG_W1_MASTER_MATROX is not set
CONFIG_W1_MASTER_DS2490=m
CONFIG_W1_MASTER_DS2482=m
CONFIG_W1_MASTER_DS1WM=m
CONFIG_W1_MASTER_GPIO=m
# 1-wire Slaves
CONFIG_W1_SLAVE_THERM=m
CONFIG_W1_SLAVE_SMEM=m
# CONFIG_W1_SLAVE_DS2405 is not set
CONFIG_W1_SLAVE_DS2408=m
CONFIG_W1_SLAVE_DS2408_READBACK=y
CONFIG_W1_SLAVE_DS2413=m
CONFIG_W1_SLAVE_DS2406=m
CONFIG_W1_SLAVE_DS2423=m
# CONFIG_W1_SLAVE_DS2805 is not set
CONFIG_W1_SLAVE_DS2431=m
CONFIG_W1_SLAVE_DS2433=m
# CONFIG_W1_SLAVE_DS2433_CRC is not set
CONFIG_W1_SLAVE_DS2438=m
CONFIG_W1_SLAVE_DS2780=m
CONFIG_W1_SLAVE_DS2781=m
CONFIG_W1_SLAVE_DS28E04=m
CONFIG_W1_SLAVE_DS28E17=m
# CONFIG_POWER_AVS is not set
CONFIG_POWER_RESET=y
# CONFIG_POWER_RESET_BRCMKONA is not set
# CONFIG_POWER_RESET_BRCMSTB is not set
CONFIG_POWER_RESET_GPIO=y
# CONFIG_POWER_RESET_GPIO_RESTART is not set
# CONFIG_POWER_RESET_LTC2952 is not set
# CONFIG_POWER_RESET_RESTART is not set
# CONFIG_POWER_RESET_VERSATILE is not set
# CONFIG_POWER_RESET_SYSCON is not set
# CONFIG_POWER_RESET_SYSCON_POWEROFF is not set
# CONFIG_SYSCON_REBOOT_MODE is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_GENERIC_ADC_BATTERY is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
CONFIG_BATTERY_DS2760=m
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_LEGO_EV3 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
CONFIG_BATTERY_MAX17040=m
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_BATTERY_MAX1721X is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LTC3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
CONFIG_BATTERY_GAUGE_LTC2941=m
# CONFIG_CHARGER_RT9455 is not set
CONFIG_HWMON=m
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ASPEED is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS620 is not set
CONFIG_SENSORS_DS1621=m
# CONFIG_SENSORS_I5K_AMB is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
CONFIG_SENSORS_GPIO_FAN=m
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IIO_HWMON is not set
# CONFIG_SENSORS_IT87 is not set
CONFIG_SENSORS_JC42=m
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31722 is not set
# CONFIG_SENSORS_MAX6621 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
CONFIG_SENSORS_LM75=m
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_NPCM7XX is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
# CONFIG_SENSORS_PWM_FAN is not set
CONFIG_SENSORS_RASPBERRYPI_HWMON=m
CONFIG_SENSORS_RPI_POE_FAN=m
# CONFIG_SENSORS_SHT15 is not set
CONFIG_SENSORS_SHT21=m
CONFIG_SENSORS_SHT3x=m
CONFIG_SENSORS_SHTC1=m
# CONFIG_SENSORS_SIS5595 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
CONFIG_SENSORS_ADS1015=m
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
CONFIG_SENSORS_INA2XX=m
# CONFIG_SENSORS_INA3221 is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
CONFIG_SENSORS_TMP102=m
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_VIA686A is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_VT8231 is not set
# CONFIG_SENSORS_W83773G is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
# CONFIG_THERMAL_STATISTICS is not set
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
# CONFIG_CPU_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_QORIQ_THERMAL is not set
# ACPI INT340X thermal drivers
# Broadcom thermal drivers
CONFIG_BCM2835_THERMAL=y
CONFIG_BRCMSTB_THERMAL=y
# CONFIG_GENERIC_ADC_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
# CONFIG_WATCHDOG_SYSFS is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
CONFIG_GPIO_WATCHDOG=m
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_ARM_SP805_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_FTWDT010_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_ALIM7101_WDT is not set
# CONFIG_I6300ESB_WDT is not set
CONFIG_BCM2835_WDT=y
# CONFIG_MEN_A21_WDT is not set
# PCI-based Watchdog Cards
# CONFIG_PCIPCWATCHDOG is not set
# CONFIG_WDTPCI is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
CONFIG_SSB_POSSIBLE=y
CONFIG_SSB=m
CONFIG_SSB_SPROM=y
CONFIG_SSB_BLOCKIO=y
CONFIG_SSB_PCIHOST_POSSIBLE=y
CONFIG_SSB_PCIHOST=y
CONFIG_SSB_B43_PCI_BRIDGE=y
CONFIG_SSB_SDIOHOST_POSSIBLE=y
# CONFIG_SSB_SDIOHOST is not set
CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
CONFIG_SSB_DRIVER_PCICORE=y
# CONFIG_SSB_DRIVER_GPIO is not set
CONFIG_BCMA_POSSIBLE=y
CONFIG_BCMA=m
CONFIG_BCMA_BLOCKIO=y
CONFIG_BCMA_HOST_PCI_POSSIBLE=y
CONFIG_BCMA_HOST_PCI=y
# CONFIG_BCMA_HOST_SOC is not set
CONFIG_BCMA_DRIVER_PCI=y
# CONFIG_BCMA_DRIVER_GMAC_CMN is not set
# CONFIG_BCMA_DRIVER_GPIO is not set
# CONFIG_BCMA_DEBUG is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
CONFIG_MFD_RPISENSE_CORE=m
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AXP20X_I2C is not set
# CONFIG_MFD_CROS_EC is not set
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_LPC_ICH is not set
# CONFIG_LPC_SCH is not set
# CONFIG_MFD_JANZ_CMODIO is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RDC321X is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
CONFIG_MFD_STMPE=y
# STMicroelectronics STMPE Interface Drivers
CONFIG_STMPE_I2C=y
CONFIG_STMPE_SPI=y
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
CONFIG_MFD_WL1273_CORE=m
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_VX855 is not set
CONFIG_MFD_ARIZONA=y
CONFIG_MFD_ARIZONA_I2C=m
CONFIG_MFD_ARIZONA_SPI=m
# CONFIG_MFD_CS47L24 is not set
CONFIG_MFD_WM5102=y
# CONFIG_MFD_WM5110 is not set
# CONFIG_MFD_WM8997 is not set
# CONFIG_MFD_WM8998 is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_RAVE_SP_CORE is not set
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=m
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
CONFIG_REGULATOR_ARIZONA_LDO1=m
CONFIG_REGULATOR_ARIZONA_MICSUPP=m
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
CONFIG_RC_CORE=y
CONFIG_RC_MAP=y
CONFIG_LIRC=y
CONFIG_RC_DECODERS=y
CONFIG_IR_NEC_DECODER=m
CONFIG_IR_RC5_DECODER=m
CONFIG_IR_RC6_DECODER=m
CONFIG_IR_JVC_DECODER=m
CONFIG_IR_SONY_DECODER=m
CONFIG_IR_SANYO_DECODER=m
CONFIG_IR_SHARP_DECODER=m
CONFIG_IR_MCE_KBD_DECODER=m
CONFIG_IR_XMP_DECODER=m
CONFIG_IR_IMON_DECODER=m
CONFIG_RC_DEVICES=y
CONFIG_RC_ATI_REMOTE=m
# CONFIG_IR_HIX5HD2 is not set
CONFIG_IR_IMON=m
# CONFIG_IR_IMON_RAW is not set
CONFIG_IR_MCEUSB=m
CONFIG_IR_REDRAT3=m
# CONFIG_IR_SPI is not set
CONFIG_IR_STREAMZAP=m
# CONFIG_IR_IGORPLUGUSB is not set
CONFIG_IR_IGUANA=m
CONFIG_IR_TTUSBIR=m
CONFIG_RC_LOOPBACK=m
CONFIG_IR_GPIO_CIR=m
CONFIG_IR_GPIO_TX=m
CONFIG_IR_PWM_TX=m
# CONFIG_IR_SERIAL is not set
# CONFIG_IR_SIR is not set
CONFIG_MEDIA_SUPPORT=m
# Multimedia core support
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_RADIO_SUPPORT=y
# CONFIG_MEDIA_SDR_SUPPORT is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
CONFIG_MEDIA_CONTROLLER=y
# CONFIG_MEDIA_CONTROLLER_DVB is not set
CONFIG_VIDEO_DEV=m
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_VIDEO_V4L2=m
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
# CONFIG_VIDEO_PCI_SKELETON is not set
CONFIG_VIDEO_TUNER=m
CONFIG_V4L2_MEM2MEM_DEV=m
CONFIG_V4L2_FWNODE=m
CONFIG_VIDEOBUF_GEN=m
CONFIG_VIDEOBUF_VMALLOC=m
CONFIG_DVB_CORE=m
# CONFIG_DVB_MMAP is not set
CONFIG_DVB_NET=y
CONFIG_TTPCI_EEPROM=m
CONFIG_DVB_MAX_ADAPTERS=16
# CONFIG_DVB_DYNAMIC_MINORS is not set
# CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
# CONFIG_DVB_ULE_DEBUG is not set
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_USB_M5602=m
CONFIG_USB_STV06XX=m
CONFIG_USB_GL860=m
CONFIG_USB_GSPCA_BENQ=m
CONFIG_USB_GSPCA_CONEX=m
CONFIG_USB_GSPCA_CPIA1=m
CONFIG_USB_GSPCA_DTCS033=m
CONFIG_USB_GSPCA_ETOMS=m
CONFIG_USB_GSPCA_FINEPIX=m
CONFIG_USB_GSPCA_JEILINJ=m
CONFIG_USB_GSPCA_JL2005BCD=m
CONFIG_USB_GSPCA_KINECT=m
CONFIG_USB_GSPCA_KONICA=m
CONFIG_USB_GSPCA_MARS=m
CONFIG_USB_GSPCA_MR97310A=m
CONFIG_USB_GSPCA_NW80X=m
CONFIG_USB_GSPCA_OV519=m
CONFIG_USB_GSPCA_OV534=m
CONFIG_USB_GSPCA_OV534_9=m
CONFIG_USB_GSPCA_PAC207=m
CONFIG_USB_GSPCA_PAC7302=m
CONFIG_USB_GSPCA_PAC7311=m
CONFIG_USB_GSPCA_SE401=m
CONFIG_USB_GSPCA_SN9C2028=m
CONFIG_USB_GSPCA_SN9C20X=m
CONFIG_USB_GSPCA_SONIXB=m
CONFIG_USB_GSPCA_SONIXJ=m
CONFIG_USB_GSPCA_SPCA500=m
CONFIG_USB_GSPCA_SPCA501=m
CONFIG_USB_GSPCA_SPCA505=m
CONFIG_USB_GSPCA_SPCA506=m
CONFIG_USB_GSPCA_SPCA508=m
CONFIG_USB_GSPCA_SPCA561=m
CONFIG_USB_GSPCA_SPCA1528=m
CONFIG_USB_GSPCA_SQ905=m
CONFIG_USB_GSPCA_SQ905C=m
CONFIG_USB_GSPCA_SQ930X=m
CONFIG_USB_GSPCA_STK014=m
CONFIG_USB_GSPCA_STK1135=m
CONFIG_USB_GSPCA_STV0680=m
CONFIG_USB_GSPCA_SUNPLUS=m
CONFIG_USB_GSPCA_T613=m
CONFIG_USB_GSPCA_TOPRO=m
# CONFIG_USB_GSPCA_TOUPTEK is not set
CONFIG_USB_GSPCA_TV8532=m
CONFIG_USB_GSPCA_VC032X=m
CONFIG_USB_GSPCA_VICAM=m
CONFIG_USB_GSPCA_XIRLINK_CIT=m
CONFIG_USB_GSPCA_ZC3XX=m
CONFIG_USB_PWC=m
# CONFIG_USB_PWC_DEBUG is not set
CONFIG_USB_PWC_INPUT_EVDEV=y
CONFIG_VIDEO_CPIA2=m
CONFIG_USB_ZR364XX=m
CONFIG_USB_STKWEBCAM=m
CONFIG_USB_S2255=m
CONFIG_VIDEO_USBTV=m
# Analog TV USB devices
CONFIG_VIDEO_PVRUSB2=m
CONFIG_VIDEO_PVRUSB2_SYSFS=y
CONFIG_VIDEO_PVRUSB2_DVB=y
# CONFIG_VIDEO_PVRUSB2_DEBUGIFC is not set
CONFIG_VIDEO_HDPVR=m
CONFIG_VIDEO_USBVISION=m
CONFIG_VIDEO_STK1160_COMMON=m
CONFIG_VIDEO_STK1160=m
CONFIG_VIDEO_GO7007=m
CONFIG_VIDEO_GO7007_USB=m
CONFIG_VIDEO_GO7007_LOADER=m
CONFIG_VIDEO_GO7007_USB_S2250_BOARD=m
# Analog/digital TV USB devices
CONFIG_VIDEO_AU0828=m
CONFIG_VIDEO_AU0828_V4L2=y
CONFIG_VIDEO_AU0828_RC=y
CONFIG_VIDEO_CX231XX=m
CONFIG_VIDEO_CX231XX_RC=y
CONFIG_VIDEO_CX231XX_ALSA=m
CONFIG_VIDEO_CX231XX_DVB=m
CONFIG_VIDEO_TM6000=m
CONFIG_VIDEO_TM6000_ALSA=m
CONFIG_VIDEO_TM6000_DVB=m
# Digital TV USB devices
CONFIG_DVB_USB=m
# CONFIG_DVB_USB_DEBUG is not set
CONFIG_DVB_USB_DIB3000MC=m
CONFIG_DVB_USB_A800=m
CONFIG_DVB_USB_DIBUSB_MB=m
CONFIG_DVB_USB_DIBUSB_MB_FAULTY=y
CONFIG_DVB_USB_DIBUSB_MC=m
CONFIG_DVB_USB_DIB0700=m
CONFIG_DVB_USB_UMT_010=m
CONFIG_DVB_USB_CXUSB=m
CONFIG_DVB_USB_M920X=m
CONFIG_DVB_USB_DIGITV=m
CONFIG_DVB_USB_VP7045=m
CONFIG_DVB_USB_VP702X=m
CONFIG_DVB_USB_GP8PSK=m
CONFIG_DVB_USB_NOVA_T_USB2=m
CONFIG_DVB_USB_TTUSB2=m
CONFIG_DVB_USB_DTT200U=m
CONFIG_DVB_USB_OPERA1=m
CONFIG_DVB_USB_AF9005=m
CONFIG_DVB_USB_AF9005_REMOTE=m
CONFIG_DVB_USB_PCTV452E=m
CONFIG_DVB_USB_DW2102=m
CONFIG_DVB_USB_CINERGY_T2=m
CONFIG_DVB_USB_DTV5100=m
CONFIG_DVB_USB_AZ6027=m
CONFIG_DVB_USB_TECHNISAT_USB2=m
CONFIG_DVB_USB_V2=m
CONFIG_DVB_USB_AF9015=m
CONFIG_DVB_USB_AF9035=m
CONFIG_DVB_USB_ANYSEE=m
CONFIG_DVB_USB_AU6610=m
CONFIG_DVB_USB_AZ6007=m
CONFIG_DVB_USB_CE6230=m
CONFIG_DVB_USB_EC168=m
CONFIG_DVB_USB_GL861=m
CONFIG_DVB_USB_LME2510=m
CONFIG_DVB_USB_MXL111SF=m
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_USB_DVBSKY=m
# CONFIG_DVB_USB_ZD1301 is not set
# CONFIG_DVB_TTUSB_BUDGET is not set
# CONFIG_DVB_TTUSB_DEC is not set
CONFIG_SMS_USB_DRV=m
CONFIG_DVB_B2C2_FLEXCOP_USB=m
# CONFIG_DVB_B2C2_FLEXCOP_USB_DEBUG is not set
CONFIG_DVB_AS102=m
# Webcam, TV (analog/digital) USB devices
CONFIG_VIDEO_EM28XX=m
CONFIG_VIDEO_EM28XX_V4L2=m
CONFIG_VIDEO_EM28XX_ALSA=m
CONFIG_VIDEO_EM28XX_DVB=m
CONFIG_VIDEO_EM28XX_RC=m
# CONFIG_MEDIA_PCI_SUPPORT is not set
CONFIG_V4L_PLATFORM_DRIVERS=y
# CONFIG_VIDEO_CAFE_CCIC is not set
# CONFIG_VIDEO_CADENCE is not set
# CONFIG_VIDEO_MUX is not set
# CONFIG_SOC_CAMERA is not set
# CONFIG_VIDEO_XILINX is not set
CONFIG_VIDEO_BCM2835_UNICAM=m
# CONFIG_V4L_MEM2MEM_DRIVERS is not set
# CONFIG_V4L_TEST_DRIVERS is not set
# CONFIG_DVB_PLATFORM_DRIVERS is not set
# Supported MMC/SDIO adapters
# CONFIG_SMS_SDIO_DRV is not set
CONFIG_RADIO_ADAPTERS=y
CONFIG_RADIO_TEA575X=m
CONFIG_RADIO_SI470X=m
CONFIG_USB_SI470X=m
CONFIG_I2C_SI470X=m
CONFIG_RADIO_SI4713=m
# CONFIG_USB_SI4713 is not set
# CONFIG_PLATFORM_SI4713 is not set
CONFIG_I2C_SI4713=m
CONFIG_USB_MR800=m
CONFIG_USB_DSBR=m
# CONFIG_RADIO_MAXIRADIO is not set
CONFIG_RADIO_SHARK=m
CONFIG_RADIO_SHARK2=m
CONFIG_USB_KEENE=m
# CONFIG_USB_RAREMONO is not set
CONFIG_USB_MA901=m
CONFIG_RADIO_TEA5764=m
CONFIG_RADIO_SAA7706H=m
CONFIG_RADIO_TEF6862=m
CONFIG_RADIO_WL1273=m
# Texas Instruments WL128x FM driver (ST based)
CONFIG_RADIO_WL128X=m
CONFIG_MEDIA_COMMON_OPTIONS=y
# common driver options
CONFIG_VIDEO_CX2341X=m
CONFIG_VIDEO_TVEEPROM=m
CONFIG_CYPRESS_FIRMWARE=m
CONFIG_VIDEOBUF2_CORE=m
CONFIG_VIDEOBUF2_V4L2=m
CONFIG_VIDEOBUF2_MEMOPS=m
CONFIG_VIDEOBUF2_DMA_CONTIG=m
CONFIG_VIDEOBUF2_VMALLOC=m
CONFIG_DVB_B2C2_FLEXCOP=m
CONFIG_SMS_SIANO_MDTV=m
CONFIG_SMS_SIANO_RC=y
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
# CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
CONFIG_MEDIA_ATTACH=y
CONFIG_VIDEO_IR_I2C=m
# I2C Encoders, decoders, sensors and other helper chips
# Audio decoders, processors and mixers
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TDA1997X is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
CONFIG_VIDEO_MSP3400=m
# CONFIG_VIDEO_CS3308 is not set
# CONFIG_VIDEO_CS5345 is not set
CONFIG_VIDEO_CS53L32A=m
# CONFIG_VIDEO_TLV320AIC23B is not set
CONFIG_VIDEO_UDA1342=m
CONFIG_VIDEO_WM8775=m
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_VP27SMPX is not set
CONFIG_VIDEO_SONY_BTF_MPX=m
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# Video decoders
CONFIG_VIDEO_ADV7180=m
# CONFIG_VIDEO_ADV7183 is not set
# CONFIG_VIDEO_ADV748X is not set
# CONFIG_VIDEO_ADV7604 is not set
# CONFIG_VIDEO_ADV7842 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_ML86V7667 is not set
# CONFIG_VIDEO_AD5820 is not set
# CONFIG_VIDEO_AK7375 is not set
# CONFIG_VIDEO_DW9714 is not set
# CONFIG_VIDEO_DW9807_VCM is not set
# CONFIG_VIDEO_SAA7110 is not set
CONFIG_VIDEO_SAA711X=m
CONFIG_VIDEO_TC358743=m
# CONFIG_VIDEO_TC358743_CEC is not set
# CONFIG_VIDEO_TVP514X is not set
CONFIG_VIDEO_TVP5150=m
# CONFIG_VIDEO_TVP7002 is not set
CONFIG_VIDEO_TW2804=m
CONFIG_VIDEO_TW9903=m
CONFIG_VIDEO_TW9906=m
# CONFIG_VIDEO_TW9910 is not set
# CONFIG_VIDEO_VPX3220 is not set
# Video and audio decoders
# CONFIG_VIDEO_SAA717X is not set
CONFIG_VIDEO_CX25840=m
# Video encoders
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_ADV7393 is not set
# CONFIG_VIDEO_ADV7511 is not set
# CONFIG_VIDEO_AD9389B is not set
# CONFIG_VIDEO_AK881X is not set
# CONFIG_VIDEO_THS8200 is not set
# Camera sensor devices
CONFIG_VIDEO_IMX219=m
# CONFIG_VIDEO_IMX258 is not set
# CONFIG_VIDEO_IMX274 is not set
# CONFIG_VIDEO_OV2640 is not set
# CONFIG_VIDEO_OV2659 is not set
# CONFIG_VIDEO_OV2680 is not set
# CONFIG_VIDEO_OV2685 is not set
# CONFIG_VIDEO_OV5640 is not set
# CONFIG_VIDEO_OV5645 is not set
CONFIG_VIDEO_OV5647=m
# CONFIG_VIDEO_OV6650 is not set
# CONFIG_VIDEO_OV5670 is not set
# CONFIG_VIDEO_OV5695 is not set
# CONFIG_VIDEO_OV7251 is not set
# CONFIG_VIDEO_OV772X is not set
CONFIG_VIDEO_OV7640=m
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_OV7740 is not set
# CONFIG_VIDEO_OV9650 is not set
# CONFIG_VIDEO_OV13858 is not set
# CONFIG_VIDEO_VS6624 is not set
# CONFIG_VIDEO_MT9M032 is not set
# CONFIG_VIDEO_MT9M111 is not set
# CONFIG_VIDEO_MT9P031 is not set
# CONFIG_VIDEO_MT9T001 is not set
# CONFIG_VIDEO_MT9T112 is not set
CONFIG_VIDEO_MT9V011=m
# CONFIG_VIDEO_MT9V032 is not set
# CONFIG_VIDEO_MT9V111 is not set
# CONFIG_VIDEO_SR030PC30 is not set
# CONFIG_VIDEO_NOON010PC30 is not set
# CONFIG_VIDEO_M5MOLS is not set
# CONFIG_VIDEO_RJ54N1 is not set
# CONFIG_VIDEO_S5K6AA is not set
# CONFIG_VIDEO_S5K6A3 is not set
# CONFIG_VIDEO_S5K4ECGX is not set
# CONFIG_VIDEO_S5K5BAF is not set
# CONFIG_VIDEO_SMIAPP is not set
# CONFIG_VIDEO_ET8EK8 is not set
# CONFIG_VIDEO_S5C73M3 is not set
# Flash devices
# CONFIG_VIDEO_ADP1653 is not set
# CONFIG_VIDEO_LM3560 is not set
# CONFIG_VIDEO_LM3646 is not set
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# Audio/Video compression chips
# CONFIG_VIDEO_SAA6752HS is not set
# SDR tuner chips
# Miscellaneous helper chips
# CONFIG_VIDEO_THS7303 is not set
# CONFIG_VIDEO_M52790 is not set
# CONFIG_VIDEO_I2C is not set
# Sensors used on soc_camera driver
# SPI helper chips
# CONFIG_VIDEO_GS1662 is not set
# Media SPI Adapters
CONFIG_CXD2880_SPI_DRV=m
CONFIG_MEDIA_TUNER=m
# Customize TV tuners
CONFIG_MEDIA_TUNER_SIMPLE=m
CONFIG_MEDIA_TUNER_TDA18250=m
CONFIG_MEDIA_TUNER_TDA8290=m
CONFIG_MEDIA_TUNER_TDA827X=m
CONFIG_MEDIA_TUNER_TDA18271=m
CONFIG_MEDIA_TUNER_TDA9887=m
CONFIG_MEDIA_TUNER_TEA5761=m
CONFIG_MEDIA_TUNER_TEA5767=m
CONFIG_MEDIA_TUNER_MSI001=m
CONFIG_MEDIA_TUNER_MT20XX=m
CONFIG_MEDIA_TUNER_MT2060=m
CONFIG_MEDIA_TUNER_MT2063=m
CONFIG_MEDIA_TUNER_MT2266=m
CONFIG_MEDIA_TUNER_MT2131=m
CONFIG_MEDIA_TUNER_QT1010=m
CONFIG_MEDIA_TUNER_XC2028=m
CONFIG_MEDIA_TUNER_XC5000=m
CONFIG_MEDIA_TUNER_XC4000=m
CONFIG_MEDIA_TUNER_MXL5005S=m
CONFIG_MEDIA_TUNER_MXL5007T=m
CONFIG_MEDIA_TUNER_MC44S803=m
CONFIG_MEDIA_TUNER_MAX2165=m
CONFIG_MEDIA_TUNER_TDA18218=m
CONFIG_MEDIA_TUNER_FC0011=m
CONFIG_MEDIA_TUNER_FC0012=m
CONFIG_MEDIA_TUNER_FC0013=m
CONFIG_MEDIA_TUNER_TDA18212=m
CONFIG_MEDIA_TUNER_E4000=m
CONFIG_MEDIA_TUNER_FC2580=m
CONFIG_MEDIA_TUNER_M88RS6000T=m
CONFIG_MEDIA_TUNER_TUA9001=m
CONFIG_MEDIA_TUNER_SI2157=m
CONFIG_MEDIA_TUNER_IT913X=m
CONFIG_MEDIA_TUNER_R820T=m
CONFIG_MEDIA_TUNER_MXL301RF=m
CONFIG_MEDIA_TUNER_QM1D1C0042=m
CONFIG_MEDIA_TUNER_QM1D1B0004=m
# Customise DVB Frontends
# Multistandard (satellite) frontends
CONFIG_DVB_STB0899=m
CONFIG_DVB_STB6100=m
CONFIG_DVB_STV090x=m
CONFIG_DVB_STV0910=m
CONFIG_DVB_STV6110x=m
CONFIG_DVB_STV6111=m
CONFIG_DVB_MXL5XX=m
CONFIG_DVB_M88DS3103=m
# Multistandard (cable + terrestrial) frontends
CONFIG_DVB_DRXK=m
CONFIG_DVB_TDA18271C2DD=m
CONFIG_DVB_SI2165=m
CONFIG_DVB_MN88472=m
CONFIG_DVB_MN88473=m
# DVB-S (satellite) frontends
CONFIG_DVB_CX24110=m
CONFIG_DVB_CX24123=m
CONFIG_DVB_MT312=m
CONFIG_DVB_ZL10036=m
CONFIG_DVB_ZL10039=m
CONFIG_DVB_S5H1420=m
CONFIG_DVB_STV0288=m
CONFIG_DVB_STB6000=m
CONFIG_DVB_STV0299=m
CONFIG_DVB_STV6110=m
CONFIG_DVB_STV0900=m
CONFIG_DVB_TDA8083=m
CONFIG_DVB_TDA10086=m
CONFIG_DVB_TDA8261=m
CONFIG_DVB_VES1X93=m
CONFIG_DVB_TUNER_ITD1000=m
CONFIG_DVB_TUNER_CX24113=m
CONFIG_DVB_TDA826X=m
CONFIG_DVB_TUA6100=m
CONFIG_DVB_CX24116=m
CONFIG_DVB_CX24117=m
CONFIG_DVB_CX24120=m
CONFIG_DVB_SI21XX=m
CONFIG_DVB_TS2020=m
CONFIG_DVB_DS3000=m
CONFIG_DVB_MB86A16=m
CONFIG_DVB_TDA10071=m
# DVB-T (terrestrial) frontends
CONFIG_DVB_SP8870=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_CX22700=m
CONFIG_DVB_CX22702=m
CONFIG_DVB_S5H1432=m
CONFIG_DVB_DRXD=m
CONFIG_DVB_L64781=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_NXT6000=m
CONFIG_DVB_MT352=m
CONFIG_DVB_ZL10353=m
CONFIG_DVB_DIB3000MB=m
CONFIG_DVB_DIB3000MC=m
CONFIG_DVB_DIB7000M=m
CONFIG_DVB_DIB7000P=m
CONFIG_DVB_DIB9000=m
CONFIG_DVB_TDA10048=m
CONFIG_DVB_AF9013=m
CONFIG_DVB_EC100=m
CONFIG_DVB_STV0367=m
CONFIG_DVB_CXD2820R=m
CONFIG_DVB_CXD2841ER=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_SI2168=m
CONFIG_DVB_AS102_FE=m
CONFIG_DVB_ZD1301_DEMOD=m
CONFIG_DVB_GP8PSK_FE=m
CONFIG_DVB_CXD2880=m
# DVB-C (cable) frontends
CONFIG_DVB_VES1820=m
CONFIG_DVB_TDA10021=m
CONFIG_DVB_TDA10023=m
CONFIG_DVB_STV0297=m
# ATSC (North American/Korean Terrestrial/Cable DTV) frontends
CONFIG_DVB_NXT200X=m
CONFIG_DVB_OR51211=m
CONFIG_DVB_OR51132=m
CONFIG_DVB_BCM3510=m
CONFIG_DVB_LGDT330X=m
CONFIG_DVB_LGDT3305=m
CONFIG_DVB_LGDT3306A=m
CONFIG_DVB_LG2160=m
CONFIG_DVB_S5H1409=m
CONFIG_DVB_AU8522=m
CONFIG_DVB_AU8522_DTV=m
CONFIG_DVB_AU8522_V4L=m
CONFIG_DVB_S5H1411=m
# ISDB-T (terrestrial) frontends
CONFIG_DVB_S921=m
CONFIG_DVB_DIB8000=m
CONFIG_DVB_MB86A20S=m
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
CONFIG_DVB_TC90522=m
CONFIG_DVB_MN88443X=m
# Digital terrestrial only tuners/PLL
CONFIG_DVB_PLL=m
CONFIG_DVB_TUNER_DIB0070=m
CONFIG_DVB_TUNER_DIB0090=m
# SEC control devices for DVB-S
CONFIG_DVB_DRX39XYJ=m
CONFIG_DVB_LNBH25=m
CONFIG_DVB_LNBP21=m
CONFIG_DVB_LNBP22=m
CONFIG_DVB_ISL6405=m
CONFIG_DVB_ISL6421=m
CONFIG_DVB_ISL6423=m
CONFIG_DVB_A8293=m
CONFIG_DVB_LGS8GL5=m
CONFIG_DVB_LGS8GXX=m
CONFIG_DVB_ATBM8830=m
CONFIG_DVB_TDA665x=m
CONFIG_DVB_IX2505V=m
CONFIG_DVB_M88RS2000=m
CONFIG_DVB_AF9033=m
CONFIG_DVB_HORUS3A=m
CONFIG_DVB_ASCOT2E=m
CONFIG_DVB_HELENE=m
# Common Interface (EN50221) controller drivers
CONFIG_DVB_CXD2099=m
CONFIG_DVB_SP2=m
# Tools to develop new frontends
# CONFIG_DVB_DUMMY_FE is not set
# Graphics support
CONFIG_VGA_ARB=y
CONFIG_VGA_ARB_MAX_GPUS=16
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=m
CONFIG_DRM_MIPI_DSI=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=m
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
CONFIG_DRM_SCHED=m
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# CONFIG_DRM_RADEON is not set
# CONFIG_DRM_AMDGPU is not set
# ACP (Audio CoProcessor) Configuration
# AMD Library routines
# CONFIG_DRM_NOUVEAU is not set
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_EXYNOS is not set
CONFIG_DRM_UDL=m
# CONFIG_DRM_AST is not set
# CONFIG_DRM_MGAG200 is not set
# CONFIG_DRM_CIRRUS_QEMU is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_QXL is not set
# CONFIG_DRM_BOCHS is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=m
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN=m
# CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
# CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_CDNS_DSI is not set
# CONFIG_DRM_DUMB_VGA_DAC is not set
# CONFIG_DRM_LVDS_ENCODER is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_SII9234 is not set
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# CONFIG_DRM_STI is not set
CONFIG_DRM_V3D=m
CONFIG_DRM_VC4=m
# CONFIG_DRM_VC4_HDMI_CEC is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_HISI_HIBMC is not set
# CONFIG_DRM_MXSFB is not set
CONFIG_DRM_TINYDRM=m
CONFIG_TINYDRM_MIPI_DBI=m
CONFIG_TINYDRM_ILI9225=m
CONFIG_TINYDRM_ILI9341=m
CONFIG_TINYDRM_MI0283QT=m
CONFIG_TINYDRM_REPAPER=m
CONFIG_TINYDRM_ST7586=m
CONFIG_TINYDRM_ST7735R=m
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_TVE200 is not set
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m
# Frame buffer Devices
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=m
CONFIG_FB_SYS_COPYAREA=m
CONFIG_FB_SYS_IMAGEBLIT=m
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=m
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_BACKLIGHT=y
CONFIG_FB_MODE_HELPERS=y
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
CONFIG_FB_BCM2708=y
# CONFIG_FB_CIRRUS is not set
# CONFIG_FB_PM2 is not set
# CONFIG_FB_ARMCLCD is not set
# CONFIG_FB_CYBER2000 is not set
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
# CONFIG_FB_UVESA is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_NVIDIA is not set
# CONFIG_FB_RIVA is not set
# CONFIG_FB_I740 is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_S3 is not set
# CONFIG_FB_SAVAGE is not set
# CONFIG_FB_SIS is not set
# CONFIG_FB_NEOMAGIC is not set
# CONFIG_FB_KYRO is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_VT8623 is not set
# CONFIG_FB_TRIDENT is not set
# CONFIG_FB_ARK is not set
# CONFIG_FB_PM3 is not set
# CONFIG_FB_CARMINE is not set
# CONFIG_FB_SMSCUFX is not set
CONFIG_FB_UDL=m
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX is not set
# CONFIG_FB_BROADSHEET is not set
CONFIG_FB_SIMPLE=y
CONFIG_FB_SSD1307=m
# CONFIG_FB_SM712 is not set
CONFIG_FB_RPISENSE=m
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_LCD_CLASS_DEVICE=m
# CONFIG_LCD_L4F00242T03 is not set
# CONFIG_LCD_LMS283GF05 is not set
# CONFIG_LCD_LTV350QV is not set
# CONFIG_LCD_ILI922X is not set
# CONFIG_LCD_ILI9320 is not set
# CONFIG_LCD_TDO24M is not set
# CONFIG_LCD_VGG2432A4 is not set
# CONFIG_LCD_PLATFORM is not set
# CONFIG_LCD_S6E63M0 is not set
# CONFIG_LCD_LD9040 is not set
# CONFIG_LCD_AMS369FG06 is not set
# CONFIG_LCD_LMS501KF03 is not set
# CONFIG_LCD_HX8357 is not set
# CONFIG_LCD_OTM3225A is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_GENERIC is not set
# CONFIG_BACKLIGHT_PWM is not set
CONFIG_BACKLIGHT_RPI=m
# CONFIG_BACKLIGHT_PM8941_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
CONFIG_BACKLIGHT_GPIO=m
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
CONFIG_LOGO_LINUX_CLUT224=y
CONFIG_SOUND=y
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_PCM_ELD=y
CONFIG_SND_DMAENGINE_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_SEQ_DEVICE=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_COMPRESS_OFFLOAD=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
# CONFIG_SND_OSSEMUL is not set
CONFIG_SND_PCM_TIMER=y
CONFIG_SND_HRTIMER=m
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
CONFIG_SND_VMASTER=y
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
CONFIG_SND_SEQ_MIDI_EVENT=m
CONFIG_SND_SEQ_MIDI=m
CONFIG_SND_SEQ_VIRMIDI=m
CONFIG_SND_MPU401_UART=m
CONFIG_SND_DRIVERS=y
CONFIG_SND_DUMMY=m
CONFIG_SND_ALOOP=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
CONFIG_SND_PCI=y
# CONFIG_SND_AD1889 is not set
# CONFIG_SND_ALS300 is not set
# CONFIG_SND_ALI5451 is not set
# CONFIG_SND_ATIIXP is not set
# CONFIG_SND_ATIIXP_MODEM is not set
# CONFIG_SND_AU8810 is not set
# CONFIG_SND_AU8820 is not set
# CONFIG_SND_AU8830 is not set
# CONFIG_SND_AW2 is not set
# CONFIG_SND_AZT3328 is not set
# CONFIG_SND_BT87X is not set
# CONFIG_SND_CA0106 is not set
# CONFIG_SND_CMIPCI is not set
# CONFIG_SND_OXYGEN is not set
# CONFIG_SND_CS4281 is not set
# CONFIG_SND_CS46XX is not set
# CONFIG_SND_CTXFI is not set
# CONFIG_SND_DARLA20 is not set
# CONFIG_SND_GINA20 is not set
# CONFIG_SND_LAYLA20 is not set
# CONFIG_SND_DARLA24 is not set
# CONFIG_SND_GINA24 is not set
# CONFIG_SND_LAYLA24 is not set
# CONFIG_SND_MONA is not set
# CONFIG_SND_MIA is not set
# CONFIG_SND_ECHO3G is not set
# CONFIG_SND_INDIGO is not set
# CONFIG_SND_INDIGOIO is not set
# CONFIG_SND_INDIGODJ is not set
# CONFIG_SND_INDIGOIOX is not set
# CONFIG_SND_INDIGODJX is not set
# CONFIG_SND_EMU10K1 is not set
# CONFIG_SND_EMU10K1X is not set
# CONFIG_SND_ENS1370 is not set
# CONFIG_SND_ENS1371 is not set
# CONFIG_SND_ES1938 is not set
# CONFIG_SND_ES1968 is not set
# CONFIG_SND_FM801 is not set
# CONFIG_SND_HDSP is not set
# CONFIG_SND_HDSPM is not set
# CONFIG_SND_ICE1712 is not set
# CONFIG_SND_ICE1724 is not set
# CONFIG_SND_INTEL8X0 is not set
# CONFIG_SND_INTEL8X0M is not set
# CONFIG_SND_KORG1212 is not set
# CONFIG_SND_LOLA is not set
# CONFIG_SND_LX6464ES is not set
# CONFIG_SND_MAESTRO3 is not set
# CONFIG_SND_MIXART is not set
# CONFIG_SND_NM256 is not set
# CONFIG_SND_PCXHR is not set
# CONFIG_SND_RIPTIDE is not set
# CONFIG_SND_RME32 is not set
# CONFIG_SND_RME96 is not set
# CONFIG_SND_RME9652 is not set
# CONFIG_SND_SE6X is not set
# CONFIG_SND_SONICVIBES is not set
# CONFIG_SND_TRIDENT is not set
# CONFIG_SND_VIA82XX is not set
# CONFIG_SND_VIA82XX_MODEM is not set
# CONFIG_SND_VIRTUOSO is not set
# CONFIG_SND_VX222 is not set
# CONFIG_SND_YMFPCI is not set
# HD-Audio
# CONFIG_SND_HDA_INTEL is not set
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
# CONFIG_SND_ARMAACI is not set
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_UA101=m
CONFIG_SND_USB_CAIAQ=m
CONFIG_SND_USB_CAIAQ_INPUT=y
CONFIG_SND_USB_6FIRE=m
CONFIG_SND_USB_HIFACE=m
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=m
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
CONFIG_SND_SOC_COMPRESS=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
CONFIG_SND_BCM2835_SOC_I2S=m
CONFIG_SND_BCM2708_SOC_GOOGLEVOICEHAT_SOUNDCARD=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DAC=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUS=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUSADC=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUSADCPRO=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUSDSP=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DIGI=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_AMP=m
CONFIG_SND_BCM2708_SOC_RPI_CIRRUS=m
CONFIG_SND_BCM2708_SOC_RPI_DAC=m
CONFIG_SND_BCM2708_SOC_RPI_PROTO=m
CONFIG_SND_BCM2708_SOC_JUSTBOOM_DAC=m
CONFIG_SND_BCM2708_SOC_JUSTBOOM_DIGI=m
CONFIG_SND_BCM2708_SOC_IQAUDIO_CODEC=m
CONFIG_SND_BCM2708_SOC_IQAUDIO_DAC=m
CONFIG_SND_BCM2708_SOC_IQAUDIO_DIGI=m
CONFIG_SND_BCM2708_SOC_I_SABRE_Q2M=m
CONFIG_SND_BCM2708_SOC_ADAU1977_ADC=m
CONFIG_SND_AUDIOINJECTOR_PI_SOUNDCARD=m
CONFIG_SND_AUDIOINJECTOR_OCTO_SOUNDCARD=m
CONFIG_SND_AUDIOSENSE_PI=m
CONFIG_SND_DIGIDAC1_SOUNDCARD=m
CONFIG_SND_BCM2708_SOC_DIONAUDIO_LOCO=m
CONFIG_SND_BCM2708_SOC_DIONAUDIO_LOCO_V2=m
CONFIG_SND_BCM2708_SOC_ALLO_PIANO_DAC=m
CONFIG_SND_BCM2708_SOC_ALLO_PIANO_DAC_PLUS=m
CONFIG_SND_BCM2708_SOC_ALLO_BOSS_DAC=m
CONFIG_SND_BCM2708_SOC_ALLO_DIGIONE=m
CONFIG_SND_BCM2708_SOC_ALLO_KATANA_DAC=m
CONFIG_SND_BCM2708_SOC_FE_PI_AUDIO=m
CONFIG_SND_PISOUND=m
CONFIG_SND_RPI_SIMPLE_SOUNDCARD=m
CONFIG_SND_RPI_WM8804_SOUNDCARD=m
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# STMicroelectronics STM32 SOC audio support
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=m
# CODEC drivers
CONFIG_SND_SOC_ARIZONA=m
CONFIG_SND_SOC_WM_ADSP=m
# CONFIG_SND_SOC_AC97_CODEC is not set
CONFIG_SND_SOC_AD193X=m
CONFIG_SND_SOC_AD193X_SPI=m
CONFIG_SND_SOC_AD193X_I2C=m
CONFIG_SND_SOC_ADAU1701=m
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
CONFIG_SND_SOC_ADAU1977=m
CONFIG_SND_SOC_ADAU1977_I2C=m
CONFIG_SND_SOC_ADAU7002=m
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4458 is not set
CONFIG_SND_SOC_AK4554=m
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
CONFIG_SND_SOC_CS4265=m
# CONFIG_SND_SOC_CS4270 is not set
CONFIG_SND_SOC_CS4271=m
CONFIG_SND_SOC_CS4271_I2C=m
# CONFIG_SND_SOC_CS4271_SPI is not set
CONFIG_SND_SOC_CS42XX8=m
CONFIG_SND_SOC_CS42XX8_I2C=m
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
CONFIG_SND_SOC_DA7213=m
CONFIG_SND_SOC_DMIC=m
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
CONFIG_SND_SOC_ICS43432=m
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
CONFIG_SND_SOC_PCM186X=m
CONFIG_SND_SOC_PCM186X_I2C=m
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
CONFIG_SND_SOC_PCM5102A=m
CONFIG_SND_SOC_PCM512x=m
CONFIG_SND_SOC_PCM512x_I2C=m
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RT5616 is not set
CONFIG_SND_SOC_PCM1794A=m
# CONFIG_SND_SOC_RT5631 is not set
CONFIG_SND_SOC_SGTL5000=m
CONFIG_SND_SOC_SIGMADSP=m
CONFIG_SND_SOC_SIGMADSP_I2C=m
# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
CONFIG_SND_SOC_SPDIF=m
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
CONFIG_SND_SOC_TAS5713=m
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
CONFIG_SND_SOC_TLV320AIC32X4=m
CONFIG_SND_SOC_TLV320AIC32X4_I2C=m
# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
CONFIG_SND_SOC_WM5102=m
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
CONFIG_SND_SOC_WM8731=m
# CONFIG_SND_SOC_WM8737 is not set
CONFIG_SND_SOC_WM8741=m
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
CONFIG_SND_SOC_WM8804=m
CONFIG_SND_SOC_WM8804_I2C=m
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
CONFIG_SND_SOC_I_SABRE_CODEC=m
CONFIG_SND_SIMPLE_CARD_UTILS=m
CONFIG_SND_SIMPLE_CARD=m
# CONFIG_SND_SIMPLE_SCU_CARD is not set
CONFIG_SND_AUDIO_GRAPH_CARD=m
# CONFIG_SND_AUDIO_GRAPH_SCU_CARD is not set
# HID support
CONFIG_HID=y
CONFIG_HID_BATTERY_STRENGTH=y
CONFIG_HIDRAW=y
CONFIG_UHID=m
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=m
# CONFIG_HID_ACCUTOUCH is not set
CONFIG_HID_ACRUX=m
# CONFIG_HID_ACRUX_FF is not set
CONFIG_HID_APPLE=m
# CONFIG_HID_APPLEIR is not set
CONFIG_HID_ASUS=m
# CONFIG_HID_AUREAL is not set
CONFIG_HID_BELKIN=m
CONFIG_HID_BETOP_FF=m
CONFIG_HID_BIGBEN_FF=m
CONFIG_HID_CHERRY=m
CONFIG_HID_CHICONY=m
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
# CONFIG_HID_CP2112 is not set
CONFIG_HID_CYPRESS=m
CONFIG_HID_DRAGONRISE=m
# CONFIG_DRAGONRISE_FF is not set
CONFIG_HID_EMS_FF=m
# CONFIG_HID_ELAN is not set
CONFIG_HID_ELECOM=m
CONFIG_HID_ELO=m
CONFIG_HID_EZKEY=m
CONFIG_HID_GEMBIRD=m
# CONFIG_HID_GFRM is not set
CONFIG_HID_HOLTEK=m
# CONFIG_HOLTEK_FF is not set
# CONFIG_HID_GOOGLE_HAMMER is not set
# CONFIG_HID_GT683R is not set
CONFIG_HID_KEYTOUCH=m
CONFIG_HID_KYE=m
CONFIG_HID_UCLOGIC=m
CONFIG_HID_WALTOP=m
CONFIG_HID_GYRATION=m
# CONFIG_HID_ICADE is not set
# CONFIG_HID_ITE is not set
# CONFIG_HID_JABRA is not set
CONFIG_HID_TWINHAN=m
CONFIG_HID_KENSINGTON=m
CONFIG_HID_LCPOWER=m
CONFIG_HID_LED=m
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=m
CONFIG_HID_LOGITECH_DJ=m
CONFIG_HID_LOGITECH_HIDPP=m
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_LOGIG940_FF=y
CONFIG_LOGIWHEELS_FF=y
CONFIG_HID_MAGICMOUSE=m
# CONFIG_HID_MAYFLASH is not set
# CONFIG_HID_REDRAGON is not set
CONFIG_HID_MICROSOFT=m
CONFIG_HID_MONTEREY=m
CONFIG_HID_MULTITOUCH=m
# CONFIG_HID_NTI is not set
CONFIG_HID_NTRIG=m
CONFIG_HID_ORTEK=m
CONFIG_HID_PANTHERLORD=m
# CONFIG_PANTHERLORD_FF is not set
# CONFIG_HID_PENMOUNT is not set
CONFIG_HID_PETALYNX=m
CONFIG_HID_PICOLCD=m
# CONFIG_HID_PICOLCD_FB is not set
# CONFIG_HID_PICOLCD_BACKLIGHT is not set
# CONFIG_HID_PICOLCD_LCD is not set
# CONFIG_HID_PICOLCD_LEDS is not set
# CONFIG_HID_PICOLCD_CIR is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
CONFIG_HID_ROCCAT=m
# CONFIG_HID_SAITEK is not set
CONFIG_HID_SAMSUNG=m
CONFIG_HID_SONY=m
CONFIG_SONY_FF=y
CONFIG_HID_SPEEDLINK=m
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
CONFIG_HID_SUNPLUS=m
# CONFIG_HID_RMI is not set
CONFIG_HID_GREENASIA=m
# CONFIG_GREENASIA_FF is not set
CONFIG_HID_SMARTJOYPLUS=m
# CONFIG_SMARTJOYPLUS_FF is not set
# CONFIG_HID_TIVO is not set
CONFIG_HID_TOPSEED=m
CONFIG_HID_THINGM=m
CONFIG_HID_THRUSTMASTER=m
# CONFIG_THRUSTMASTER_FF is not set
# CONFIG_HID_UDRAW_PS3 is not set
CONFIG_HID_WACOM=m
CONFIG_HID_WIIMOTE=m
CONFIG_HID_XINMO=m
CONFIG_HID_ZEROPLUS=m
# CONFIG_ZEROPLUS_FF is not set
CONFIG_HID_ZYDACRON=m
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# USB HID support
CONFIG_USB_HID=y
CONFIG_HID_PID=y
CONFIG_USB_HIDDEV=y
# I2C HID support
# CONFIG_I2C_HID is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_PCI=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
CONFIG_USB_MON=m
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_XHCI_HCD=y
# CONFIG_USB_XHCI_DBGCAP is not set
CONFIG_USB_XHCI_PCI=y
CONFIG_USB_XHCI_PLATFORM=y
# CONFIG_USB_EHCI_HCD is not set
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
# CONFIG_USB_OHCI_HCD is not set
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_U132_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
CONFIG_USB_DWCOTG=y
# CONFIG_USB_HCD_BCMA is not set
# CONFIG_USB_HCD_SSB is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_WDM=m
CONFIG_USB_TMC=m
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_REALTEK=m
CONFIG_REALTEK_AUTOPM=y
CONFIG_USB_STORAGE_DATAFAB=m
CONFIG_USB_STORAGE_FREECOM=m
CONFIG_USB_STORAGE_ISD200=m
CONFIG_USB_STORAGE_USBAT=m
CONFIG_USB_STORAGE_SDDR09=m
CONFIG_USB_STORAGE_SDDR55=m
CONFIG_USB_STORAGE_JUMPSHOT=m
CONFIG_USB_STORAGE_ALAUDA=m
CONFIG_USB_STORAGE_ONETOUCH=m
CONFIG_USB_STORAGE_KARMA=m
CONFIG_USB_STORAGE_CYPRESS_ATACB=m
CONFIG_USB_STORAGE_ENE_UB6250=m
CONFIG_USB_UAS=y
# USB Imaging devices
CONFIG_USB_MDC800=m
CONFIG_USB_MICROTEK=m
CONFIG_USBIP_CORE=m
CONFIG_USBIP_VHCI_HCD=m
CONFIG_USBIP_VHCI_HC_PORTS=8
CONFIG_USBIP_VHCI_NR_HCS=1
CONFIG_USBIP_HOST=m
CONFIG_USBIP_VUDC=m
# CONFIG_USBIP_DEBUG is not set
# CONFIG_USB_MUSB_HDRC is not set
# CONFIG_USB_DWC3 is not set
CONFIG_USB_DWC2=m
# CONFIG_USB_DWC2_HOST is not set
# Gadget/Dual-role mode requires USB Gadget support to be enabled
# CONFIG_USB_DWC2_PERIPHERAL is not set
CONFIG_USB_DWC2_DUAL_ROLE=y
# CONFIG_USB_DWC2_PCI is not set
# CONFIG_USB_DWC2_DEBUG is not set
# CONFIG_USB_DWC2_TRACK_MISSED_SOFS is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_SIMPLE is not set
CONFIG_USB_SERIAL_AIRCABLE=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_F81232=m
# CONFIG_USB_SERIAL_F8153X is not set
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_IUU=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_METRO=m
CONFIG_USB_SERIAL_MOS7720=m
CONFIG_USB_SERIAL_MOS7840=m
# CONFIG_USB_SERIAL_MXUPORT is not set
CONFIG_USB_SERIAL_NAVMAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OTI6858=m
CONFIG_USB_SERIAL_QCAUX=m
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SPCP8X5=m
CONFIG_USB_SERIAL_SAFE=m
# CONFIG_USB_SERIAL_SAFE_PADDED is not set
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_SYMBOL=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_WWAN=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_SERIAL_OPTICON=m
CONFIG_USB_SERIAL_XSENS_MT=m
CONFIG_USB_SERIAL_WISHBONE=m
CONFIG_USB_SERIAL_SSU100=m
CONFIG_USB_SERIAL_QT2=m
# CONFIG_USB_SERIAL_UPD78F0730 is not set
CONFIG_USB_SERIAL_DEBUG=m
# USB Miscellaneous drivers
CONFIG_USB_EMI62=m
CONFIG_USB_EMI26=m
CONFIG_USB_ADUTUX=m
CONFIG_USB_SEVSEG=m
CONFIG_USB_RIO500=m
CONFIG_USB_LEGOTOWER=m
CONFIG_USB_LCD=m
CONFIG_USB_CYPRESS_CY7C63=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_IDMOUSE=m
CONFIG_USB_FTDI_ELAN=m
CONFIG_USB_APPLEDISPLAY=m
CONFIG_USB_LD=m
CONFIG_USB_TRANCEVIBRATOR=m
CONFIG_USB_IOWARRIOR=m
CONFIG_USB_TEST=m
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
CONFIG_USB_ISIGHTFW=m
CONFIG_USB_YUREX=m
CONFIG_USB_EZUSB_FX2=m
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# CONFIG_USB_CHAOSKEY is not set
CONFIG_USB_ATM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_CXACRU=m
CONFIG_USB_UEAGLEATM=m
CONFIG_USB_XUSBATM=m
# USB Physical Layer drivers
# CONFIG_NOP_USB_XCEIV is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
CONFIG_USB_GADGET=m
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_AMD5536UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_NET2280 is not set
# CONFIG_USB_GOKU is not set
# CONFIG_USB_EG20T is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_DUMMY_HCD is not set
CONFIG_USB_LIBCOMPOSITE=m
CONFIG_USB_F_ACM=m
CONFIG_USB_F_SS_LB=m
CONFIG_USB_U_SERIAL=m
CONFIG_USB_U_ETHER=m
CONFIG_USB_U_AUDIO=m
CONFIG_USB_F_SERIAL=m
CONFIG_USB_F_OBEX=m
CONFIG_USB_F_NCM=m
CONFIG_USB_F_ECM=m
CONFIG_USB_F_EEM=m
CONFIG_USB_F_SUBSET=m
CONFIG_USB_F_RNDIS=m
CONFIG_USB_F_MASS_STORAGE=m
CONFIG_USB_F_FS=m
CONFIG_USB_F_UAC1=m
CONFIG_USB_F_UAC2=m
CONFIG_USB_F_UVC=m
CONFIG_USB_F_MIDI=m
CONFIG_USB_F_HID=m
CONFIG_USB_F_PRINTER=m
CONFIG_USB_CONFIGFS=m
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_OBEX=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_ECM_SUBSET=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_EEM=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_LB_SS=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_UAC1=y
# CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set
CONFIG_USB_CONFIGFS_F_UAC2=y
CONFIG_USB_CONFIGFS_F_MIDI=y
CONFIG_USB_CONFIGFS_F_HID=y
CONFIG_USB_CONFIGFS_F_UVC=y
CONFIG_USB_CONFIGFS_F_PRINTER=y
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO=m
# CONFIG_GADGET_UAC1 is not set
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
# CONFIG_USB_ETH_EEM is not set
# CONFIG_USB_G_NCM is not set
CONFIG_USB_GADGETFS=m
# CONFIG_USB_FUNCTIONFS is not set
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_USB_MIDI_GADGET=m
CONFIG_USB_G_PRINTER=m
CONFIG_USB_CDC_COMPOSITE=m
CONFIG_USB_G_ACM_MS=m
CONFIG_USB_G_MULTI=m
CONFIG_USB_G_MULTI_RNDIS=y
# CONFIG_USB_G_MULTI_CDC is not set
CONFIG_USB_G_HID=m
# CONFIG_USB_G_DBGP is not set
CONFIG_USB_G_WEBCAM=m
# CONFIG_TYPEC is not set
# CONFIG_USB_ROLE_SWITCH is not set
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_UWB is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
# CONFIG_PWRSEQ_SD8787 is not set
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=32
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
CONFIG_MMC_BCM2835_MMC=y
CONFIG_MMC_BCM2835_DMA=y
CONFIG_MMC_BCM2835_PIO_DMA_BARRIER=2
CONFIG_MMC_BCM2835_SDHOST=y
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_ARMMMCI is not set
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_IO_ACCESSORS=y
# CONFIG_MMC_SDHCI_PCI is not set
CONFIG_MMC_SDHCI_PLTFM=y
# CONFIG_MMC_SDHCI_OF_ARASAN is not set
# CONFIG_MMC_SDHCI_OF_AT91 is not set
# CONFIG_MMC_SDHCI_OF_DWCMSHC is not set
# CONFIG_MMC_SDHCI_CADENCE is not set
# CONFIG_MMC_SDHCI_F_SDH30 is not set
CONFIG_MMC_SDHCI_IPROC=y
# CONFIG_MMC_TIFM_SD is not set
CONFIG_MMC_SPI=m
# CONFIG_MMC_CB710 is not set
# CONFIG_MMC_VIA_SDMMC is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
# CONFIG_MMC_CQHCI is not set
# CONFIG_MMC_TOSHIBA_PCI is not set
# CONFIG_MMC_BCM2835 is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MMC_SDHCI_XENON is not set
# CONFIG_MMC_SDHCI_OMAP is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_CR0014114 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_LM3692X is not set
CONFIG_LEDS_PCA9532=m
# CONFIG_LEDS_PCA9532_GPIO is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
CONFIG_LEDS_PCA955X=m
# CONFIG_LEDS_PCA955X_GPIO is not set
CONFIG_LEDS_PCA963X=m
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
CONFIG_LEDS_IS31FL32XX=m
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_MLXREG is not set
# CONFIG_LEDS_USER is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_ONESHOT=y
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_BACKLIGHT=y
CONFIG_LEDS_TRIGGER_CPU=y
# CONFIG_LEDS_TRIGGER_ACTIVITY is not set
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
CONFIG_LEDS_TRIGGER_TRANSIENT=m
CONFIG_LEDS_TRIGGER_CAMERA=m
CONFIG_LEDS_TRIGGER_INPUT=y
CONFIG_LEDS_TRIGGER_PANIC=y
CONFIG_LEDS_TRIGGER_NETDEV=m
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
# CONFIG_EDAC is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
# CONFIG_RTC_HCTOSYS is not set
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
CONFIG_RTC_DRV_ABX80X=m
CONFIG_RTC_DRV_DS1307=m
# CONFIG_RTC_DRV_DS1307_CENTURY is not set
CONFIG_RTC_DRV_DS1374=m
# CONFIG_RTC_DRV_DS1374_WDT is not set
CONFIG_RTC_DRV_DS1672=m
# CONFIG_RTC_DRV_HYM8563 is not set
CONFIG_RTC_DRV_MAX6900=m
CONFIG_RTC_DRV_RS5C372=m
CONFIG_RTC_DRV_ISL1208=m
CONFIG_RTC_DRV_ISL12022=m
# CONFIG_RTC_DRV_ISL12026 is not set
CONFIG_RTC_DRV_X1205=m
CONFIG_RTC_DRV_PCF8523=m
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF85363 is not set
CONFIG_RTC_DRV_PCF8563=m
CONFIG_RTC_DRV_PCF8583=m
CONFIG_RTC_DRV_M41T80=m
# CONFIG_RTC_DRV_M41T80_WDT is not set
CONFIG_RTC_DRV_BQ32K=m
CONFIG_RTC_DRV_S35390A=m
CONFIG_RTC_DRV_FM3130=m
# CONFIG_RTC_DRV_RX8010 is not set
CONFIG_RTC_DRV_RX8581=m
CONFIG_RTC_DRV_RX8025=m
CONFIG_RTC_DRV_EM3027=m
CONFIG_RTC_DRV_RV3028=m
# CONFIG_RTC_DRV_RV8803 is not set
# SPI RTC drivers
CONFIG_RTC_DRV_M41T93=m
CONFIG_RTC_DRV_M41T94=m
CONFIG_RTC_DRV_DS1302=m
CONFIG_RTC_DRV_DS1305=m
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
CONFIG_RTC_DRV_DS1390=m
# CONFIG_RTC_DRV_MAX6916 is not set
CONFIG_RTC_DRV_R9701=m
CONFIG_RTC_DRV_RX4581=m
# CONFIG_RTC_DRV_RX6110 is not set
CONFIG_RTC_DRV_RS5C348=m
CONFIG_RTC_DRV_MAX6902=m
CONFIG_RTC_DRV_PCF2123=m
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
CONFIG_RTC_DRV_DS3232=m
CONFIG_RTC_DRV_DS3232_HWMON=y
CONFIG_RTC_DRV_PCF2127=m
CONFIG_RTC_DRV_RV3029C2=m
CONFIG_RTC_DRV_RV3029_HWMON=y
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
# CONFIG_RTC_DRV_PL030 is not set
# CONFIG_RTC_DRV_PL031 is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_SNVS is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
# CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_AMBA_PL08X is not set
CONFIG_DMA_BCM2835=y
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_PL330_DMA is not set
CONFIG_DMA_BCM2708=y
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# CONFIG_DW_DMAC_PCI is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
CONFIG_AUXDISPLAY=y
CONFIG_HD44780=m
# CONFIG_IMG_ASCII_LCD is not set
# CONFIG_HT16K33 is not set
CONFIG_CHARLCD=m
CONFIG_UIO=m
# CONFIG_UIO_CIF is not set
CONFIG_UIO_PDRV_GENIRQ=m
# CONFIG_UIO_DMEM_GENIRQ is not set
# CONFIG_UIO_AEC is not set
# CONFIG_UIO_SERCOS3 is not set
# CONFIG_UIO_PCI_GENERIC is not set
# CONFIG_UIO_NETX is not set
# CONFIG_UIO_PRUSS is not set
# CONFIG_UIO_MF624 is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO_MENU=y
# CONFIG_VIRTIO_PCI is not set
# CONFIG_VIRTIO_MMIO is not set
# Microsoft Hyper-V guest support
CONFIG_STAGING=y
CONFIG_PRISM2_USB=m
# CONFIG_COMEDI is not set
# CONFIG_RTL8192U is not set
# CONFIG_RTLLIB is not set
# CONFIG_RTL8723BS is not set
CONFIG_R8712U=m
CONFIG_R8188EU=m
CONFIG_88EU_AP_MODE=y
# CONFIG_R8822BE is not set
# CONFIG_RTS5208 is not set
# CONFIG_VT6655 is not set
CONFIG_VT6656=m
# IIO staging drivers
# Accelerometers
# CONFIG_ADIS16203 is not set
# CONFIG_ADIS16240 is not set
# Analog to digital converters
# CONFIG_AD7606 is not set
# CONFIG_AD7780 is not set
# CONFIG_AD7816 is not set
# CONFIG_AD7192 is not set
# CONFIG_AD7280 is not set
# Analog digital bi-direction converters
# CONFIG_ADT7316 is not set
# Capacitance to digital converters
# CONFIG_AD7150 is not set
# CONFIG_AD7152 is not set
# CONFIG_AD7746 is not set
# Direct Digital Synthesis
# CONFIG_AD9832 is not set
# CONFIG_AD9834 is not set
# Network Analyzer, Impedance Converters
# CONFIG_AD5933 is not set
# Active energy metering IC
# CONFIG_ADE7854 is not set
# Resolver to digital converters
# CONFIG_AD2S90 is not set
# CONFIG_AD2S1210 is not set
# CONFIG_FB_SM750 is not set
# CONFIG_FB_XGI is not set
# Speakup console speech
CONFIG_SPEAKUP=m
# CONFIG_SPEAKUP_SYNTH_ACNTSA is not set
# CONFIG_SPEAKUP_SYNTH_APOLLO is not set
# CONFIG_SPEAKUP_SYNTH_AUDPTR is not set
# CONFIG_SPEAKUP_SYNTH_BNS is not set
# CONFIG_SPEAKUP_SYNTH_DECTLK is not set
# CONFIG_SPEAKUP_SYNTH_DECEXT is not set
# CONFIG_SPEAKUP_SYNTH_LTLK is not set
CONFIG_SPEAKUP_SYNTH_SOFT=m
# CONFIG_SPEAKUP_SYNTH_SPKOUT is not set
# CONFIG_SPEAKUP_SYNTH_TXPRT is not set
# CONFIG_SPEAKUP_SYNTH_DUMMY is not set
CONFIG_STAGING_MEDIA=y
# CONFIG_I2C_BCM2048 is not set
# Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_MTD_SPINAND_MT29F is not set
# CONFIG_DGNC is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_UNISYSSPAR is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
CONFIG_FB_TFT=m
CONFIG_FB_TFT_AGM1264K_FL=m
CONFIG_FB_TFT_BD663474=m
CONFIG_FB_TFT_HX8340BN=m
CONFIG_FB_TFT_HX8347D=m
CONFIG_FB_TFT_HX8353D=m
CONFIG_FB_TFT_HX8357D=m
CONFIG_FB_TFT_ILI9163=m
CONFIG_FB_TFT_ILI9320=m
CONFIG_FB_TFT_ILI9325=m
CONFIG_FB_TFT_ILI9340=m
CONFIG_FB_TFT_ILI9341=m
CONFIG_FB_TFT_ILI9481=m
CONFIG_FB_TFT_ILI9486=m
CONFIG_FB_TFT_PCD8544=m
CONFIG_FB_TFT_RA8875=m
CONFIG_FB_TFT_S6D02A1=m
CONFIG_FB_TFT_S6D1121=m
CONFIG_FB_TFT_SH1106=m
CONFIG_FB_TFT_SSD1289=m
# CONFIG_FB_TFT_SSD1305 is not set
CONFIG_FB_TFT_SSD1306=m
CONFIG_FB_TFT_SSD1331=m
CONFIG_FB_TFT_SSD1351=m
CONFIG_FB_TFT_ST7735R=m
CONFIG_FB_TFT_ST7789V=m
CONFIG_FB_TFT_TINYLCD=m
CONFIG_FB_TFT_TLS8204=m
# CONFIG_FB_TFT_UC1611 is not set
CONFIG_FB_TFT_UC1701=m
CONFIG_FB_TFT_UPD161704=m
CONFIG_FB_TFT_WATTEROTT=m
CONFIG_FB_FLEX=m
CONFIG_FB_TFT_FBTFT_DEVICE=m
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
# CONFIG_MOST is not set
# CONFIG_KS7010 is not set
# CONFIG_GREYBUS is not set
CONFIG_BCM_VIDEOCORE=y
CONFIG_BCM2835_VCHIQ=y
CONFIG_SND_BCM2835=m
CONFIG_VIDEO_BCM2835=m
CONFIG_BCM2835_VCHIQ_MMAL=m
CONFIG_BCM_VC_SM_CMA=m
CONFIG_VIDEO_CODEC_BCM2835=m
# CONFIG_PI433 is not set
# CONFIG_MTK_MMC is not set
# Gasket devices
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_EROFS_FS is not set
# CONFIG_GOLDFISH is not set
# CONFIG_CHROME_PLATFORMS is not set
# CONFIG_MELLANOX_PLATFORM is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_BCM2835_TIMER=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
CONFIG_ARM_TIMER_SP804=y
CONFIG_MAILBOX=y
# CONFIG_ARM_MHU is not set
# CONFIG_PLATFORM_MHU is not set
# CONFIG_PL320_MBOX is not set
# CONFIG_ALTERA_MBOX is not set
CONFIG_BCM2835_MBOX=y
# CONFIG_MAILBOX_TEST is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# Rpmsg drivers
# CONFIG_RPMSG_QCOM_GLINK_RPM is not set
# CONFIG_RPMSG_VIRTIO is not set
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# Broadcom SoC drivers
CONFIG_BCM2835_POWER=y
CONFIG_RASPBERRYPI_POWER=y
# CONFIG_SOC_BRCMSTB is not set
# NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# Qualcomm SoC drivers
# CONFIG_SOC_TI is not set
# Xilinx SoC drivers
# CONFIG_XILINX_VCU is not set
# CONFIG_PM_DEVFREQ is not set
CONFIG_EXTCON=m
# Extcon Device Drivers
# CONFIG_EXTCON_ADC_JACK is not set
CONFIG_EXTCON_ARIZONA=m
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_MEMORY is not set
CONFIG_IIO=m
CONFIG_IIO_BUFFER=y
CONFIG_IIO_BUFFER_CB=m
# CONFIG_IIO_BUFFER_HW_CONSUMER is not set
CONFIG_IIO_KFIFO_BUF=m
CONFIG_IIO_TRIGGERED_BUFFER=m
# CONFIG_IIO_CONFIGFS is not set
CONFIG_IIO_TRIGGER=y
CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
# CONFIG_IIO_SW_DEVICE is not set
# CONFIG_IIO_SW_TRIGGER is not set
# Accelerometers
# CONFIG_ADIS16201 is not set
# CONFIG_ADIS16209 is not set
# CONFIG_BMA180 is not set
# CONFIG_BMA220 is not set
# CONFIG_BMC150_ACCEL is not set
# CONFIG_DA280 is not set
# CONFIG_DA311 is not set
# CONFIG_DMARD06 is not set
# CONFIG_DMARD09 is not set
# CONFIG_DMARD10 is not set
# CONFIG_IIO_CROS_EC_ACCEL_LEGACY is not set
# CONFIG_IIO_ST_ACCEL_3AXIS is not set
# CONFIG_KXSD9 is not set
# CONFIG_KXCJK1013 is not set
# CONFIG_MC3230 is not set
# CONFIG_MMA7455_I2C is not set
# CONFIG_MMA7455_SPI is not set
# CONFIG_MMA7660 is not set
# CONFIG_MMA8452 is not set
# CONFIG_MMA9551 is not set
# CONFIG_MMA9553 is not set
# CONFIG_MXC4005 is not set
# CONFIG_MXC6255 is not set
# CONFIG_SCA3000 is not set
# CONFIG_STK8312 is not set
# CONFIG_STK8BA50 is not set
# CONFIG_AD7266 is not set
# CONFIG_AD7291 is not set
# CONFIG_AD7298 is not set
# CONFIG_AD7476 is not set
# CONFIG_AD7766 is not set
# CONFIG_AD7791 is not set
# CONFIG_AD7793 is not set
# CONFIG_AD7887 is not set
# CONFIG_AD7923 is not set
# CONFIG_AD799X is not set
# CONFIG_CC10001_ADC is not set
# CONFIG_ENVELOPE_DETECTOR is not set
# CONFIG_HI8435 is not set
# CONFIG_HX711 is not set
# CONFIG_INA2XX_ADC is not set
# CONFIG_LTC2471 is not set
# CONFIG_LTC2485 is not set
# CONFIG_LTC2497 is not set
# CONFIG_MAX1027 is not set
# CONFIG_MAX11100 is not set
# CONFIG_MAX1118 is not set
# CONFIG_MAX1363 is not set
# CONFIG_MAX9611 is not set
CONFIG_MCP320X=m
CONFIG_MCP3422=m
# CONFIG_NAU7802 is not set
# CONFIG_SD_ADC_MODULATOR is not set
# CONFIG_TI_ADC081C is not set
# CONFIG_TI_ADC0832 is not set
# CONFIG_TI_ADC084S021 is not set
# CONFIG_TI_ADC12138 is not set
# CONFIG_TI_ADC108S102 is not set
# CONFIG_TI_ADC128S052 is not set
# CONFIG_TI_ADC161S626 is not set
CONFIG_TI_ADS1015=m
# CONFIG_TI_ADS7950 is not set
# CONFIG_TI_ADS8688 is not set
# CONFIG_TI_TLC4541 is not set
# CONFIG_VF610_ADC is not set
# Analog Front Ends
# CONFIG_IIO_RESCALE is not set
# Amplifiers
# CONFIG_AD8366 is not set
# Chemical Sensors
# CONFIG_ATLAS_PH_SENSOR is not set
# CONFIG_BME680 is not set
# CONFIG_CCS811 is not set
# CONFIG_IAQCORE is not set
# CONFIG_VZ89X is not set
# Hid Sensor IIO Common
CONFIG_IIO_MS_SENSORS_I2C=m
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# Counters
# Digital to analog converters
# CONFIG_AD5064 is not set
# CONFIG_AD5360 is not set
# CONFIG_AD5380 is not set
# CONFIG_AD5421 is not set
# CONFIG_AD5446 is not set
# CONFIG_AD5449 is not set
# CONFIG_AD5592R is not set
# CONFIG_AD5593R is not set
# CONFIG_AD5504 is not set
# CONFIG_AD5624R_SPI is not set
# CONFIG_LTC2632 is not set
# CONFIG_AD5686_SPI is not set
# CONFIG_AD5696_I2C is not set
# CONFIG_AD5755 is not set
# CONFIG_AD5758 is not set
# CONFIG_AD5761 is not set
# CONFIG_AD5764 is not set
# CONFIG_AD5791 is not set
# CONFIG_AD7303 is not set
# CONFIG_AD8801 is not set
# CONFIG_DPOT_DAC is not set
# CONFIG_DS4424 is not set
# CONFIG_M62332 is not set
# CONFIG_MAX517 is not set
# CONFIG_MAX5821 is not set
# CONFIG_MCP4725 is not set
# CONFIG_MCP4922 is not set
# CONFIG_TI_DAC082S085 is not set
# CONFIG_TI_DAC5571 is not set
# CONFIG_VF610_DAC is not set
# IIO dummy driver
# Frequency Synthesizers DDS/PLL
# Clock Generator/Distribution
# CONFIG_AD9523 is not set
# Phase-Locked Loop (PLL) frequency synthesizers
# CONFIG_ADF4350 is not set
# Digital gyroscope sensors
# CONFIG_ADIS16080 is not set
# CONFIG_ADIS16130 is not set
# CONFIG_ADIS16136 is not set
# CONFIG_ADIS16260 is not set
# CONFIG_ADXRS450 is not set
# CONFIG_BMG160 is not set
# CONFIG_MPU3050_I2C is not set
# CONFIG_IIO_ST_GYRO_3AXIS is not set
# CONFIG_ITG3200 is not set
# Health Sensors
# Heart Rate Monitors
# CONFIG_AFE4403 is not set
# CONFIG_AFE4404 is not set
# CONFIG_MAX30100 is not set
# CONFIG_MAX30102 is not set
# Humidity sensors
# CONFIG_AM2315 is not set
CONFIG_DHT11=m
CONFIG_HDC100X=m
# CONFIG_HTS221 is not set
CONFIG_HTU21=m
# CONFIG_SI7005 is not set
# CONFIG_SI7020 is not set
# Inertial measurement units
# CONFIG_ADIS16400 is not set
# CONFIG_ADIS16480 is not set
# CONFIG_BMI160_I2C is not set
# CONFIG_BMI160_SPI is not set
# CONFIG_KMX61 is not set
CONFIG_INV_MPU6050_IIO=m
CONFIG_INV_MPU6050_I2C=m
# CONFIG_INV_MPU6050_SPI is not set
# CONFIG_IIO_ST_LSM6DSX is not set
# Light sensors
# CONFIG_ADJD_S311 is not set
# CONFIG_AL3320A is not set
# CONFIG_APDS9300 is not set
# CONFIG_APDS9960 is not set
# CONFIG_BH1750 is not set
# CONFIG_BH1780 is not set
# CONFIG_CM32181 is not set
# CONFIG_CM3232 is not set
# CONFIG_CM3323 is not set
# CONFIG_CM3605 is not set
# CONFIG_CM36651 is not set
# CONFIG_GP2AP020A00F is not set
# CONFIG_SENSORS_ISL29018 is not set
# CONFIG_SENSORS_ISL29028 is not set
# CONFIG_ISL29125 is not set
# CONFIG_JSA1212 is not set
# CONFIG_RPR0521 is not set
# CONFIG_LTR501 is not set
# CONFIG_LV0104CS is not set
# CONFIG_MAX44000 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PA12203001 is not set
# CONFIG_SI1133 is not set
# CONFIG_SI1145 is not set
# CONFIG_STK3310 is not set
# CONFIG_ST_UVIS25 is not set
# CONFIG_TCS3414 is not set
# CONFIG_TCS3472 is not set
# CONFIG_SENSORS_TSL2563 is not set
# CONFIG_TSL2583 is not set
# CONFIG_TSL2772 is not set
CONFIG_TSL4531=m
# CONFIG_US5182D is not set
# CONFIG_VCNL4000 is not set
CONFIG_VEML6070=m
# CONFIG_VL6180 is not set
# CONFIG_ZOPT2201 is not set
# Magnetometer sensors
# CONFIG_AK8974 is not set
# CONFIG_AK8975 is not set
# CONFIG_AK09911 is not set
# CONFIG_BMC150_MAGN_I2C is not set
# CONFIG_BMC150_MAGN_SPI is not set
# CONFIG_MAG3110 is not set
# CONFIG_MMC35240 is not set
# CONFIG_IIO_ST_MAGN_3AXIS is not set
# CONFIG_SENSORS_HMC5843_I2C is not set
# CONFIG_SENSORS_HMC5843_SPI is not set
# Multiplexers
# CONFIG_IIO_MUX is not set
# Inclinometer sensors
# Triggers - standalone
# CONFIG_IIO_INTERRUPT_TRIGGER is not set
# CONFIG_IIO_SYSFS_TRIGGER is not set
# Digital potentiometers
# CONFIG_AD5272 is not set
# CONFIG_DS1803 is not set
# CONFIG_MAX5481 is not set
# CONFIG_MAX5487 is not set
# CONFIG_MCP4018 is not set
# CONFIG_MCP4131 is not set
# CONFIG_MCP4531 is not set
# CONFIG_TPL0102 is not set
# Digital potentiostats
# CONFIG_LMP91000 is not set
# Pressure sensors
# CONFIG_ABP060MG is not set
CONFIG_BMP280=m
CONFIG_BMP280_I2C=m
CONFIG_BMP280_SPI=m
# CONFIG_HP03 is not set
# CONFIG_MPL115_I2C is not set
# CONFIG_MPL115_SPI is not set
# CONFIG_MPL3115 is not set
# CONFIG_MS5611 is not set
# CONFIG_MS5637 is not set
# CONFIG_IIO_ST_PRESS is not set
# CONFIG_T5403 is not set
# CONFIG_HP206C is not set
# CONFIG_ZPA2326 is not set
# Lightning sensors
# CONFIG_AS3935 is not set
# Proximity and distance sensors
# CONFIG_ISL29501 is not set
# CONFIG_LIDAR_LITE_V2 is not set
# CONFIG_RFD77402 is not set
# CONFIG_SRF04 is not set
# CONFIG_SX9500 is not set
# CONFIG_SRF08 is not set
# CONFIG_AD2S1200 is not set
# Temperature sensors
# CONFIG_MAXIM_THERMOCOUPLE is not set
# CONFIG_MLX90614 is not set
# CONFIG_MLX90632 is not set
# CONFIG_TMP006 is not set
# CONFIG_TMP007 is not set
# CONFIG_TSYS01 is not set
# CONFIG_TSYS02D is not set
# CONFIG_NTB is not set
# CONFIG_VME_BUS is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
CONFIG_PWM_BCM2835=m
# CONFIG_PWM_FSL_FTM is not set
CONFIG_PWM_PCA9685=m
# CONFIG_PWM_STMPE is not set
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
# CONFIG_IPACK_BUS is not set
CONFIG_RESET_CONTROLLER=y
# CONFIG_RESET_TI_SYSCON is not set
# CONFIG_FMC is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_CPCAP_USB is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_SAMSUNG_USB2 is not set
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
# CONFIG_ARM_CCI_PMU is not set
# CONFIG_ARM_CCN is not set
CONFIG_ARM_PMU=y
CONFIG_RPI_AXIPERF=m
CONFIG_RAS=y
# Android
# CONFIG_ANDROID is not set
# CONFIG_LIBNVDIMM is not set
# CONFIG_DAX is not set
CONFIG_NVMEM=y
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
# CONFIG_TEE is not set
CONFIG_MULTIPLEXER=m
# Multiplexer drivers
# CONFIG_MUX_ADG792A is not set
# CONFIG_MUX_ADGS1408 is not set
# CONFIG_MUX_GPIO is not set
# CONFIG_MUX_MMIO is not set
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
CONFIG_FS_IOMAP=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
# CONFIG_EXT4_ENCRYPTION is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
CONFIG_REISERFS_FS_XATTR=y
CONFIG_REISERFS_FS_POSIX_ACL=y
CONFIG_REISERFS_FS_SECURITY=y
CONFIG_JFS_FS=m
CONFIG_JFS_POSIX_ACL=y
CONFIG_JFS_SECURITY=y
# CONFIG_JFS_DEBUG is not set
CONFIG_JFS_STATISTICS=y
CONFIG_XFS_FS=m
CONFIG_XFS_QUOTA=y
CONFIG_XFS_POSIX_ACL=y
CONFIG_XFS_RT=y
# CONFIG_XFS_ONLINE_SCRUB is not set
# CONFIG_XFS_WARN is not set
# CONFIG_XFS_DEBUG is not set
CONFIG_GFS2_FS=m
# CONFIG_GFS2_FS_LOCKING_DLM is not set
CONFIG_OCFS2_FS=m
CONFIG_OCFS2_FS_O2CB=m
CONFIG_OCFS2_FS_USERSPACE_CLUSTER=m
CONFIG_OCFS2_FS_STATS=y
CONFIG_OCFS2_DEBUG_MASKLOG=y
# CONFIG_OCFS2_DEBUG_FS is not set
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
# CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set
# CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set
# CONFIG_BTRFS_DEBUG is not set
# CONFIG_BTRFS_ASSERT is not set
# CONFIG_BTRFS_FS_REF_VERIFY is not set
CONFIG_NILFS2_FS=m
CONFIG_F2FS_FS=y
CONFIG_F2FS_STAT_FS=y
CONFIG_F2FS_FS_XATTR=y
CONFIG_F2FS_FS_POSIX_ACL=y
# CONFIG_F2FS_FS_SECURITY is not set
# CONFIG_F2FS_CHECK_FS is not set
# CONFIG_F2FS_FS_ENCRYPTION is not set
# CONFIG_F2FS_IO_TRACE is not set
# CONFIG_F2FS_FAULT_INJECTION is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
CONFIG_QUOTA=y
# CONFIG_QUOTA_NETLINK_INTERFACE is not set
CONFIG_PRINT_QUOTA_WARNING=y
# CONFIG_QUOTA_DEBUG is not set
CONFIG_QUOTA_TREE=m
CONFIG_QFMT_V1=m
CONFIG_QFMT_V2=m
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=y
CONFIG_AUTOFS_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
CONFIG_OVERLAY_FS=m
# CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
# CONFIG_OVERLAY_FS_INDEX is not set
# CONFIG_OVERLAY_FS_XINO_AUTO is not set
# CONFIG_OVERLAY_FS_METACOPY is not set
# Caches
CONFIG_FSCACHE=y
CONFIG_FSCACHE_STATS=y
CONFIG_FSCACHE_HISTOGRAM=y
# CONFIG_FSCACHE_DEBUG is not set
# CONFIG_FSCACHE_OBJECT_LIST is not set
CONFIG_CACHEFILES=y
# CONFIG_CACHEFILES_DEBUG is not set
# CONFIG_CACHEFILES_HISTOGRAM is not set
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=m
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="ascii"
# CONFIG_FAT_DEFAULT_UTF8 is not set
CONFIG_NTFS_FS=m
# CONFIG_NTFS_DEBUG is not set
CONFIG_NTFS_RW=y
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
# CONFIG_HUGETLBFS is not set
CONFIG_MEMFD_CREATE=y
CONFIG_CONFIGFS_FS=y
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
CONFIG_ECRYPT_FS=m
# CONFIG_ECRYPT_FS_MESSAGING is not set
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
CONFIG_JFFS2_SUMMARY=y
# CONFIG_JFFS2_FS_XATTR is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_RTIME=y
CONFIG_UBIFS_FS=m
# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
# CONFIG_UBIFS_ATIME_SUPPORT is not set
CONFIG_UBIFS_FS_XATTR=y
# CONFIG_UBIFS_FS_ENCRYPTION is not set
CONFIG_UBIFS_FS_SECURITY=y
# CONFIG_CRAMFS is not set
CONFIG_SQUASHFS=m
CONFIG_SQUASHFS_FILE_CACHE=y
# CONFIG_SQUASHFS_FILE_DIRECT is not set
CONFIG_SQUASHFS_DECOMP_SINGLE=y
# CONFIG_SQUASHFS_DECOMP_MULTI is not set
# CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_ZLIB=y
# CONFIG_SQUASHFS_LZ4 is not set
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
# CONFIG_SQUASHFS_ZSTD is not set
# CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_NFS_SWAP=y
CONFIG_NFS_V4_1=y
# CONFIG_NFS_V4_2 is not set
CONFIG_PNFS_FILE_LAYOUT=y
CONFIG_PNFS_BLOCK=m
CONFIG_PNFS_FLEXFILE_LAYOUT=m
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
# CONFIG_NFS_V4_1_MIGRATION is not set
CONFIG_ROOT_NFS=y
CONFIG_NFS_FSCACHE=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFSD=m
CONFIG_NFSD_V2_ACL=y
CONFIG_NFSD_V3=y
CONFIG_NFSD_V3_ACL=y
CONFIG_NFSD_V4=y
# CONFIG_NFSD_BLOCKLAYOUT is not set
# CONFIG_NFSD_SCSILAYOUT is not set
# CONFIG_NFSD_FLEXFILELAYOUT is not set
# CONFIG_NFSD_FAULT_INJECTION is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_SUNRPC_BACKCHANNEL=y
CONFIG_SUNRPC_SWAP=y
CONFIG_RPCSEC_GSS_KRB5=m
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
CONFIG_CIFS=m
# CONFIG_CIFS_STATS2 is not set
CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y
CONFIG_CIFS_WEAK_PW_HASH=y
CONFIG_CIFS_UPCALL=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_CIFS_ACL=y
CONFIG_CIFS_DEBUG=y
# CONFIG_CIFS_DEBUG2 is not set
# CONFIG_CIFS_DEBUG_DUMP_KEYS is not set
CONFIG_CIFS_DFS_UPCALL=y
CONFIG_CIFS_FSCACHE=y
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_9P_FS=m
# CONFIG_9P_FSCACHE is not set
CONFIG_9P_FS_POSIX_ACL=y
# CONFIG_9P_FS_SECURITY is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="utf8"
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_CODEPAGE_737=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852=m
CONFIG_NLS_CODEPAGE_855=m
CONFIG_NLS_CODEPAGE_857=m
CONFIG_NLS_CODEPAGE_860=m
CONFIG_NLS_CODEPAGE_861=m
CONFIG_NLS_CODEPAGE_862=m
CONFIG_NLS_CODEPAGE_863=m
CONFIG_NLS_CODEPAGE_864=m
CONFIG_NLS_CODEPAGE_865=m
CONFIG_NLS_CODEPAGE_866=m
CONFIG_NLS_CODEPAGE_869=m
CONFIG_NLS_CODEPAGE_936=m
CONFIG_NLS_CODEPAGE_950=m
CONFIG_NLS_CODEPAGE_932=m
CONFIG_NLS_CODEPAGE_949=m
CONFIG_NLS_CODEPAGE_874=m
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_3=m
CONFIG_NLS_ISO8859_4=m
CONFIG_NLS_ISO8859_5=m
CONFIG_NLS_ISO8859_6=m
CONFIG_NLS_ISO8859_7=m
CONFIG_NLS_ISO8859_9=m
CONFIG_NLS_ISO8859_13=m
CONFIG_NLS_ISO8859_14=m
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R=m
CONFIG_NLS_KOI8_U=m
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
CONFIG_NLS_UTF8=m
CONFIG_DLM=m
# CONFIG_DLM_DEBUG is not set
# Security options
CONFIG_KEYS=y
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_TRUSTED_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
CONFIG_SECURITYFS=y
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_FORTIFY_SOURCE is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_XOR_BLOCKS=m
CONFIG_ASYNC_CORE=m
CONFIG_ASYNC_MEMCPY=m
CONFIG_ASYNC_XOR=m
CONFIG_ASYNC_PQ=m
CONFIG_ASYNC_RAID6_RECOV=m
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=m
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=m
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=m
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_KPP=m
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_RSA=y
# CONFIG_CRYPTO_DH is not set
CONFIG_CRYPTO_ECDH=m
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=m
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_PCRYPT is not set
CONFIG_CRYPTO_WORKQUEUE=y
CONFIG_CRYPTO_CRYPTD=m
# CONFIG_CRYPTO_MCRYPTD is not set
CONFIG_CRYPTO_AUTHENC=m
# CONFIG_CRYPTO_TEST is not set
CONFIG_CRYPTO_SIMD=m
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
# CONFIG_CRYPTO_AEGIS128 is not set
# CONFIG_CRYPTO_AEGIS128L is not set
# CONFIG_CRYPTO_AEGIS256 is not set
# CONFIG_CRYPTO_MORUS640 is not set
# CONFIG_CRYPTO_MORUS1280 is not set
CONFIG_CRYPTO_SEQIV=m
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CFB is not set
CONFIG_CRYPTO_CTR=m
CONFIG_CRYPTO_CTS=m
CONFIG_CRYPTO_ECB=m
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
CONFIG_CRYPTO_XTS=m
# CONFIG_CRYPTO_KEYWRAP is not set
# Hash modes
CONFIG_CRYPTO_CMAC=m
CONFIG_CRYPTO_HMAC=m
CONFIG_CRYPTO_XCBC=m
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
CONFIG_CRYPTO_CRC32=y
# CONFIG_CRYPTO_CRCT10DIF is not set
CONFIG_CRYPTO_GHASH=m
# CONFIG_CRYPTO_POLY1305 is not set
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=m
CONFIG_CRYPTO_MICHAEL_MIC=m
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=m
CONFIG_CRYPTO_SHA256=m
CONFIG_CRYPTO_SHA512=m
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_WP512=m
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=m
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
CONFIG_CRYPTO_CAST_COMMON=m
CONFIG_CRYPTO_CAST5=m
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_SM4 is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_LZO=m
# CONFIG_CRYPTO_842 is not set
CONFIG_CRYPTO_LZ4=m
# CONFIG_CRYPTO_LZ4HC is not set
# CONFIG_CRYPTO_ZSTD is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_DRBG_MENU=m
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=m
CONFIG_CRYPTO_JITTERENTROPY=m
CONFIG_CRYPTO_USER_API=m
# CONFIG_CRYPTO_USER_API_HASH is not set
CONFIG_CRYPTO_USER_API_SKCIPHER=m
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HASH_INFO=y
# CONFIG_CRYPTO_HW is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
# CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
CONFIG_BINARY_PRINTF=y
# Library routines
CONFIG_RAID6_PQ=m
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_RATIONAL=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_CRC_CCITT=m
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC64 is not set
# CONFIG_CRC4 is not set
CONFIG_CRC7=m
CONFIG_LIBCRC32C=y
CONFIG_CRC8=m
CONFIG_XXHASH=m
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=m
CONFIG_LZO_COMPRESS=m
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMPRESS=m
CONFIG_ZSTD_DECOMPRESS=m
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_BTREE=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SGL_ALLOC=y
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
CONFIG_LRU_CACHE=m
CONFIG_CLZ_TAB=y
# CONFIG_CORDIC is not set
# CONFIG_DDR is not set
# CONFIG_IRQ_POLL is not set
CONFIG_MPILIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_POOL=y
CONFIG_ARCH_HAS_SG_CHAIN=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
CONFIG_BOOT_PRINTK_DELAY=y
# CONFIG_DYNAMIC_DEBUG is not set
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_PAGE_OWNER is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
CONFIG_FRAME_POINTER=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
CONFIG_MAGIC_SYSRQ_SERIAL=y
CONFIG_DEBUG_KERNEL=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_PAGE_REF is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_DEBUG_PER_CPU_MAPS is not set
# CONFIG_DEBUG_HIGHMEM is not set
CONFIG_ARCH_HAS_KCOV=y
# CONFIG_DEBUG_SHIRQ is not set
# Debug Lockups and Hangs
# CONFIG_SOFTLOCKUP_DETECTOR is not set
CONFIG_DETECT_HUNG_TASK=y
CONFIG_DEFAULT_HUNG_TASK_TIMEOUT=120
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
# CONFIG_WQ_WATCHDOG is not set
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_SCHED_DEBUG=y
CONFIG_SCHED_INFO=y
CONFIG_SCHEDSTATS=y
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
CONFIG_TRACE_IRQFLAGS=y
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PI_LIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=21
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
CONFIG_LATENCYTOP=y
CONFIG_NOP_TRACER=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACER_MAX_TRACE=y
CONFIG_TRACE_CLOCK=y
CONFIG_RING_BUFFER=y
CONFIG_EVENT_TRACING=y
CONFIG_CONTEXT_SWITCH_TRACER=y
CONFIG_RING_BUFFER_ALLOW_SWAP=y
CONFIG_PREEMPTIRQ_TRACEPOINTS=y
CONFIG_TRACING=y
CONFIG_GENERIC_TRACER=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
CONFIG_FUNCTION_TRACER=y
CONFIG_FUNCTION_GRAPH_TRACER=y
# CONFIG_PREEMPTIRQ_EVENTS is not set
CONFIG_IRQSOFF_TRACER=y
CONFIG_SCHED_TRACER=y
# CONFIG_HWLAT_TRACER is not set
# CONFIG_FTRACE_SYSCALLS is not set
CONFIG_TRACER_SNAPSHOT=y
CONFIG_TRACER_SNAPSHOT_PER_CPU_SWAP=y
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
CONFIG_STACK_TRACER=y
CONFIG_BLK_DEV_IO_TRACE=y
CONFIG_KPROBE_EVENTS=y
# CONFIG_UPROBE_EVENTS is not set
CONFIG_PROBE_EVENTS=y
CONFIG_DYNAMIC_FTRACE=y
CONFIG_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_FUNCTION_PROFILER=y
CONFIG_FTRACE_MCOUNT_RECORD=y
# CONFIG_FTRACE_STARTUP_TEST is not set
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_RING_BUFFER_STARTUP_TEST is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
# CONFIG_TRACE_EVAL_MAP_FILE is not set
CONFIG_TRACING_EVENTS_GPIO=y
# CONFIG_DMA_API_DEBUG is not set
CONFIG_RUNTIME_TESTING_MENU=y
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_SORT is not set
# CONFIG_KPROBES_SANITY_TEST is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_ASYNC_RAID6_TEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_BITFIELD is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_OVERFLOW is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_IDA is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_FIND_BIT_BENCHMARK is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_MEMTEST is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
CONFIG_KGDB=y
CONFIG_KGDB_SERIAL_CONSOLE=y
# CONFIG_KGDB_TESTS is not set
CONFIG_KGDB_KDB=y
CONFIG_KDB_DEFAULT_ENABLE=0x1
CONFIG_KDB_KEYBOARD=y
CONFIG_KDB_CONTINUE_CATASTROPHIC=0
# CONFIG_UBSAN is not set
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
# CONFIG_ARM_PTDUMP_DEBUGFS is not set
# CONFIG_DEBUG_WX is not set
CONFIG_ARM_UNWIND=y
CONFIG_OLD_MCOUNT=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_ARM_KPROBES_TEST is not set
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
5.5.0 config:
# Automatically generated file; DO NOT EDIT.
# Linux/arm 5.5.0-rc6 Kernel Configuration
# Compiler: gcc (Raspbian 8.3.0-6+rpi1) 8.3.0
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=80300
CONFIG_CLANG_VERSION=0
CONFIG_CC_CAN_LINK=y
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_CC_HAS_ASM_INLINE=y
CONFIG_CC_HAS_WARN_MAYBE_UNINITIALIZED=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="-v7l"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_SIM=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_GENERIC_MSI_IRQ=y
CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
CONFIG_GENERIC_IRQ_DEBUGFS=y
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
# CONFIG_PREEMPT_NONE is not set
CONFIG_PREEMPT_VOLUNTARY=y
# CONFIG_PREEMPT is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
# CONFIG_PSI is not set
# end of CPU/Task time and stats accounting
CONFIG_CPU_ISOLATION=y
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
# end of RCU Subsystem
CONFIG_IKCONFIG=m
CONFIG_IKCONFIG_PROC=y
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# CONFIG_UCLAMP_TASK is not set
# end of Scheduler features
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
# CONFIG_MEMCG_SWAP is not set
CONFIG_MEMCG_KMEM=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
# CONFIG_CFS_BANDWIDTH is not set
# CONFIG_RT_GROUP_SCHED is not set
CONFIG_CGROUP_PIDS=y
# CONFIG_CGROUP_RDMA is not set
CONFIG_CGROUP_FREEZER=y
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
# CONFIG_CGROUP_PERF is not set
CONFIG_CGROUP_BPF=y
# CONFIG_CGROUP_DEBUG is not set
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_CHECKPOINT_RESTORE is not set
CONFIG_SCHED_AUTOGROUP=y
# CONFIG_SYSFS_DEPRECATED is not set
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
CONFIG_EXPERT=y
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_BPF_SYSCALL=y
# CONFIG_USERFAULTFD is not set
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_RSEQ=y
# CONFIG_DEBUG_RSEQ is not set
CONFIG_EMBEDDED=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
# CONFIG_SLUB_MEMCG_SYSFS_ON is not set
# CONFIG_COMPAT_BRK is not set
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
CONFIG_SLUB_CPU_PARTIAL=y
CONFIG_SYSTEM_DATA_VERIFICATION=y
CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
# end of General setup
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ZONE_DMA=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_FIQ=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=3
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# end of Multiple platform selection
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_AXXIA is not set
CONFIG_ARCH_BCM=y
# IPROC architected SoCs
# CONFIG_ARCH_BCM_CYGNUS is not set
# CONFIG_ARCH_BCM_HR2 is not set
# CONFIG_ARCH_BCM_NSP is not set
# CONFIG_ARCH_BCM_5301X is not set
# KONA architected SoCs
# CONFIG_ARCH_BCM_281XX is not set
# CONFIG_ARCH_BCM_21664 is not set
# CONFIG_ARCH_BCM_23550 is not set
# Other Architectures
CONFIG_ARCH_BCM2835=y
# CONFIG_ARCH_BCM_53573 is not set
# CONFIG_ARCH_BCM_63XX is not set
# CONFIG_ARCH_BRCMSTB is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MILBEAUT is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_NPCM is not set
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
# CONFIG_SOC_AM33XX is not set
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
# end of TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_SIRF is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_RDA is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32 is not set
# CONFIG_ARCH_SUNXI is not set
# CONFIG_ARCH_TANGO is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZX is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
CONFIG_ARM_LPAE=y
CONFIG_ARM_THUMB=y
# CONFIG_ARM_THUMBEE is not set
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_ICACHE_MISMATCH_WORKAROUND is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_CPU_SPECTRE=y
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
# CONFIG_CACHE_L2X0 is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_DEBUG_ALIGN_RODATA=y
# CONFIG_ARM_ERRATA_430973 is not set
CONFIG_ARM_ERRATA_643719=y
# CONFIG_ARM_ERRATA_720789 is not set
# CONFIG_ARM_ERRATA_754322 is not set
# CONFIG_ARM_ERRATA_754327 is not set
# CONFIG_ARM_ERRATA_764369 is not set
# CONFIG_ARM_ERRATA_775420 is not set
# CONFIG_ARM_ERRATA_798181 is not set
# CONFIG_ARM_ERRATA_773022 is not set
# CONFIG_ARM_ERRATA_818325_852422 is not set
# CONFIG_ARM_ERRATA_821420 is not set
# CONFIG_ARM_ERRATA_825619 is not set
# CONFIG_ARM_ERRATA_857271 is not set
# CONFIG_ARM_ERRATA_852421 is not set
# CONFIG_ARM_ERRATA_852423 is not set
# CONFIG_ARM_ERRATA_857272 is not set
# end of System Type
# Bus support
# CONFIG_ARM_ERRATA_814220 is not set
# end of Bus support
# Kernel Features
CONFIG_HAVE_SMP=y
CONFIG_SMP=y
CONFIG_SMP_ON_UP=y
CONFIG_ARM_CPU_TOPOLOGY=y
# CONFIG_SCHED_MC is not set
# CONFIG_SCHED_SMT is not set
CONFIG_HAVE_ARM_ARCH_TIMER=y
# CONFIG_MCPM is not set
# CONFIG_BIG_LITTLE is not set
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_NR_CPUS=4
# CONFIG_HOTPLUG_CPU is not set
# CONFIG_ARM_PSCI is not set
CONFIG_ARCH_NR_GPIO=0
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
# CONFIG_THUMB2_KERNEL is not set
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_SYS_SUPPORTS_HUGETLBFS=y
CONFIG_HAVE_ARCH_TRANSPARENT_HUGEPAGE=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_ARM_MODULE_PLTS=y
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
CONFIG_UACCESS_WITH_MEMCPY=y
CONFIG_SECCOMP=y
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# CONFIG_XEN is not set
# end of Kernel Features
# Boot options
CONFIG_USE_OF=y
# CONFIG_ATAGS is not set
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
# CONFIG_ARM_APPENDED_DTB is not set
CONFIG_CMDLINE="console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait"
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# end of Boot options
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
CONFIG_ARM_RASPBERRYPI_CPUFREQ=y
# CONFIG_ARM_BCM2835_CPUFREQ is not set
# CONFIG_QORIQ_CPUFREQ is not set
# end of CPU Frequency scaling
# CPU Idle
# CONFIG_CPU_IDLE is not set
# end of CPU Idle
# end of CPU Power Management
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
CONFIG_KERNEL_MODE_NEON=y
# end of Floating point emulation
# Power management options
# CONFIG_SUSPEND is not set
# CONFIG_HIBERNATION is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_PM_GENERIC_DOMAINS_OF=y
# CONFIG_ENERGY_MODEL is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# end of Power management options
# Firmware Drivers
# CONFIG_ARM_SCMI_PROTOCOL is not set
# CONFIG_ARM_SCPI_PROTOCOL is not set
# CONFIG_FIRMWARE_MEMMAP is not set
CONFIG_RASPBERRYPI_FIRMWARE=y
# CONFIG_FW_CFG_SYSFS is not set
# CONFIG_TRUSTED_FOUNDATIONS is not set
CONFIG_HAVE_ARM_SMCCC=y
# CONFIG_GOOGLE_FIRMWARE is not set
# Tegra firmware driver
# end of Tegra firmware driver
# end of Firmware Drivers
CONFIG_ARM_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM=m
CONFIG_CRYPTO_SHA1_ARM_NEON=m
# CONFIG_CRYPTO_SHA1_ARM_CE is not set
# CONFIG_CRYPTO_SHA2_ARM_CE is not set
# CONFIG_CRYPTO_SHA256_ARM is not set
# CONFIG_CRYPTO_SHA512_ARM is not set
CONFIG_CRYPTO_AES_ARM=m
CONFIG_CRYPTO_AES_ARM_BS=m
# CONFIG_CRYPTO_AES_ARM_CE is not set
# CONFIG_CRYPTO_GHASH_ARM_CE is not set
# CONFIG_CRYPTO_CRC32_ARM_CE is not set
# CONFIG_CRYPTO_CHACHA20_NEON is not set
# CONFIG_CRYPTO_POLY1305_ARM is not set
# CONFIG_CRYPTO_NHPOLY1305_NEON is not set
# CONFIG_CRYPTO_CURVE25519_NEON is not set
# CONFIG_VIRTUALIZATION is not set
# General architecture-dependent options
CONFIG_OPROFILE=m
CONFIG_HAVE_OPROFILE=y
CONFIG_KPROBES=y
CONFIG_JUMP_LABEL=y
# CONFIG_STATIC_KEYS_SELFTEST is not set
CONFIG_OPTPROBES=y
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_KRETPROBES=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_KEEPINITRD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_ARCH_32BIT_OFF_T=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_HAVE_RCU_TABLE_FREE=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP_FILTER=y
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_CC_HAS_STACKPROTECTOR_NONE=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS=8
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_HAVE_COPY_THREAD_TLS=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_ARCH_HAS_PHYS_TO_DMA=y
# CONFIG_LOCK_EVENT_COUNTS is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_PLUGIN_HOSTCC=""
CONFIG_HAVE_GCC_PLUGINS=y
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_CGROUP_RWSTAT=y
CONFIG_BLK_DEV_BSG=y
CONFIG_BLK_DEV_BSGLIB=y
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
CONFIG_BLK_DEV_THROTTLING=y
# CONFIG_BLK_DEV_THROTTLING_LOW is not set
# CONFIG_BLK_CMDLINE_PARSER is not set
# CONFIG_BLK_WBT is not set
# CONFIG_BLK_CGROUP_IOLATENCY is not set
# CONFIG_BLK_CGROUP_IOCOST is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_AIX_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
CONFIG_MAC_PARTITION=y
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
# CONFIG_CMDLINE_PARTITION is not set
# end of Partition Types
CONFIG_BLK_MQ_PCI=y
CONFIG_BLK_PM=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
# end of IO Schedulers
CONFIG_ASN1=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
CONFIG_BINFMT_MISC=m
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_FAST_GUP=y
CONFIG_ARCH_KEEP_MEMBLOCK=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
CONFIG_CONTIG_ALLOC=y
CONFIG_PHYS_ADDR_T_64BIT=y
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_TRANSPARENT_HUGEPAGE is not set
CONFIG_CLEANCACHE=y
CONFIG_FRONTSWAP=y
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
# CONFIG_CMA_DEBUGFS is not set
CONFIG_CMA_AREAS=7
# CONFIG_ZSWAP is not set
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
CONFIG_ZSMALLOC=m
CONFIG_PGTABLE_MAPPING=y
# CONFIG_ZSMALLOC_STAT is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_FRAME_VECTOR=y
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_BENCHMARK is not set
CONFIG_ARCH_HAS_PTE_SPECIAL=y
# end of Memory Management options
CONFIG_NET=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
CONFIG_SKB_EXTENSIONS=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=y
CONFIG_XFRM_USER=y
# CONFIG_XFRM_INTERFACE is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
CONFIG_XFRM_IPCOMP=m
CONFIG_NET_KEY=m
# CONFIG_NET_KEY_MIGRATE is not set
# CONFIG_XDP_SOCKETS is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
# CONFIG_IP_FIB_TRIE_STATS is not set
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_CLASSID=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
# CONFIG_IP_PNP_BOOTP is not set
CONFIG_IP_PNP_RARP=y
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_NET_IP_TUNNEL=m
CONFIG_NET_IPGRE=m
# CONFIG_NET_IPGRE_BROADCAST is not set
CONFIG_IP_MROUTE_COMMON=y
CONFIG_IP_MROUTE=y
CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
CONFIG_SYN_COOKIES=y
CONFIG_NET_IPVTI=m
CONFIG_NET_UDP_TUNNEL=m
# CONFIG_NET_FOU is not set
# CONFIG_NET_FOU_IP_TUNNELS is not set
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
# CONFIG_INET_ESP_OFFLOAD is not set
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_DIAG=m
CONFIG_INET_TCP_DIAG=m
# CONFIG_INET_UDP_DIAG is not set
# CONFIG_INET_RAW_DIAG is not set
# CONFIG_INET_DIAG_DESTROY is not set
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
# CONFIG_TCP_CONG_HSTCP is not set
# CONFIG_TCP_CONG_HYBLA is not set
# CONFIG_TCP_CONG_VEGAS is not set
# CONFIG_TCP_CONG_NV is not set
# CONFIG_TCP_CONG_SCALABLE is not set
# CONFIG_TCP_CONG_LP is not set
# CONFIG_TCP_CONG_VENO is not set
# CONFIG_TCP_CONG_YEAH is not set
# CONFIG_TCP_CONG_ILLINOIS is not set
# CONFIG_TCP_CONG_DCTCP is not set
# CONFIG_TCP_CONG_CDG is not set
CONFIG_TCP_CONG_BBR=m
CONFIG_DEFAULT_CUBIC=y
# CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=m
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
# CONFIG_INET6_ESP_OFFLOAD is not set
CONFIG_INET6_IPCOMP=m
# CONFIG_IPV6_MIP6 is not set
# CONFIG_IPV6_ILA is not set
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
# CONFIG_IPV6_VTI is not set
CONFIG_IPV6_SIT=m
CONFIG_IPV6_SIT_6RD=y
CONFIG_IPV6_NDISC_NODETYPE=y
CONFIG_IPV6_TUNNEL=m
# CONFIG_IPV6_GRE is not set
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_IPV6_MROUTE=y
CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y
CONFIG_IPV6_PIMSM_V2=y
# CONFIG_IPV6_SEG6_LWTUNNEL is not set
# CONFIG_IPV6_SEG6_HMAC is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
# Core Netfilter Configuration
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_FAMILY_BRIDGE=y
CONFIG_NETFILTER_FAMILY_ARP=y
CONFIG_NETFILTER_NETLINK_ACCT=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NETFILTER_NETLINK_OSF=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_LOG_COMMON=m
# CONFIG_NF_LOG_NETDEV is not set
CONFIG_NETFILTER_CONNCOUNT=m
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_ZONES=y
CONFIG_NF_CONNTRACK_PROCFS=y
CONFIG_NF_CONNTRACK_EVENTS=y
# CONFIG_NF_CONNTRACK_TIMEOUT is not set
CONFIG_NF_CONNTRACK_TIMESTAMP=y
CONFIG_NF_CONNTRACK_LABELS=y
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_GRE=y
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_BROADCAST=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
CONFIG_NF_CONNTRACK_SNMP=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SANE=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
# CONFIG_NETFILTER_NETLINK_GLUE_CT is not set
CONFIG_NF_NAT=m
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_SIP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_REDIRECT=y
CONFIG_NF_NAT_MASQUERADE=y
# CONFIG_NF_TABLES is not set
CONFIG_NETFILTER_XTABLES=m
# Xtables combined modules
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_CONNMARK=m
CONFIG_NETFILTER_XT_SET=m
# Xtables targets
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_CT=m
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
CONFIG_NETFILTER_XT_TARGET_HMARK=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_NAT=m
CONFIG_NETFILTER_XT_TARGET_NETMAP=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_NOTRACK=m
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m
# Xtables matches
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_BPF=m
# CONFIG_NETFILTER_XT_MATCH_CGROUP is not set
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_CPU=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DEVGROUP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ECN=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
# CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_L2TP=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_NFACCT=m
CONFIG_NETFILTER_XT_MATCH_OSF=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_SOCKET=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
# end of Core Netfilter Configuration
CONFIG_IP_SET=m
CONFIG_IP_SET_MAX=256
CONFIG_IP_SET_BITMAP_IP=m
CONFIG_IP_SET_BITMAP_IPMAC=m
CONFIG_IP_SET_BITMAP_PORT=m
CONFIG_IP_SET_HASH_IP=m
# CONFIG_IP_SET_HASH_IPMARK is not set
CONFIG_IP_SET_HASH_IPPORT=m
CONFIG_IP_SET_HASH_IPPORTIP=m
CONFIG_IP_SET_HASH_IPPORTNET=m
# CONFIG_IP_SET_HASH_IPMAC is not set
# CONFIG_IP_SET_HASH_MAC is not set
# CONFIG_IP_SET_HASH_NETPORTNET is not set
CONFIG_IP_SET_HASH_NET=m
# CONFIG_IP_SET_HASH_NETNET is not set
CONFIG_IP_SET_HASH_NETPORT=m
CONFIG_IP_SET_HASH_NETIFACE=m
CONFIG_IP_SET_LIST_SET=m
CONFIG_IP_VS=m
# CONFIG_IP_VS_IPV6 is not set
# CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_AH_ESP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
CONFIG_IP_VS_PROTO_SCTP=y
# IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
# CONFIG_IP_VS_FO is not set
# CONFIG_IP_VS_OVF is not set
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
# CONFIG_IP_VS_MH is not set
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
# IPVS SH scheduler
CONFIG_IP_VS_SH_TAB_BITS=8
# IPVS MH scheduler
CONFIG_IP_VS_MH_TAB_INDEX=12
# IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IP_VS_NFCT=y
CONFIG_IP_VS_PE_SIP=m
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m
CONFIG_NF_SOCKET_IPV4=m
CONFIG_NF_TPROXY_IPV4=m
CONFIG_NF_DUP_IPV4=m
# CONFIG_NF_LOG_ARP is not set
CONFIG_NF_LOG_IPV4=m
CONFIG_NF_REJECT_IPV4=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_RPFILTER=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
# CONFIG_IP_NF_TARGET_SYNPROXY is not set
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_CLUSTERIP=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# end of IP: Netfilter Configuration
# IPv6: Netfilter Configuration
CONFIG_NF_SOCKET_IPV6=m
CONFIG_NF_TPROXY_IPV6=m
CONFIG_NF_DUP_IPV6=m
CONFIG_NF_REJECT_IPV6=m
CONFIG_NF_LOG_IPV6=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RPFILTER=m
CONFIG_IP6_NF_MATCH_RT=m
# CONFIG_IP6_NF_MATCH_SRH is not set
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
# CONFIG_IP6_NF_TARGET_SYNPROXY is not set
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_RAW=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_IP6_NF_TARGET_NPT=m
# end of IPv6: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV6=m
# CONFIG_NF_CONNTRACK_BRIDGE is not set
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_IP6=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_OBJCNT is not set
CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
CONFIG_SCTP_COOKIE_HMAC_MD5=y
CONFIG_SCTP_COOKIE_HMAC_SHA1=y
CONFIG_INET_SCTP_DIAG=m
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
CONFIG_ATM=m
# CONFIG_ATM_CLIP is not set
# CONFIG_ATM_LANE is not set
# CONFIG_ATM_BR2684 is not set
CONFIG_L2TP=m
# CONFIG_L2TP_DEBUGFS is not set
CONFIG_L2TP_V3=y
CONFIG_L2TP_IP=m
CONFIG_L2TP_ETH=m
CONFIG_STP=m
CONFIG_GARP=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_IGMP_SNOOPING=y
# CONFIG_BRIDGE_VLAN_FILTERING is not set
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
# CONFIG_VLAN_8021Q_MVRP is not set
# CONFIG_DECNET is not set
CONFIG_LLC=m
# CONFIG_LLC2 is not set
CONFIG_ATALK=m
# CONFIG_DEV_APPLETALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
CONFIG_6LOWPAN=m
# CONFIG_6LOWPAN_DEBUGFS is not set
CONFIG_6LOWPAN_NHC=m
CONFIG_6LOWPAN_NHC_DEST=m
CONFIG_6LOWPAN_NHC_FRAGMENT=m
CONFIG_6LOWPAN_NHC_HOP=m
CONFIG_6LOWPAN_NHC_IPV6=m
CONFIG_6LOWPAN_NHC_MOBILITY=m
CONFIG_6LOWPAN_NHC_ROUTING=m
CONFIG_6LOWPAN_NHC_UDP=m
# CONFIG_6LOWPAN_GHC_EXT_HDR_HOP is not set
# CONFIG_6LOWPAN_GHC_UDP is not set
# CONFIG_6LOWPAN_GHC_ICMPV6 is not set
# CONFIG_6LOWPAN_GHC_EXT_HDR_DEST is not set
# CONFIG_6LOWPAN_GHC_EXT_HDR_FRAG is not set
# CONFIG_6LOWPAN_GHC_EXT_HDR_ROUTE is not set
CONFIG_IEEE802154=m
# CONFIG_IEEE802154_NL802154_EXPERIMENTAL is not set
CONFIG_IEEE802154_SOCKET=m
CONFIG_IEEE802154_6LOWPAN=m
CONFIG_MAC802154=m
CONFIG_NET_SCHED=y
# Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFB=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
# CONFIG_NET_SCH_CBS is not set
# CONFIG_NET_SCH_ETF is not set
# CONFIG_NET_SCH_TAPRIO is not set
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_DRR=m
CONFIG_NET_SCH_MQPRIO=m
# CONFIG_NET_SCH_SKBPRIO is not set
CONFIG_NET_SCH_CHOKE=m
CONFIG_NET_SCH_QFQ=m
CONFIG_NET_SCH_CODEL=m
CONFIG_NET_SCH_FQ_CODEL=m
# CONFIG_NET_SCH_CAKE is not set
CONFIG_NET_SCH_FQ=m
CONFIG_NET_SCH_HHF=m
CONFIG_NET_SCH_PIE=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_SCH_PLUG=m
# CONFIG_NET_SCH_DEFAULT is not set
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
# CONFIG_CLS_U32_PERF is not set
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_CLS_CGROUP=m
# CONFIG_NET_CLS_BPF is not set
# CONFIG_NET_CLS_FLOWER is not set
# CONFIG_NET_CLS_MATCHALL is not set
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
# CONFIG_NET_EMATCH_CANID is not set
CONFIG_NET_EMATCH_IPSET=m
# CONFIG_NET_EMATCH_IPT is not set
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
# CONFIG_NET_ACT_SAMPLE is not set
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
# CONFIG_NET_ACT_MPLS is not set
# CONFIG_NET_ACT_VLAN is not set
# CONFIG_NET_ACT_BPF is not set
# CONFIG_NET_ACT_CONNMARK is not set
# CONFIG_NET_ACT_CTINFO is not set
# CONFIG_NET_ACT_SKBMOD is not set
# CONFIG_NET_ACT_IFE is not set
# CONFIG_NET_ACT_TUNNEL_KEY is not set
# CONFIG_NET_ACT_CT is not set
# CONFIG_NET_TC_SKB_EXT is not set
CONFIG_NET_SCH_FIFO=y
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
CONFIG_BATMAN_ADV=m
CONFIG_BATMAN_ADV_BATMAN_V=y
CONFIG_BATMAN_ADV_BLA=y
CONFIG_BATMAN_ADV_DAT=y
# CONFIG_BATMAN_ADV_NC is not set
CONFIG_BATMAN_ADV_MCAST=y
# CONFIG_BATMAN_ADV_DEBUGFS is not set
# CONFIG_BATMAN_ADV_DEBUG is not set
CONFIG_BATMAN_ADV_SYSFS=y
# CONFIG_BATMAN_ADV_TRACING is not set
CONFIG_OPENVSWITCH=m
CONFIG_OPENVSWITCH_GRE=m
CONFIG_OPENVSWITCH_VXLAN=m
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=m
# CONFIG_MPLS_ROUTING is not set
CONFIG_NET_NSH=m
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
CONFIG_NET_L3_MASTER_DEV=y
# CONFIG_NET_NCSI is not set
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_XPS=y
# CONFIG_CGROUP_NET_PRIO is not set
CONFIG_CGROUP_NET_CLASSID=y
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
# CONFIG_BPF_STREAM_PARSER is not set
CONFIG_NET_FLOW_LIMIT=y
# Network testing
CONFIG_NET_PKTGEN=m
# CONFIG_NET_DROP_MONITOR is not set
# end of Network testing
# end of Networking options
CONFIG_HAMRADIO=y
# Packet Radio protocols
CONFIG_AX25=m
CONFIG_AX25_DAMA_SLAVE=y
CONFIG_NETROM=m
CONFIG_ROSE=m
# AX.25 network device drivers
CONFIG_MKISS=m
CONFIG_6PACK=m
CONFIG_BPQETHER=m
CONFIG_BAYCOM_SER_FDX=m
CONFIG_BAYCOM_SER_HDX=m
CONFIG_YAM=m
# end of AX.25 network device drivers
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_BCM=m
CONFIG_CAN_GW=m
# CONFIG_CAN_J1939 is not set
# CAN Device Drivers
CONFIG_CAN_VCAN=m
# CONFIG_CAN_VXCAN is not set
CONFIG_CAN_SLCAN=m
CONFIG_CAN_DEV=m
CONFIG_CAN_CALC_BITTIMING=y
# CONFIG_CAN_FLEXCAN is not set
# CONFIG_CAN_GRCAN is not set
# CONFIG_CAN_KVASER_PCIEFD is not set
# CONFIG_CAN_TI_HECC is not set
# CONFIG_CAN_C_CAN is not set
# CONFIG_CAN_CC770 is not set
# CONFIG_CAN_IFI_CANFD is not set
# CONFIG_CAN_M_CAN is not set
# CONFIG_CAN_PEAK_PCIEFD is not set
# CONFIG_CAN_RCAR is not set
# CONFIG_CAN_RCAR_CANFD is not set
# CONFIG_CAN_SJA1000 is not set
# CONFIG_CAN_SOFTING is not set
# CAN SPI interfaces
# CONFIG_CAN_HI311X is not set
CONFIG_CAN_MCP251X=m
# end of CAN SPI interfaces
# CAN USB interfaces
# CONFIG_CAN_8DEV_USB is not set
# CONFIG_CAN_EMS_USB is not set
# CONFIG_CAN_ESD_USB2 is not set
CONFIG_CAN_GS_USB=m
# CONFIG_CAN_KVASER_USB is not set
# CONFIG_CAN_MCBA_USB is not set
# CONFIG_CAN_PEAK_USB is not set
# CONFIG_CAN_UCAN is not set
# end of CAN USB interfaces
# CONFIG_CAN_DEBUG_DEVICES is not set
# end of CAN Device Drivers
CONFIG_BT=m
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=m
CONFIG_BT_HS=y
CONFIG_BT_LE=y
CONFIG_BT_6LOWPAN=m
# CONFIG_BT_LEDS is not set
# CONFIG_BT_SELFTEST is not set
CONFIG_BT_DEBUGFS=y
# Bluetooth device drivers
CONFIG_BT_INTEL=m
CONFIG_BT_BCM=m
CONFIG_BT_RTL=m
CONFIG_BT_HCIBTUSB=m
# CONFIG_BT_HCIBTUSB_AUTOSUSPEND is not set
CONFIG_BT_HCIBTUSB_BCM=y
# CONFIG_BT_HCIBTUSB_MTK is not set
CONFIG_BT_HCIBTUSB_RTL=y
# CONFIG_BT_HCIBTSDIO is not set
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_SERDEV=y
CONFIG_BT_HCIUART_H4=y
# CONFIG_BT_HCIUART_NOKIA is not set
# CONFIG_BT_HCIUART_BCSP is not set
# CONFIG_BT_HCIUART_ATH3K is not set
# CONFIG_BT_HCIUART_LL is not set
CONFIG_BT_HCIUART_3WIRE=y
# CONFIG_BT_HCIUART_INTEL is not set
CONFIG_BT_HCIUART_BCM=y
# CONFIG_BT_HCIUART_QCA is not set
# CONFIG_BT_HCIUART_AG6XX is not set
# CONFIG_BT_HCIUART_MRVL is not set
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBPA10X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIVHCI=m
CONFIG_BT_MRVL=m
CONFIG_BT_MRVL_SDIO=m
CONFIG_BT_ATH3K=m
# CONFIG_BT_MTKSDIO is not set
# CONFIG_BT_MTKUART is not set
# end of Bluetooth device drivers
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=m
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_CERTIFICATION_ONUS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
CONFIG_LIB80211=m
CONFIG_LIB80211_CRYPT_WEP=m
CONFIG_LIB80211_CRYPT_CCMP=m
CONFIG_LIB80211_CRYPT_TKIP=m
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
CONFIG_MAC80211_MESH=y
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
CONFIG_WIMAX=m
CONFIG_WIMAX_DEBUG_LEVEL=8
CONFIG_RFKILL=m
CONFIG_RFKILL_LEDS=y
CONFIG_RFKILL_INPUT=y
# CONFIG_RFKILL_GPIO is not set
CONFIG_NET_9P=m
# CONFIG_NET_9P_DEBUG is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
CONFIG_NFC=m
# CONFIG_NFC_DIGITAL is not set
# CONFIG_NFC_NCI is not set
# CONFIG_NFC_HCI is not set
# Near Field Communication (NFC) devices
# CONFIG_NFC_PN533_USB is not set
# CONFIG_NFC_PN533_I2C is not set
# CONFIG_NFC_PN532_UART is not set
# end of Near Field Communication (NFC) devices
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
# CONFIG_FAILOVER is not set
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_ARM_AMBA=y
CONFIG_HAVE_PCI=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCI_DOMAINS_GENERIC=y
CONFIG_PCI_SYSCALL=y
CONFIG_PCIEPORTBUS=y
CONFIG_PCIEAER=y
# CONFIG_PCIEAER_INJECT is not set
# CONFIG_PCIE_ECRC is not set
# CONFIG_PCIEASPM is not set
CONFIG_PCIE_PME=y
# CONFIG_PCIE_DPC is not set
# CONFIG_PCIE_PTM is not set
# CONFIG_PCIE_BW is not set
CONFIG_PCI_MSI=y
CONFIG_PCI_MSI_IRQ_DOMAIN=y
CONFIG_PCI_QUIRKS=y
# CONFIG_PCI_DEBUG is not set
# CONFIG_PCI_STUB is not set
# CONFIG_PCI_IOV is not set
# CONFIG_PCI_PRI is not set
# CONFIG_PCI_PASID is not set
# CONFIG_HOTPLUG_PCI is not set
# PCI controller drivers
# CONFIG_PCI_FTPCI100 is not set
# CONFIG_PCI_HOST_GENERIC is not set
# CONFIG_PCIE_XILINX is not set
# CONFIG_PCI_V3_SEMI is not set
# CONFIG_PCIE_ALTERA is not set
CONFIG_PCIE_BRCMSTB=y
# DesignWare PCI Core Support
# CONFIG_PCIE_DW_PLAT_HOST is not set
# CONFIG_PCI_LAYERSCAPE is not set
# CONFIG_PCI_MESON is not set
# end of DesignWare PCI Core Support
# Cadence PCIe controllers support
# CONFIG_PCIE_CADENCE_PLAT_HOST is not set
# end of Cadence PCIe controllers support
# end of PCI controller drivers
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# end of PCI Endpoint
# PCI switch controller drivers
# CONFIG_PCI_SW_SWITCHTEC is not set
# end of PCI switch controller drivers
# CONFIG_PCCARD is not set
# CONFIG_RAPIDIO is not set
# Generic Driver Options
# CONFIG_UEVENT_HELPER is not set
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER is not set
# CONFIG_FW_LOADER_COMPRESS is not set
# end of Firmware loader
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# end of Generic Driver Options
# Bus devices
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_MOXTET is not set
# CONFIG_SIMPLE_PM_BUS is not set
# CONFIG_VEXPRESS_CONFIG is not set
# end of Bus devices
CONFIG_CONNECTOR=m
# CONFIG_GNSS is not set
CONFIG_MTD=m
# CONFIG_MTD_TESTS is not set
# Partition parsers
# CONFIG_MTD_AR7_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
CONFIG_MTD_OF_PARTS=m
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# end of Partition parsers
# User Modules And Translation Layers
CONFIG_MTD_BLKDEVS=m
CONFIG_MTD_BLOCK=m
# CONFIG_MTD_BLOCK_RO is not set
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_INTEL_VR_NOR is not set
# CONFIG_MTD_PLATRAM is not set
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
CONFIG_MTD_BLOCK2MTD=m
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# CONFIG_MTD_ONENAND is not set
# CONFIG_MTD_RAW_NAND is not set
# CONFIG_MTD_SPI_NAND is not set
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
# end of LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_SPI_NOR=m
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_SPI_CADENCE_QUADSPI is not set
# CONFIG_SPI_MTK_QUADSPI is not set
CONFIG_MTD_UBI=m
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
# CONFIG_MTD_UBI_BLOCK is not set
# CONFIG_MTD_HYPERBUS is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_DYNAMIC=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_RESERVED_MEM=y
CONFIG_OF_RESOLVE=y
CONFIG_OF_OVERLAY=y
CONFIG_OF_CONFIGFS=y
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
CONFIG_CDROM=m
# CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
CONFIG_ZRAM=m
# CONFIG_ZRAM_WRITEBACK is not set
# CONFIG_ZRAM_MEMORY_TRACKING is not set
# CONFIG_BLK_DEV_UMEM is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_DRBD=m
# CONFIG_DRBD_FAULT_INJECTION is not set
CONFIG_BLK_DEV_NBD=m
# CONFIG_BLK_DEV_SX8 is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
CONFIG_CDROM_PKTCDVD=m
CONFIG_CDROM_PKTCDVD_BUFFERS=8
# CONFIG_CDROM_PKTCDVD_WCACHE is not set
CONFIG_ATA_OVER_ETH=m
# CONFIG_BLK_DEV_RBD is not set
# CONFIG_BLK_DEV_RSXX is not set
# NVME Support
# CONFIG_BLK_DEV_NVME is not set
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# end of NVME Support
# Misc devices
CONFIG_BCM2835_SMI=m
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_PHANTOM is not set
# CONFIG_TIFM_CORE is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_HP_ILO is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_PCI_ENDPOINT_TEST is not set
# CONFIG_XILINX_SDFEC is not set
# CONFIG_PVPANIC is not set
# CONFIG_C2PORT is not set
# EEPROM support
CONFIG_EEPROM_AT24=m
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
CONFIG_EEPROM_93CX6=m
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# CONFIG_CB710_CORE is not set
# Texas Instruments shared transport line discipline
CONFIG_TI_ST=m
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# Intel MIC & related support
# CONFIG_VOP_BUS is not set
# end of Intel MIC & related support
# CONFIG_ECHO is not set
# CONFIG_MISC_ALCOR_PCI is not set
# CONFIG_MISC_RTSX_PCI is not set
# CONFIG_MISC_RTSX_USB is not set
# CONFIG_HABANA_AI is not set
# end of Misc devices
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_PROC_FS is not set
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
CONFIG_CHR_DEV_ST=m
CONFIG_BLK_DEV_SR=m
# CONFIG_BLK_DEV_SR_VENDOR is not set
CONFIG_CHR_DEV_SG=m
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
CONFIG_SCSI_ISCSI_ATTRS=y
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=m
CONFIG_ISCSI_BOOT_SYSFS=m
# CONFIG_SCSI_CXGB3_ISCSI is not set
# CONFIG_SCSI_CXGB4_ISCSI is not set
# CONFIG_SCSI_BNX2_ISCSI is not set
# CONFIG_BE2ISCSI is not set
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_HPSA is not set
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_3W_SAS is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_AIC94XX is not set
# CONFIG_SCSI_MVSAS is not set
# CONFIG_SCSI_MVUMI is not set
# CONFIG_SCSI_ADVANSYS is not set
# CONFIG_SCSI_ARCMSR is not set
# CONFIG_SCSI_ESAS2R is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
# CONFIG_MEGARAID_SAS is not set
# CONFIG_SCSI_MPT3SAS is not set
# CONFIG_SCSI_MPT2SAS is not set
# CONFIG_SCSI_SMARTPQI is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_HPTIOP is not set
# CONFIG_SCSI_MYRB is not set
# CONFIG_SCSI_MYRS is not set
# CONFIG_SCSI_SNIC is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_FDOMAIN_PCI is not set
# CONFIG_SCSI_GDTH is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_STEX is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
# CONFIG_SCSI_QLA_ISCSI is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_AM53C974 is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_WD719X is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_PMCRAID is not set
# CONFIG_SCSI_PM8001 is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
# CONFIG_ATA is not set
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID10=m
CONFIG_MD_RAID456=m
# CONFIG_MD_MULTIPATH is not set
# CONFIG_MD_FAULTY is not set
# CONFIG_MD_CLUSTER is not set
# CONFIG_BCACHE is not set
CONFIG_BLK_DEV_DM_BUILTIN=y
CONFIG_BLK_DEV_DM=m
# CONFIG_DM_DEBUG is not set
CONFIG_DM_BUFIO=m
# CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set
CONFIG_DM_BIO_PRISON=m
CONFIG_DM_PERSISTENT_DATA=m
# CONFIG_DM_UNSTRIPED is not set
CONFIG_DM_CRYPT=m
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_THIN_PROVISIONING=m
CONFIG_DM_CACHE=m
CONFIG_DM_CACHE_SMQ=m
# CONFIG_DM_WRITECACHE is not set
# CONFIG_DM_ERA is not set
# CONFIG_DM_CLONE is not set
CONFIG_DM_MIRROR=m
CONFIG_DM_LOG_USERSPACE=m
CONFIG_DM_RAID=m
CONFIG_DM_ZERO=m
# CONFIG_DM_MULTIPATH is not set
CONFIG_DM_DELAY=m
# CONFIG_DM_DUST is not set
# CONFIG_DM_UEVENT is not set
# CONFIG_DM_FLAKEY is not set
# CONFIG_DM_VERITY is not set
# CONFIG_DM_SWITCH is not set
# CONFIG_DM_LOG_WRITES is not set
# CONFIG_DM_INTEGRITY is not set
# CONFIG_TARGET_CORE is not set
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# CONFIG_FIREWIRE is not set
# CONFIG_FIREWIRE_NOSY is not set
# end of IEEE 1394 (FireWire) support
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
CONFIG_BONDING=m
CONFIG_DUMMY=m
# CONFIG_EQUALIZER is not set
# CONFIG_NET_FC is not set
CONFIG_IFB=m
# CONFIG_NET_TEAM is not set
CONFIG_MACVLAN=m
# CONFIG_MACVTAP is not set
CONFIG_IPVLAN_L3S=y
CONFIG_IPVLAN=m
# CONFIG_IPVTAP is not set
CONFIG_VXLAN=m
# CONFIG_GENEVE is not set
# CONFIG_GTP is not set
# CONFIG_MACSEC is not set
CONFIG_NETCONSOLE=m
# CONFIG_NETCONSOLE_DYNAMIC is not set
CONFIG_NETPOLL=y
CONFIG_NET_POLL_CONTROLLER=y
CONFIG_TUN=m
# CONFIG_TUN_VNET_CROSS_LE is not set
CONFIG_VETH=m
# CONFIG_NLMON is not set
CONFIG_NET_VRF=m
# CONFIG_ARCNET is not set
CONFIG_ATM_DRIVERS=y
# CONFIG_ATM_DUMMY is not set
# CONFIG_ATM_TCP is not set
# CONFIG_ATM_LANAI is not set
# CONFIG_ATM_ENI is not set
# CONFIG_ATM_NICSTAR is not set
# CONFIG_ATM_IDT77252 is not set
# CONFIG_ATM_IA is not set
# CONFIG_ATM_FORE200E is not set
# CONFIG_ATM_HE is not set
# CONFIG_ATM_SOLOS is not set
# Distributed Switch Architecture drivers
# end of Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_3COM=y
# CONFIG_VORTEX is not set
# CONFIG_TYPHOON is not set
CONFIG_NET_VENDOR_ADAPTEC=y
# CONFIG_ADAPTEC_STARFIRE is not set
CONFIG_NET_VENDOR_AGERE=y
# CONFIG_ET131X is not set
CONFIG_NET_VENDOR_ALACRITECH=y
# CONFIG_SLICOSS is not set
CONFIG_NET_VENDOR_ALTEON=y
# CONFIG_ACENIC is not set
# CONFIG_ALTERA_TSE is not set
CONFIG_NET_VENDOR_AMAZON=y
# CONFIG_ENA_ETHERNET is not set
CONFIG_NET_VENDOR_AMD=y
# CONFIG_AMD8111_ETH is not set
# CONFIG_PCNET32 is not set
CONFIG_NET_VENDOR_AQUANTIA=y
CONFIG_NET_VENDOR_ARC=y
CONFIG_NET_VENDOR_ATHEROS=y
# CONFIG_ATL2 is not set
# CONFIG_ATL1 is not set
# CONFIG_ATL1E is not set
# CONFIG_ATL1C is not set
# CONFIG_ALX is not set
CONFIG_NET_VENDOR_AURORA=y
# CONFIG_AURORA_NB8800 is not set
CONFIG_NET_VENDOR_BROADCOM=y
# CONFIG_B44 is not set
CONFIG_BCMGENET=y
# CONFIG_BNX2 is not set
# CONFIG_CNIC is not set
# CONFIG_TIGON3 is not set
# CONFIG_BNX2X is not set
# CONFIG_SYSTEMPORT is not set
# CONFIG_BNXT is not set
CONFIG_NET_VENDOR_BROCADE=y
# CONFIG_BNA is not set
CONFIG_NET_VENDOR_CADENCE=y
# CONFIG_MACB is not set
CONFIG_NET_VENDOR_CAVIUM=y
CONFIG_NET_VENDOR_CHELSIO=y
# CONFIG_CHELSIO_T1 is not set
# CONFIG_CHELSIO_T3 is not set
# CONFIG_CHELSIO_T4 is not set
# CONFIG_CHELSIO_T4VF is not set
CONFIG_NET_VENDOR_CIRRUS=y
# CONFIG_CS89x0 is not set
CONFIG_NET_VENDOR_CISCO=y
# CONFIG_ENIC is not set
CONFIG_NET_VENDOR_CORTINA=y
# CONFIG_GEMINI_ETHERNET is not set
# CONFIG_DM9000 is not set
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_DEC=y
# CONFIG_NET_TULIP is not set
CONFIG_NET_VENDOR_DLINK=y
# CONFIG_DL2K is not set
# CONFIG_SUNDANCE is not set
CONFIG_NET_VENDOR_EMULEX=y
# CONFIG_BE2NET is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_FARADAY=y
# CONFIG_FTMAC100 is not set
# CONFIG_FTGMAC100 is not set
CONFIG_NET_VENDOR_GOOGLE=y
# CONFIG_GVE is not set
CONFIG_NET_VENDOR_HISILICON=y
# CONFIG_HIX5HD2_GMAC is not set
# CONFIG_HISI_FEMAC is not set
# CONFIG_HIP04_ETH is not set
# CONFIG_HNS is not set
# CONFIG_HNS_DSAF is not set
# CONFIG_HNS_ENET is not set
# CONFIG_HNS3 is not set
CONFIG_NET_VENDOR_HUAWEI=y
CONFIG_NET_VENDOR_I825XX=y
CONFIG_NET_VENDOR_INTEL=y
# CONFIG_E100 is not set
# CONFIG_E1000 is not set
# CONFIG_E1000E is not set
# CONFIG_IGB is not set
# CONFIG_IGBVF is not set
# CONFIG_IXGB is not set
# CONFIG_IXGBE is not set
# CONFIG_IXGBEVF is not set
# CONFIG_I40E is not set
# CONFIG_I40EVF is not set
# CONFIG_ICE is not set
# CONFIG_FM10K is not set
# CONFIG_IGC is not set
# CONFIG_JME is not set
CONFIG_NET_VENDOR_MARVELL=y
# CONFIG_MVMDIO is not set
# CONFIG_SKGE is not set
# CONFIG_SKY2 is not set
CONFIG_NET_VENDOR_MELLANOX=y
# CONFIG_MLX4_EN is not set
# CONFIG_MLX5_CORE is not set
# CONFIG_MLXSW_CORE is not set
# CONFIG_MLXFW is not set
CONFIG_NET_VENDOR_MICREL=y
# CONFIG_KS8842 is not set
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_KSZ884X_PCI is not set
CONFIG_NET_VENDOR_MICROCHIP=y
CONFIG_ENC28J60=m
# CONFIG_ENC28J60_WRITEVERIFY is not set
# CONFIG_ENCX24J600 is not set
# CONFIG_LAN743X is not set
CONFIG_NET_VENDOR_MICROSEMI=y
CONFIG_NET_VENDOR_MYRI=y
# CONFIG_MYRI10GE is not set
# CONFIG_FEALNX is not set
CONFIG_NET_VENDOR_NATSEMI=y
# CONFIG_NATSEMI is not set
# CONFIG_NS83820 is not set
CONFIG_NET_VENDOR_NETERION=y
# CONFIG_S2IO is not set
# CONFIG_VXGE is not set
CONFIG_NET_VENDOR_NETRONOME=y
# CONFIG_NFP is not set
CONFIG_NET_VENDOR_NI=y
# CONFIG_NI_XGE_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_8390=y
# CONFIG_AX88796 is not set
# CONFIG_NE2K_PCI is not set
CONFIG_NET_VENDOR_NVIDIA=y
# CONFIG_FORCEDETH is not set
CONFIG_NET_VENDOR_OKI=y
# CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_PACKET_ENGINES=y
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
CONFIG_NET_VENDOR_PENSANDO=y
CONFIG_NET_VENDOR_QLOGIC=y
# CONFIG_QLA3XXX is not set
# CONFIG_QLCNIC is not set
# CONFIG_NETXEN_NIC is not set
# CONFIG_QED is not set
CONFIG_NET_VENDOR_QUALCOMM=y
CONFIG_QCA7000=m
CONFIG_QCA7000_SPI=m
# CONFIG_QCA7000_UART is not set
# CONFIG_QCOM_EMAC is not set
# CONFIG_RMNET is not set
CONFIG_NET_VENDOR_RDC=y
# CONFIG_R6040 is not set
CONFIG_NET_VENDOR_REALTEK=y
# CONFIG_8139CP is not set
# CONFIG_8139TOO is not set
# CONFIG_R8169 is not set
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
CONFIG_NET_VENDOR_SAMSUNG=y
# CONFIG_SXGBE_ETH is not set
CONFIG_NET_VENDOR_SEEQ=y
CONFIG_NET_VENDOR_SOLARFLARE=y
# CONFIG_SFC is not set
# CONFIG_SFC_FALCON is not set
CONFIG_NET_VENDOR_SILAN=y
# CONFIG_SC92031 is not set
CONFIG_NET_VENDOR_SIS=y
# CONFIG_SIS900 is not set
# CONFIG_SIS190 is not set
CONFIG_NET_VENDOR_SMSC=y
# CONFIG_SMC91X is not set
# CONFIG_EPIC100 is not set
# CONFIG_SMC911X is not set
# CONFIG_SMSC911X is not set
# CONFIG_SMSC9420 is not set
CONFIG_NET_VENDOR_SOCIONEXT=y
CONFIG_NET_VENDOR_STMICRO=y
# CONFIG_STMMAC_ETH is not set
CONFIG_NET_VENDOR_SUN=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NIU is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
CONFIG_NET_VENDOR_TEHUTI=y
# CONFIG_TEHUTI is not set
CONFIG_NET_VENDOR_TI=y
# CONFIG_TI_CPSW_PHY_SEL is not set
# CONFIG_TLAN is not set
CONFIG_NET_VENDOR_VIA=y
# CONFIG_VIA_RHINE is not set
# CONFIG_VIA_VELOCITY is not set
CONFIG_NET_VENDOR_WIZNET=y
CONFIG_WIZNET_W5100=m
# CONFIG_WIZNET_W5300 is not set
# CONFIG_WIZNET_BUS_DIRECT is not set
# CONFIG_WIZNET_BUS_INDIRECT is not set
CONFIG_WIZNET_BUS_ANY=y
CONFIG_WIZNET_W5100_SPI=m
CONFIG_NET_VENDOR_XILINX=y
# CONFIG_XILINX_AXI_EMAC is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
CONFIG_MDIO_BCM_UNIMAC=y
CONFIG_MDIO_BITBANG=m
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
# CONFIG_MDIO_GPIO is not set
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_MSCC_MIIM is not set
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
# MII PHY device drivers
# CONFIG_ADIN_PHY is not set
# CONFIG_AMD_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AX88796B_PHY is not set
CONFIG_BCM7XXX_PHY=y
# CONFIG_BCM87XX_PHY is not set
CONFIG_BCM_NET_PHYLIB=y
CONFIG_BROADCOM_PHY=y
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_DP83822_PHY is not set
# CONFIG_DP83TC811_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
# CONFIG_DP83869_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_ICPLUS_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MICREL_PHY is not set
CONFIG_MICROCHIP_PHY=y
# CONFIG_MICROCHIP_T1_PHY is not set
# CONFIG_MICROSEMI_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_NXP_TJA11XX_PHY is not set
# CONFIG_AT803X_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_RENESAS_PHY is not set
# CONFIG_ROCKCHIP_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
CONFIG_PPP=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOATM=m
CONFIG_PPPOE=m
# CONFIG_PPTP is not set
CONFIG_PPPOL2TP=m
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_SLIP=m
CONFIG_SLHC=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
# CONFIG_SLIP_MODE_SLIP6 is not set
CONFIG_USB_NET_DRIVERS=y
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=y
CONFIG_USB_LAN78XX=y
CONFIG_USB_USBNET=y
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_CDC_EEM=m
CONFIG_USB_NET_CDC_NCM=m
CONFIG_USB_NET_HUAWEI_CDC_NCM=m
CONFIG_USB_NET_CDC_MBIM=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9700=m
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=y
CONFIG_USB_NET_GL620A=m
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_NET_CDC_SUBSET_ENABLE=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_ZAURUS=m
CONFIG_USB_NET_CX82310_ETH=m
CONFIG_USB_NET_KALMIA=m
CONFIG_USB_NET_QMI_WWAN=m
CONFIG_USB_HSO=m
CONFIG_USB_NET_INT51X1=m
CONFIG_USB_IPHETH=m
CONFIG_USB_SIERRA_NET=m
CONFIG_USB_VL600=m
# CONFIG_USB_NET_CH9200 is not set
# CONFIG_USB_NET_AQC111 is not set
CONFIG_WLAN=y
# CONFIG_WIRELESS_WDS is not set
CONFIG_WLAN_VENDOR_ADMTEK=y
# CONFIG_ADM8211 is not set
CONFIG_ATH_COMMON=m
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
# CONFIG_ATH5K is not set
# CONFIG_ATH5K_PCI is not set
CONFIG_ATH9K_HW=m
CONFIG_ATH9K_COMMON=m
CONFIG_ATH9K_BTCOEX_SUPPORT=y
CONFIG_ATH9K=m
CONFIG_ATH9K_PCI=y
# CONFIG_ATH9K_AHB is not set
# CONFIG_ATH9K_DEBUGFS is not set
# CONFIG_ATH9K_DYNACK is not set
# CONFIG_ATH9K_WOW is not set
CONFIG_ATH9K_RFKILL=y
# CONFIG_ATH9K_CHANNEL_CONTEXT is not set
CONFIG_ATH9K_PCOEM=y
# CONFIG_ATH9K_PCI_NO_EEPROM is not set
CONFIG_ATH9K_HTC=m
# CONFIG_ATH9K_HTC_DEBUGFS is not set
# CONFIG_ATH9K_HWRNG is not set
CONFIG_CARL9170=m
CONFIG_CARL9170_LEDS=y
CONFIG_CARL9170_WPC=y
# CONFIG_CARL9170_HWRNG is not set
CONFIG_ATH6KL=m
# CONFIG_ATH6KL_SDIO is not set
CONFIG_ATH6KL_USB=m
# CONFIG_ATH6KL_DEBUG is not set
# CONFIG_ATH6KL_TRACING is not set
CONFIG_AR5523=m
# CONFIG_WIL6210 is not set
# CONFIG_ATH10K is not set
# CONFIG_WCN36XX is not set
CONFIG_WLAN_VENDOR_ATMEL=y
# CONFIG_ATMEL is not set
CONFIG_AT76C50X_USB=m
CONFIG_WLAN_VENDOR_BROADCOM=y
CONFIG_B43=m
CONFIG_B43_BCMA=y
CONFIG_B43_SSB=y
CONFIG_B43_BUSES_BCMA_AND_SSB=y
# CONFIG_B43_BUSES_BCMA is not set
# CONFIG_B43_BUSES_SSB is not set
CONFIG_B43_PCI_AUTOSELECT=y
CONFIG_B43_PCICORE_AUTOSELECT=y
# CONFIG_B43_SDIO is not set
CONFIG_B43_BCMA_PIO=y
CONFIG_B43_PIO=y
CONFIG_B43_PHY_G=y
# CONFIG_B43_PHY_N is not set
CONFIG_B43_PHY_LP=y
CONFIG_B43_PHY_HT=y
CONFIG_B43_LEDS=y
CONFIG_B43_HWRNG=y
# CONFIG_B43_DEBUG is not set
CONFIG_B43LEGACY=m
CONFIG_B43LEGACY_PCI_AUTOSELECT=y
CONFIG_B43LEGACY_PCICORE_AUTOSELECT=y
CONFIG_B43LEGACY_LEDS=y
CONFIG_B43LEGACY_HWRNG=y
CONFIG_B43LEGACY_DEBUG=y
CONFIG_B43LEGACY_DMA=y
CONFIG_B43LEGACY_PIO=y
CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y
# CONFIG_B43LEGACY_DMA_MODE is not set
# CONFIG_B43LEGACY_PIO_MODE is not set
CONFIG_BRCMUTIL=m
# CONFIG_BRCMSMAC is not set
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
CONFIG_BRCMFMAC_SDIO=y
CONFIG_BRCMFMAC_USB=y
# CONFIG_BRCMFMAC_PCIE is not set
# CONFIG_BRCM_TRACING is not set
CONFIG_BRCMDBG=y
CONFIG_WLAN_VENDOR_CISCO=y
CONFIG_WLAN_VENDOR_INTEL=y
# CONFIG_IPW2100 is not set
# CONFIG_IPW2200 is not set
# CONFIG_IWL4965 is not set
# CONFIG_IWL3945 is not set
# CONFIG_IWLWIFI is not set
CONFIG_WLAN_VENDOR_INTERSIL=y
CONFIG_HOSTAP=m
# CONFIG_HOSTAP_FIRMWARE is not set
# CONFIG_HOSTAP_PLX is not set
# CONFIG_HOSTAP_PCI is not set
# CONFIG_HERMES is not set
CONFIG_P54_COMMON=m
CONFIG_P54_USB=m
# CONFIG_P54_PCI is not set
# CONFIG_P54_SPI is not set
CONFIG_P54_LEDS=y
# CONFIG_PRISM54 is not set
CONFIG_WLAN_VENDOR_MARVELL=y
CONFIG_LIBERTAS=m
CONFIG_LIBERTAS_USB=m
CONFIG_LIBERTAS_SDIO=m
# CONFIG_LIBERTAS_SPI is not set
# CONFIG_LIBERTAS_DEBUG is not set
# CONFIG_LIBERTAS_MESH is not set
CONFIG_LIBERTAS_THINFIRM=m
# CONFIG_LIBERTAS_THINFIRM_DEBUG is not set
CONFIG_LIBERTAS_THINFIRM_USB=m
CONFIG_MWIFIEX=m
CONFIG_MWIFIEX_SDIO=m
# CONFIG_MWIFIEX_PCIE is not set
# CONFIG_MWIFIEX_USB is not set
# CONFIG_MWL8K is not set
CONFIG_WLAN_VENDOR_MEDIATEK=y
CONFIG_MT7601U=m
CONFIG_MT76_CORE=m
CONFIG_MT76_LEDS=y
CONFIG_MT76_USB=m
CONFIG_MT76x02_LIB=m
CONFIG_MT76x02_USB=m
CONFIG_MT76x0_COMMON=m
CONFIG_MT76x0U=m
# CONFIG_MT76x0E is not set
CONFIG_MT76x2_COMMON=m
# CONFIG_MT76x2E is not set
CONFIG_MT76x2U=m
# CONFIG_MT7603E is not set
# CONFIG_MT7615E is not set
CONFIG_WLAN_VENDOR_RALINK=y
CONFIG_RT2X00=m
# CONFIG_RT2400PCI is not set
# CONFIG_RT2500PCI is not set
# CONFIG_RT61PCI is not set
# CONFIG_RT2800PCI is not set
CONFIG_RT2500USB=m
CONFIG_RT73USB=m
CONFIG_RT2800USB=m
CONFIG_RT2800USB_RT33XX=y
CONFIG_RT2800USB_RT35XX=y
CONFIG_RT2800USB_RT3573=y
CONFIG_RT2800USB_RT53XX=y
CONFIG_RT2800USB_RT55XX=y
CONFIG_RT2800USB_UNKNOWN=y
CONFIG_RT2800_LIB=m
CONFIG_RT2X00_LIB_USB=m
CONFIG_RT2X00_LIB=m
CONFIG_RT2X00_LIB_FIRMWARE=y
CONFIG_RT2X00_LIB_CRYPTO=y
CONFIG_RT2X00_LIB_LEDS=y
# CONFIG_RT2X00_DEBUG is not set
CONFIG_WLAN_VENDOR_REALTEK=y
# CONFIG_RTL8180 is not set
CONFIG_RTL8187=m
CONFIG_RTL8187_LEDS=y
CONFIG_RTL_CARDS=m
# CONFIG_RTL8192CE is not set
# CONFIG_RTL8192SE is not set
# CONFIG_RTL8192DE is not set
# CONFIG_RTL8723AE is not set
# CONFIG_RTL8723BE is not set
# CONFIG_RTL8188EE is not set
# CONFIG_RTL8192EE is not set
# CONFIG_RTL8821AE is not set
CONFIG_RTL8192CU=m
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_USB=m
CONFIG_RTLWIFI_DEBUG=y
CONFIG_RTL8192C_COMMON=m
CONFIG_RTL8XXXU=m
# CONFIG_RTL8XXXU_UNTESTED is not set
# CONFIG_RTW88 is not set
CONFIG_WLAN_VENDOR_RSI=y
# CONFIG_RSI_91X is not set
CONFIG_WLAN_VENDOR_ST=y
# CONFIG_CW1200 is not set
CONFIG_WLAN_VENDOR_TI=y
# CONFIG_WL1251 is not set
# CONFIG_WL12XX is not set
# CONFIG_WL18XX is not set
# CONFIG_WLCORE is not set
CONFIG_WLAN_VENDOR_ZYDAS=y
CONFIG_USB_ZD1201=m
CONFIG_ZD1211RW=m
# CONFIG_ZD1211RW_DEBUG is not set
CONFIG_WLAN_VENDOR_QUANTENNA=y
# CONFIG_QTNFMAC_PCIE is not set
CONFIG_MAC80211_HWSIM=m
CONFIG_USB_NET_RNDIS_WLAN=m
# CONFIG_VIRT_WIFI is not set
# WiMAX Wireless Broadband devices
CONFIG_WIMAX_I2400M=m
CONFIG_WIMAX_I2400M_USB=m
CONFIG_WIMAX_I2400M_DEBUG_LEVEL=8
# end of WiMAX Wireless Broadband devices
# CONFIG_WAN is not set
CONFIG_IEEE802154_DRIVERS=m
# CONFIG_IEEE802154_FAKELB is not set
CONFIG_IEEE802154_AT86RF230=m
# CONFIG_IEEE802154_AT86RF230_DEBUGFS is not set
CONFIG_IEEE802154_MRF24J40=m
CONFIG_IEEE802154_CC2520=m
# CONFIG_IEEE802154_ATUSB is not set
# CONFIG_IEEE802154_ADF7242 is not set
# CONFIG_IEEE802154_CA8210 is not set
# CONFIG_IEEE802154_MCR20A is not set
# CONFIG_IEEE802154_HWSIM is not set
# CONFIG_VMXNET3 is not set
# CONFIG_NETDEVSIM is not set
# CONFIG_NET_FAILOVER is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
CONFIG_INPUT_FF_MEMLESS=m
# CONFIG_INPUT_POLLDEV is not set
# CONFIG_INPUT_SPARSEKMAP is not set
CONFIG_INPUT_MATRIXKMAP=m
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
# CONFIG_INPUT_MOUSEDEV_PSAUX is not set
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_EVDEV=m
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADC is not set
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
# CONFIG_KEYBOARD_ATKBD is not set
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=m
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
CONFIG_KEYBOARD_MATRIX=m
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_STMPE is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
CONFIG_INPUT_JOYSTICK=y
# CONFIG_JOYSTICK_ANALOG is not set
# CONFIG_JOYSTICK_A3D is not set
# CONFIG_JOYSTICK_ADI is not set
# CONFIG_JOYSTICK_COBRA is not set
# CONFIG_JOYSTICK_GF2K is not set
# CONFIG_JOYSTICK_GRIP is not set
# CONFIG_JOYSTICK_GRIP_MP is not set
# CONFIG_JOYSTICK_GUILLEMOT is not set
# CONFIG_JOYSTICK_INTERACT is not set
# CONFIG_JOYSTICK_SIDEWINDER is not set
# CONFIG_JOYSTICK_TMDC is not set
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_USB=m
# CONFIG_JOYSTICK_IFORCE_232 is not set
# CONFIG_JOYSTICK_WARRIOR is not set
# CONFIG_JOYSTICK_MAGELLAN is not set
# CONFIG_JOYSTICK_SPACEORB is not set
# CONFIG_JOYSTICK_SPACEBALL is not set
# CONFIG_JOYSTICK_STINGER is not set
# CONFIG_JOYSTICK_TWIDJOY is not set
# CONFIG_JOYSTICK_ZHENHUA is not set
# CONFIG_JOYSTICK_AS5011 is not set
# CONFIG_JOYSTICK_JOYDUMP is not set
CONFIG_JOYSTICK_XPAD=m
CONFIG_JOYSTICK_XPAD_FF=y
CONFIG_JOYSTICK_XPAD_LEDS=y
CONFIG_JOYSTICK_PSXPAD_SPI=m
CONFIG_JOYSTICK_PSXPAD_SPI_FF=y
# CONFIG_JOYSTICK_PXRC is not set
# CONFIG_JOYSTICK_FSIA6B is not set
CONFIG_JOYSTICK_RPISENSE=m
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
CONFIG_TOUCHSCREEN_ADS7846=m
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_ADC is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
# CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
CONFIG_TOUCHSCREEN_EGALAX=m
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
CONFIG_TOUCHSCREEN_EXC3000=m
# CONFIG_TOUCHSCREEN_FUJITSU is not set
CONFIG_TOUCHSCREEN_GOODIX=m
# CONFIG_TOUCHSCREEN_HIDEEP is not set
CONFIG_TOUCHSCREEN_ILI210X=m
# CONFIG_TOUCHSCREEN_S6SY761 is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
CONFIG_TOUCHSCREEN_EDT_FT5X06=m
# CONFIG_TOUCHSCREEN_RASPBERRYPI_FW is not set
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
CONFIG_TOUCHSCREEN_USB_COMPOSITE=m
CONFIG_TOUCHSCREEN_USB_EGALAX=y
CONFIG_TOUCHSCREEN_USB_PANJIT=y
CONFIG_TOUCHSCREEN_USB_3M=y
CONFIG_TOUCHSCREEN_USB_ITM=y
CONFIG_TOUCHSCREEN_USB_ETURBO=y
CONFIG_TOUCHSCREEN_USB_GUNZE=y
CONFIG_TOUCHSCREEN_USB_DMC_TSC10=y
CONFIG_TOUCHSCREEN_USB_IRTOUCH=y
CONFIG_TOUCHSCREEN_USB_IDEALTEK=y
CONFIG_TOUCHSCREEN_USB_GENERAL_TOUCH=y
CONFIG_TOUCHSCREEN_USB_GOTOP=y
CONFIG_TOUCHSCREEN_USB_JASTEC=y
CONFIG_TOUCHSCREEN_USB_ELO=y
CONFIG_TOUCHSCREEN_USB_E2I=y
CONFIG_TOUCHSCREEN_USB_ZYTRONIC=y
CONFIG_TOUCHSCREEN_USB_ETT_TC45USB=y
CONFIG_TOUCHSCREEN_USB_NEXIO=y
CONFIG_TOUCHSCREEN_USB_EASYTOUCH=y
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
CONFIG_TOUCHSCREEN_STMPE=m
# CONFIG_TOUCHSCREEN_SUR40 is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
# CONFIG_TOUCHSCREEN_IQS5XX is not set
CONFIG_INPUT_MISC=y
CONFIG_INPUT_AD714X=m
CONFIG_INPUT_AD714X_I2C=m
CONFIG_INPUT_AD714X_SPI=m
# CONFIG_INPUT_ARIZONA_HAPTICS is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MSM_VIBRATOR is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
CONFIG_INPUT_ATI_REMOTE2=m
CONFIG_INPUT_KEYSPAN_REMOTE=m
# CONFIG_INPUT_KXTJ9 is not set
CONFIG_INPUT_POWERMATE=m
CONFIG_INPUT_YEALINK=m
CONFIG_INPUT_CM109=m
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
CONFIG_INPUT_UINPUT=m
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_PWM_VIBRA is not set
CONFIG_INPUT_GPIO_ROTARY_ENCODER=m
CONFIG_INPUT_ADXL34X=m
CONFIG_INPUT_ADXL34X_I2C=m
CONFIG_INPUT_ADXL34X_SPI=m
# CONFIG_INPUT_IMS_PCU is not set
CONFIG_INPUT_CMA3000=m
# CONFIG_INPUT_CMA3000_I2C is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=m
CONFIG_SERIO_SERPORT=m
# CONFIG_SERIO_AMBAKMI is not set
# CONFIG_SERIO_PCIPS2 is not set
# CONFIG_SERIO_LIBPS2 is not set
CONFIG_SERIO_RAW=m
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
CONFIG_GAMEPORT=m
CONFIG_GAMEPORT_NS558=m
CONFIG_GAMEPORT_L4=m
# CONFIG_GAMEPORT_EMU10K1 is not set
# CONFIG_GAMEPORT_FM801 is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_BRCM_CHAR_DRIVERS=y
CONFIG_BCM2708_VCMEM=y
CONFIG_BCM_VCIO=y
CONFIG_BCM_VC_SM=y
CONFIG_BCM2835_DEVGPIOMEM=y
CONFIG_BCM2835_SMI_DEV=m
CONFIG_RPIVID_MEM=m
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
# CONFIG_LEGACY_PTYS is not set
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_NOZOMI is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
# CONFIG_NULL_TTY is not set
CONFIG_LDISC_AUTOLOAD=y
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
# CONFIG_SERIAL_8250_DMA is not set
CONFIG_SERIAL_8250_PCI=y
CONFIG_SERIAL_8250_EXAR=y
CONFIG_SERIAL_8250_NR_UARTS=1
CONFIG_SERIAL_8250_RUNTIME_UARTS=0
CONFIG_SERIAL_8250_EXTENDED=y
# CONFIG_SERIAL_8250_MANY_PORTS is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_SHARE_IRQ=y
# CONFIG_SERIAL_8250_DETECT_IRQ is not set
# CONFIG_SERIAL_8250_RSA is not set
CONFIG_SERIAL_8250_BCM2835AUX=y
CONFIG_SERIAL_8250_FSL=y
# CONFIG_SERIAL_8250_DW is not set
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_AMBA_PL010 is not set
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_KGDB_NMI is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_CONSOLE_POLL=y
# CONFIG_SERIAL_JSM is not set
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
CONFIG_SERIAL_SC16IS7XX_CORE=m
CONFIG_SERIAL_SC16IS7XX=m
CONFIG_SERIAL_SC16IS7XX_I2C=y
CONFIG_SERIAL_SC16IS7XX_SPI=y
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_RP2 is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
CONFIG_SERIAL_DEV_BUS=m
CONFIG_TTY_PRINTK=y
CONFIG_TTY_PRINTK_LEVEL=6
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
CONFIG_HW_RANDOM_BCM2835=y
CONFIG_HW_RANDOM_IPROC_RNG200=y
# CONFIG_APPLICOM is not set
CONFIG_RAW_DRIVER=y
CONFIG_MAX_RAW_DEVS=256
CONFIG_TCG_TPM=m
CONFIG_HW_RANDOM_TPM=y
CONFIG_TCG_TIS_CORE=m
# CONFIG_TCG_TIS is not set
CONFIG_TCG_TIS_SPI=m
# CONFIG_TCG_TIS_SPI_CR50 is not set
# CONFIG_TCG_TIS_I2C_ATMEL is not set
# CONFIG_TCG_TIS_I2C_INFINEON is not set
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_ATMEL is not set
# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
CONFIG_DEVPORT=y
# CONFIG_XILLYBUS is not set
# end of Character devices
# CONFIG_RANDOM_TRUST_BOOTLOADER is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=m
CONFIG_I2C_MUX=m
# Multiplexer I2C Chip support
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
# CONFIG_I2C_MUX_GPIO is not set
CONFIG_I2C_MUX_GPMUX=m
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
CONFIG_I2C_MUX_PCA954x=m
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
# end of Multiplexer I2C Chip support
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=m
# I2C Hardware Bus support
# PC SMBus host controller drivers
CONFIG_I2C_BCM2708=m
CONFIG_I2C_BCM2708_BAUDRATE=100000
# CONFIG_I2C_ALI1535 is not set
# CONFIG_I2C_ALI1563 is not set
# CONFIG_I2C_ALI15X3 is not set
# CONFIG_I2C_AMD756 is not set
# CONFIG_I2C_AMD8111 is not set
# CONFIG_I2C_I801 is not set
# CONFIG_I2C_ISCH is not set
# CONFIG_I2C_PIIX4 is not set
# CONFIG_I2C_NFORCE2 is not set
# CONFIG_I2C_NVIDIA_GPU is not set
# CONFIG_I2C_SIS5595 is not set
# CONFIG_I2C_SIS630 is not set
# CONFIG_I2C_SIS96X is not set
# CONFIG_I2C_VIA is not set
# CONFIG_I2C_VIAPRO is not set
# I2C system bus drivers (mostly embedded / system-on-chip)
CONFIG_I2C_BCM2835=m
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_DESIGNWARE_PCI is not set
# CONFIG_I2C_EMEV2 is not set
CONFIG_I2C_GPIO=m
# CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
# CONFIG_I2C_NOMADIK is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
CONFIG_I2C_ROBOTFUZZ_OSIF=m
# CONFIG_I2C_TAOS_EVM is not set
CONFIG_I2C_TINY_USB=m
# Other I2C/SMBus bus drivers
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BCM2835=m
CONFIG_SPI_BCM2835AUX=m
# CONFIG_SPI_BCM_QSPI is not set
CONFIG_SPI_BITBANG=m
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
# CONFIG_SPI_NXP_FLEXSPI is not set
CONFIG_SPI_GPIO=m
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_PL022 is not set
# CONFIG_SPI_PXA2XX is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
# CONFIG_SPI_MXIC is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=m
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
CONFIG_SPI_SLAVE=y
# CONFIG_SPI_SLAVE_TIME is not set
# CONFIG_SPI_SLAVE_SYSTEM_CONTROL is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=m
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
CONFIG_PPS_CLIENT_LDISC=m
CONFIG_PPS_CLIENT_GPIO=m
# PPS generators support
# PTP clock support
# CONFIG_PTP_1588_CLOCK is not set
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AMD is not set
CONFIG_PINCTRL_MCP23S08=m
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_OCELOT is not set
CONFIG_PINCTRL_BCM2835=y
# CONFIG_PINCTRL_EQUILIBRIUM is not set
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
# CONFIG_DEBUG_GPIO is not set
# CONFIG_GPIO_SYSFS is not set
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
CONFIG_GPIO_RASPBERRYPI_EXP=y
CONFIG_GPIO_BCM_VIRT=y
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_EXAR is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_PL061 is not set
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
CONFIG_GPIO_PCA953X=m
CONFIG_GPIO_PCF857X=m
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
CONFIG_GPIO_ARIZONA=m
# CONFIG_HTC_EGPIO is not set
CONFIG_GPIO_STMPE=y
# end of MFD GPIO expanders
# PCI GPIO expanders
# CONFIG_GPIO_BT8XX is not set
# CONFIG_GPIO_PCI_IDIO_16 is not set
# CONFIG_GPIO_PCIE_IDIO_24 is not set
# CONFIG_GPIO_RDC321X is not set
# end of PCI GPIO expanders
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# USB GPIO expanders
# end of USB GPIO expanders
CONFIG_GPIO_MOCKUP=m
CONFIG_W1=m
CONFIG_W1_CON=y
# 1-wire Bus Masters
# CONFIG_W1_MASTER_MATROX is not set
CONFIG_W1_MASTER_DS2490=m
CONFIG_W1_MASTER_DS2482=m
CONFIG_W1_MASTER_DS1WM=m
CONFIG_W1_MASTER_GPIO=m
# CONFIG_W1_MASTER_SGI is not set
# end of 1-wire Bus Masters
# 1-wire Slaves
CONFIG_W1_SLAVE_THERM=m
CONFIG_W1_SLAVE_SMEM=m
# CONFIG_W1_SLAVE_DS2405 is not set
CONFIG_W1_SLAVE_DS2408=m
CONFIG_W1_SLAVE_DS2408_READBACK=y
CONFIG_W1_SLAVE_DS2413=m
CONFIG_W1_SLAVE_DS2406=m
CONFIG_W1_SLAVE_DS2423=m
# CONFIG_W1_SLAVE_DS2805 is not set
# CONFIG_W1_SLAVE_DS2430 is not set
CONFIG_W1_SLAVE_DS2431=m
CONFIG_W1_SLAVE_DS2433=m
# CONFIG_W1_SLAVE_DS2433_CRC is not set
CONFIG_W1_SLAVE_DS2438=m
# CONFIG_W1_SLAVE_DS250X is not set
CONFIG_W1_SLAVE_DS2780=m
CONFIG_W1_SLAVE_DS2781=m
CONFIG_W1_SLAVE_DS28E04=m
CONFIG_W1_SLAVE_DS28E17=m
# end of 1-wire Slaves
# CONFIG_POWER_AVS is not set
CONFIG_POWER_RESET=y
# CONFIG_POWER_RESET_BRCMKONA is not set
# CONFIG_POWER_RESET_BRCMSTB is not set
CONFIG_POWER_RESET_GPIO=y
# CONFIG_POWER_RESET_GPIO_RESTART is not set
# CONFIG_POWER_RESET_LTC2952 is not set
# CONFIG_POWER_RESET_RESTART is not set
# CONFIG_POWER_RESET_VERSATILE is not set
# CONFIG_POWER_RESET_SYSCON is not set
# CONFIG_POWER_RESET_SYSCON_POWEROFF is not set
# CONFIG_SYSCON_REBOOT_MODE is not set
# CONFIG_NVMEM_REBOOT_MODE is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_GENERIC_ADC_BATTERY is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
CONFIG_BATTERY_DS2760=m
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_LEGO_EV3 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
CONFIG_BATTERY_MAX17040=m
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_BATTERY_MAX1721X is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
CONFIG_BATTERY_GAUGE_LTC2941=m
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_UCS1002 is not set
CONFIG_HWMON=m
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_AS370 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ASPEED is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS620 is not set
CONFIG_SENSORS_DS1621=m
# CONFIG_SENSORS_I5K_AMB is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
CONFIG_SENSORS_GPIO_FAN=m
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IIO_HWMON is not set
# CONFIG_SENSORS_IT87 is not set
CONFIG_SENSORS_JC42=m
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2947_I2C is not set
# CONFIG_SENSORS_LTC2947_SPI is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31722 is not set
# CONFIG_SENSORS_MAX6621 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
CONFIG_SENSORS_LM75=m
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_NPCM7XX is not set
# CONFIG_SENSORS_OCC_P8_I2C is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
# CONFIG_SENSORS_PWM_FAN is not set
CONFIG_SENSORS_RASPBERRYPI_HWMON=m
CONFIG_SENSORS_RPI_POE_FAN=m
# CONFIG_SENSORS_SHT15 is not set
CONFIG_SENSORS_SHT21=m
CONFIG_SENSORS_SHT3x=m
CONFIG_SENSORS_SHTC1=m
# CONFIG_SENSORS_SIS5595 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
CONFIG_SENSORS_INA2XX=m
# CONFIG_SENSORS_INA3221 is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
CONFIG_SENSORS_TMP102=m
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_TMP513 is not set
# CONFIG_SENSORS_VIA686A is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_VT8231 is not set
# CONFIG_SENSORS_W83773G is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
# CONFIG_THERMAL_STATISTICS is not set
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_CPU_THERMAL is not set
# CONFIG_CLOCK_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_THERMAL_MMIO is not set
# CONFIG_QORIQ_THERMAL is not set
# Broadcom thermal drivers
CONFIG_BCM2835_THERMAL=y
CONFIG_BRCMSTB_THERMAL=y
# end of Broadcom thermal drivers
# CONFIG_GENERIC_ADC_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
# CONFIG_WATCHDOG_SYSFS is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
CONFIG_GPIO_WATCHDOG=m
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_ARM_SP805_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_FTWDT010_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_ALIM7101_WDT is not set
# CONFIG_I6300ESB_WDT is not set
CONFIG_BCM2835_WDT=y
# CONFIG_MEN_A21_WDT is not set
# PCI-based Watchdog Cards
# CONFIG_PCIPCWATCHDOG is not set
# CONFIG_WDTPCI is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
CONFIG_SSB=m
CONFIG_SSB_SPROM=y
CONFIG_SSB_BLOCKIO=y
CONFIG_SSB_PCIHOST_POSSIBLE=y
CONFIG_SSB_PCIHOST=y
CONFIG_SSB_B43_PCI_BRIDGE=y
CONFIG_SSB_SDIOHOST_POSSIBLE=y
# CONFIG_SSB_SDIOHOST is not set
CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
CONFIG_SSB_DRIVER_PCICORE=y
# CONFIG_SSB_DRIVER_GPIO is not set
CONFIG_BCMA_POSSIBLE=y
CONFIG_BCMA=m
CONFIG_BCMA_BLOCKIO=y
CONFIG_BCMA_HOST_PCI_POSSIBLE=y
CONFIG_BCMA_HOST_PCI=y
# CONFIG_BCMA_HOST_SOC is not set
CONFIG_BCMA_DRIVER_PCI=y
# CONFIG_BCMA_DRIVER_GMAC_CMN is not set
# CONFIG_BCMA_DRIVER_GPIO is not set
# CONFIG_BCMA_DEBUG is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
CONFIG_MFD_RPISENSE_CORE=m
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AXP20X_I2C is not set
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_LPC_ICH is not set
# CONFIG_LPC_SCH is not set
# CONFIG_MFD_JANZ_CMODIO is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RDC321X is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
CONFIG_MFD_STMPE=y
# STMicroelectronics STMPE Interface Drivers
CONFIG_STMPE_I2C=y
CONFIG_STMPE_SPI=y
# end of STMicroelectronics STMPE Interface Drivers
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
CONFIG_MFD_WL1273_CORE=m
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_VX855 is not set
# CONFIG_MFD_LOCHNAGAR is not set
CONFIG_MFD_ARIZONA=y
CONFIG_MFD_ARIZONA_I2C=m
CONFIG_MFD_ARIZONA_SPI=m
# CONFIG_MFD_CS47L24 is not set
CONFIG_MFD_WM5102=y
# CONFIG_MFD_WM5110 is not set
# CONFIG_MFD_WM8997 is not set
# CONFIG_MFD_WM8998 is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_ROHM_BD70528 is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# CONFIG_RAVE_SP_CORE is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=m
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
CONFIG_REGULATOR_ARIZONA_LDO1=m
CONFIG_REGULATOR_ARIZONA_MICSUPP=m
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_SLG51000 is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_SY8824X is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
CONFIG_RC_CORE=y
CONFIG_RC_MAP=y
CONFIG_LIRC=y
# CONFIG_BPF_LIRC_MODE2 is not set
CONFIG_RC_DECODERS=y
CONFIG_IR_NEC_DECODER=m
CONFIG_IR_RC5_DECODER=m
CONFIG_IR_RC6_DECODER=m
CONFIG_IR_JVC_DECODER=m
CONFIG_IR_SONY_DECODER=m
CONFIG_IR_SANYO_DECODER=m
CONFIG_IR_SHARP_DECODER=m
CONFIG_IR_MCE_KBD_DECODER=m
CONFIG_IR_XMP_DECODER=m
CONFIG_IR_IMON_DECODER=m
# CONFIG_IR_RCMM_DECODER is not set
CONFIG_RC_DEVICES=y
CONFIG_RC_ATI_REMOTE=m
# CONFIG_IR_HIX5HD2 is not set
CONFIG_IR_IMON=m
# CONFIG_IR_IMON_RAW is not set
CONFIG_IR_MCEUSB=m
CONFIG_IR_REDRAT3=m
# CONFIG_IR_SPI is not set
CONFIG_IR_STREAMZAP=m
# CONFIG_IR_IGORPLUGUSB is not set
CONFIG_IR_IGUANA=m
CONFIG_IR_TTUSBIR=m
CONFIG_RC_LOOPBACK=m
CONFIG_IR_GPIO_CIR=m
CONFIG_IR_GPIO_TX=m
CONFIG_IR_PWM_TX=m
# CONFIG_IR_SERIAL is not set
# CONFIG_IR_SIR is not set
# CONFIG_RC_XBOX_DVD is not set
CONFIG_MEDIA_SUPPORT=m
# Multimedia core support
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_RADIO_SUPPORT=y
# CONFIG_MEDIA_SDR_SUPPORT is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
CONFIG_MEDIA_CONTROLLER=y
CONFIG_MEDIA_CONTROLLER_DVB=y
# CONFIG_MEDIA_CONTROLLER_REQUEST_API is not set
CONFIG_VIDEO_DEV=m
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_VIDEO_V4L2=m
CONFIG_VIDEO_V4L2_I2C=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_VIDEO_TUNER=m
CONFIG_V4L2_MEM2MEM_DEV=m
CONFIG_V4L2_FWNODE=m
CONFIG_VIDEOBUF_GEN=m
CONFIG_VIDEOBUF_VMALLOC=m
CONFIG_DVB_CORE=m
# CONFIG_DVB_MMAP is not set
CONFIG_DVB_NET=y
CONFIG_TTPCI_EEPROM=m
CONFIG_DVB_MAX_ADAPTERS=16
# CONFIG_DVB_DYNAMIC_MINORS is not set
# CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
# CONFIG_DVB_ULE_DEBUG is not set
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_USB_M5602=m
CONFIG_USB_STV06XX=m
CONFIG_USB_GL860=m
CONFIG_USB_GSPCA_BENQ=m
CONFIG_USB_GSPCA_CONEX=m
CONFIG_USB_GSPCA_CPIA1=m
CONFIG_USB_GSPCA_DTCS033=m
CONFIG_USB_GSPCA_ETOMS=m
CONFIG_USB_GSPCA_FINEPIX=m
CONFIG_USB_GSPCA_JEILINJ=m
CONFIG_USB_GSPCA_JL2005BCD=m
CONFIG_USB_GSPCA_KINECT=m
CONFIG_USB_GSPCA_KONICA=m
CONFIG_USB_GSPCA_MARS=m
CONFIG_USB_GSPCA_MR97310A=m
CONFIG_USB_GSPCA_NW80X=m
CONFIG_USB_GSPCA_OV519=m
CONFIG_USB_GSPCA_OV534=m
CONFIG_USB_GSPCA_OV534_9=m
CONFIG_USB_GSPCA_PAC207=m
CONFIG_USB_GSPCA_PAC7302=m
CONFIG_USB_GSPCA_PAC7311=m
CONFIG_USB_GSPCA_SE401=m
CONFIG_USB_GSPCA_SN9C2028=m
CONFIG_USB_GSPCA_SN9C20X=m
CONFIG_USB_GSPCA_SONIXB=m
CONFIG_USB_GSPCA_SONIXJ=m
CONFIG_USB_GSPCA_SPCA500=m
CONFIG_USB_GSPCA_SPCA501=m
CONFIG_USB_GSPCA_SPCA505=m
CONFIG_USB_GSPCA_SPCA506=m
CONFIG_USB_GSPCA_SPCA508=m
CONFIG_USB_GSPCA_SPCA561=m
CONFIG_USB_GSPCA_SPCA1528=m
CONFIG_USB_GSPCA_SQ905=m
CONFIG_USB_GSPCA_SQ905C=m
CONFIG_USB_GSPCA_SQ930X=m
CONFIG_USB_GSPCA_STK014=m
CONFIG_USB_GSPCA_STK1135=m
CONFIG_USB_GSPCA_STV0680=m
CONFIG_USB_GSPCA_SUNPLUS=m
CONFIG_USB_GSPCA_T613=m
CONFIG_USB_GSPCA_TOPRO=m
# CONFIG_USB_GSPCA_TOUPTEK is not set
CONFIG_USB_GSPCA_TV8532=m
CONFIG_USB_GSPCA_VC032X=m
CONFIG_USB_GSPCA_VICAM=m
CONFIG_USB_GSPCA_XIRLINK_CIT=m
CONFIG_USB_GSPCA_ZC3XX=m
CONFIG_USB_PWC=m
# CONFIG_USB_PWC_DEBUG is not set
CONFIG_USB_PWC_INPUT_EVDEV=y
CONFIG_VIDEO_CPIA2=m
CONFIG_USB_ZR364XX=m
CONFIG_USB_STKWEBCAM=m
CONFIG_USB_S2255=m
CONFIG_VIDEO_USBTV=m
# Analog TV USB devices
CONFIG_VIDEO_PVRUSB2=m
CONFIG_VIDEO_PVRUSB2_SYSFS=y
CONFIG_VIDEO_PVRUSB2_DVB=y
# CONFIG_VIDEO_PVRUSB2_DEBUGIFC is not set
CONFIG_VIDEO_HDPVR=m
CONFIG_VIDEO_USBVISION=m
CONFIG_VIDEO_STK1160_COMMON=m
CONFIG_VIDEO_STK1160=m
CONFIG_VIDEO_GO7007=m
CONFIG_VIDEO_GO7007_USB=m
CONFIG_VIDEO_GO7007_LOADER=m
CONFIG_VIDEO_GO7007_USB_S2250_BOARD=m
# Analog/digital TV USB devices
CONFIG_VIDEO_AU0828=m
CONFIG_VIDEO_AU0828_V4L2=y
CONFIG_VIDEO_AU0828_RC=y
CONFIG_VIDEO_CX231XX=m
CONFIG_VIDEO_CX231XX_RC=y
CONFIG_VIDEO_CX231XX_ALSA=m
CONFIG_VIDEO_CX231XX_DVB=m
CONFIG_VIDEO_TM6000=m
CONFIG_VIDEO_TM6000_ALSA=m
CONFIG_VIDEO_TM6000_DVB=m
# Digital TV USB devices
CONFIG_DVB_USB=m
# CONFIG_DVB_USB_DEBUG is not set
CONFIG_DVB_USB_DIB3000MC=m
CONFIG_DVB_USB_A800=m
CONFIG_DVB_USB_DIBUSB_MB=m
CONFIG_DVB_USB_DIBUSB_MB_FAULTY=y
CONFIG_DVB_USB_DIBUSB_MC=m
CONFIG_DVB_USB_DIB0700=m
CONFIG_DVB_USB_UMT_010=m
CONFIG_DVB_USB_CXUSB=m
# CONFIG_DVB_USB_CXUSB_ANALOG is not set
CONFIG_DVB_USB_M920X=m
CONFIG_DVB_USB_DIGITV=m
CONFIG_DVB_USB_VP7045=m
CONFIG_DVB_USB_VP702X=m
CONFIG_DVB_USB_GP8PSK=m
CONFIG_DVB_USB_NOVA_T_USB2=m
CONFIG_DVB_USB_TTUSB2=m
CONFIG_DVB_USB_DTT200U=m
CONFIG_DVB_USB_OPERA1=m
CONFIG_DVB_USB_AF9005=m
CONFIG_DVB_USB_AF9005_REMOTE=m
CONFIG_DVB_USB_PCTV452E=m
CONFIG_DVB_USB_DW2102=m
CONFIG_DVB_USB_CINERGY_T2=m
CONFIG_DVB_USB_DTV5100=m
CONFIG_DVB_USB_AZ6027=m
CONFIG_DVB_USB_TECHNISAT_USB2=m
CONFIG_DVB_USB_V2=m
CONFIG_DVB_USB_AF9015=m
CONFIG_DVB_USB_AF9035=m
CONFIG_DVB_USB_ANYSEE=m
CONFIG_DVB_USB_AU6610=m
CONFIG_DVB_USB_AZ6007=m
CONFIG_DVB_USB_CE6230=m
CONFIG_DVB_USB_EC168=m
CONFIG_DVB_USB_GL861=m
CONFIG_DVB_USB_LME2510=m
CONFIG_DVB_USB_MXL111SF=m
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_USB_DVBSKY=m
# CONFIG_DVB_USB_ZD1301 is not set
# CONFIG_DVB_TTUSB_BUDGET is not set
# CONFIG_DVB_TTUSB_DEC is not set
CONFIG_SMS_USB_DRV=m
CONFIG_DVB_B2C2_FLEXCOP_USB=m
# CONFIG_DVB_B2C2_FLEXCOP_USB_DEBUG is not set
CONFIG_DVB_AS102=m
# Webcam, TV (analog/digital) USB devices
CONFIG_VIDEO_EM28XX=m
CONFIG_VIDEO_EM28XX_V4L2=m
CONFIG_VIDEO_EM28XX_ALSA=m
CONFIG_VIDEO_EM28XX_DVB=m
CONFIG_VIDEO_EM28XX_RC=m
# CONFIG_MEDIA_PCI_SUPPORT is not set
CONFIG_V4L_PLATFORM_DRIVERS=y
# CONFIG_VIDEO_CAFE_CCIC is not set
# CONFIG_VIDEO_CADENCE is not set
# CONFIG_VIDEO_ASPEED is not set
# CONFIG_VIDEO_MUX is not set
# CONFIG_VIDEO_XILINX is not set
# CONFIG_V4L_MEM2MEM_DRIVERS is not set
# CONFIG_V4L_TEST_DRIVERS is not set
# CONFIG_DVB_PLATFORM_DRIVERS is not set
# Supported MMC/SDIO adapters
# CONFIG_SMS_SDIO_DRV is not set
CONFIG_RADIO_ADAPTERS=y
CONFIG_RADIO_TEA575X=m
CONFIG_RADIO_SI470X=m
CONFIG_USB_SI470X=m
CONFIG_I2C_SI470X=m
CONFIG_RADIO_SI4713=m
# CONFIG_USB_SI4713 is not set
# CONFIG_PLATFORM_SI4713 is not set
CONFIG_I2C_SI4713=m
CONFIG_USB_MR800=m
CONFIG_USB_DSBR=m
# CONFIG_RADIO_MAXIRADIO is not set
CONFIG_RADIO_SHARK=m
CONFIG_RADIO_SHARK2=m
CONFIG_USB_KEENE=m
# CONFIG_USB_RAREMONO is not set
CONFIG_USB_MA901=m
CONFIG_RADIO_TEA5764=m
CONFIG_RADIO_SAA7706H=m
CONFIG_RADIO_TEF6862=m
CONFIG_RADIO_WL1273=m
# Texas Instruments WL128x FM driver (ST based)
CONFIG_RADIO_WL128X=m
# end of Texas Instruments WL128x FM driver (ST based)
CONFIG_MEDIA_COMMON_OPTIONS=y
# common driver options
CONFIG_VIDEO_CX2341X=m
CONFIG_VIDEO_TVEEPROM=m
CONFIG_CYPRESS_FIRMWARE=m
CONFIG_VIDEOBUF2_CORE=m
CONFIG_VIDEOBUF2_V4L2=m
CONFIG_VIDEOBUF2_MEMOPS=m
CONFIG_VIDEOBUF2_DMA_CONTIG=m
CONFIG_VIDEOBUF2_VMALLOC=m
CONFIG_DVB_B2C2_FLEXCOP=m
CONFIG_SMS_SIANO_MDTV=m
CONFIG_SMS_SIANO_RC=y
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
# CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
CONFIG_MEDIA_ATTACH=y
CONFIG_VIDEO_IR_I2C=m
# I2C Encoders, decoders, sensors and other helper chips
# Audio decoders, processors and mixers
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TDA1997X is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
CONFIG_VIDEO_MSP3400=m
# CONFIG_VIDEO_CS3308 is not set
# CONFIG_VIDEO_CS5345 is not set
CONFIG_VIDEO_CS53L32A=m
# CONFIG_VIDEO_TLV320AIC23B is not set
CONFIG_VIDEO_UDA1342=m
CONFIG_VIDEO_WM8775=m
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_VP27SMPX is not set
CONFIG_VIDEO_SONY_BTF_MPX=m
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# Video decoders
CONFIG_VIDEO_ADV7180=m
# CONFIG_VIDEO_ADV7183 is not set
# CONFIG_VIDEO_ADV748X is not set
# CONFIG_VIDEO_ADV7604 is not set
# CONFIG_VIDEO_ADV7842 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_ML86V7667 is not set
# CONFIG_VIDEO_SAA7110 is not set
CONFIG_VIDEO_SAA711X=m
CONFIG_VIDEO_TC358743=m
# CONFIG_VIDEO_TC358743_CEC is not set
# CONFIG_VIDEO_TVP514X is not set
CONFIG_VIDEO_TVP5150=m
# CONFIG_VIDEO_TVP7002 is not set
CONFIG_VIDEO_TW2804=m
CONFIG_VIDEO_TW9903=m
CONFIG_VIDEO_TW9906=m
# CONFIG_VIDEO_TW9910 is not set
# CONFIG_VIDEO_VPX3220 is not set
# Video and audio decoders
# CONFIG_VIDEO_SAA717X is not set
CONFIG_VIDEO_CX25840=m
# Video encoders
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_ADV7393 is not set
# CONFIG_VIDEO_ADV7511 is not set
# CONFIG_VIDEO_AD9389B is not set
# CONFIG_VIDEO_AK881X is not set
# CONFIG_VIDEO_THS8200 is not set
# Camera sensor devices
# CONFIG_VIDEO_HI556 is not set
# CONFIG_VIDEO_IMX214 is not set
CONFIG_VIDEO_IMX219=m
# CONFIG_VIDEO_IMX258 is not set
# CONFIG_VIDEO_IMX274 is not set
# CONFIG_VIDEO_IMX290 is not set
# CONFIG_VIDEO_IMX319 is not set
# CONFIG_VIDEO_IMX355 is not set
# CONFIG_VIDEO_OV2640 is not set
# CONFIG_VIDEO_OV2659 is not set
# CONFIG_VIDEO_OV2680 is not set
# CONFIG_VIDEO_OV2685 is not set
# CONFIG_VIDEO_OV5640 is not set
# CONFIG_VIDEO_OV5645 is not set
CONFIG_VIDEO_OV5647=m
# CONFIG_VIDEO_OV6650 is not set
# CONFIG_VIDEO_OV5670 is not set
# CONFIG_VIDEO_OV5675 is not set
# CONFIG_VIDEO_OV5695 is not set
# CONFIG_VIDEO_OV7251 is not set
# CONFIG_VIDEO_OV772X is not set
CONFIG_VIDEO_OV7640=m
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_OV7740 is not set
# CONFIG_VIDEO_OV8856 is not set
# CONFIG_VIDEO_OV9640 is not set
# CONFIG_VIDEO_OV9650 is not set
# CONFIG_VIDEO_OV13858 is not set
CONFIG_VIDEO_IRS1125=m
# CONFIG_VIDEO_VS6624 is not set
# CONFIG_VIDEO_MT9M001 is not set
# CONFIG_VIDEO_MT9M032 is not set
# CONFIG_VIDEO_MT9M111 is not set
# CONFIG_VIDEO_MT9P031 is not set
# CONFIG_VIDEO_MT9T001 is not set
# CONFIG_VIDEO_MT9T112 is not set
CONFIG_VIDEO_MT9V011=m
# CONFIG_VIDEO_MT9V032 is not set
# CONFIG_VIDEO_MT9V111 is not set
# CONFIG_VIDEO_SR030PC30 is not set
# CONFIG_VIDEO_NOON010PC30 is not set
# CONFIG_VIDEO_M5MOLS is not set
# CONFIG_VIDEO_RJ54N1 is not set
# CONFIG_VIDEO_S5K6AA is not set
# CONFIG_VIDEO_S5K6A3 is not set
# CONFIG_VIDEO_S5K4ECGX is not set
# CONFIG_VIDEO_S5K5BAF is not set
# CONFIG_VIDEO_SMIAPP is not set
# CONFIG_VIDEO_ET8EK8 is not set
# CONFIG_VIDEO_S5C73M3 is not set
# Lens drivers
# CONFIG_VIDEO_AD5820 is not set
# CONFIG_VIDEO_AK7375 is not set
# CONFIG_VIDEO_DW9714 is not set
# CONFIG_VIDEO_DW9807_VCM is not set
# Flash devices
# CONFIG_VIDEO_ADP1653 is not set
# CONFIG_VIDEO_LM3560 is not set
# CONFIG_VIDEO_LM3646 is not set
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# Audio/Video compression chips
# CONFIG_VIDEO_SAA6752HS is not set
# SDR tuner chips
# Miscellaneous helper chips
# CONFIG_VIDEO_THS7303 is not set
# CONFIG_VIDEO_M52790 is not set
# CONFIG_VIDEO_I2C is not set
# CONFIG_VIDEO_ST_MIPID02 is not set
# end of I2C Encoders, decoders, sensors and other helper chips
# SPI helper chips
# CONFIG_VIDEO_GS1662 is not set
# end of SPI helper chips
# Media SPI Adapters
CONFIG_CXD2880_SPI_DRV=m
# end of Media SPI Adapters
CONFIG_MEDIA_TUNER=m
# Customize TV tuners
CONFIG_MEDIA_TUNER_SIMPLE=m
CONFIG_MEDIA_TUNER_TDA18250=m
CONFIG_MEDIA_TUNER_TDA8290=m
CONFIG_MEDIA_TUNER_TDA827X=m
CONFIG_MEDIA_TUNER_TDA18271=m
CONFIG_MEDIA_TUNER_TDA9887=m
CONFIG_MEDIA_TUNER_TEA5761=m
CONFIG_MEDIA_TUNER_TEA5767=m
CONFIG_MEDIA_TUNER_MSI001=m
CONFIG_MEDIA_TUNER_MT20XX=m
CONFIG_MEDIA_TUNER_MT2060=m
CONFIG_MEDIA_TUNER_MT2063=m
CONFIG_MEDIA_TUNER_MT2266=m
CONFIG_MEDIA_TUNER_MT2131=m
CONFIG_MEDIA_TUNER_QT1010=m
CONFIG_MEDIA_TUNER_XC2028=m
CONFIG_MEDIA_TUNER_XC5000=m
CONFIG_MEDIA_TUNER_XC4000=m
CONFIG_MEDIA_TUNER_MXL5005S=m
CONFIG_MEDIA_TUNER_MXL5007T=m
CONFIG_MEDIA_TUNER_MC44S803=m
CONFIG_MEDIA_TUNER_MAX2165=m
CONFIG_MEDIA_TUNER_TDA18218=m
CONFIG_MEDIA_TUNER_FC0011=m
CONFIG_MEDIA_TUNER_FC0012=m
CONFIG_MEDIA_TUNER_FC0013=m
CONFIG_MEDIA_TUNER_TDA18212=m
CONFIG_MEDIA_TUNER_E4000=m
CONFIG_MEDIA_TUNER_FC2580=m
CONFIG_MEDIA_TUNER_M88RS6000T=m
CONFIG_MEDIA_TUNER_TUA9001=m
CONFIG_MEDIA_TUNER_SI2157=m
CONFIG_MEDIA_TUNER_IT913X=m
CONFIG_MEDIA_TUNER_R820T=m
CONFIG_MEDIA_TUNER_MXL301RF=m
CONFIG_MEDIA_TUNER_QM1D1C0042=m
CONFIG_MEDIA_TUNER_QM1D1B0004=m
# end of Customize TV tuners
# Customise DVB Frontends
# Multistandard (satellite) frontends
CONFIG_DVB_STB0899=m
CONFIG_DVB_STB6100=m
CONFIG_DVB_STV090x=m
CONFIG_DVB_STV0910=m
CONFIG_DVB_STV6110x=m
CONFIG_DVB_STV6111=m
CONFIG_DVB_MXL5XX=m
CONFIG_DVB_M88DS3103=m
# Multistandard (cable + terrestrial) frontends
CONFIG_DVB_DRXK=m
CONFIG_DVB_TDA18271C2DD=m
CONFIG_DVB_SI2165=m
CONFIG_DVB_MN88472=m
CONFIG_DVB_MN88473=m
# DVB-S (satellite) frontends
CONFIG_DVB_CX24110=m
CONFIG_DVB_CX24123=m
CONFIG_DVB_MT312=m
CONFIG_DVB_ZL10036=m
CONFIG_DVB_ZL10039=m
CONFIG_DVB_S5H1420=m
CONFIG_DVB_STV0288=m
CONFIG_DVB_STB6000=m
CONFIG_DVB_STV0299=m
CONFIG_DVB_STV6110=m
CONFIG_DVB_STV0900=m
CONFIG_DVB_TDA8083=m
CONFIG_DVB_TDA10086=m
CONFIG_DVB_TDA8261=m
CONFIG_DVB_VES1X93=m
CONFIG_DVB_TUNER_ITD1000=m
CONFIG_DVB_TUNER_CX24113=m
CONFIG_DVB_TDA826X=m
CONFIG_DVB_TUA6100=m
CONFIG_DVB_CX24116=m
CONFIG_DVB_CX24117=m
CONFIG_DVB_CX24120=m
CONFIG_DVB_SI21XX=m
CONFIG_DVB_TS2020=m
CONFIG_DVB_DS3000=m
CONFIG_DVB_MB86A16=m
CONFIG_DVB_TDA10071=m
# DVB-T (terrestrial) frontends
CONFIG_DVB_SP8870=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_CX22700=m
CONFIG_DVB_CX22702=m
CONFIG_DVB_S5H1432=m
CONFIG_DVB_DRXD=m
CONFIG_DVB_L64781=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_NXT6000=m
CONFIG_DVB_MT352=m
CONFIG_DVB_ZL10353=m
CONFIG_DVB_DIB3000MB=m
CONFIG_DVB_DIB3000MC=m
CONFIG_DVB_DIB7000M=m
CONFIG_DVB_DIB7000P=m
CONFIG_DVB_DIB9000=m
CONFIG_DVB_TDA10048=m
CONFIG_DVB_AF9013=m
CONFIG_DVB_EC100=m
CONFIG_DVB_STV0367=m
CONFIG_DVB_CXD2820R=m
CONFIG_DVB_CXD2841ER=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_SI2168=m
CONFIG_DVB_AS102_FE=m
CONFIG_DVB_ZD1301_DEMOD=m
CONFIG_DVB_GP8PSK_FE=m
CONFIG_DVB_CXD2880=m
# DVB-C (cable) frontends
CONFIG_DVB_VES1820=m
CONFIG_DVB_TDA10021=m
CONFIG_DVB_TDA10023=m
CONFIG_DVB_STV0297=m
# ATSC (North American/Korean Terrestrial/Cable DTV) frontends
CONFIG_DVB_NXT200X=m
CONFIG_DVB_OR51211=m
CONFIG_DVB_OR51132=m
CONFIG_DVB_BCM3510=m
CONFIG_DVB_LGDT330X=m
CONFIG_DVB_LGDT3305=m
CONFIG_DVB_LGDT3306A=m
CONFIG_DVB_LG2160=m
CONFIG_DVB_S5H1409=m
CONFIG_DVB_AU8522=m
CONFIG_DVB_AU8522_DTV=m
CONFIG_DVB_AU8522_V4L=m
CONFIG_DVB_S5H1411=m
# ISDB-T (terrestrial) frontends
CONFIG_DVB_S921=m
CONFIG_DVB_DIB8000=m
CONFIG_DVB_MB86A20S=m
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
CONFIG_DVB_TC90522=m
CONFIG_DVB_MN88443X=m
# Digital terrestrial only tuners/PLL
CONFIG_DVB_PLL=m
CONFIG_DVB_TUNER_DIB0070=m
CONFIG_DVB_TUNER_DIB0090=m
# SEC control devices for DVB-S
CONFIG_DVB_DRX39XYJ=m
CONFIG_DVB_LNBH25=m
CONFIG_DVB_LNBH29=m
CONFIG_DVB_LNBP21=m
CONFIG_DVB_LNBP22=m
CONFIG_DVB_ISL6405=m
CONFIG_DVB_ISL6421=m
CONFIG_DVB_ISL6423=m
CONFIG_DVB_A8293=m
CONFIG_DVB_LGS8GL5=m
CONFIG_DVB_LGS8GXX=m
CONFIG_DVB_ATBM8830=m
CONFIG_DVB_TDA665x=m
CONFIG_DVB_IX2505V=m
CONFIG_DVB_M88RS2000=m
CONFIG_DVB_AF9033=m
CONFIG_DVB_HORUS3A=m
CONFIG_DVB_ASCOT2E=m
CONFIG_DVB_HELENE=m
# Common Interface (EN50221) controller drivers
CONFIG_DVB_CXD2099=m
CONFIG_DVB_SP2=m
# Tools to develop new frontends
# CONFIG_DVB_DUMMY_FE is not set
# end of Customise DVB Frontends
# Graphics support
CONFIG_VGA_ARB=y
CONFIG_VGA_ARB_MAX_GPUS=16
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=m
CONFIG_DRM_MIPI_DBI=m
CONFIG_DRM_MIPI_DSI=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=m
CONFIG_DRM_KMS_FB_HELPER=y
# CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
CONFIG_DRM_GEM_SHMEM_HELPER=y
CONFIG_DRM_SCHED=m
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# CONFIG_DRM_KOMEDA is not set
# end of ARM devices
# CONFIG_DRM_RADEON is not set
# CONFIG_DRM_AMDGPU is not set
# ACP (Audio CoProcessor) Configuration
# end of ACP (Audio CoProcessor) Configuration
# CONFIG_DRM_NOUVEAU is not set
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_EXYNOS is not set
CONFIG_DRM_UDL=m
# CONFIG_DRM_AST is not set
# CONFIG_DRM_MGAG200 is not set
# CONFIG_DRM_CIRRUS_QEMU is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_QXL is not set
# CONFIG_DRM_BOCHS is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=m
# CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LB035Q02 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
# CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN=m
# CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
# CONFIG_DRM_PANEL_ROCKTECH_JH057N00900 is not set
# CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
# CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
# CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
# CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
# CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
# CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
# CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_CDNS_DSI is not set
# CONFIG_DRM_DUMB_VGA_DAC is not set
# CONFIG_DRM_LVDS_ENCODER is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_SII9234 is not set
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_TI_SN65DSI86 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# end of Display Interface Bridges
# CONFIG_DRM_STI is not set
CONFIG_DRM_V3D=m
CONFIG_DRM_VC4=m
# CONFIG_DRM_VC4_HDMI_CEC is not set
# CONFIG_DRM_ETNAVIV is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
# CONFIG_DRM_GM12U320 is not set
# CONFIG_TINYDRM_HX8357D is not set
CONFIG_TINYDRM_ILI9225=m
CONFIG_TINYDRM_ILI9341=m
CONFIG_TINYDRM_MI0283QT=m
CONFIG_TINYDRM_REPAPER=m
CONFIG_TINYDRM_ST7586=m
CONFIG_TINYDRM_ST7735R=m
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_TVE200 is not set
# CONFIG_DRM_LIMA is not set
# CONFIG_DRM_PANFROST is not set
# CONFIG_DRM_MCDE is not set
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SYS_FILLRECT=m
CONFIG_FB_SYS_COPYAREA=m
CONFIG_FB_SYS_IMAGEBLIT=m
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=m
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_BACKLIGHT=m
CONFIG_FB_MODE_HELPERS=y
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
CONFIG_FB_BCM2708=y
# CONFIG_FB_CIRRUS is not set
# CONFIG_FB_PM2 is not set
# CONFIG_FB_ARMCLCD is not set
# CONFIG_FB_CYBER2000 is not set
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
# CONFIG_FB_UVESA is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_NVIDIA is not set
# CONFIG_FB_RIVA is not set
# CONFIG_FB_I740 is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_S3 is not set
# CONFIG_FB_SAVAGE is not set
# CONFIG_FB_SIS is not set
# CONFIG_FB_NEOMAGIC is not set
# CONFIG_FB_KYRO is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_VT8623 is not set
# CONFIG_FB_TRIDENT is not set
# CONFIG_FB_ARK is not set
# CONFIG_FB_PM3 is not set
# CONFIG_FB_CARMINE is not set
# CONFIG_FB_SMSCUFX is not set
CONFIG_FB_UDL=m
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX is not set
CONFIG_FB_SIMPLE=y
CONFIG_FB_SSD1307=m
# CONFIG_FB_SM712 is not set
CONFIG_FB_RPISENSE=m
# end of Frame buffer Devices
# Backlight & LCD device support
# CONFIG_LCD_CLASS_DEVICE is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=m
# CONFIG_BACKLIGHT_GENERIC is not set
# CONFIG_BACKLIGHT_PWM is not set
CONFIG_BACKLIGHT_RPI=m
# CONFIG_BACKLIGHT_QCOM_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
CONFIG_BACKLIGHT_GPIO=m
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
# end of Console display driver support
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
CONFIG_LOGO_LINUX_CLUT224=y
# end of Graphics support
CONFIG_SOUND=y
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_PCM_ELD=y
CONFIG_SND_DMAENGINE_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_SEQ_DEVICE=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_COMPRESS_OFFLOAD=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
# CONFIG_SND_OSSEMUL is not set
CONFIG_SND_PCM_TIMER=y
CONFIG_SND_HRTIMER=m
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
CONFIG_SND_VMASTER=y
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
CONFIG_SND_SEQ_MIDI_EVENT=m
CONFIG_SND_SEQ_MIDI=m
CONFIG_SND_SEQ_VIRMIDI=m
CONFIG_SND_MPU401_UART=m
CONFIG_SND_DRIVERS=y
CONFIG_SND_DUMMY=m
CONFIG_SND_ALOOP=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
CONFIG_SND_PCI=y
# CONFIG_SND_AD1889 is not set
# CONFIG_SND_ALS300 is not set
# CONFIG_SND_ALI5451 is not set
# CONFIG_SND_ATIIXP is not set
# CONFIG_SND_ATIIXP_MODEM is not set
# CONFIG_SND_AU8810 is not set
# CONFIG_SND_AU8820 is not set
# CONFIG_SND_AU8830 is not set
# CONFIG_SND_AW2 is not set
# CONFIG_SND_AZT3328 is not set
# CONFIG_SND_BT87X is not set
# CONFIG_SND_CA0106 is not set
# CONFIG_SND_CMIPCI is not set
# CONFIG_SND_OXYGEN is not set
# CONFIG_SND_CS4281 is not set
# CONFIG_SND_CS46XX is not set
# CONFIG_SND_CTXFI is not set
# CONFIG_SND_DARLA20 is not set
# CONFIG_SND_GINA20 is not set
# CONFIG_SND_LAYLA20 is not set
# CONFIG_SND_DARLA24 is not set
# CONFIG_SND_GINA24 is not set
# CONFIG_SND_LAYLA24 is not set
# CONFIG_SND_MONA is not set
# CONFIG_SND_MIA is not set
# CONFIG_SND_ECHO3G is not set
# CONFIG_SND_INDIGO is not set
# CONFIG_SND_INDIGOIO is not set
# CONFIG_SND_INDIGODJ is not set
# CONFIG_SND_INDIGOIOX is not set
# CONFIG_SND_INDIGODJX is not set
# CONFIG_SND_EMU10K1 is not set
# CONFIG_SND_EMU10K1X is not set
# CONFIG_SND_ENS1370 is not set
# CONFIG_SND_ENS1371 is not set
# CONFIG_SND_ES1938 is not set
# CONFIG_SND_ES1968 is not set
# CONFIG_SND_FM801 is not set
# CONFIG_SND_HDSP is not set
# CONFIG_SND_HDSPM is not set
# CONFIG_SND_ICE1712 is not set
# CONFIG_SND_ICE1724 is not set
# CONFIG_SND_INTEL8X0 is not set
# CONFIG_SND_INTEL8X0M is not set
# CONFIG_SND_KORG1212 is not set
# CONFIG_SND_LOLA is not set
# CONFIG_SND_LX6464ES is not set
# CONFIG_SND_MAESTRO3 is not set
# CONFIG_SND_MIXART is not set
# CONFIG_SND_NM256 is not set
# CONFIG_SND_PCXHR is not set
# CONFIG_SND_RIPTIDE is not set
# CONFIG_SND_RME32 is not set
# CONFIG_SND_RME96 is not set
# CONFIG_SND_RME9652 is not set
# CONFIG_SND_SE6X is not set
# CONFIG_SND_SONICVIBES is not set
# CONFIG_SND_TRIDENT is not set
# CONFIG_SND_VIA82XX is not set
# CONFIG_SND_VIA82XX_MODEM is not set
# CONFIG_SND_VIRTUOSO is not set
# CONFIG_SND_VX222 is not set
# CONFIG_SND_YMFPCI is not set
# HD-Audio
# CONFIG_SND_HDA_INTEL is not set
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
# CONFIG_SND_ARMAACI is not set
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y
CONFIG_SND_USB_UA101=m
CONFIG_SND_USB_CAIAQ=m
CONFIG_SND_USB_CAIAQ_INPUT=y
CONFIG_SND_USB_6FIRE=m
CONFIG_SND_USB_HIFACE=m
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=m
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
CONFIG_SND_SOC_COMPRESS=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
CONFIG_SND_BCM2835_SOC_I2S=m
CONFIG_SND_BCM2708_SOC_GOOGLEVOICEHAT_SOUNDCARD=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DAC=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUS=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUSADC=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUSADCPRO=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DACPLUSDSP=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_DIGI=m
CONFIG_SND_BCM2708_SOC_HIFIBERRY_AMP=m
CONFIG_SND_BCM2708_SOC_RPI_CIRRUS=m
CONFIG_SND_BCM2708_SOC_RPI_DAC=m
CONFIG_SND_BCM2708_SOC_RPI_PROTO=m
CONFIG_SND_BCM2708_SOC_JUSTBOOM_BOTH=m
CONFIG_SND_BCM2708_SOC_JUSTBOOM_DAC=m
CONFIG_SND_BCM2708_SOC_JUSTBOOM_DIGI=m
CONFIG_SND_BCM2708_SOC_IQAUDIO_CODEC=m
CONFIG_SND_BCM2708_SOC_IQAUDIO_DAC=m
CONFIG_SND_BCM2708_SOC_IQAUDIO_DIGI=m
CONFIG_SND_BCM2708_SOC_I_SABRE_Q2M=m
CONFIG_SND_BCM2708_SOC_ADAU1977_ADC=m
CONFIG_SND_AUDIOINJECTOR_PI_SOUNDCARD=m
CONFIG_SND_AUDIOINJECTOR_OCTO_SOUNDCARD=m
CONFIG_SND_AUDIOSENSE_PI=m
CONFIG_SND_DIGIDAC1_SOUNDCARD=m
CONFIG_SND_BCM2708_SOC_DIONAUDIO_LOCO=m
CONFIG_SND_BCM2708_SOC_DIONAUDIO_LOCO_V2=m
CONFIG_SND_BCM2708_SOC_ALLO_PIANO_DAC=m
CONFIG_SND_BCM2708_SOC_ALLO_PIANO_DAC_PLUS=m
CONFIG_SND_BCM2708_SOC_ALLO_BOSS_DAC=m
CONFIG_SND_BCM2708_SOC_ALLO_DIGIONE=m
CONFIG_SND_BCM2708_SOC_ALLO_KATANA_DAC=m
CONFIG_SND_BCM2708_SOC_FE_PI_AUDIO=m
CONFIG_SND_PISOUND=m
CONFIG_SND_RPI_SIMPLE_SOUNDCARD=m
CONFIG_SND_RPI_WM8804_SOUNDCARD=m
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_AUDMIX is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_FSL_MICFIL is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=m
# CODEC drivers
CONFIG_SND_SOC_ARIZONA=m
CONFIG_SND_SOC_WM_ADSP=m
# CONFIG_SND_SOC_AC97_CODEC is not set
CONFIG_SND_SOC_AD193X=m
CONFIG_SND_SOC_AD193X_SPI=m
CONFIG_SND_SOC_AD193X_I2C=m
CONFIG_SND_SOC_ADAU1701=m
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
CONFIG_SND_SOC_ADAU1977=m
CONFIG_SND_SOC_ADAU1977_I2C=m
CONFIG_SND_SOC_ADAU7002=m
# CONFIG_SND_SOC_ADAU7118_HW is not set
# CONFIG_SND_SOC_ADAU7118_I2C is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4118 is not set
# CONFIG_SND_SOC_AK4458 is not set
CONFIG_SND_SOC_AK4554=m
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
CONFIG_SND_SOC_CS4265=m
# CONFIG_SND_SOC_CS4270 is not set
CONFIG_SND_SOC_CS4271=m
CONFIG_SND_SOC_CS4271_I2C=m
# CONFIG_SND_SOC_CS4271_SPI is not set
CONFIG_SND_SOC_CS42XX8=m
CONFIG_SND_SOC_CS42XX8_I2C=m
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
CONFIG_SND_SOC_DA7213=m
CONFIG_SND_SOC_DMIC=m
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
CONFIG_SND_SOC_ICS43432=m
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
# CONFIG_SND_SOC_MAX98357A is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
CONFIG_SND_SOC_PCM186X=m
CONFIG_SND_SOC_PCM186X_I2C=m
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
CONFIG_SND_SOC_PCM5102A=m
CONFIG_SND_SOC_PCM512x=m
CONFIG_SND_SOC_PCM512x_I2C=m
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RT5616 is not set
CONFIG_SND_SOC_PCM1794A=m
# CONFIG_SND_SOC_RT5631 is not set
CONFIG_SND_SOC_SGTL5000=m
CONFIG_SND_SOC_SIGMADSP=m
CONFIG_SND_SOC_SIGMADSP_I2C=m
# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
CONFIG_SND_SOC_SPDIF=m
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS2562 is not set
# CONFIG_SND_SOC_TAS2770 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
CONFIG_SND_SOC_TAS5713=m
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
CONFIG_SND_SOC_TLV320AIC32X4=m
CONFIG_SND_SOC_TLV320AIC32X4_I2C=m
# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_UDA1334 is not set
CONFIG_SND_SOC_WM5102=m
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
CONFIG_SND_SOC_WM8731=m
# CONFIG_SND_SOC_WM8737 is not set
CONFIG_SND_SOC_WM8741=m
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
CONFIG_SND_SOC_WM8804=m
CONFIG_SND_SOC_WM8804_I2C=m
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8904 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8822 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
CONFIG_SND_SOC_I_SABRE_CODEC=m
# end of CODEC drivers
CONFIG_SND_SIMPLE_CARD_UTILS=m
CONFIG_SND_SIMPLE_CARD=m
CONFIG_SND_AUDIO_GRAPH_CARD=m
# HID support
CONFIG_HID=y
CONFIG_HID_BATTERY_STRENGTH=y
CONFIG_HIDRAW=y
CONFIG_UHID=m
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=m
# CONFIG_HID_ACCUTOUCH is not set
CONFIG_HID_ACRUX=m
# CONFIG_HID_ACRUX_FF is not set
CONFIG_HID_APPLE=m
# CONFIG_HID_APPLEIR is not set
CONFIG_HID_ASUS=m
# CONFIG_HID_AUREAL is not set
CONFIG_HID_BELKIN=m
CONFIG_HID_BETOP_FF=m
CONFIG_HID_BIGBEN_FF=m
CONFIG_HID_CHERRY=m
CONFIG_HID_CHICONY=m
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_MACALLY is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
# CONFIG_HID_CP2112 is not set
# CONFIG_HID_CREATIVE_SB0540 is not set
CONFIG_HID_CYPRESS=m
CONFIG_HID_DRAGONRISE=m
# CONFIG_DRAGONRISE_FF is not set
CONFIG_HID_EMS_FF=m
# CONFIG_HID_ELAN is not set
CONFIG_HID_ELECOM=m
CONFIG_HID_ELO=m
CONFIG_HID_EZKEY=m
CONFIG_HID_GEMBIRD=m
# CONFIG_HID_GFRM is not set
CONFIG_HID_HOLTEK=m
# CONFIG_HOLTEK_FF is not set
# CONFIG_HID_GT683R is not set
CONFIG_HID_KEYTOUCH=m
CONFIG_HID_KYE=m
CONFIG_HID_UCLOGIC=m
CONFIG_HID_WALTOP=m
# CONFIG_HID_VIEWSONIC is not set
CONFIG_HID_GYRATION=m
# CONFIG_HID_ICADE is not set
# CONFIG_HID_ITE is not set
# CONFIG_HID_JABRA is not set
CONFIG_HID_TWINHAN=m
CONFIG_HID_KENSINGTON=m
CONFIG_HID_LCPOWER=m
CONFIG_HID_LED=m
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=m
CONFIG_HID_LOGITECH_DJ=m
CONFIG_HID_LOGITECH_HIDPP=m
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_LOGIG940_FF=y
CONFIG_LOGIWHEELS_FF=y
CONFIG_HID_MAGICMOUSE=m
# CONFIG_HID_MALTRON is not set
# CONFIG_HID_MAYFLASH is not set
# CONFIG_HID_REDRAGON is not set
CONFIG_HID_MICROSOFT=m
CONFIG_HID_MONTEREY=m
CONFIG_HID_MULTITOUCH=m
# CONFIG_HID_NTI is not set
CONFIG_HID_NTRIG=m
CONFIG_HID_ORTEK=m
CONFIG_HID_PANTHERLORD=m
# CONFIG_PANTHERLORD_FF is not set
# CONFIG_HID_PENMOUNT is not set
CONFIG_HID_PETALYNX=m
CONFIG_HID_PICOLCD=m
# CONFIG_HID_PICOLCD_FB is not set
# CONFIG_HID_PICOLCD_BACKLIGHT is not set
# CONFIG_HID_PICOLCD_LEDS is not set
# CONFIG_HID_PICOLCD_CIR is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
CONFIG_HID_ROCCAT=m
# CONFIG_HID_SAITEK is not set
CONFIG_HID_SAMSUNG=m
CONFIG_HID_SONY=m
CONFIG_SONY_FF=y
CONFIG_HID_SPEEDLINK=m
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
CONFIG_HID_SUNPLUS=m
# CONFIG_HID_RMI is not set
CONFIG_HID_GREENASIA=m
# CONFIG_GREENASIA_FF is not set
CONFIG_HID_SMARTJOYPLUS=m
# CONFIG_SMARTJOYPLUS_FF is not set
# CONFIG_HID_TIVO is not set
CONFIG_HID_TOPSEED=m
CONFIG_HID_THINGM=m
CONFIG_HID_THRUSTMASTER=m
# CONFIG_THRUSTMASTER_FF is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_U2FZERO is not set
CONFIG_HID_WACOM=m
CONFIG_HID_WIIMOTE=m
CONFIG_HID_XINMO=m
CONFIG_HID_ZEROPLUS=m
# CONFIG_ZEROPLUS_FF is not set
CONFIG_HID_ZYDACRON=m
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# end of Special HID drivers
# USB HID support
CONFIG_USB_HID=y
CONFIG_HID_PID=y
CONFIG_USB_HIDDEV=y
# end of USB HID support
# I2C HID support
# CONFIG_I2C_HID is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_USB_CONN_GPIO is not set
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_PCI=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
CONFIG_USB_AUTOSUSPEND_DELAY=2
CONFIG_USB_MON=m
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_XHCI_HCD=y
# CONFIG_USB_XHCI_DBGCAP is not set
CONFIG_USB_XHCI_PCI=y
CONFIG_USB_XHCI_PLATFORM=y
# CONFIG_USB_EHCI_HCD is not set
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
# CONFIG_USB_OHCI_HCD is not set
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_U132_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
CONFIG_USB_DWCOTG=y
# CONFIG_USB_HCD_BCMA is not set
# CONFIG_USB_HCD_SSB is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_WDM=m
CONFIG_USB_TMC=m
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_REALTEK=m
CONFIG_REALTEK_AUTOPM=y
CONFIG_USB_STORAGE_DATAFAB=m
CONFIG_USB_STORAGE_FREECOM=m
CONFIG_USB_STORAGE_ISD200=m
CONFIG_USB_STORAGE_USBAT=m
CONFIG_USB_STORAGE_SDDR09=m
CONFIG_USB_STORAGE_SDDR55=m
CONFIG_USB_STORAGE_JUMPSHOT=m
CONFIG_USB_STORAGE_ALAUDA=m
CONFIG_USB_STORAGE_ONETOUCH=m
CONFIG_USB_STORAGE_KARMA=m
CONFIG_USB_STORAGE_CYPRESS_ATACB=m
CONFIG_USB_STORAGE_ENE_UB6250=m
CONFIG_USB_UAS=y
# USB Imaging devices
CONFIG_USB_MDC800=m
CONFIG_USB_MICROTEK=m
CONFIG_USBIP_CORE=m
CONFIG_USBIP_VHCI_HCD=m
CONFIG_USBIP_VHCI_HC_PORTS=8
CONFIG_USBIP_VHCI_NR_HCS=1
CONFIG_USBIP_HOST=m
CONFIG_USBIP_VUDC=m
# CONFIG_USBIP_DEBUG is not set
# CONFIG_USB_CDNS3 is not set
# CONFIG_USB_MUSB_HDRC is not set
# CONFIG_USB_DWC3 is not set
CONFIG_USB_DWC2=m
# CONFIG_USB_DWC2_HOST is not set
# Gadget/Dual-role mode requires USB Gadget support to be enabled
# CONFIG_USB_DWC2_PERIPHERAL is not set
CONFIG_USB_DWC2_DUAL_ROLE=y
# CONFIG_USB_DWC2_PCI is not set
# CONFIG_USB_DWC2_DEBUG is not set
# CONFIG_USB_DWC2_TRACK_MISSED_SOFS is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_SIMPLE is not set
CONFIG_USB_SERIAL_AIRCABLE=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_F81232=m
# CONFIG_USB_SERIAL_F8153X is not set
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_IUU=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_METRO=m
CONFIG_USB_SERIAL_MOS7720=m
CONFIG_USB_SERIAL_MOS7840=m
# CONFIG_USB_SERIAL_MXUPORT is not set
CONFIG_USB_SERIAL_NAVMAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OTI6858=m
CONFIG_USB_SERIAL_QCAUX=m
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SPCP8X5=m
CONFIG_USB_SERIAL_SAFE=m
# CONFIG_USB_SERIAL_SAFE_PADDED is not set
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_SYMBOL=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_WWAN=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_SERIAL_OPTICON=m
CONFIG_USB_SERIAL_XSENS_MT=m
CONFIG_USB_SERIAL_WISHBONE=m
CONFIG_USB_SERIAL_SSU100=m
CONFIG_USB_SERIAL_QT2=m
# CONFIG_USB_SERIAL_UPD78F0730 is not set
CONFIG_USB_SERIAL_DEBUG=m
# USB Miscellaneous drivers
CONFIG_USB_EMI62=m
CONFIG_USB_EMI26=m
CONFIG_USB_ADUTUX=m
CONFIG_USB_SEVSEG=m
CONFIG_USB_LEGOTOWER=m
CONFIG_USB_LCD=m
CONFIG_USB_CYPRESS_CY7C63=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_IDMOUSE=m
CONFIG_USB_FTDI_ELAN=m
CONFIG_USB_APPLEDISPLAY=m
CONFIG_USB_LD=m
CONFIG_USB_TRANCEVIBRATOR=m
CONFIG_USB_IOWARRIOR=m
CONFIG_USB_TEST=m
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
CONFIG_USB_ISIGHTFW=m
CONFIG_USB_YUREX=m
CONFIG_USB_EZUSB_FX2=m
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# CONFIG_USB_CHAOSKEY is not set
CONFIG_USB_ATM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_CXACRU=m
CONFIG_USB_UEAGLEATM=m
CONFIG_USB_XUSBATM=m
# USB Physical Layer drivers
# CONFIG_NOP_USB_XCEIV is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
# end of USB Physical Layer drivers
CONFIG_USB_GADGET=m
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_AMD5536UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_NET2280 is not set
# CONFIG_USB_GOKU is not set
# CONFIG_USB_EG20T is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_DUMMY_HCD is not set
# end of USB Peripheral Controller
CONFIG_USB_LIBCOMPOSITE=m
CONFIG_USB_F_ACM=m
CONFIG_USB_F_SS_LB=m
CONFIG_USB_U_SERIAL=m
CONFIG_USB_U_ETHER=m
CONFIG_USB_U_AUDIO=m
CONFIG_USB_F_SERIAL=m
CONFIG_USB_F_OBEX=m
CONFIG_USB_F_NCM=m
CONFIG_USB_F_ECM=m
CONFIG_USB_F_EEM=m
CONFIG_USB_F_SUBSET=m
CONFIG_USB_F_RNDIS=m
CONFIG_USB_F_MASS_STORAGE=m
CONFIG_USB_F_FS=m
CONFIG_USB_F_UAC1=m
CONFIG_USB_F_UAC2=m
CONFIG_USB_F_UVC=m
CONFIG_USB_F_MIDI=m
CONFIG_USB_F_HID=m
CONFIG_USB_F_PRINTER=m
CONFIG_USB_CONFIGFS=m
CONFIG_USB_CONFIGFS_SERIAL=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_OBEX=y
CONFIG_USB_CONFIGFS_NCM=y
CONFIG_USB_CONFIGFS_ECM=y
CONFIG_USB_CONFIGFS_ECM_SUBSET=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_EEM=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_LB_SS=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_UAC1=y
# CONFIG_USB_CONFIGFS_F_UAC1_LEGACY is not set
CONFIG_USB_CONFIGFS_F_UAC2=y
CONFIG_USB_CONFIGFS_F_MIDI=y
CONFIG_USB_CONFIGFS_F_HID=y
CONFIG_USB_CONFIGFS_F_UVC=y
CONFIG_USB_CONFIGFS_F_PRINTER=y
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO=m
# CONFIG_GADGET_UAC1 is not set
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
# CONFIG_USB_ETH_EEM is not set
# CONFIG_USB_G_NCM is not set
CONFIG_USB_GADGETFS=m
# CONFIG_USB_FUNCTIONFS is not set
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_USB_MIDI_GADGET=m
CONFIG_USB_G_PRINTER=m
CONFIG_USB_CDC_COMPOSITE=m
CONFIG_USB_G_ACM_MS=m
CONFIG_USB_G_MULTI=m
CONFIG_USB_G_MULTI_RNDIS=y
# CONFIG_USB_G_MULTI_CDC is not set
CONFIG_USB_G_HID=m
# CONFIG_USB_G_DBGP is not set
CONFIG_USB_G_WEBCAM=m
# CONFIG_TYPEC is not set
# CONFIG_USB_ROLE_SWITCH is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
# CONFIG_PWRSEQ_SD8787 is not set
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=32
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
CONFIG_MMC_BCM2835_MMC=y
CONFIG_MMC_BCM2835_DMA=y
CONFIG_MMC_BCM2835_PIO_DMA_BARRIER=2
CONFIG_MMC_BCM2835_SDHOST=y
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_ARMMMCI is not set
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_IO_ACCESSORS=y
# CONFIG_MMC_SDHCI_PCI is not set
CONFIG_MMC_SDHCI_PLTFM=y
# CONFIG_MMC_SDHCI_OF_ARASAN is not set
# CONFIG_MMC_SDHCI_OF_ASPEED is not set
# CONFIG_MMC_SDHCI_OF_AT91 is not set
# CONFIG_MMC_SDHCI_OF_DWCMSHC is not set
# CONFIG_MMC_SDHCI_CADENCE is not set
# CONFIG_MMC_SDHCI_F_SDH30 is not set
# CONFIG_MMC_SDHCI_MILBEAUT is not set
CONFIG_MMC_SDHCI_IPROC=y
# CONFIG_MMC_TIFM_SD is not set
CONFIG_MMC_SPI=m
# CONFIG_MMC_CB710 is not set
# CONFIG_MMC_VIA_SDMMC is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
# CONFIG_MMC_CQHCI is not set
# CONFIG_MMC_TOSHIBA_PCI is not set
# CONFIG_MMC_BCM2835 is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MMC_SDHCI_XENON is not set
# CONFIG_MMC_SDHCI_OMAP is not set
# CONFIG_MMC_SDHCI_AM654 is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_AN30259A is not set
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_CR0014114 is not set
# CONFIG_LEDS_EL15203000 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3532 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_LM3692X is not set
CONFIG_LEDS_PCA9532=m
# CONFIG_LEDS_PCA9532_GPIO is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
CONFIG_LEDS_PCA955X=m
# CONFIG_LEDS_PCA955X_GPIO is not set
CONFIG_LEDS_PCA963X=m
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
CONFIG_LEDS_IS31FL32XX=m
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_MLXREG is not set
# CONFIG_LEDS_USER is not set
# CONFIG_LEDS_SPI_BYTE is not set
# CONFIG_LEDS_TI_LMU_COMMON is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_ONESHOT=y
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
CONFIG_LEDS_TRIGGER_BACKLIGHT=y
CONFIG_LEDS_TRIGGER_CPU=y
# CONFIG_LEDS_TRIGGER_ACTIVITY is not set
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
CONFIG_LEDS_TRIGGER_TRANSIENT=m
CONFIG_LEDS_TRIGGER_CAMERA=m
CONFIG_LEDS_TRIGGER_INPUT=y
CONFIG_LEDS_TRIGGER_PANIC=y
CONFIG_LEDS_TRIGGER_NETDEV=m
# CONFIG_LEDS_TRIGGER_PATTERN is not set
# CONFIG_LEDS_TRIGGER_AUDIO is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
# CONFIG_EDAC is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
# CONFIG_RTC_HCTOSYS is not set
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
CONFIG_RTC_DRV_ABX80X=m
CONFIG_RTC_DRV_DS1307=m
# CONFIG_RTC_DRV_DS1307_CENTURY is not set
CONFIG_RTC_DRV_DS1374=m
# CONFIG_RTC_DRV_DS1374_WDT is not set
CONFIG_RTC_DRV_DS1672=m
# CONFIG_RTC_DRV_HYM8563 is not set
CONFIG_RTC_DRV_MAX6900=m
CONFIG_RTC_DRV_RS5C372=m
CONFIG_RTC_DRV_ISL1208=m
CONFIG_RTC_DRV_ISL12022=m
# CONFIG_RTC_DRV_ISL12026 is not set
CONFIG_RTC_DRV_X1205=m
CONFIG_RTC_DRV_PCF8523=m
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF85363 is not set
CONFIG_RTC_DRV_PCF8563=m
CONFIG_RTC_DRV_PCF8583=m
CONFIG_RTC_DRV_M41T80=m
# CONFIG_RTC_DRV_M41T80_WDT is not set
CONFIG_RTC_DRV_BQ32K=m
CONFIG_RTC_DRV_S35390A=m
CONFIG_RTC_DRV_FM3130=m
# CONFIG_RTC_DRV_RX8010 is not set
CONFIG_RTC_DRV_RX8581=m
CONFIG_RTC_DRV_RX8025=m
CONFIG_RTC_DRV_EM3027=m
CONFIG_RTC_DRV_RV3028=m
# CONFIG_RTC_DRV_RV8803 is not set
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
CONFIG_RTC_DRV_M41T93=m
CONFIG_RTC_DRV_M41T94=m
CONFIG_RTC_DRV_DS1302=m
CONFIG_RTC_DRV_DS1305=m
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
CONFIG_RTC_DRV_DS1390=m
# CONFIG_RTC_DRV_MAX6916 is not set
CONFIG_RTC_DRV_R9701=m
CONFIG_RTC_DRV_RX4581=m
# CONFIG_RTC_DRV_RX6110 is not set
CONFIG_RTC_DRV_RS5C348=m
CONFIG_RTC_DRV_MAX6902=m
CONFIG_RTC_DRV_PCF2123=m
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
CONFIG_RTC_DRV_DS3232=m
CONFIG_RTC_DRV_DS3232_HWMON=y
CONFIG_RTC_DRV_PCF2127=m
CONFIG_RTC_DRV_RV3029C2=m
CONFIG_RTC_DRV_RV3029_HWMON=y
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
# CONFIG_RTC_DRV_PL030 is not set
# CONFIG_RTC_DRV_PL031 is not set
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_SNVS is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_AMBA_PL08X is not set
CONFIG_DMA_BCM2835=y
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_FSL_QDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_PL330_DMA is not set
CONFIG_DMA_BCM2708=y
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# CONFIG_DW_DMAC_PCI is not set
# CONFIG_DW_EDMA is not set
# CONFIG_DW_EDMA_PCIE is not set
# CONFIG_SF_PDMA is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_SELFTESTS is not set
# end of DMABUF options
CONFIG_AUXDISPLAY=y
CONFIG_HD44780=m
# CONFIG_IMG_ASCII_LCD is not set
# CONFIG_HT16K33 is not set
# CONFIG_PANEL_CHANGE_MESSAGE is not set
# CONFIG_CHARLCD_BL_OFF is not set
# CONFIG_CHARLCD_BL_ON is not set
CONFIG_CHARLCD_BL_FLASH=y
CONFIG_CHARLCD=m
CONFIG_UIO=m
# CONFIG_UIO_CIF is not set
CONFIG_UIO_PDRV_GENIRQ=m
# CONFIG_UIO_DMEM_GENIRQ is not set
# CONFIG_UIO_AEC is not set
# CONFIG_UIO_SERCOS3 is not set
# CONFIG_UIO_PCI_GENERIC is not set
# CONFIG_UIO_NETX is not set
# CONFIG_UIO_PRUSS is not set
# CONFIG_UIO_MF624 is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO_MENU=y
# CONFIG_VIRTIO_PCI is not set
# CONFIG_VIRTIO_MMIO is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
CONFIG_STAGING=y
CONFIG_PRISM2_USB=m
# CONFIG_COMEDI is not set
# CONFIG_RTL8192U is not set
# CONFIG_RTLLIB is not set
# CONFIG_RTL8723BS is not set
CONFIG_R8712U=m
CONFIG_R8188EU=m
CONFIG_88EU_AP_MODE=y
# CONFIG_RTS5208 is not set
# CONFIG_VT6655 is not set
CONFIG_VT6656=m
# IIO staging drivers
# Accelerometers
# CONFIG_ADIS16203 is not set
# CONFIG_ADIS16240 is not set
# end of Accelerometers
# Analog to digital converters
# CONFIG_AD7816 is not set
# CONFIG_AD7192 is not set
# CONFIG_AD7280 is not set
# end of Analog to digital converters
# Analog digital bi-direction converters
# CONFIG_ADT7316 is not set
# end of Analog digital bi-direction converters
# Capacitance to digital converters
# CONFIG_AD7150 is not set
# CONFIG_AD7746 is not set
# end of Capacitance to digital converters
# Direct Digital Synthesis
# CONFIG_AD9832 is not set
# CONFIG_AD9834 is not set
# end of Direct Digital Synthesis
# Network Analyzer, Impedance Converters
# CONFIG_AD5933 is not set
# end of Network Analyzer, Impedance Converters
# Active energy metering IC
# CONFIG_ADE7854 is not set
# end of Active energy metering IC
# Resolver to digital converters
# CONFIG_AD2S1210 is not set
# end of Resolver to digital converters
# end of IIO staging drivers
# CONFIG_FB_SM750 is not set
# Speakup console speech
CONFIG_SPEAKUP=m
# CONFIG_SPEAKUP_SYNTH_ACNTSA is not set
# CONFIG_SPEAKUP_SYNTH_APOLLO is not set
# CONFIG_SPEAKUP_SYNTH_AUDPTR is not set
# CONFIG_SPEAKUP_SYNTH_BNS is not set
# CONFIG_SPEAKUP_SYNTH_DECTLK is not set
# CONFIG_SPEAKUP_SYNTH_DECEXT is not set
# CONFIG_SPEAKUP_SYNTH_LTLK is not set
CONFIG_SPEAKUP_SYNTH_SOFT=m
# CONFIG_SPEAKUP_SYNTH_SPKOUT is not set
# CONFIG_SPEAKUP_SYNTH_TXPRT is not set
# CONFIG_SPEAKUP_SYNTH_DUMMY is not set
# end of Speakup console speech
CONFIG_STAGING_MEDIA=y
# soc_camera sensor drivers
# Android
# end of Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_UNISYSSPAR is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
CONFIG_FB_TFT=m
CONFIG_FB_TFT_AGM1264K_FL=m
CONFIG_FB_TFT_BD663474=m
CONFIG_FB_TFT_HX8340BN=m
CONFIG_FB_TFT_HX8347D=m
CONFIG_FB_TFT_HX8353D=m
CONFIG_FB_TFT_HX8357D=m
CONFIG_FB_TFT_ILI9163=m
CONFIG_FB_TFT_ILI9320=m
CONFIG_FB_TFT_ILI9325=m
CONFIG_FB_TFT_ILI9340=m
CONFIG_FB_TFT_ILI9341=m
CONFIG_FB_TFT_ILI9481=m
CONFIG_FB_TFT_ILI9486=m
CONFIG_FB_TFT_PCD8544=m
CONFIG_FB_TFT_RA8875=m
CONFIG_FB_TFT_S6D02A1=m
CONFIG_FB_TFT_S6D1121=m
# CONFIG_FB_TFT_SEPS525 is not set
CONFIG_FB_TFT_SH1106=m
CONFIG_FB_TFT_SSD1289=m
# CONFIG_FB_TFT_SSD1305 is not set
CONFIG_FB_TFT_SSD1306=m
CONFIG_FB_TFT_SSD1331=m
CONFIG_FB_TFT_SSD1351=m
CONFIG_FB_TFT_ST7735R=m
CONFIG_FB_TFT_ST7789V=m
CONFIG_FB_TFT_TINYLCD=m
CONFIG_FB_TFT_TLS8204=m
# CONFIG_FB_TFT_UC1611 is not set
CONFIG_FB_TFT_UC1701=m
CONFIG_FB_TFT_UPD161704=m
CONFIG_FB_TFT_WATTEROTT=m
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
# CONFIG_MOST is not set
# CONFIG_KS7010 is not set
CONFIG_BCM_VIDEOCORE=y
CONFIG_BCM2835_VCHIQ=y
CONFIG_SND_BCM2835=m
CONFIG_VIDEO_BCM2835=m
CONFIG_BCM2835_VCHIQ_MMAL=m
CONFIG_BCM_VC_SM_CMA=m
CONFIG_VIDEO_CODEC_BCM2835=m
# CONFIG_PI433 is not set
# Gasket devices
# end of Gasket devices
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_FIELDBUS_DEV is not set
# CONFIG_KPC2000 is not set
# CONFIG_USB_WUSB_CBAF is not set
# CONFIG_UWB is not set
# CONFIG_EXFAT_FS is not set
# CONFIG_QLGE is not set
CONFIG_NET_VENDOR_HP=y
# CONFIG_HP100 is not set
# CONFIG_WFX is not set
# CONFIG_GOLDFISH is not set
# CONFIG_MFD_CROS_EC is not set
# CONFIG_CHROME_PLATFORMS is not set
# CONFIG_MELLANOX_PLATFORM is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
CONFIG_COMMON_CLK_HIFIBERRY_DACPRO=m
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_CLK_BCM2835=y
CONFIG_CLK_RASPBERRYPI=y
# end of Common Clock Framework
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_BCM2835_TIMER=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
CONFIG_ARM_TIMER_SP804=y
# end of Clock Source drivers
CONFIG_MAILBOX=y
# CONFIG_ARM_MHU is not set
# CONFIG_PLATFORM_MHU is not set
# CONFIG_PL320_MBOX is not set
# CONFIG_ALTERA_MBOX is not set
CONFIG_BCM2835_MBOX=y
# CONFIG_MAILBOX_TEST is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# end of Remoteproc drivers
# Rpmsg drivers
# CONFIG_RPMSG_QCOM_GLINK_RPM is not set
# CONFIG_RPMSG_VIRTIO is not set
# end of Rpmsg drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Aspeed SoC drivers
# end of Aspeed SoC drivers
# Broadcom SoC drivers
CONFIG_BCM2835_POWER=y
CONFIG_RASPBERRYPI_POWER=y
# CONFIG_SOC_BRCMSTB is not set
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# Qualcomm SoC drivers
# end of Qualcomm SoC drivers
# CONFIG_SOC_TI is not set
# Xilinx SoC drivers
# CONFIG_XILINX_VCU is not set
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
# CONFIG_PM_DEVFREQ is not set
CONFIG_EXTCON=m
# Extcon Device Drivers
# CONFIG_EXTCON_ADC_JACK is not set
CONFIG_EXTCON_ARIZONA=m
# CONFIG_EXTCON_FSA9480 is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_PTN5150 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_MEMORY is not set
CONFIG_IIO=m
CONFIG_IIO_BUFFER=y
CONFIG_IIO_BUFFER_CB=m
# CONFIG_IIO_BUFFER_HW_CONSUMER is not set
CONFIG_IIO_KFIFO_BUF=m
CONFIG_IIO_TRIGGERED_BUFFER=m
# CONFIG_IIO_CONFIGFS is not set
CONFIG_IIO_TRIGGER=y
CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
# CONFIG_IIO_SW_DEVICE is not set
# CONFIG_IIO_SW_TRIGGER is not set
# Accelerometers
# CONFIG_ADIS16201 is not set
# CONFIG_ADIS16209 is not set
# CONFIG_ADXL372_SPI is not set
# CONFIG_ADXL372_I2C is not set
# CONFIG_BMA180 is not set
# CONFIG_BMA220 is not set
# CONFIG_BMC150_ACCEL is not set
# CONFIG_DA280 is not set
# CONFIG_DA311 is not set
# CONFIG_DMARD06 is not set
# CONFIG_DMARD09 is not set
# CONFIG_DMARD10 is not set
# CONFIG_IIO_ST_ACCEL_3AXIS is not set
# CONFIG_KXSD9 is not set
# CONFIG_KXCJK1013 is not set
# CONFIG_MC3230 is not set
# CONFIG_MMA7455_I2C is not set
# CONFIG_MMA7455_SPI is not set
# CONFIG_MMA7660 is not set
# CONFIG_MMA8452 is not set
# CONFIG_MMA9551 is not set
# CONFIG_MMA9553 is not set
# CONFIG_MXC4005 is not set
# CONFIG_MXC6255 is not set
# CONFIG_SCA3000 is not set
# CONFIG_STK8312 is not set
# CONFIG_STK8BA50 is not set
# CONFIG_AD7124 is not set
# CONFIG_AD7266 is not set
# CONFIG_AD7291 is not set
# CONFIG_AD7292 is not set
# CONFIG_AD7298 is not set
# CONFIG_AD7476 is not set
# CONFIG_AD7606_IFACE_PARALLEL is not set
# CONFIG_AD7606_IFACE_SPI is not set
# CONFIG_AD7766 is not set
# CONFIG_AD7768_1 is not set
# CONFIG_AD7780 is not set
# CONFIG_AD7791 is not set
# CONFIG_AD7793 is not set
# CONFIG_AD7887 is not set
# CONFIG_AD7923 is not set
# CONFIG_AD7949 is not set
# CONFIG_AD799X is not set
# CONFIG_CC10001_ADC is not set
# CONFIG_ENVELOPE_DETECTOR is not set
# CONFIG_HI8435 is not set
# CONFIG_HX711 is not set
# CONFIG_INA2XX_ADC is not set
# CONFIG_LTC2471 is not set
# CONFIG_LTC2485 is not set
# CONFIG_LTC2497 is not set
# CONFIG_MAX1027 is not set
# CONFIG_MAX11100 is not set
# CONFIG_MAX1118 is not set
# CONFIG_MAX1363 is not set
# CONFIG_MAX9611 is not set
CONFIG_MCP320X=m
CONFIG_MCP3422=m
# CONFIG_MCP3911 is not set
# CONFIG_NAU7802 is not set
# CONFIG_SD_ADC_MODULATOR is not set
# CONFIG_STMPE_ADC is not set
# CONFIG_TI_ADC081C is not set
# CONFIG_TI_ADC0832 is not set
# CONFIG_TI_ADC084S021 is not set
# CONFIG_TI_ADC12138 is not set
# CONFIG_TI_ADC108S102 is not set
# CONFIG_TI_ADC128S052 is not set
# CONFIG_TI_ADC161S626 is not set
CONFIG_TI_ADS1015=m
# CONFIG_TI_ADS7950 is not set
# CONFIG_TI_ADS8344 is not set
# CONFIG_TI_ADS8688 is not set
# CONFIG_TI_ADS124S08 is not set
# CONFIG_TI_TLC4541 is not set
# CONFIG_VF610_ADC is not set
# CONFIG_XILINX_XADC is not set
# Analog Front Ends
# CONFIG_IIO_RESCALE is not set
# end of Analog Front Ends
# Amplifiers
# CONFIG_AD8366 is not set
# end of Amplifiers
# Chemical Sensors
# CONFIG_ATLAS_PH_SENSOR is not set
# CONFIG_BME680 is not set
# CONFIG_CCS811 is not set
# CONFIG_IAQCORE is not set
# CONFIG_PMS7003 is not set
# CONFIG_SENSIRION_SGP30 is not set
# CONFIG_SPS30 is not set
# CONFIG_VZ89X is not set
# end of Chemical Sensors
# Hid Sensor IIO Common
# end of Hid Sensor IIO Common
CONFIG_IIO_MS_SENSORS_I2C=m
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# end of SSP Sensor Common
# Digital to analog converters
# CONFIG_AD5064 is not set
# CONFIG_AD5360 is not set
# CONFIG_AD5380 is not set
# CONFIG_AD5421 is not set
# CONFIG_AD5446 is not set
# CONFIG_AD5449 is not set
# CONFIG_AD5592R is not set
# CONFIG_AD5593R is not set
# CONFIG_AD5504 is not set
# CONFIG_AD5624R_SPI is not set
# CONFIG_LTC1660 is not set
# CONFIG_LTC2632 is not set
# CONFIG_AD5686_SPI is not set
# CONFIG_AD5696_I2C is not set
# CONFIG_AD5755 is not set
# CONFIG_AD5758 is not set
# CONFIG_AD5761 is not set
# CONFIG_AD5764 is not set
# CONFIG_AD5791 is not set
# CONFIG_AD7303 is not set
# CONFIG_AD8801 is not set
# CONFIG_DPOT_DAC is not set
# CONFIG_DS4424 is not set
# CONFIG_M62332 is not set
# CONFIG_MAX517 is not set
# CONFIG_MAX5821 is not set
# CONFIG_MCP4725 is not set
# CONFIG_MCP4922 is not set
# CONFIG_TI_DAC082S085 is not set
# CONFIG_TI_DAC5571 is not set
# CONFIG_TI_DAC7311 is not set
# CONFIG_TI_DAC7612 is not set
# CONFIG_VF610_DAC is not set
# end of Digital to analog converters
# IIO dummy driver
# end of IIO dummy driver
# Frequency Synthesizers DDS/PLL
# Clock Generator/Distribution
# CONFIG_AD9523 is not set
# end of Clock Generator/Distribution
# Phase-Locked Loop (PLL) frequency synthesizers
# CONFIG_ADF4350 is not set
# CONFIG_ADF4371 is not set
# end of Phase-Locked Loop (PLL) frequency synthesizers
# end of Frequency Synthesizers DDS/PLL
# Digital gyroscope sensors
# CONFIG_ADIS16080 is not set
# CONFIG_ADIS16130 is not set
# CONFIG_ADIS16136 is not set
# CONFIG_ADIS16260 is not set
# CONFIG_ADXRS450 is not set
# CONFIG_BMG160 is not set
# CONFIG_FXAS21002C is not set
# CONFIG_MPU3050_I2C is not set
# CONFIG_IIO_ST_GYRO_3AXIS is not set
# CONFIG_ITG3200 is not set
# end of Digital gyroscope sensors
# Health Sensors
# Heart Rate Monitors
# CONFIG_AFE4403 is not set
# CONFIG_AFE4404 is not set
# CONFIG_MAX30100 is not set
# CONFIG_MAX30102 is not set
# end of Heart Rate Monitors
# end of Health Sensors
# Humidity sensors
# CONFIG_AM2315 is not set
CONFIG_DHT11=m
CONFIG_HDC100X=m
# CONFIG_HTS221 is not set
CONFIG_HTU21=m
# CONFIG_SI7005 is not set
# CONFIG_SI7020 is not set
# end of Humidity sensors
# Inertial measurement units
# CONFIG_ADIS16400 is not set
# CONFIG_ADIS16460 is not set
# CONFIG_ADIS16480 is not set
# CONFIG_BMI160_I2C is not set
# CONFIG_BMI160_SPI is not set
# CONFIG_FXOS8700_I2C is not set
# CONFIG_FXOS8700_SPI is not set
# CONFIG_KMX61 is not set
CONFIG_INV_MPU6050_IIO=m
CONFIG_INV_MPU6050_I2C=m
# CONFIG_INV_MPU6050_SPI is not set
# CONFIG_IIO_ST_LSM6DSX is not set
# end of Inertial measurement units
# Light sensors
# CONFIG_ADJD_S311 is not set
# CONFIG_ADUX1020 is not set
# CONFIG_AL3320A is not set
# CONFIG_APDS9300 is not set
CONFIG_APDS9960=m
# CONFIG_BH1750 is not set
# CONFIG_BH1780 is not set
# CONFIG_CM32181 is not set
# CONFIG_CM3232 is not set
# CONFIG_CM3323 is not set
# CONFIG_CM3605 is not set
# CONFIG_CM36651 is not set
# CONFIG_GP2AP020A00F is not set
# CONFIG_SENSORS_ISL29018 is not set
# CONFIG_SENSORS_ISL29028 is not set
# CONFIG_ISL29125 is not set
# CONFIG_JSA1212 is not set
# CONFIG_RPR0521 is not set
# CONFIG_LTR501 is not set
# CONFIG_LV0104CS is not set
# CONFIG_MAX44000 is not set
# CONFIG_MAX44009 is not set
# CONFIG_NOA1305 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PA12203001 is not set
# CONFIG_SI1133 is not set
# CONFIG_SI1145 is not set
# CONFIG_STK3310 is not set
# CONFIG_ST_UVIS25 is not set
# CONFIG_TCS3414 is not set
# CONFIG_TCS3472 is not set
# CONFIG_SENSORS_TSL2563 is not set
# CONFIG_TSL2583 is not set
# CONFIG_TSL2772 is not set
CONFIG_TSL4531=m
# CONFIG_US5182D is not set
# CONFIG_VCNL4000 is not set
# CONFIG_VCNL4035 is not set
# CONFIG_VEML6030 is not set
CONFIG_VEML6070=m
# CONFIG_VL6180 is not set
# CONFIG_ZOPT2201 is not set
# end of Light sensors
# Magnetometer sensors
# CONFIG_AK8974 is not set
# CONFIG_AK8975 is not set
# CONFIG_AK09911 is not set
# CONFIG_BMC150_MAGN_I2C is not set
# CONFIG_BMC150_MAGN_SPI is not set
# CONFIG_MAG3110 is not set
# CONFIG_MMC35240 is not set
# CONFIG_IIO_ST_MAGN_3AXIS is not set
# CONFIG_SENSORS_HMC5843_I2C is not set
# CONFIG_SENSORS_HMC5843_SPI is not set
# CONFIG_SENSORS_RM3100_I2C is not set
# CONFIG_SENSORS_RM3100_SPI is not set
# end of Magnetometer sensors
# Multiplexers
# CONFIG_IIO_MUX is not set
# end of Multiplexers
# Inclinometer sensors
# end of Inclinometer sensors
# Triggers - standalone
# CONFIG_IIO_INTERRUPT_TRIGGER is not set
# CONFIG_IIO_SYSFS_TRIGGER is not set
# end of Triggers - standalone
# Digital potentiometers
# CONFIG_AD5272 is not set
# CONFIG_DS1803 is not set
# CONFIG_MAX5432 is not set
# CONFIG_MAX5481 is not set
# CONFIG_MAX5487 is not set
# CONFIG_MCP4018 is not set
# CONFIG_MCP4131 is not set
# CONFIG_MCP4531 is not set
# CONFIG_MCP41010 is not set
# CONFIG_TPL0102 is not set
# end of Digital potentiometers
# Digital potentiostats
# CONFIG_LMP91000 is not set
# end of Digital potentiostats
# Pressure sensors
# CONFIG_ABP060MG is not set
CONFIG_BMP280=m
CONFIG_BMP280_I2C=m
CONFIG_BMP280_SPI=m
# CONFIG_DPS310 is not set
# CONFIG_HP03 is not set
# CONFIG_MPL115_I2C is not set
# CONFIG_MPL115_SPI is not set
# CONFIG_MPL3115 is not set
# CONFIG_MS5611 is not set
# CONFIG_MS5637 is not set
# CONFIG_IIO_ST_PRESS is not set
# CONFIG_T5403 is not set
# CONFIG_HP206C is not set
# CONFIG_ZPA2326 is not set
# end of Pressure sensors
# Lightning sensors
# CONFIG_AS3935 is not set
# end of Lightning sensors
# Proximity and distance sensors
# CONFIG_ISL29501 is not set
# CONFIG_LIDAR_LITE_V2 is not set
# CONFIG_MB1232 is not set
# CONFIG_RFD77402 is not set
# CONFIG_SRF04 is not set
# CONFIG_SX9500 is not set
# CONFIG_SRF08 is not set
# CONFIG_VL53L0X_I2C is not set
# end of Proximity and distance sensors
# CONFIG_AD2S90 is not set
# CONFIG_AD2S1200 is not set
# Temperature sensors
# CONFIG_LTC2983 is not set
# CONFIG_MAXIM_THERMOCOUPLE is not set
# CONFIG_MLX90614 is not set
# CONFIG_MLX90632 is not set
# CONFIG_TMP006 is not set
# CONFIG_TMP007 is not set
# CONFIG_TSYS01 is not set
# CONFIG_TSYS02D is not set
# CONFIG_MAX31856 is not set
# end of Temperature sensors
# CONFIG_NTB is not set
# CONFIG_VME_BUS is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
CONFIG_PWM_BCM2835=m
# CONFIG_PWM_FSL_FTM is not set
CONFIG_PWM_PCA9685=m
# CONFIG_PWM_STMPE is not set
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
# CONFIG_AL_FIC is not set
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_RESET_CONTROLLER=y
# CONFIG_RESET_TI_SYSCON is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_DP is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_CPCAP_USB is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
# CONFIG_PHY_SAMSUNG_USB2 is not set
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
# CONFIG_ARM_CCI_PMU is not set
# CONFIG_ARM_CCN is not set
CONFIG_ARM_PMU=y
CONFIG_RPI_AXIPERF=m
# end of Performance monitor support
CONFIG_RAS=y
# Android
# CONFIG_ANDROID is not set
# end of Android
# CONFIG_LIBNVDIMM is not set
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
# CONFIG_TEE is not set
CONFIG_MULTIPLEXER=m
# Multiplexer drivers
# CONFIG_MUX_ADG792A is not set
# CONFIG_MUX_ADGS1408 is not set
# CONFIG_MUX_GPIO is not set
# CONFIG_MUX_MMIO is not set
# end of Multiplexer drivers
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# CONFIG_INTERCONNECT is not set
# CONFIG_COUNTER is not set
# end of Device Drivers
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
CONFIG_REISERFS_FS_XATTR=y
CONFIG_REISERFS_FS_POSIX_ACL=y
CONFIG_REISERFS_FS_SECURITY=y
CONFIG_JFS_FS=m
CONFIG_JFS_POSIX_ACL=y
CONFIG_JFS_SECURITY=y
# CONFIG_JFS_DEBUG is not set
CONFIG_JFS_STATISTICS=y
CONFIG_XFS_FS=m
CONFIG_XFS_QUOTA=y
CONFIG_XFS_POSIX_ACL=y
CONFIG_XFS_RT=y
# CONFIG_XFS_ONLINE_SCRUB is not set
# CONFIG_XFS_WARN is not set
# CONFIG_XFS_DEBUG is not set
CONFIG_GFS2_FS=m
# CONFIG_GFS2_FS_LOCKING_DLM is not set
CONFIG_OCFS2_FS=m
CONFIG_OCFS2_FS_O2CB=m
CONFIG_OCFS2_FS_USERSPACE_CLUSTER=m
CONFIG_OCFS2_FS_STATS=y
CONFIG_OCFS2_DEBUG_MASKLOG=y
# CONFIG_OCFS2_DEBUG_FS is not set
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
# CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set
# CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set
# CONFIG_BTRFS_DEBUG is not set
# CONFIG_BTRFS_ASSERT is not set
# CONFIG_BTRFS_FS_REF_VERIFY is not set
CONFIG_NILFS2_FS=m
CONFIG_F2FS_FS=y
CONFIG_F2FS_STAT_FS=y
CONFIG_F2FS_FS_XATTR=y
CONFIG_F2FS_FS_POSIX_ACL=y
# CONFIG_F2FS_FS_SECURITY is not set
# CONFIG_F2FS_CHECK_FS is not set
# CONFIG_F2FS_IO_TRACE is not set
# CONFIG_F2FS_FAULT_INJECTION is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
# CONFIG_FS_VERITY is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
CONFIG_QUOTA=y
# CONFIG_QUOTA_NETLINK_INTERFACE is not set
CONFIG_PRINT_QUOTA_WARNING=y
# CONFIG_QUOTA_DEBUG is not set
CONFIG_QUOTA_TREE=m
CONFIG_QFMT_V1=m
CONFIG_QFMT_V2=m
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=y
CONFIG_AUTOFS_FS=y
CONFIG_FUSE_FS=m
CONFIG_CUSE=m
# CONFIG_VIRTIO_FS is not set
CONFIG_OVERLAY_FS=m
# CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
# CONFIG_OVERLAY_FS_INDEX is not set
# CONFIG_OVERLAY_FS_XINO_AUTO is not set
# CONFIG_OVERLAY_FS_METACOPY is not set
# Caches
CONFIG_FSCACHE=y
CONFIG_FSCACHE_STATS=y
CONFIG_FSCACHE_HISTOGRAM=y
# CONFIG_FSCACHE_DEBUG is not set
# CONFIG_FSCACHE_OBJECT_LIST is not set
CONFIG_CACHEFILES=y
# CONFIG_CACHEFILES_DEBUG is not set
# CONFIG_CACHEFILES_HISTOGRAM is not set
# end of Caches
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=m
# end of CD-ROM/DVD Filesystems
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="ascii"
# CONFIG_FAT_DEFAULT_UTF8 is not set
CONFIG_NTFS_FS=m
# CONFIG_NTFS_DEBUG is not set
CONFIG_NTFS_RW=y
# end of DOS/FAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
# CONFIG_HUGETLBFS is not set
CONFIG_MEMFD_CREATE=y
CONFIG_CONFIGFS_FS=y
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
CONFIG_ECRYPT_FS=m
# CONFIG_ECRYPT_FS_MESSAGING is not set
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
CONFIG_JFFS2_SUMMARY=y
# CONFIG_JFFS2_FS_XATTR is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_RTIME=y
CONFIG_UBIFS_FS=m
# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_ZSTD=y
# CONFIG_UBIFS_ATIME_SUPPORT is not set
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_SECURITY=y
# CONFIG_UBIFS_FS_AUTHENTICATION is not set
# CONFIG_CRAMFS is not set
CONFIG_SQUASHFS=m
CONFIG_SQUASHFS_FILE_CACHE=y
# CONFIG_SQUASHFS_FILE_DIRECT is not set
CONFIG_SQUASHFS_DECOMP_SINGLE=y
# CONFIG_SQUASHFS_DECOMP_MULTI is not set
# CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_ZLIB=y
# CONFIG_SQUASHFS_LZ4 is not set
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
# CONFIG_SQUASHFS_ZSTD is not set
# CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_EROFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_NFS_SWAP=y
CONFIG_NFS_V4_1=y
# CONFIG_NFS_V4_2 is not set
CONFIG_PNFS_FILE_LAYOUT=y
CONFIG_PNFS_BLOCK=m
CONFIG_PNFS_FLEXFILE_LAYOUT=m
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
# CONFIG_NFS_V4_1_MIGRATION is not set
CONFIG_ROOT_NFS=y
CONFIG_NFS_FSCACHE=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFSD=m
CONFIG_NFSD_V2_ACL=y
CONFIG_NFSD_V3=y
CONFIG_NFSD_V3_ACL=y
CONFIG_NFSD_V4=y
# CONFIG_NFSD_BLOCKLAYOUT is not set
# CONFIG_NFSD_SCSILAYOUT is not set
# CONFIG_NFSD_FLEXFILELAYOUT is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_SUNRPC_BACKCHANNEL=y
CONFIG_SUNRPC_SWAP=y
CONFIG_RPCSEC_GSS_KRB5=m
# CONFIG_SUNRPC_DISABLE_INSECURE_ENCTYPES is not set
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
CONFIG_CIFS=m
# CONFIG_CIFS_STATS2 is not set
CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y
CONFIG_CIFS_WEAK_PW_HASH=y
CONFIG_CIFS_UPCALL=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_CIFS_DEBUG=y
# CONFIG_CIFS_DEBUG2 is not set
# CONFIG_CIFS_DEBUG_DUMP_KEYS is not set
CONFIG_CIFS_DFS_UPCALL=y
CONFIG_CIFS_FSCACHE=y
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_9P_FS=m
# CONFIG_9P_FSCACHE is not set
CONFIG_9P_FS_POSIX_ACL=y
# CONFIG_9P_FS_SECURITY is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="utf8"
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_CODEPAGE_737=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852=m
CONFIG_NLS_CODEPAGE_855=m
CONFIG_NLS_CODEPAGE_857=m
CONFIG_NLS_CODEPAGE_860=m
CONFIG_NLS_CODEPAGE_861=m
CONFIG_NLS_CODEPAGE_862=m
CONFIG_NLS_CODEPAGE_863=m
CONFIG_NLS_CODEPAGE_864=m
CONFIG_NLS_CODEPAGE_865=m
CONFIG_NLS_CODEPAGE_866=m
CONFIG_NLS_CODEPAGE_869=m
CONFIG_NLS_CODEPAGE_936=m
CONFIG_NLS_CODEPAGE_950=m
CONFIG_NLS_CODEPAGE_932=m
CONFIG_NLS_CODEPAGE_949=m
CONFIG_NLS_CODEPAGE_874=m
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_3=m
CONFIG_NLS_ISO8859_4=m
CONFIG_NLS_ISO8859_5=m
CONFIG_NLS_ISO8859_6=m
CONFIG_NLS_ISO8859_7=m
CONFIG_NLS_ISO8859_9=m
CONFIG_NLS_ISO8859_13=m
CONFIG_NLS_ISO8859_14=m
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R=m
CONFIG_NLS_KOI8_U=m
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
CONFIG_NLS_UTF8=m
CONFIG_DLM=m
# CONFIG_DLM_DEBUG is not set
# CONFIG_UNICODE is not set
CONFIG_IO_WQ=y
# end of File systems
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_REQUEST_CACHE is not set
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_TRUSTED_KEYS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
CONFIG_SECURITYFS=y
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_FORTIFY_SOURCE is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_XOR_BLOCKS=m
CONFIG_ASYNC_CORE=m
CONFIG_ASYNC_MEMCPY=m
CONFIG_ASYNC_XOR=m
CONFIG_ASYNC_PQ=m
CONFIG_ASYNC_RAID6_RECOV=m
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=m
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_SKCIPHER=y
CONFIG_CRYPTO_SKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=m
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=m
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_KPP=m
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=m
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_PCRYPT is not set
CONFIG_CRYPTO_CRYPTD=m
CONFIG_CRYPTO_AUTHENC=m
# CONFIG_CRYPTO_TEST is not set
CONFIG_CRYPTO_SIMD=m
# Public-key cryptography
CONFIG_CRYPTO_RSA=y
# CONFIG_CRYPTO_DH is not set
CONFIG_CRYPTO_ECC=m
CONFIG_CRYPTO_ECDH=m
# CONFIG_CRYPTO_ECRDSA is not set
# CONFIG_CRYPTO_CURVE25519 is not set
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
# CONFIG_CRYPTO_AEGIS128 is not set
CONFIG_CRYPTO_SEQIV=m
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CFB is not set
CONFIG_CRYPTO_CTR=m
CONFIG_CRYPTO_CTS=m
CONFIG_CRYPTO_ECB=m
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_OFB is not set
# CONFIG_CRYPTO_PCBC is not set
CONFIG_CRYPTO_XTS=m
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_ADIANTUM is not set
CONFIG_CRYPTO_ESSIV=m
# Hash modes
CONFIG_CRYPTO_CMAC=m
CONFIG_CRYPTO_HMAC=m
CONFIG_CRYPTO_XCBC=m
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
CONFIG_CRYPTO_CRC32=y
CONFIG_CRYPTO_XXHASH=m
CONFIG_CRYPTO_BLAKE2B=m
# CONFIG_CRYPTO_BLAKE2S is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
CONFIG_CRYPTO_GHASH=m
# CONFIG_CRYPTO_POLY1305 is not set
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=m
CONFIG_CRYPTO_MICHAEL_MIC=m
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=m
CONFIG_CRYPTO_SHA256=m
CONFIG_CRYPTO_SHA512=m
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_STREEBOG is not set
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_WP512=m
# Ciphers
CONFIG_CRYPTO_AES=m
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=m
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
CONFIG_CRYPTO_CAST_COMMON=m
CONFIG_CRYPTO_CAST5=m
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_SM4 is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_LZO=m
# CONFIG_CRYPTO_842 is not set
CONFIG_CRYPTO_LZ4=m
# CONFIG_CRYPTO_LZ4HC is not set
CONFIG_CRYPTO_ZSTD=m
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_DRBG_MENU=m
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=m
CONFIG_CRYPTO_JITTERENTROPY=m
CONFIG_CRYPTO_USER_API=m
# CONFIG_CRYPTO_USER_API_HASH is not set
CONFIG_CRYPTO_USER_API_SKCIPHER=m
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
# CONFIG_CRYPTO_STATS is not set
CONFIG_CRYPTO_HASH_INFO=y
# Crypto library routines
CONFIG_CRYPTO_LIB_AES=m
CONFIG_CRYPTO_LIB_ARC4=m
# CONFIG_CRYPTO_LIB_BLAKE2S is not set
# CONFIG_CRYPTO_LIB_CHACHA is not set
# CONFIG_CRYPTO_LIB_CURVE25519 is not set
CONFIG_CRYPTO_LIB_DES=y
CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
# CONFIG_CRYPTO_LIB_POLY1305 is not set
# CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_LIB_SHA256=m
# CONFIG_CRYPTO_HW is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
# CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
# CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
CONFIG_BINARY_PRINTF=y
# Library routines
CONFIG_RAID6_PQ=m
CONFIG_RAID6_PQ_BENCHMARK=y
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_CORDIC=m
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_CRC_CCITT=m
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC64 is not set
# CONFIG_CRC4 is not set
CONFIG_CRC7=m
CONFIG_LIBCRC32C=y
CONFIG_CRC8=m
CONFIG_XXHASH=m
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=m
CONFIG_LZO_COMPRESS=m
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMPRESS=m
CONFIG_ZSTD_DECOMPRESS=m
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_BTREE=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_DMA_ADDR_T_64BIT=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y
CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y
CONFIG_SWIOTLB=y
CONFIG_DMA_NONCOHERENT_MMAP=y
CONFIG_DMA_REMAP=y
CONFIG_DMA_CMA=y
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=5
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
# CONFIG_DMA_API_DEBUG is not set
CONFIG_SGL_ALLOC=y
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
CONFIG_LRU_CACHE=m
CONFIG_CLZ_TAB=y
# CONFIG_IRQ_POLL is not set
CONFIG_MPILIB=y
CONFIG_DIMLIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_HAVE_GENERIC_VDSO=y
CONFIG_GENERIC_GETTIMEOFDAY=y
CONFIG_GENERIC_VDSO_32=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# end of Library routines
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
CONFIG_BOOT_PRINTK_DELAY=y
# CONFIG_DYNAMIC_DEBUG is not set
CONFIG_SYMBOLIC_ERRNAME=y
CONFIG_DEBUG_BUGVERBOSE=y
# end of printk and dmesg options
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_HEADERS_INSTALL is not set
CONFIG_OPTIMIZE_INLINING=y
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
CONFIG_ARCH_WANT_FRAME_POINTERS=y
CONFIG_FRAME_POINTER=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
# Generic Kernel Debugging Instruments
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
CONFIG_MAGIC_SYSRQ_SERIAL=y
CONFIG_DEBUG_FS=y
CONFIG_HAVE_ARCH_KGDB=y
CONFIG_KGDB=y
CONFIG_KGDB_SERIAL_CONSOLE=y
# CONFIG_KGDB_TESTS is not set
CONFIG_KGDB_KDB=y
CONFIG_KDB_DEFAULT_ENABLE=0x1
CONFIG_KDB_KEYBOARD=y
CONFIG_KDB_CONTINUE_CATASTROPHIC=0
# CONFIG_UBSAN is not set
CONFIG_UBSAN_ALIGNMENT=y
# end of Generic Kernel Debugging Instruments
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_PAGE_REF is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_DEBUG_PER_CPU_MAPS is not set
# CONFIG_DEBUG_HIGHMEM is not set
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_KASAN_STACK=1
# end of Memory Debugging
# CONFIG_DEBUG_SHIRQ is not set
# Debug Oops, Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
# CONFIG_SOFTLOCKUP_DETECTOR is not set
CONFIG_DETECT_HUNG_TASK=y
CONFIG_DEFAULT_HUNG_TASK_TIMEOUT=120
# CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
# CONFIG_WQ_WATCHDOG is not set
# end of Debug Oops, Lockups and Hangs
# Scheduler Debugging
CONFIG_SCHED_DEBUG=y
CONFIG_SCHED_INFO=y
CONFIG_SCHEDSTATS=y
# end of Scheduler Debugging
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_TRACE_IRQFLAGS=y
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
# Debug kernel data structures
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# end of Debug kernel data structures
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=21
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
CONFIG_LATENCYTOP=y
CONFIG_NOP_TRACER=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACER_MAX_TRACE=y
CONFIG_TRACE_CLOCK=y
CONFIG_RING_BUFFER=y
CONFIG_EVENT_TRACING=y
CONFIG_CONTEXT_SWITCH_TRACER=y
CONFIG_RING_BUFFER_ALLOW_SWAP=y
CONFIG_PREEMPTIRQ_TRACEPOINTS=y
CONFIG_TRACING=y
CONFIG_GENERIC_TRACER=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
CONFIG_FUNCTION_TRACER=y
CONFIG_FUNCTION_GRAPH_TRACER=y
# CONFIG_PREEMPTIRQ_EVENTS is not set
CONFIG_IRQSOFF_TRACER=y
CONFIG_SCHED_TRACER=y
# CONFIG_HWLAT_TRACER is not set
# CONFIG_FTRACE_SYSCALLS is not set
CONFIG_TRACER_SNAPSHOT=y
CONFIG_TRACER_SNAPSHOT_PER_CPU_SWAP=y
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
CONFIG_STACK_TRACER=y
CONFIG_BLK_DEV_IO_TRACE=y
CONFIG_KPROBE_EVENTS=y
# CONFIG_UPROBE_EVENTS is not set
CONFIG_BPF_EVENTS=y
CONFIG_DYNAMIC_EVENTS=y
CONFIG_PROBE_EVENTS=y
CONFIG_DYNAMIC_FTRACE=y
CONFIG_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_FUNCTION_PROFILER=y
CONFIG_FTRACE_MCOUNT_RECORD=y
# CONFIG_FTRACE_STARTUP_TEST is not set
# CONFIG_TRACE_EVENT_INJECT is not set
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_RING_BUFFER_STARTUP_TEST is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
# CONFIG_TRACE_EVAL_MAP_FILE is not set
# CONFIG_SAMPLES is not set
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
# arm Debugging
# CONFIG_ARM_PTDUMP_DEBUGFS is not set
# CONFIG_DEBUG_WX is not set
CONFIG_UNWINDER_FRAME_POINTER=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_ARM_KPROBES_TEST is not set
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
# end of arm Debugging
# Kernel Testing and Coverage
# CONFIG_KUNIT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
CONFIG_RUNTIME_TESTING_MENU=y
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_SORT is not set
# CONFIG_KPROBES_SANITY_TEST is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_REED_SOLOMON_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_ASYNC_RAID6_TEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_STRSCPY is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_BITFIELD is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_XARRAY is not set
# CONFIG_TEST_OVERFLOW is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_IDA is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_VMALLOC is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_BLACKHOLE_DEV is not set
# CONFIG_FIND_BIT_BENCHMARK is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_TEST_MEMCAT_P is not set
# CONFIG_TEST_STACKINIT is not set
# CONFIG_TEST_MEMINIT is not set
# CONFIG_MEMTEST is not set
# end of Kernel Testing and Coverage
# end of Kernel hacking
soystemd-free diet
#13 2020-01-16 20:16:32
tuxd3v
Re: Is any work planned for devuan on the raspberry pi 4?
uther wrote:
We have some progress. I've extracted two configs. Default 4.19.75-v7l+ (just in case) and 5.5.0-rc6-v7l+ They're pretty lenghy, so do you prefer them pasted here directly or on some pastebin?
During compilation 5.5.0 kernel there was couple of warnings about soundcard and Realtek network card. No errors thou.
Thanks a lot for your work smile
I assume the default kernel that comes in Raspbian is the '4.19.75-v7l+' ?
Have you tested the WiFi/Bluetooth , and the network?
Can you do, in the default image,and kernel, as root:
dmesg
You can use any site available, I usually use: paste2, others use another service they like smile
Best Regards,
tux
Best Regards,
tux
#14 2020-01-16 23:02:31
uther
Do the most selfless things out of the most selfish reasons. wink
That's correct.
Network - yes, and it works, I didn't run any particular tests, but was able to download updates and browse the web.
WiFi - yes, it works.
Bluetooth - must check
Audio - does not work either OOTB or after the update && upgrade
Periferals - keyboard works only after reconnecting the cable. After booting up, the LED on the keyboard does not light up.
The biggest issue acually was to output to the screen properly. I needed to put hdmi_force_hotplug=1 in the /boot/config.txt, otherwise there's no signal after boot. And only one µHDMI port works properly - the one near USB-c. At least that's the case with my display. As of now the 1024x768 image is streched to native display resolution. I know I can tweak it in config.txt, but didn't bother yet.
def kernel dmesg dump
root@raspberrypi:/home/pi# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[    0.000000] On node 0 totalpages: 1012736
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
[    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:640x480M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 video=HDMI-A-2:1280x720M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=00:A6:32:64:BB:73 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 3735592K/4050944K available (8192K kernel code, 661K rwdata, 2352K rodata, 2048K init, 850K bss, 53208K reserved, 262144K cma-reserved, 3264512K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   ( 662 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 28124 entries in 83 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000018] Switching to timer-based delay loop, resolution 18ns
[    0.000241] Console: colour dummy device 80x30
[    0.000265] console [tty1] enabled
[    0.000306] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.000328] pid_max: default: 32768 minimum: 301
[    0.000589] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000607] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001353] CPU: Testing write buffer coherency: ok
[    0.001763] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002403] Setting up static identity map for 0x200000 - 0x20003c
[    0.002560] rcu: Hierarchical SRCU implementation.
[    0.003418] smp: Bringing up secondary CPUs ...
[    0.004320] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005357] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.006346] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.006478] smp: Brought up 1 node, 4 CPUs
[    0.006492] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.006502] CPU: All CPU(s) started in HYP mode.
[    0.006510] CPU: Virtualization extensions available.
[    0.007296] devtmpfs: initialized
[    0.017674] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.017878] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.017899] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.025431] pinctrl core: initialized pinctrl subsystem
[    0.026284] NET: Registered protocol family 16
[    0.029286] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.030795] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.030805] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.030998] Serial: AMBA PL011 UART driver
[    0.034031] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.069690] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[    0.072138] vgaarb: loaded
[    0.072504] SCSI subsystem initialized
[    0.072700] usbcore: registered new interface driver usbfs
[    0.072751] usbcore: registered new interface driver hub
[    0.072818] usbcore: registered new device driver usb
[    0.090402] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-24 17:34, variant start
[    0.100115] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8fa065b414d8fc07c525e7ddffc8
[    0.111657] clocksource: Switched to clocksource arch_sys_counter
[    0.189107] VFS: Disk quotas dquot_6.6.0
[    0.189183] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.189334] FS-Cache: Loaded
[    0.189517] CacheFiles: Loaded
[    0.190032] simple-framebuffer 3eb62000.framebuffer: framebuffer at 0x3eb62000, 0x96000 bytes, mapped to 0x(ptrval)
[    0.190046] simple-framebuffer 3eb62000.framebuffer: format=r5g6b5, mode=640x480x16, linelength=1280
[    0.191486] Console: switching to colour frame buffer device 80x30
[    0.192773] simple-framebuffer 3eb62000.framebuffer: fb0: simplefb registered!
[    0.201782] NET: Registered protocol family 2
[    0.202434] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.202459] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.202530] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.202600] TCP: Hash tables configured (established 8192 bind 8192)
[    0.202720] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.202746] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.203036] NET: Registered protocol family 1
[    0.203574] RPC: Registered named UNIX socket transport module.
[    0.203584] RPC: Registered udp transport module.
[    0.203594] RPC: Registered tcp transport module.
[    0.203602] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.203618] PCI: CLS 0 bytes, default 64
[    0.206669] Initialise system trusted keyrings
[    0.206826] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[    0.215783] FS-Cache: Netfs 'nfs' registered for caching
[    0.216277] NFS: Registering the id_resolver key type
[    0.216309] Key type id_resolver registered
[    0.216319] Key type id_legacy registered
[    0.216337] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.218575] Key type asymmetric registered
[    0.218585] Asymmetric key parser 'x509' registered
[    0.218694] bounce: pool size: 64 pages
[    0.218742] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.218903] io scheduler noop registered
[    0.218914] io scheduler deadline registered (default)
[    0.219063] io scheduler cfq registered
[    0.219074] io scheduler mq-deadline registered (default)
[    0.219084] io scheduler kyber registered
[    0.250559] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[    0.250578] brcm-pcie fd500000.pcie: could not get clock
[    0.250639] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    0.250676] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[    0.301692] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[    0.301961] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    0.301977] pci_bus 0000:00: root bus resource [bus 00-01]
[    0.301993] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[    0.302036] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    0.302178] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.304918] PCI: bus0: Fast back to back transfers disabled
[    0.304935] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.305137] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    0.305262] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.305583] pci 0000:01:00.0: PME# supported from D0 D3cold
[    0.308325] PCI: bus1: Fast back to back transfers disabled
[    0.308342] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[    0.308388] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    0.308407] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    0.308478] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.308495] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    0.308703] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    0.308882] pcieport 0000:00:00.0: Signaling PME with IRQ 55
[    0.309049] pcieport 0000:00:00.0: AER enabled with IRQ 55
[    0.309217] pci 0000:01:00.0: enabling device (0140 -> 0142)
[    0.312479] iproc-rng200 fe104000.rng: hwrng registered
[    0.312693] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.313185] vc-sm: Videocore shared memory driver
[    0.313576] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    0.323524] brd: module loaded
[    0.333171] loop: module loaded
[    0.333900] Loading iSCSI transport class v2.0-870.
[    0.335566] libphy: Fixed MDIO Bus: probed
[    0.335980] bcmgenet fd580000.genet: failed to get enet clock
[    0.335997] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[    0.336014] bcmgenet fd580000.genet: failed to get enet-wol clock
[    0.336029] bcmgenet fd580000.genet: failed to get enet-eee clock
[    0.336052] bcmgenet: Skipping UMAC reset
[    0.336275] unimac-mdio unimac-mdio.-19: DMA mask not set
[    0.351687] libphy: bcmgenet MII bus: probed
[    0.392212] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[    0.393098] usbcore: registered new interface driver r8152
[    0.393158] usbcore: registered new interface driver lan78xx
[    0.393211] usbcore: registered new interface driver smsc95xx
[    0.393509] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.393539] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    0.395780] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[    0.396096] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 56
[    0.396961] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.396974] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.396986] usb usb1: Product: xHCI Host Controller
[    0.396996] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[    0.397007] usb usb1: SerialNumber: 0000:01:00.0
[    0.397522] hub 1-0:1.0: USB hub found
[    0.397603] hub 1-0:1.0: 1 port detected
[    0.398065] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.398088] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    0.398106] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    0.398519] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    0.398532] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.398544] usb usb2: Product: xHCI Host Controller
[    0.398555] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[    0.398566] usb usb2: SerialNumber: 0000:01:00.0
[    0.399057] hub 2-0:1.0: USB hub found
[    0.399121] hub 2-0:1.0: 4 ports detected
[    0.400289] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.425858] dwc_otg fe980000.usb: base=(ptrval)
[    0.626114] Core Release: 2.80a
[    0.626134] Setting default values for core params
[    0.626163] Finished setting default values for core params
[    0.826490] Using Buffer DMA mode
[    0.826500] Periodic Transfer Interrupt Enhancement - disabled
[    0.826509] Multiprocessor Interrupt Enhancement - disabled
[    0.826520] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.826578] Dedicated Tx FIFOs mode
[    0.827214] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded34000 dma = 0x00000000ded34000 len=9024
[    0.827238] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.827250] dwc_otg: Microframe scheduler enabled
[    0.827313] WARN::hcd_init_fiq:457: FIQ on core 1
[    0.827329] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
[    0.827346] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[    0.827380] dwc_otg fe980000.usb: DWC OTG Controller
[    0.827410] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[    0.827441] dwc_otg fe980000.usb: irq 37, io mem 0x00000000
[    0.827494] Init: Port Power? op_state=1
[    0.827503] Init: Power Port (0)
[    0.827760] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.827773] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.827785] usb usb3: Product: DWC OTG Controller
[    0.827796] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
[    0.827806] usb usb3: SerialNumber: fe980000.usb
[    0.828306] hub 3-0:1.0: USB hub found
[    0.828354] hub 3-0:1.0: 1 port detected
[    0.828941] dwc_otg: FIQ enabled
[    0.828950] dwc_otg: NAK holdoff enabled
[    0.828959] dwc_otg: FIQ split-transaction FSM enabled
[    0.828972] Module dwc_common_port init
[    0.829175] usbcore: registered new interface driver uas
[    0.829285] usbcore: registered new interface driver usb-storage
[    0.829450] mousedev: PS/2 mouse device common for all mice
[    0.830597] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.830796] bcm2835-cpufreq: min=600000 max=1500000
[    0.831394] sdhci: Secure Digital Host Controller Interface driver
[    0.831403] sdhci: Copyright(c) Pierre Ossman
[    0.831813] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    0.832180] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.835140] ledtrig-cpu: registered to indicate activity on CPUs
[    0.835278] hidraw: raw HID events driver (C) Jiri Kosina
[    0.835399] usbcore: registered new interface driver usbhid
[    0.835408] usbhid: USB HID core driver
[    0.836175] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[    0.837979] [vc_sm_connected_init]: start
[    0.847335] [vc_sm_connected_init]: end - returning 0
[    0.848390] Initializing XFRM netlink socket
[    0.848417] NET: Registered protocol family 17
[    0.848498] Key type dns_resolver registered
[    0.848902] Registering SWP/SWPB emulation handler
[    0.849487] registered taskstats version 1
[    0.849503] Loading compiled-in X.509 certificates
[    0.857249] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    0.857314] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    0.860275] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    0.860777] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[    0.861387] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    0.861399] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    0.887465] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[    0.905724] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.907329] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.908934] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.911935] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.913545] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.922528] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    0.925008] of_cfs_init
[    0.925089] of_cfs_init: OK
[    0.925747] Waiting for root device /dev/mmcblk0p7...
[    0.971035] random: fast init done
[    0.971714] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    0.982568] mmc1: new high speed SDIO card at address 0001
[    1.027796] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[    1.028951] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    1.033169]  mmcblk0: p1 p2 < p5 p6 p7 >
[    1.050290] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.050330] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[    1.055581] devtmpfs: mounted
[    1.061934] Freeing unused kernel memory: 2048K
[    1.091912] Run /sbin/init as init process
[    1.154355] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[    1.154370] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.154382] usb 1-1: Product: USB2.0 Hub
[    1.156132] hub 1-1:1.0: USB hub found
[    1.156479] hub 1-1:1.0: 4 ports detected
[    1.481704] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[    1.541953] systemd[1]: System time before build time, advancing clock.
[    1.622704] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.09
[    1.622719] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.622730] usb 1-1.3: Product: USB Receiver
[    1.622742] usb 1-1.3: Manufacturer: Logitech
[    1.644516] NET: Registered protocol family 10
[    1.645730] Segment Routing with IPv6
[    1.687501] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.688161] systemd[1]: Detected architecture arm.
[    1.695830] systemd[1]: Set hostname to <raspberrypi>.
[    1.697998] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[    1.970034] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    1.970055] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.355128] random: systemd: uninitialized urandom read (16 bytes read)
[    2.363720] random: systemd: uninitialized urandom read (16 bytes read)
[    2.364241] systemd[1]: Listening on fsck to fsckd communication Socket.
[    2.364664] random: systemd: uninitialized urandom read (16 bytes read)
[    2.365273] systemd[1]: Listening on Journal Socket.
[    2.374408] systemd[1]: Mounting POSIX Message Queue File System...
[    2.385726] systemd[1]: Starting Load Kernel Modules...
[    2.479494] i2c /dev entries driver
[    2.842110] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[    2.978216] systemd-journald[110]: Received request to flush runtime journal from PID 1
[    3.534911] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[    3.540230] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[    3.542963] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[    3.547955] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[    3.565568] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    3.567864] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    3.567887] [vc_sm_connected_init]: start
[    3.571447] [vc_sm_connected_init]: installed successfully
[    3.582573] media: Linux media interface: v0.10
[    3.606688] videodev: Linux video capture interface: v2.00
[    3.657182] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.657490] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    3.689885] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    3.740455] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    3.749493] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    3.768024] bcm2835_audio soc:audio: card created with 8 channels
[    3.802409] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    3.802446] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    3.810856] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    3.810889] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    3.825574] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    3.825607] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    4.066657] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    4.066690] checking generic (3eb62000 96000) vs hw (0 ffffffffffffffff)
[    4.066701] fb: switching to vc4drmfb from simple
[    4.067257] Console: switching to colour dummy device 80x30
[    4.068484] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[    4.068500] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.068510] [drm] No driver support for vblank timestamp query.
[    4.068518] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[    4.070395] vc4-drm soc:gpu: HDMI-A-1: EDID is invalid:
[    4.070412] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.070422] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.070432] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.070441] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.070450] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.070459] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.070468] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.070478] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.090102] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    4.132712] Console: switching to colour frame buffer device 80x30
[    4.132759] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[    4.257685] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.355142] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.356917] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[    4.460695] brcmfmac: F1 signature read @0x18000000=0x15264345
[    4.469874] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.470760] usbcore: registered new interface driver brcmfmac
[    4.497812] input: Logitech Unifying Device. Wireless PID:4082 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4082.0004/input/input0
[    4.498594] input: Logitech Unifying Device. Wireless PID:4082 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4082.0004/input/input1
[    4.499033] hid-generic 0003:046D:4082.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4082] on usb-0000:01:00.0-1.3:1
[    4.704341] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.719720] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[    4.823391] input: Logitech MX Master 3 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4082.0004/input/input5
[    4.824380] logitech-hidpp-device 0003:046D:4082.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Master 3] on usb-0000:01:00.0-1.3:1
[    6.676963] random: crng init done
[    6.676983] random: 7 urandom warning(s) missed due to ratelimiting
[    6.841509] 8021q: 802.1Q VLAN Support v1.8
[    6.895163] uart-pl011 fe201000.serial: no DMA platform data
[    7.228737] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    7.411009] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    7.411027] brcmfmac: power management disabled
[    7.840323] bcmgenet: Skipping UMAC reset
[    7.942188] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[    7.942499] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.986462] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    8.951775] bcmgenet fd580000.genet eth0: Link is Down
[   12.091242] fuse init (API version 7.27)
[   13.290608] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   13.629462] Bluetooth: Core ver 2.22
[   13.629516] NET: Registered protocol family 31
[   13.629520] Bluetooth: HCI device and connection manager initialized
[   13.629532] Bluetooth: HCI socket layer initialized
[   13.629540] Bluetooth: L2CAP socket layer initialized
[   13.629561] Bluetooth: SCO socket layer initialized
[   13.645599] Bluetooth: HCI UART driver ver 2.3
[   13.645606] Bluetooth: HCI UART protocol H4 registered
[   13.645644] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   13.645748] Bluetooth: HCI UART protocol Broadcom registered
[   13.936697] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.936704] Bluetooth: BNEP filters: protocol multicast
[   13.936714] Bluetooth: BNEP socket layer initialized
[   13.971191] Bluetooth: RFCOMM TTY layer initialized
[   13.971204] Bluetooth: RFCOMM socket layer initialized
[   13.971217] Bluetooth: RFCOMM ver 1.11
[   18.311031] logitech-hidpp-device 0003:046D:4082.0004: HID++ 4.5 device connected.
[   30.101710] usb 1-1.1: new low-speed USB device number 4 using xhci_hcd
[   30.269228] usb 1-1.1: New USB device found, idVendor=2516, idProduct=001a, bcdDevice= 1.04
[   30.269245] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   30.269258] usb 1-1.1: Product: Keyboard -- QuickFire XT
[   30.269269] usb 1-1.1: Manufacturer: CM Storm
[   30.297790] input: CM Storm Keyboard -- QuickFire XT as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:2516:001A.0005/input/input6
[   30.362561] hid-generic 0003:2516:001A.0005: input,hidraw2: USB HID v1.10 Keyboard [CM Storm Keyboard -- QuickFire XT] on usb-0000:01:00.0-1.1/input0
[   30.398167] input: CM Storm Keyboard -- QuickFire XT Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:2516:001A.0006/input/input7
[   30.462077] input: CM Storm Keyboard -- QuickFire XT System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:2516:001A.0006/input/input8
[   30.462409] hid-generic 0003:2516:001A.0006: input,hidraw3: USB HID v1.10 Device [CM Storm Keyboard -- QuickFire XT] on usb-0000:01:00.0-1.1/input1
[   30.571051] usb 1-1.1: USB disconnect, device number 4
[   33.171713] usb 1-1.4: new low-speed USB device number 5 using xhci_hcd
[   33.339438] usb 1-1.4: New USB device found, idVendor=2516, idProduct=001a, bcdDevice= 1.04
[   33.339455] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   33.339468] usb 1-1.4: Product: Keyboard -- QuickFire XT
[   33.339480] usb 1-1.4: Manufacturer: CM Storm
[   33.360298] input: CM Storm Keyboard -- QuickFire XT as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:2516:001A.0007/input/input9
[   33.422633] hid-generic 0003:2516:001A.0007: input,hidraw2: USB HID v1.10 Keyboard [CM Storm Keyboard -- QuickFire XT] on usb-0000:01:00.0-1.4/input0
[   33.458712] input: CM Storm Keyboard -- QuickFire XT Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:2516:001A.0008/input/input10
[   33.522144] input: CM Storm Keyboard -- QuickFire XT System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:2516:001A.0008/input/input11
[   33.522499] hid-generic 0003:2516:001A.0008: input,hidraw3: USB HID v1.10 Device [CM Storm Keyboard -- QuickFire XT] on usb-0000:01:00.0-1.4/input1
[  130.005620] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  130.005636] brcmfmac: power management disabled
[  138.587219] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  323.661624] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  323.661711] brcmfmac: power management disabled
[  326.371895] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  326.371914] brcmfmac: power management disabled
[  339.671886] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
[  339.671926] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  424.358348] usb 1-1.3: USB disconnect, device number 3
[  439.501833] usb 1-1.3: new full-speed USB device number 6 using xhci_hcd
[  439.642842] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.09
[  439.642859] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  439.642872] usb 1-1.3: Product: USB Receiver
[  439.642884] usb 1-1.3: Manufacturer: Logitech
[  439.674088] logitech-djreceiver 0003:046D:C52B.000B: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[  439.827351] input: Logitech MX Master 3 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.000B/0003:046D:4082.000C/input/input12
[  439.828619] logitech-hidpp-device 0003:046D:4082.000C: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Master 3] on usb-0000:01:00.0-1.3:1
[  440.248971] logitech-hidpp-device 0003:046D:4082.000C: HID++ 4.5 device connected.
[  507.826812] usb 1-1.3: USB disconnect, device number 6
[  535.263447] usb 1-1.3: new full-speed USB device number 7 using xhci_hcd
[  535.404400] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.09
[  535.404416] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  535.404429] usb 1-1.3: Product: USB Receiver
[  535.404441] usb 1-1.3: Manufacturer: Logitech
[  535.434219] logitech-djreceiver 0003:046D:C52B.000F: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[  535.590715] input: Logitech MX Master 3 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.000F/0003:046D:4082.0010/input/input13
[  535.592016] logitech-hidpp-device 0003:046D:4082.0010: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Master 3] on usb-0000:01:00.0-1.3:1
[  537.726613] logitech-hidpp-device 0003:046D:4082.0010: HID++ 4.5 device connected.
soystemd-free diet
#15 2020-01-17 09:59:15
N.B. If only using one monitor, you have to use the HDMI socket next to the USB C power socket.
(I'm not using mine at the moment, still awaiting EDID & USB boot to get fixed.)
I also had to add,
hdmi_force_hotplug:0=1
hdmi_group=2
hdmi_mode=39 (or 81 to get 1366x768)
when using Raspbian O/S.
#16 2020-01-17 23:02:19
tuxd3v
Hello,
I tried to create a config file and this is the result, I also compared it with 4.19 and also 5.5, and your dmesg..
Its a good start...the kernel has also support for 2 other broadcom Socs..
but it supports raspberrypi3,4 arm64..
You can check Here the Image, and also the kernels
NOTES!!
When the Image was produced,I didn't notice, but my RPI4 builder config, had at least 1 bug sad
You need to edit '/etc/fstab'
Change:
/dev/mmcblk0p1        /boot    ext2    defaults        0        2
to
/dev/mmcblk0p1        /boot    vfat    defaults        0        2
Please provide some feedback,
things you think should be improved smile
Best Regards,
tux
#17 2020-01-18 12:28:20
uther
Oh. So that accually shows my laziness. My apologies then.
tuxd3v wrote:
NOTES!!
Change:
to
Good to know! Downloaded all the packages. I should do tests tommorow.
If there are particular logs you want to inspect, let me know beforehand, so I could extract them all at once.
From monday I'm going offgrid for a couple of days. Next weekend I plan to do more extensive tests if the image you provided boots up properly - some light number crunching, default settings tweaking, maybe softRAID setup and code compilation.
soystemd-free diet
#18 2020-01-18 18:54:29
tuxd3v
This preliminary Image needs editing '/etc/fstab', you can burn the image in a card and the edit fstab on the card smile
Next image will have that corrected..
root Passwd: 'tor'
devuan Passwd: 'devuan'
Things that would be interesting would be,
a) If you have a serial debugger, connect to the uart, and get all the information about bootloader/boot process.
b) Find if thermal zones do exist, what temps system have..if something really out of what to be expected..
find /sys/class/thermal -name thermal_\* -exec ls -l {} \; -exec cat {}/temp \;
c) Get information about cpuinfo, and if it is correct..
'cat /proc/cpuinfo'
d) get information about swap, and system memory:
swapon -a && free -m
e) check swap quantity and algos( it should be 'lz4' )
swapon --show
find /sys/class/block -name zram\* -exec cat {}/comp_algorithm \;
f) List Loaded Modules:
lsmod
I updated the shared folder with '.condig' file for kernel 5.5, 'bcm2711_defconfig',
Updated also the generated kernel/KernelHeaders/Modules/Libc_headers( for this updated .config )
Feel free to provide information that you also think would be useful, like WiFi/Bluetooth, or adjust the config file wink
Share your thoughts smile
Best Regards,
tux
#19 2020-01-19 16:08:24
tuxd3v
Hello Uther,
Does you know if the image boot's up?
I updated Image, kernel and so on, for the current .config file 'bcm2711_defconfig', present in the shared folder smile
the fstab problem was solved, added also in '/boot/config.txt'
# 64bit-mode
arm_control=0x200
Best Regards,
tux
Best Regards,
tux
#20 2020-01-19 17:08:54
uther
I've just downloaded updated image. I'm flashing it right now, so we will see.
ED: Ok. So we have first obstacle. I've never accually booted up system this way, so forgive me any stupid questions at this point.
I see there is linux-headers directory in /usr/src and there is vmlinuz executive in /boot/. So what is the purpose of the .deb packages with the kernel?
ED2: The newest image still contains fstab bug. I needed to change ext4 to vfat manually under /boot/.
soystemd-free diet
#21 2020-01-19 17:30:01
tuxd3v
I see there is linux-headers directory in /usr/src and there is vmlinuz executive in /boot/. So what are .deb packages wiht the kernel for?
No problem...that packages are or will be installed inside the system, once it boot up smile
Indeed there are there already a kernel, vmlinuz...
But don't worry with that.. it says 'vmlinuz' instead of 'vmlinux' but it his a uncompressed image ( 'vmlinux' ), the name is for a compressed one.. don't pay attention to it smile
There are several packages because one of main failures in distributions is that they provide a kernel but forget to provide the headers, and libc-dev so if you really want to make development you are stopped right there..
To ensure that everyone has the tools to proceed in its projects all the packages are provided smile
EDIT: Dont install linux-image-5.5.0-rc6+-2-dbg_arm64.deb
You can copy them to sdcard( exclude dbg package.. ), and when system boot's up, install them:
dpkg -i linux-headers-5.5.0-rc6+-2_arm64.deb  linux-image-5.5.0-rc6+-2_arm64.deb  linux-libc-dev_5.5.0-rc6+-2_arm64.deb
No, the new Image has the ext2 corrected fo vfat:
# <file system>	<dir>	<type>	<options>		<dump>		<pass>
/dev/mmcblk0p2		/	ext4	defaults,noatime	0		1
/dev/zram0 		none    swap    pri=1			0		0
/dev/zram1 		none    swap    pri=2			0		0
/dev/zram2 		none    swap    pri=4			0		0
/dev/zram3 		none    swap    pri=3			0		0
Best Regards,
tux
#22 2020-01-19 17:56:45
tuxd3v
If you are not able to boot, according with some documentation, change in '/boot/config.txt':
arm_control=0x200 -> arm_64bit=1
Best Regards,
tux
#23 2020-01-19 17:57:53
uther
tuxd3v wrote:
No, the new Image has the 'ext2' corrected fo 'vfat':
Sorry, I'm blind. I downloaded alpha version two times.
Anyway. Alpha image didn't boot. Sequence was stuck at rainbow square.
For the record, I've unpacked the archive with unxz, flashed .img with dd and edited fstab. .deb files were copied to /usr/src
I'm downloading beta right now.
Will try, thanks.
soystemd-free diet
#24 2020-01-19 18:08:01
tuxd3v
No problem smile
At least we know that the alpha kernel, or the config.txt was wrong..
yeah I should have done the same way, try the beta image wink
Please, don't forget to try with arm_64bit=1 in '/boot/config.txt'..
If that doesn't work, try also with 'arm_control=0x200'
if it doesn't work, try something different..
Comment line kernel=RPi4_u-boot.bin, change it to kernel=vmlinuz-5.5.0-rc6+
thanks..
Best Regards,
tux
#25 2020-01-19 18:19:07
uther
Unfortunately beta doesn't work neither. Checked both with arm_control=0x200 and arm_64bit=1. Exactly the same output as with the alpha.
EDIT:
changed kernel=RPi4_u-boot.bin to kernel=vmlinuz-5.5.0-rc6+ - green led flashed couple times more, but the final output is the same.
Checked both kernel links with arm_control=0x200 and arm_64bit=1 variants.
soystemd-free diet
