#1 2019-11-19 02:49:28
Copper36
Configuring Liferea
Sorry for bringing it up here, but I have not been able to find out how to contact Liferea devs (who would be the first choice to ask)...
The older version that was OK used to have black text on a clean white background in its reading pane. Now it is dark grey or light grey, which makes it simply painful to use. I have not found any tips on how to change it back except for this brief description on editing its CSS files:
https://lzone.de/liferea/blog/2016/08/2 … ering.html
Found both of them, tried to alter the settings but it does not seem to work (I do not see any effect). I suspect I'm doing something completely wrong.
Is there anyone having experience with configuring CSS files who could advise on what exactly should be done?
Thank you.
Liferea 1.12-rc3
Devuan ASCII 64 bit
#2 2019-11-19 03:00:18
Re: Configuring Liferea
I thought I'd have a look at #10: Custom CSS for Article Rendering  and the link is dead:
Not Found
The requested URL /liferea/blog/Liferea+Trick+#10:+Custom+CSS+for+Article+Rendering was not found on this server.
Apache Server at lzone.de Port 80
#3 2019-11-19 03:21:13
Copper36
Right, it looks like the whole "trick" is everything above that 10-bullet  list... the full name of the page I provided link to in my post is:
https://lzone.de/liferea/blog/2016/08/23/Liferea-Trick-10-Custom-CSS-for-Article-Rendering.html
So that's probably it.
#4 2019-11-19 03:39:08
Maybe I'm just doing something stupid . . .  <<<<  this
~/.config/liferea/liferea.css
Is the file that's needed to change colors etc.
