#1 2019-10-16 00:49:40
aut0exec
Beowulf and Avahi-daemon
Switched one of my Cinnamon Ascii systems over to beowulf repo's and with a few exceptions (self induced issues) everything upgraded without a hitch! I know Beowulf isn't officially released but I've been using it on a bunch of other machines with no issues so far.
Anyways, generally want nothing to do with avahi-daemon so I purge it almost as soon as I see it on a machine. For some reason though 'apt upgrade' is wanting to reinstall it after it has been purged. I can't seem to track down where the dependency is that might be requiring avahi either. Anyone have any suggestions? This is a new one for me...
#2 2019-10-16 02:37:08
Re: Beowulf and Avahi-daemon
I've used this to show what packages depend on a package:
~$ apt-cache rdepends avahi-daemon
avahi-daemon
Reverse Depends:
  libvirt-daemon-system
  cups-daemon
  cups-core-drivers
  cups-browsed
  cups
  telepathy-salut
  task-desktop
  sane-utils
  rhythmbox
  pulseaudio-utils
  pulseaudio-module-zeroconf
  pulseaudio
  padevchooser
  owserver
  mpd
  mpd
  mandos
  libsane
  libnss-mdns
  libmono-zeroconf1.0-cil
  libapache2-mod-dnssd
  hplip
  gshare
  gobby
  gnome
  gajim
  forked-daapd
  education-main-server
  education-desktop-other
  cups-daemon
  cups-core-drivers
  cups-browsed
  cups
  banshee
  avahi-utils
  avahi-dnsconfd
  avahi-discover
  apt-cacher-ng
#3 2019-10-17 01:46:45
aut0exec
Thanks golinux. That was a good TIL for me! Removed everything in the output and Apt upgrade still wants to reinstall avahi-daemon though. This is the weirdest thing. I have at least three other Beowulf and ceres machines running cinnamon and none of them do this!
After removing everything I decided to reinstall the components I actually did need but noticed if '--no-install-recommends' I was able to prevent avahi-daemon from reinstalling while still upgrading the other software! Tried the same thing with 'apt upgrade' and it exhibited the same behavior. I don't have any apt pinning or odd configurations to my knowledge either. Wondering if I should just reinstall, haha.
#4 2019-10-17 15:50:24
Put APT::Install-Recommends "no"; in /etc/apt/apt.conf.d/norecommends and Recommends will be excluded on upgrades as well as installations.
Maybe aptitude why avahi-daemon will tell you something useful.
#5 2019-10-18 15:21:54
aut0exec
Another TIL! Thanks red...
So initially aptitude responded with 'hplip' so it was removed and then after another run, it came back with the following:
user@userpc:~# aptitude why avahi-daemon
i   task-cinnamon-desktop Depends    task-desktop
i A task-desktop          Recommends avahi-daemon
So looks like cinnamon has some sort of dependency on avahi-daemon in beowulf?
