#1 2019-09-02 21:10:51
jmchenry110
Plasma 5.16
Greetings!
Just had a question about the KDE Plasma Desktop Environment packages.  I noticed that in testing, the version is sitting at 5.14.  Will 5.16 drop anytime soon?  Or is there a way to update this myself outside of compiling?  I know Ubuntu has PPAs which I know that Devuan doesn't support.  Didn't know if there was anything like that with regard to Devuan.  Thanks for the information ahead of time!
#2 2019-09-02 21:29:55
Re: Plasma 5.16
You can check which versions are available in which release/repo here:
https://pkginfo.devuan.org/
#3 2019-09-02 22:18:19
Re: Plasma 5.16
sid/ceres still has 5.14. If (when) 5.16 moves into sid/ceres, it will likely migrate down into debian bullseye and our next release after beowulf. I think backporting kde would be a difficult task.
