#1 2019-08-11 18:27:27
alphalpha
apt https fail (beowulf)
im trying to set the apt mirrorlist from http to https but it fails due to some certificate error:
apt install apt-transport-https
sed s'/http:/https:/g' -i /etc/apt/sources.list
apt update
Error:
https://deb.devuan.org/merged beowulf-security Release
  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification
cat /etc/apt/sources.list
## package repositories
deb https://deb.devuan.org/merged beowulf main
deb https://deb.devuan.org/merged beowulf-updates main
deb https://deb.devuan.org/merged beowulf-security main
#deb https://deb.devuan.org/merged beowulf-backports main
## source repositories
#deb-src https://deb.devuan.org/merged beowulf main
#deb-src https://deb.devuan.org/merged beowulf-updates main
#deb-src https://deb.devuan.org/merged beowulf-security
#deb-src https://deb.devuan.org/merged beowulf-backports main
what am i doing wrong?
#2 2019-08-11 18:54:45
Re: apt https fail (beowulf)
Most devuan mirrors do not support https.  Either use http or choose one specific mirror that provides https.
#3 2019-08-12 08:21:41
alphalpha
thx
#4 2019-08-15 11:03:31
alphalpha
sudo apt update
Ign:1 https://sledjhamr.org/devuan beowulf InRelease
Ign:2 https://ftp.fau.de/devuan beowulf InRelease
Ign:3 https://pkgmaster.devuan.org beowulf InRelease
Ign:4 https://sledjhamr.org/devuan beowulf-updates InRelease
Ign:5 https://ftp.fau.de/devuan beowulf-updates InRelease
Ign:6 https://pkgmaster.devuan.org beowulf-updates InRelease
Ign:7 https://sledjhamr.org/devuan beowulf-security InRelease
Ign:8 https://ftp.fau.de/devuan beowulf-security InRelease
Ign:9 https://pkgmaster.devuan.org beowulf-security InRelease
Err:10 https://sledjhamr.org/devuan beowulf Release
  404  Not Found [IP: 37.220.36.58 443]
Err:11 https://ftp.fau.de/devuan beowulf Release
  404  Not Found [IP: 131.188.12.211 443]
Err:12 https://sledjhamr.org/devuan beowulf-updates Release
Err:13 https://pkgmaster.devuan.org beowulf Release
  404  Not Found [IP: 5.196.38.18 443]
Err:14 https://ftp.fau.de/devuan beowulf-updates Release
Err:15 https://sledjhamr.org/devuan beowulf-security Release
Err:16 https://pkgmaster.devuan.org beowulf-updates Release
Err:17 https://ftp.fau.de/devuan beowulf-security Release
Err:18 https://pkgmaster.devuan.org beowulf-security Release
E: The repository 'https://sledjhamr.org/devuan beowulf Release' does not have a Release file.
E: The repository 'https://ftp.fau.de/devuan beowulf Release' does not have a Release file.
E: The repository 'https://sledjhamr.org/devuan beowulf-updates Release' does not have a Release file.
E: The repository 'https://pkgmaster.devuan.org beowulf Release' does not have a Release file.
E: The repository 'https://ftp.fau.de/devuan beowulf-updates Release' does not have a Release file.
E: The repository 'https://sledjhamr.org/devuan beowulf-security Release' does not have a Release file.
E: The repository 'https://pkgmaster.devuan.org beowulf-updates Release' does not have a Release file.
E: The repository 'https://ftp.fau.de/devuan beowulf-security Release' does not have a Release file.
E: The repository 'https://pkgmaster.devuan.org beowulf-security Release' does not have a Release file.
#5 2019-09-28 22:05:23
stanz
Greetings...
This is just the post I was looking for! smile
I'm adding both options/protocols, to my build: apt-transport-https and apt-transport-tor.
Tor worked as expected, because the hidden services have been added to the 'get-devuan' page..! (Thx!)
A VERY helpful link (thx golinux!). As I had the same errors, and began my forum search...
Same errors I first received (with same addy format), so I surfed to their .org clicked on, till I got to beowulf's directory - getting the full path.
Minor adjustment to your sources.list..
## testing repos
deb https://sledjhamr.org/devuan/merged beowulf main contrib non-free
deb https://ftp.fau.de/devuan/merged beowulf main contrib non-free
## devuan mirror that provides https
deb https://pkgmaster.devuan.org/merged beowulf main contrib non-free
deb https://pkgmaster.devuan.org/merged beowulf-security main contrib non-free
deb https://pkgmaster.devuan.org/merged beowulf-updates main contrib non-free
~$ sudo apt update
Hit:2 https://sledjhamr.org/devuan/merged beowulf InRelease
Hit:3 https://pkgmaster.devuan.org/merged beowulf InRelease
Get:4 https://ftp.fau.de/devuan/merged beowulf InRelease [25.6 kB]
Hit:5 https://pkgmaster.devuan.org/merged beowulf-security InRelease
Hit:6 https://pkgmaster.devuan.org/merged beowulf-updates InRelease
Get:7 https://ftp.fau.de/devuan/merged beowulf/main i386 Packages [8,002 kB]
Get:8 https://ftp.fau.de/devuan/merged beowulf/contrib i386 Packages [47.0 kB]
Get:9 https://ftp.fau.de/devuan/merged beowulf/non-free i386 Packages [76.7 kB]
Fetched 8,152 kB in 11s (749 kB/s)
Building dependency tree
I hope this helps!
asta..
miyoisomix.i2p
#6 2019-10-05 15:57:59
alphalpha
stanz wrote:
I hope this helps!
asta..
yay this works smile thx
