#1 2019-07-18 18:18:25
macondo
What other distro are you using (besides devuan)?
Void Linux (very good)
#2 2019-07-18 18:33:05
Re: What other distro are you using (besides devuan)?
There is another distro?   LOLOL!
(Couldn't resist)
#3 2019-07-18 19:14:43
PedroReina
Debian on old boxes, Devuan on the new ones. No other distro to work, but I like to try others for fun. At work we have MAX, a Spanish distro based on Ubuntu with Mate desktop.
#4 2019-07-18 19:38:46
GNUser
OpenBSD and Tiny Core Linux
I dual boot Devuan and OpenBSD on my Libreboot laptop, which one I use on a given day depends on my mood.
Tiny Core Linux on my netbook-turned-router/fileserver/webserver
#5 2019-07-18 23:39:08
alupoj
What to you think about Gentoo being more secure than Devuan for small installations like a text mode only computers?
#6 2019-07-19 07:21:37
omnio
Mageia on my laptop.
#7 2019-07-19 09:03:11
Panopticon
I was running artix as daily driver for a little while with openrc and lxqt but decided to move over to Devuan full time, Beowulf seems pretty stable and Miyolinux i3 spin is good, i have 6 different distros multibooting though, im always hopping around learning new things. Seems some things are done with much saner defaults with Devuan/Debian than Archlinux.
#8 2019-07-19 10:40:11
yeti
I used to have a lot of stuff in VMs but stripped that down a lot few weeks ago.
Call it a mass extinction!
void is nice, had it for a long time... but I'm still not that much into rolling releases.
Ubuntu-VMs helped to build stuff for digital neighbours. I'll reinstall what's needed if needed...
9ants and other plan9 derivates got too few of my attention for too long, keeping 9front and somewhen installing the original will be enough.
One version of Reactos is enough!
On real hardware I only run Devuan, Debian, Raspbian, OpenWrt and I plan to get Plan9 or 9front again (still throwing coins about which flavour and about the "on X86, X86-64 or ARM" question).
#9 2019-07-19 17:48:35
I have MX Linux in a VM (along with Devuan) and Arch Linux in a container but I don't really use them, they're just for testing.
My laptop runs Debian buster 'cos I need Secure Boot support and I quite like systemd *dives for cover*
#10 2019-07-22 17:06:06
Job
Devuan main box.
FreeBSD second box.
Debian Jessie media server.
#11 2019-07-22 22:16:32
SmokeyGrey
I've experimented a few other distros recently.
I really like Void, and I'm tempted to switch my laptop over.
PCLinuxOS was interesting, but not my thing.
I've tried MX Linux, because it's frequently suggested as another non-systemd debian, but as far as I can tell systemd is running?
From the BSDs, OpenBSD is my favourite.
As for actual hardware installs, currently it's all Devuan.
#12 2019-07-23 09:46:29
I've just jumped from PcLinuxOs myself, to other non-systemd Os's.
FreeBSD-12 & Devuan-ascii (of course) I'm trialing artix64 on my asus R550() laptop , using openrc.
#13 2019-07-25 03:08:15
reunite_pangaea
Linux Mint.
*Is not as awesome as others on here. sad
#14 2020-06-03 19:37:35
talbergor
Void Linux is cool, just came from that.
Quite like #!++ and PCLOS aswell smile
#15 2020-06-03 21:30:04
Ron
None.
#16 2020-06-04 00:33:26
szutt
Servers : devuan
Developement workstation : devuan
Client workstation (non-developper job, just regular office job) : mx linux (I installed linux mint for 2 years but finally migrated to mx linux)
#17 2020-06-04 06:49:58
Gentoo
#18 2020-06-04 10:57:56
PedroReina
Old boxes still with ancient Debian versions. Rock solid, by the way.
Raspberry with Raspbian. Not happy, of course.
#19 2020-06-04 11:57:22
HevyDevy
Im using openbsd for awhile now on a test machine just for learning. But main machine always has devuan from now on. Ive tried all the bleeding edge but bandwidth is limited for me so i like stable systems like devuan that dont need too much updating.
#20 2020-06-04 13:08:36
bgstack15
I have a gaming desktop running Fedora 31 (upgraded from at least Fedora 28). My headless stuff all runs CentOS 7. Anything with a display attached primarily, is Devuan Ceres.
#21 2020-06-04 17:26:50
Ogis1975
Debian Buster.
            ----+- Peter Kropotkin -+----
#22 2020-06-04 17:42:25
Well, I'm still not convinced Devuan is right for me yet, as I am still using AntiX, which I have used for many years.... big_smile
I do like using MIYO now & then though.... wink
Edit: Actually Beowulf is getting me more interested, I've installed it onto a couple of my machines. smile
#23 2020-06-20 06:28:54
MiyoLinux
smile
Aside from Devuan...
NuTyX
Venom
...and my latest exploration...which looks to be a keeper...
NetBSD. big_smile
#24 2020-06-20 10:38:30
I've switched to Alpine Linux for my daily driver — the musl libc base ensures a fundamental incompatibility with systemd that I'm sure will be appreciated by the community here smile
The init system is busybox as PID1 with OpenRC as the service manager (with s6 as an alternative option) but I've changed to /sbin/openrc-init for PID1 by specifying it as a kernel command line option:
init=/sbin/openrc-init
All I had to do to get it working was copy the supplied agetty init script to TTY-specific versions and enable them to start:
# ln -s /etc/init.d/agetty{,.tty1} # repeat for other TTYs as desired
# rc-update add agetty.tty1 # repeat for other TTYs as desired
The startup is blisteringly fast, quicker than my Debian buster box (which is using systemd) and the resource usage is pleasingly minimal.
Drew DeVault is one of the Alpine developers and he created sway so I'm using that to dodge the X server bloat monster (Wayland ftw!) and I've installed and enabled elogind so that I can disable the setuid bit on the sway executable and run a true rootless desktop.
I've also managed to get mokutil added to their testing repositories so that I could enrol my own Secure Boot key (created with their sbsigntool utility) and use it to sign the Alpine kernel and start the system with Secure Boot enabled.
It's an awesome distribution and *very* easy to package for (the APKBUILDs are almost identical to Arch's PKGBUILDs), very highly recommended.
#25 2020-06-21 19:00:06
vlax
Ubuntu derivatives (Mint and Sparky) on family machines ;
AVLinux (Debian based) ;
and BLAG 3 (Fedora 3 based) + Slax live
satellite mestizo
