#1 2019-07-13 00:56:40
Micronaut
[Solved] Grub "savedefault" not working
It was great fun to discover Grub could be configured to save the last manual choice as the default for future boots. I used it with my Linux Mint Rosa (17.3) install and it worked fine. But now it won't work with Devuan Ascii. I can't figure out what is different. Just put:
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
in the /etc/default/grub config file and run update-grub. It worked with Mint. What is different about grub in Devuan?
#2 2019-07-13 01:05:29
Re: [Solved] Grub "savedefault" not working
I suspect the question is probably "what is different between mint and devuan".
#3 2019-07-13 08:18:08
Please post the output of
grub-editenv list
See also https://www.gnu.org/software/grub/manua … ment-block
#4 2019-07-13 21:25:57
Micronaut
"grub-editenv list" produced no output at all. Even when run in a root terminal. From what I can see about grub-editenv in the man pages, that is where the default should be saved. But it's clearly not getting saved. This was a re-install over the previous Linux (Mint 17.3) -- could differences between the different versions of grub have caused a problem?
#5 2019-07-14 12:49:55
Try creating the /boot/grub/grubenv file:
# dd if=/dev/zero of=/boot/grub/grubenv bs=1024 count=1
I have no idea if that will work, I don't use /etc/default/grub myself.
#6 2019-07-14 20:17:11
Micronaut
Wow, I am reluctant to use dd on a disk that has a working OS on it. Anyway, after going back and manually comparing the grub default on the new Devuan system with the one from the Mint system, I changed the parms to lower case. "saved" instead of "SAVED" and "true" instead of "TRUE". It seems to be working now. Odd that the control items are NAMED in upper case, but the parm apparently must be lower case to be recognized.
#7 2019-07-14 20:40:12
The command is outputting to a file rather than the block device, it won't over-write your disk.
Anyway, please add [SOLVED] to the thread title to help others who may have this problem.
#8 2019-08-17 15:29:14
djk44883
Just a note to add to SOLVED, at one time I thought there was something about quotes.  I just looked at my file to see how I had saved configured... mixed quote and not quote and back-ticks, it doesn't seem to matter.
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
I agree, the mix is sloopy
#9 2019-08-17 15:45:36
bgstack15
The /etc/default/grub file whose contents you show here, takes the form of a shell script that is executed before running Grub, so that the variables are defined for Grub to use.
In a shell script, backticks are used to wrap around a statement that is the same as something that could be executed on the shell prompt. So
means that the output of that command should be substituted. So if the output of that command is "Devuan" then the line is evaluated as  GRUB_DISTRIBUTOR=Devuan.
The double quotes are just quotes, so the exact string "quiet" is the value for that last entry.
But back to the backticks and their contents. In most shells, the double-pipe || means a logical OR. In shell, that means if the first command returns false (that is, it fails in some way), run the second statement. So if lsb_release -i -s (with sending any errors to the null device, so suppress all error messages) fails, then just show the word Debian.
