#1 2019-07-09 07:39:24
kapqa
(Reportbug Error) AudioDriver / SPDIF crackling with Firefox on Ascii
Hello ,
i am reporting here an error that i inserted in the program "reportbug".
The reportbug failed with the error
Connecting to reportbug.debian.org via SMTP...
SMTP send failure: {'submit@bugs.devuan.org': (550, b'relay not permitted')}.
Do you want to retry (or else save the report and exit)? [Y|n|q|?]?
This is the problem
I am using a Devuan Ascii with
Linux rich-PC 4.9.0-6-amd64 #1 SMP Debian 4.9.88-1+deb9u1 (2018-05-07) x86_64 GNU/Linux
and installed upon fresh copy the AMDGPU for Radeon RX560
with
apt install firmware-linux
apt install llvm-3.9 clang-3.9
according to this hint here
https://linuxconfig.org/how-to-install- … etch-linux
What i noticed is that the SPDIF/Digital Audio Connection is crackling quite heavily with Firefox Quantum.
I had installed first the newer kernel 4.9.0.9 and thought this might be related to the kernel upgrade but the crackling is shown also in the stock kernel.
Might this be related to the AMDGPU?
The Audio is showing as
"HD-Audio Generic Digital Stereo (IEC598)"
Please show me how to correctly debug the error.
Thanks
#2 2019-07-09 07:44:38
kapqa
Re: (Reportbug Error) AudioDriver / SPDIF crackling with Firefox on Ascii
It seems that the crackling goes away after some time;
#3 2019-07-09 08:28:44
I always use direct email method to report bugs not reportbug which can do weird things.
#4 2019-07-09 08:43:10
kapqa
the installed firefox is from the repo Mozilla Firefox 60.7.2
#5 2019-07-09 11:01:53
kapqa
maybe this error is related to the installed packages "llvm"  and "clang3-9". i deinstalled the programs, the amdgpu seems working nontheless, and the crackling for now seems gone.
#6 2019-07-09 16:16:53
Is your mail transport agent actually working?
In respect of your crackling audio try https://wiki.archlinux.org/index.php/Pu … _crackling
#7 2019-07-09 18:06:09
kapqa
that i don't know. i used the same "settings" as on debian where i previously could send 2 such reports succesfully (with, i suppose, let debian chose smtp-server)
thanks, should problem re-surface, i will try this.
