#1 2019-06-17 19:27:51
mknoop
InRelease, Release, and Release.gpg files need updating
On the server http://pkgmaster.devuan.org/merged/dists/ none of the InRelease, Release, or Release.gpg files in any of the folders have been updated since 14-Jun-2019.  This prevents any updating or upgrading of packages.
#2 2019-06-18 17:03:01
Re: InRelease, Release, and Release.gpg files need updating
They seem to have been updated yesterday.
#3 2019-06-19 22:28:06
mknoop
Well, today is 6/19 and now the last versions of the files are 6/17.  Once again, no updates for packages.
#4 2019-06-19 22:35:12
Perhaps you can find the needle in the haystack that is causing this?
https://pkgmaster.devuan.org/amprolla.txt
#5 2019-06-20 00:55:40
mknoop
On the issue from 6/14, all that I could find were a lot of error 404 on the debian website.  It as as if it was not online.  Then it ended with :
2019/06/14 15:02:31 [ERR] ("Connection broken: ConnectionResetError(104, 'Connection reset by peer')", ConnectionResetError(104, 'Connection reset by peer'))
It seems that the internet connection to the devuan server was terminated.
On the issue from 6/17, the same massive 404 messages from debian, but no internet disconnection message.
That's all I can see from that.  Does that make any sense to anyone?
#6 2019-06-20 02:19:59
Thanks for taking a look.  That actually surprised me so good for you!
There are some other ideas here:
https://lists.dyne.org/lurker/message/2 … 89.en.html
But the real issue is somewhere here:
https://git.devuan.org/devuan-infrastructure/amprolla3
#7 2019-06-20 19:29:43
mknoop
I am afraid I have reached the level of my incompetence here.  I am not a python programmer, so a lot of this is gibberish to me.
I am going to keep trying to understand it, but don't hold your breath waiting for help from me.
#8 2019-06-20 19:36:47
I won't be venturing there either.   smile  I'm just the messenger . . .
#9 2019-06-20 19:50:21
Dutch_Master
I'm no coder either, but scripts (and programs for that matter) follow a logical sequence. But I don't understand this section:
(from https://git.devuan.org/devuan-infrastru … _update.py)
if get_time(rem_date) > get_time(loc_date):
        info('Remote Release is newer!')
        return True
    return False
What I think is happening here is that when a newer time code is found, the program returns, but only to one level up, where the next code line tells it to return false (i.e. the time code was not newer). But perhaps I misinterpreted (s'cuse the pun tongue ) the code.
HTH!
#10 2019-06-20 20:25:11
yeti
amprolla_update.py#L22-36 simplified:
$ cat asdds.py
def left_is_bigger(left, right):
    if left > right:
        print('%d > %d' % (left,right))
        return True
    print('%d <= %d' % (left,right))
    return False
left_is_bigger(1337, 42)
left_is_bigger(42, 1337)
$ python3 asdds.py
1337 > 42
42 <= 1337
return does not leave indentation levels, it leaves the function.
#11 2019-06-20 20:40:33
Dutch_Master
Ah, ok. Thx for the explanation.
#12 2019-07-08 07:39:10
mknoop
It has happened again.  The release files for all the http://pkgmaster.devuan.org/merged/dists/ directories have not been updated since 7/07/19 01:30.
