#1 2019-06-12 05:30:47
fabien
Display manager issue
Hello people,
I have a issue with display manager in general, doesn't matter which one. They all freeze, maybe one time out of five.
I tried slim, sddm and lightDM, the problem is the same.
When it happen, If I open an other TTY and then "startx", my session open and freeze as well.
Which information should I give you if I want help?
Thank you.
Fabien
#2 2019-06-12 06:07:19
Re: Display manager issue
Have you read the Release Notes?  Plenty of tips in there that might help you sort this.  Those notes are for ascii.  I guessed because you didn't specify which release you were on.
#3 2019-06-12 10:44:41
Well then it can't be a display manager issue, can it?
Boot to a console and try startx from there to eliminate the DM as a source of this issue.
Have you checked your drive & memory health?
What are your sources?
apt policy
Check the syslog for any clues.
#4 2019-06-12 21:21:41
Excalibur
Hello,
       It looks like X11 is having problems with your hardware. As you have managed to start up an X session using startx, try logging on via a tty and see if there is an .xsession-errors file in your home directory. The contents of this file may give you a clue as to what has gone wrong.
#5 2019-06-15 07:45:27
fabien
Thank you for helping guys, I will first read the release notes.
#6 2019-06-16 13:37:46
F_Sauce
Just a thought, but I would do a «memtest» to see if the RAM is alright also.
