#1 2019-05-28 19:41:59
mknoop
ceres repository no longer has a Release file - cannot update
When I run apt-get update I get the following:
Ign:1 http://deb.devuan.org/merged ceres InRelease
Err:2 http://deb.devuan.org/merged ceres Release
  404  Not Found [IP: 131.188.12.211 80]
E: The repository 'http://deb.devuan.org/merged ceres Release' no longer has a Release file.
This has been happening for two days now.
I tried reading man apt-secure but the only solution I could find there was to accept insecure repositories, which is not recommended.
In think something has to be done with the repository.
#2 2019-05-28 19:51:01
Re: ceres repository no longer has a Release file - cannot update
Does it work if you change ceres to unstable?
http://deb.devuan.org/merged/dists/unstable/
#3 2019-05-28 19:56:09
mknoop
Yes - it worked with unstable instead of ceres.
I wonder why?
#4 2019-05-28 21:04:03
mknoop wrote:
I wonder why?
Because ceres/sid/unstable are identical.
Devuan's pkgmaster is currently being worked on . . . not too smoothly, it seems.  Some linkages seem to be fubared.
#5 2019-06-05 12:07:34
I believe this problem and others with the repo have been fixed. Please let us know if that's not the case.
