#1 2019-04-30 03:08:57
Ron
[SOLVED] Weird message while updating the system
When trying to install updates tonight, I got a message box that read:
Some of the packages could not be retrieved from the server(s).
Do you want to continue, ignoring these packages?
So I clicked "no." Below is the message I got afterwards:
W: Failed to fetch http://mirrors.dotsrc.org/debian-security/pool/updates/main/g/gst-plugins-base1.0/libgstreamer-plugins-base1.0-0_1.10.4-1+deb9u1_amd64.deb
  404  Not Found
W: Failed to fetch http://mirrors.dotsrc.org/debian-security/pool/updates/main/g/gst-plugins-base1.0/gstreamer1.0-plugins-base_1.10.4-1+deb9u1_amd64.deb
  404  Not Found
W: Failed to fetch http://mirrors.dotsrc.org/debian-security/pool/updates/main/g/gst-plugins-base1.0/gstreamer1.0-x_1.10.4-1+deb9u1_amd64.deb
  404  Not Found
I've never had this happen before. Should these 3 things become available later on? Should I just redo this again and click "Yes" this time, or just wait?
#2 2019-04-30 04:09:46
Re: [SOLVED] Weird message while updating the system
Try a different mirror or pkgmaster.devuan.org
#3 2019-05-01 01:09:39
Ron
Well, I just retried it today before trying anything else, and everything installed like it normally does without any kind of messages.
So is everything good to go and I got a fully up-to-date system? ?
#4 2019-05-01 13:53:04
Ogis1975
Yes, you are good to go. In this case, it was only necessary to wait and give time for the servers to synchronize.
            ----+- Peter Kropotkin -+----
#5 2019-05-02 02:59:48
Ron
Okay, thanks for the confirmation Ogis1975.
