#1 2019-02-24 04:58:04
MysticLord
Changing desktop enviroments
Coming here from Mint Debian. Just one question for now.
1. How do I change my desktop environment (xfce, lxqt, etc)?
#2 2019-02-24 05:16:04
#3 2019-02-24 12:54:48
xinomilo
Unknown
Re: Changing desktop enviroments
install relevant packages (usually DEname or DEname-desktop-environment) and choose the new DE on login screen, preferably after reboot.
remove unwanted DEs afterwards, if you don't want to get too "heavy" on system resources.
#4 2019-02-24 14:34:38
MysticLord
What about removing old configuration files and directories? Does apt know what files/dirs an app creates, and can it remove them?
How do I know which packages are necessary?
What DE do you recommend for a netbook with 2 gb ram and a single core 1.6 ghz processor?
What if I want to get rid of a DE altogether and learn to do everything via terminal, what do I delete to accomplish this?
I am into emulation, reverse engineering old video games, and I'm an ok Java programmer. I'm somewhat clued in to this stuff, just never bothered to learn before. I might need I think X (?) to run an emulator and web browser, but I want to delete everything I don't need and cook my own tools when needed. Yes this is insane but I'm stuck with a netbook for now so I may as well optimize for it's limitations.
#5 2019-02-24 16:40:51
dxrobertson
If you want to install a desktop environment, install lightdm then install the meta-packages for either xfce (package xfce4) or lxqt (package lxqt or even lighter- lxqt-core).  I have run both on a netbook similar to yours with no problems.  Understand when installing a meta-package that ALOT gets installed; all the way out to pulseaudio.
Its difficult to uninstall a DE and wanting it to fully clean up after itself.  Files will be left behind; configs, etc.  But for the most part it will be removed.
What you might want to try is to install the devuan netinst.iso and do not install any desktop environment at all, make sure to un-check default desktop.  This will give you console only.  Then if want X, install lightdm along with a basic window manager such as openbox.  This will allow you to install and use desktop applications such as a web browser.  Make sure you install a terminal such as xterm or lxterminal to make the window manager usable.  If you find this too basic, then install xfce or lxqt.
You can get a much lighter desktop if you do not install via meta-package, instead install the individual packages (xfce4*, lxqt*) with --no-install-recommends.  But you really need to understand the components of the chosen desktop env to do this.
