#1 2019-02-13 03:18:34
robert-e
Is some part of systemd running in ascii 2 ?
Yesterday I was poking around looking at config files, to see why wicd was randomly  disconnecting from the router.  I notice a number of systemd folders/files that I thought should not exist.  This is ascii 2, new install shortly after it was released.  I made 3 new ext3 partitions and formatted them.  /boot, / and swap.  I kept the /home partition unformated.  I renamed the .config files so as not to screw up with newer packages.
I choose slim and mate desktop and installed.  I also pinned systemd in /etc/apt/preferences.d.  I use synaptic for updates, seldom apt-get, and occasionally gdebi. Today I have renamed all the found systemd files/folders and all seemed okay.  I rebooted and all stayed renamed except for the systemd folder in /run.  I deleted it, rebooted and it was recreated.  I deleted it again, created a new empty systemd folder and attempted to make it immutable.  The os would not allow that.  I was under the impression that only libsystemd0 should be in existance.  It seems that some aspect of systemd is running on bootup.  Before I trash this install, could someone enlighten me to what is going on?  As the pretend preacher in "Cat Ballou" says; "All contributions are greatfully received".
Regards,
Bob
#2 2019-02-13 04:01:39
Re: Is some part of systemd running in ascii 2 ?
Happy to see you made it here!  You might want to take a look at this post.
#3 2019-02-13 05:19:50
robert-e
Yes, I did first thing.  That is why I deleted the (other) systemd folders and files; they should not have mattered to the os.  However when the systemd folder in /run got recreated on reboot, I got kind of concerned.  Moreso, when I could not chattr +i that empty folder to immutable.  I know I can just reinstall and pay more attention, but there is little learning in that. wink
Thanks for all your trouble for me.
Best regards,
Bob
#4 2019-02-13 05:24:25
I wish we had a workshop of magic elves to remove those unnecessary systemd files but alas . . .
Best regards,
Bob
No problem.  No trouble.  smile  Really nice to see you back!
#5 2019-02-13 05:42:10
KatolaZ
Best regards,
Bob
Hi Bob,
can you plase report the list of files you see under /run/systemd/ after boot? Could you please confirm that you are not using any non-Devuan repo?
Thanks
KatolaZ
#6 2019-02-13 11:54:41
dxrobertson
I also have systemd files in /run.  I believe elogind may have something to do with it.  I am running all Beowulf, with LXQt 0.14 from unstable.
root@acer:~# cd /run
root@acer:/run# find systemd
systemd
systemd/inhibit
systemd/inhibit/1
systemd/inhibit/1.ref
systemd/cgroups-agent
systemd/inaccessible
systemd/inaccessible/blk
systemd/inaccessible/chr
systemd/inaccessible/sock
systemd/inaccessible/fifo
systemd/inaccessible/dir
systemd/inaccessible/reg
systemd/machines
systemd/sessions
systemd/sessions/1
systemd/sessions/1.ref
systemd/users
systemd/users/1000
systemd/seats
systemd/seats/seat0
root@acer:/run#
I then removed /run/systemd.
Then went to a console via <CTRL><ALT>F2, and was surprised to find a series of messages displayed, and continuing to display:
[2299.263755 ] elogind-daemond[2150] failed to save user data /run/systemd/users/1000: no such file or directory
There are also similar messages for session, instead of user.
PID 2150 is elogind-daemon.
elogind version:
root@acer:~# apt list --installed elogind
Listing... Done
elogind/testing,now 239.3+20190131-1 amd64 [installed]
Another reference to run/systemd, unrelated, and since its a "not"; probably actually needed.  From syslog:
Feb 11 16:30:01 acer CRON[3837]: (root) CMD ([ -x /etc/init.d/anacron ] && if [ ! -d /run/systemd/system ]; then /usr/sbin/invoke-rc.d anacron start >/dev/null; fi)
#7 2019-02-13 16:00:06
dxrobertson
I looked at elogind code, it seems the /run/systemd and subsequent directories are pretty ingrained in the code.
This is probably one of the (quote from KatolaZ from https://dev1galaxy.org/viewtopic.php?id=1925) :
...only because they happen to provide a systemd unit file for
those systems where systemd is used.
#8 2019-02-13 17:46:52
yeti
Maybe the last unavoidable systemd packages can be renamed to fake-$originalname_*.deb to make clear that they are harmless? Via provides $originalname dependices could be satisfied.
Would that possibly reduce the iterating questions about systemd pieces still present in Devuan?
#9 2019-02-13 18:00:20
Sadly, there are just not enough hands on deck to do the repackaging and long term maintainence.  Any volunteers out there?
(golinux hears the sound of silence)
#10 2019-02-13 18:23:37
robert-e
KatolaZ:  here you go .. Note that I am not concerned about the stray (unused) systemd files; only that systemd code should not be running, expecially on boot.
root@thinkpad:/run# tree -alp  systemd
systemd
├── [srwx------]  cgroups-agent
├── [d---------]  inaccessible
│   ├── [b---------]  blk
│   ├── [c---------]  chr
│   ├── [d---------]  dir
│   ├── [p---------]  fifo
│   ├── [----------]  reg
│   └── [s---------]  sock
├── [drwxr-xr-x]  inhibit
│   ├── [-rw-r--r--]  1
│   └── [prw-------]  1.ref
├── [drwxr-xr-x]  machines
├── [drwxr-xr-x]  seats
│   └── [-rw-r--r--]  seat0
├── [drwxr-xr-x]  sessions
└── [drwxr-xr-x]  users
    └── [-rw-r--r--]  1000
7 directories, 12 files
root@thinkpad:/run#
# sources.list
# note .. was pkgmster on install
# deb cdrom:[devuan_ascii_2.0.0_amd64_dvd-1]/ ascii main non-free
#deb cdrom:[devuan_ascii_2.0.0_amd64_dvd-1]/ ascii main non-free
deb http://deb.devuan.org/merged ascii main non-free contrib
deb-src http://deb.devuan.org/merged ascii main non-free contrib
deb http://deb.devuan.org/merged ascii-security main non-free contrib
deb-src http://deb.devuan.org/merged ascii-security main non-free contrib
deb http://deb.devuan.org/merged ascii-updates main non-free contrib
deb-src http://deb.devuan.org/merged ascii-updates main non-free contrib
#pinning
/preferences.d/avoid-systemd
Package: systemd-sysv
Pin: release o=Debian
Pin-Priority: -1
#11 2019-02-13 21:51:04
dxrobertson
I dont know if this is a viable "fix" to propose, but /run/systemd could be changed to a symlink that points to /run/nosystemd (or whatever).  A process would have to be written (along with other required processing to make it work) to do this during init process.  As something fun to try I just manually made this change and everything seems to be working ok.
dxrobertson@acer:/run$ ls -l
total 32
-rw-------  1 root       root          0 Feb 13 15:15 agetty.reload
drwxr-xr-x  2 root       root         80 Feb 13 15:15 console-setup
-rw-r--r--  1 root       root          5 Feb 13 15:15 crond.pid
----------  1 root       root          0 Feb 13 15:15 crond.reboot
drwxr-xr-x  2 messagebus messagebus   80 Feb 13 15:15 dbus
-rw-r--r--  1 root       root          5 Feb 13 15:16 dhclient.pid
-rw-r--r--  1 root       root          5 Feb 13 15:15 elogind.pid
prw-------  1 root       root          0 Feb 13 15:15 initctl
drwxr-xr-x  2 root       root         80 Feb 13 15:15 initramfs
drwx--x--x  3 root       root         60 Feb 13 15:15 lightdm
-rw-r--r--  1 root       root          5 Feb 13 15:15 lightdm.pid
drwxrwxrwt  2 root       root         60 Feb 13 15:15 lock
drwxr-xr-x  2 root       root         80 Feb 13 16:30 mount
drwxr-xr-x  2 root       root        100 Feb 13 15:15 network
drwxr-xr-x  8 root       root        180 Feb 13 15:15 nosystemd
drwxrwxr-x 14 root       root        320 Feb 13 15:15 openrc
drwxr-xr-x  4 root       root         80 Feb 13 15:15 pm-utils
-rw-r--r--  1 root       root          4 Feb 13 15:15 rsyslogd.pid
-rw-r--r--  1 root       root          1 Feb 13 15:15 runlevel
drwxr-xr-x  2 root       root         60 Feb 13 15:15 sendsigs.omit.d
lrwxrwxrwx  1 root       root          8 Feb 13 15:15 shm -> /dev/shm
drwx--x--x  3 root       root         60 Feb 13 15:15 sudo
lrwxrwxrwx  1 root       root         14 Feb 13 16:27 systemd -> /run/nosystemd
drwxr-xr-x  8 root       root        220 Feb 13 16:29 udev
drwx------  2 root       root         40 Feb 13 15:15 udisks2
drwxr-xr-x  3 root       root         60 Feb 13 15:15 user
-rw-rw-r--  1 root       utmp       4224 Feb 13 15:15 utmp
test it:
dxrobertson@acer:~$ cat /run/systemd/users/1000
# This is private data. Do not parse.
NAME=dxrobertson
STATE=active
STOPPING=no
RUNTIME=/run/user/1000
DISPLAY=1
REALTIME=1550088940339646
MONOTONIC=25991508
SESSIONS=1
SEATS=seat0
ACTIVE_SESSIONS=1
ONLINE_SESSIONS=1
ACTIVE_SEATS=seat0
ONLINE_SEATS=seat0
I personally am not bothered by this use of /run/systemd.  Its just a directory name.  If it makes Devuan easier to maintain and less likely to cause potential problems, then thats fine.
#12 2019-02-13 22:05:30
KatolaZ
It's most probably elogind-related, and it's stuff needed for session management. If you ```apt-get remove --purge elogind```, the folder will disappear (but you will not be able to automount any USB drive as a user, reboot/suspend as a user, and similar stuff). elogind is an alternative to systemd-logind which replaces systemd code (and removes most of the unnecessary stuff).
HTH
KatolaZ
#13 2019-02-13 23:29:29
robert-e
Ok, it is not a problem.  I will pruge elogind and use pmount.  I have used it before and it works.  Afraid of systemd?  Not by a long shot, although I so like to learn.  Thanks for your time.
Bob
