#1 2019-02-10 14:24:01
Phoen7x
Wireguard (VPN) Kernel Modul
Hello everybody,
What about devuan with wireguard support?
I have implemented the following instructions and successfully installed wireguard.
# echo "deb https://ftp.fau.de/devuan/merged/ unstable main" > /etc/apt/sources.list.d/unstable.list
# printf 'Package: *\nPin: release a=unstable\nPin-Priority: 90\n' > /etc/apt/preferences.d/limit-unstable
# apt update
# apt install wireguard
If i want to add a new interface i get
# ip link add dev wg0 type wireguard
RTNETLINK answers: Operation not supported
If I modeprobe wireguard:
modprobe: FATAL: Module wireguard not found in directory /lib/modules/4.17.0
If I want to install wireguard from source:
$ make
make[1]: *** /lib/modules/4.17.0/build: Datei oder Verzeichnis nicht gefunden.  Schluss.
Makefile:36: die Regel für Ziel „module“ scheiterte
make: *** [module] Fehler 2
Seems there is a problem with the kernelmodul?
Device is an OrangePi Zero.
#2 2019-02-11 13:29:34
Phoen7x
Re: Wireguard (VPN) Kernel Modul
Could it be possible that there is the wrong kernel(-headers)?
uname -r:
4.17.0
But its: Linux devuan 4.17.0 armv7l GNU/Linux
I've installed:
devuan_ascii_2.0.0_armhf_sunxi.img.xz with orangepi_zero_defconfig.bin
But maybe something went wrong and it's not the right kernel??
I've installed linux-headers-4.17.0 but i think the right must be linux-headers-sun8i
#3 2019-02-11 15:41:18
The best place for this question would be #devuan-arm on freenode.  parazyd doesn't read this forum.
#4 2019-02-13 05:43:27
KatolaZ
uname -r:
4.17.0
I've installed:
You need matching kernel headers for wireguard-dkms to work.
HND
KatolaZ
#5 2019-02-16 18:52:38
Phoen7x
And which are matching? I've installed with
# apt install linux-headers-$(uname -r)
so I think that are all that are availible?
