#1 2019-01-22 12:41:11
Fjalar
Devuan as VirtualBox host system
I am running 2.0 Ascii on a HP DL380G6, with VirtualBox 5.2.12 installed per Devuan repo. I have reasons to believe that the thing is unstable (particularly one virtual machine keeps crashing) and I'd like to upgrade to VirtualBox 6.
My questions are:
1: Has anybody here had similar issues with the version (virtual machine aborting while under load)?
2: What would be the best practise to upgrade (i. e. use a VirtualBox repo)?
TIA
Matthias
#2 2019-01-22 12:53:30
PedroReina
Re: Devuan as VirtualBox host system
I'm running Devuan 2.0 64 bits with VirtualBox 6. I installed it with this command:
gdebi --o Install-Recommends=no -n virtualbox-6.0_6.0.0-127566~Debian~stretch_amd64.deb
Next you will need to compile four kernel modules, but VirtualBox itself will guide you and it is very easy.
I cannot comment about stability, sorry.
#3 2019-01-22 17:20:40
I have got the 5.2.18 Debian Stretch package loaded directly from Oracle installed on a Ryzen2700X and 32 GByte of RAM, no issues.
Maybe thats the way to go.
Good luck, Rolf
#4 2019-01-22 17:30:39
Good luck, Rolf
I also use the oracle packages.
#5 2019-01-22 22:17:34
Fjalar
I understand I would use a VirtualBox repository then. Which would be the correct one? VirtualBox offers
deb https://download.virtualbox.org/virtualbox/debian <mydist> contrib
and a variety of distributions, apparently based on Debian and Ubuntu.
#6 2019-01-23 19:39:26
For ASCII you use the Debian Stretch package. Download it and install it with dpkg -i.
Good luck, Rolf
#7 2019-01-24 18:13:17
Fjalar
Wouldn't it make more sense to add the stretch repository and then upgrade?
#8 2019-01-24 20:58:17
There are pro and cons for both.
I used the entry in the sources.list at first, then got that this can be risky if there are package updates from Oracle that may conflict with the Debian/Devuan stuff. Then had the entry active only for the install, and got tired of commenting it out when I learned that I can also simply install the package with dpkg -i, and I use it since. Good enough for my small private environment.
Your choice.
Regards, Rolf
#9 2019-01-24 21:05:46
PedroReina
Some deb in the wild dont install correctly with dpkg (Google Chrome comes to mind), so usually I prefer gdebi. If you have the luxury of a X server, gdebi-gtk is very handy too.
#10 2019-01-24 21:21:26
xinomilo
Unknown
# dpkg -i package.deb,
followed by
# apt -f install
(= to bring in any dependencies missing) is the same as installing with gdebi. smile
#11 2019-01-25 12:59:29
PedroReina
xinomilo wrote:
followed by # apt -f install
Thanks for the tip smile
