#1 2019-01-19 19:21:30
w3
Systemd maintainer for Debian quits
Apparently the Systemd maintainer for Debian has quit, see anounce.
he basically said that he has had enough.
Apparently the straw that broke the camels back was an issue where systemd changes the ethernet port names from a user defined name to a systemd defined name without informing the user here is the actual thread in which Biebl vents his frustration at Poettering It is fascinating reading, so are the links from that thread.
#2 2019-01-19 19:59:21
zephyr
Re: Systemd maintainer for Debian quits
Poopering is an unmitigated idiot, good to know someone has come to their senses! ...and now let the systemd demise begin! tongue
Thank you very, very much for posting, just too good of a find! cool
cheers
zephyr
CROWZ
#3 2019-01-19 20:02:16
We've been having some fun over here.
Debian systemd maintainer "taking a break"
#4 2019-01-19 20:17:19
Ron
This is a perfect example of why I avoid everything of Poettering's.
#5 2019-01-19 22:38:16
ChuangTzu
Its fun watching poorly constructed things collapse (from a safe distance that is).
Also having fun here: https://www.linuxquestions.org/question … 175646356/
#6 2019-03-23 03:29:53
Job
Like someone once said "complaining won't get you too far".  I gave up on Debian after some updates, systemd did not like some of my scripts.  I will reboot my box then I get a strange message about system updating or I will try and update the box but I will get a message that another program is using "su -".  Somethings in those lines.  After some investigation, I realized that I have to kill my scripts.  That was the end for me.
