#1 2018-12-21 18:47:34
keos
Problems to install and run Unetbootin
hi, i'm having problem to install Unetbootin ...
The only place from where i was able to install it:
https://unetbootin.en.uptodown.com/ubuntu/download
but it doesn't work ... it is saying all the time that usb is mount which is not true ...
How can i get Unetbootin?
Thanks!
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#2 2018-12-21 19:22:04
Re: Problems to install and run Unetbootin
Here you go again.  Devuan is not compatible with Ubuntu/Mint packages.
#3 2018-12-21 21:53:50
unetbootin was removed from Debian with I think Stretch.
Try your luck with: https://unetbootin.github.io/linux_download.html
