#1 2018-11-08 14:27:54
eric_openssl
Disconnect / Reconnect
Hello I am a happy new registered person.
Is it possible to reconnect instantaty when we disconnect by click previous ? ( cancelin the session disconnect? )
And is it possible to change timeout for inactivity on the server ? I searched but there is no option, maybe a simple hook ?
#2 2018-11-08 14:56:59
Re: Disconnect / Reconnect
Welcome! I don't quite understand your question but I may know the answer.  When you login, there is an option to stay logged in (or something like that).  Just tick that box and you won't get bit by the timeout bug.
#3 2018-11-08 19:51:17
eric_openssl
I don't found the option but i make a try to remember, under Iceweasel and it is ok. There is a cookie but i think he sudenly deleted. Thanks helping Golinux.
#4 2018-11-08 20:23:10
Maybe this will help:
https://dev1galaxy.org/files/login.png
#5 2018-11-13 20:21:49
eric_openssl
It's good it's workd fine thanks you.
