#1 2018-10-25 21:45:30
leegold
A Way To Make a Bootable USB from an Iso file in Devuan
I was looking for a bootable USB maker where you can use a .iso to make a bootable USB. In Windows it would be an .exe called "Rufus" for example. Looked in Synaptic but couldn't find one. I'm using Devuan GNU/Linux ascii. Would prefer not to use dd(?)
Thanks
#2 2018-10-25 21:58:18
Re: A Way To Make a Bootable USB from an Iso file in Devuan
Take a look at refracta2usb.
You can also dd the drive but I can't seem to find the command atm.  It's somewhere in here . . . LOL!
Oh here it is:
dd if=<full path to installer iso> of=/dev/sdx
#3 2018-10-25 22:29:50
#4 2018-10-26 19:22:48
GNUser
I really like bootiso. It is free software, available here: https://github.com/jsamr/bootiso
#5 2018-10-26 21:36:44
sgage
Etcher works quite well. https://etcher.io/
