#1 2018-10-25 14:04:48
James1138
How to upgrade Claws Mail client to Stretch backport
I first added the Stretch backports to the sources list but when I then installed Claws Mail email client - I found version 3.14 installed instead of the 3.17 in the backport.
Help,
Thanks,
James
Indiana/USA
#2 2018-10-25 14:51:07
ilargi
Re: How to upgrade Claws Mail client to Stretch backport
You may want to try adding this to /etc/apt/sources.list instead of stretch-backports:
deb http://deb.devuan.org/merged ascii-backports main
Update your sources:
apt-get update
And now install claws-mail-3.17
apt-get install -t ascii-backports claws-mail
Hope this helps|
#3 2018-10-25 15:15:13
@James1138 . . . never use Debian repos directly.  Our Devuan mirror(s) filter unwanted packages that are incompatible with Devuan.
#4 2018-10-26 14:28:07
James1138
Thanks for the tip. Did that but found I shall stay with 3.14 because 3.17 forces a person to install Dillo.
James
Indiana/USA
#5 2018-10-26 15:18:31
ilargi
claws-mail 3.17 wanting to drag dillo is most likely just because you are also trying to install claws-mail-dillo-viewer or claws-mail-extra-plugins. These two have dillo as a dependency, but not claws-mail itself.
You can check dependencies here:
https://pkginfo.devuan.org/
