#1 2018-09-10 15:19:24
Giorgos
Software-properties-kde can't run.
Do you think, that's a bug?
Anyone succeeded rinning it?
>kdesu software-properties-kde
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
kbuildsycoca4 running...
kdesu(3104)/kdesu (kdelibs) KDESu::PtyProcess::exec: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/process.cpp : 293 ]  Running "/bin/su"
kdesu(3104)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/su.cpp : 259 ]  Read line "Password: "
kdesu(3104)/kdesu (kdelibs) KDESu::PtyProcess::WaitSlave: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/process.cpp : 379 ]  Child pid 3122
kdesu(3104)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/su.cpp : 259 ]  Read line ""
kdesu(3104)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/su.cpp : 259 ]  Read line "kdesu_stub"
kdesud(3124)/kdesu (kdelibs) KDESu::PtyProcess::exec: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/process.cpp : 293 ]  Running "/bin/su"
kdesud(3124)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/su.cpp : 259 ]  Read line "Password: "
kdesud(3124)/kdesu (kdelibs) KDESu::PtyProcess::WaitSlave: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/process.cpp : 379 ]  Child pid 3127
kdesud(3124)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/su.cpp : 259 ]  Read line ""
kdesud(3124)/kdesu (kdelibs) KDESu::SuProcess::ConverseSU: [ /build/kde4libs-9mfSCR/kde4libs-4.14.26/kdesu/su.cpp : 259 ]  Read line "kdesu_stub"
After the last line it just fails silently.
#2 2018-09-10 16:41:18
Re: Software-properties-kde can't run.
gksu has been deprecated on beowulf iirc maybe KDEsu has also?  Has been discussed on DNG ml and elsewhere.
#3 2018-09-11 10:52:29
Giorgos
Oh I see! I didn't know.
Though is seems to be the other way around.
I think kdesudo (and gksudo) is going to be obsoleted.
https://packages.debian.org/search?sear … ords=kdesu
Indeed at my system kdesudo fails to properly execute anything.
On the other hand, kdesu can flawlessly launch programs (Dolphin, Kate etc).
Seems to me that's a Software-properties-kde bug (not Kdesu's).
