#1 2018-08-11 02:47:00
xe-non
new desktop-live iso
My suggestions ,
#> release , desktop-live iso for xfce , kde , gnome and mate.
#> release , community desktop-live iso for i3 , openbox and awesom.
#> add choose-init option to desktop-live  installer.
#> add one click option to download iso on devuan.org/get-devuan .
#2 2018-08-11 03:34:12
Re: new desktop-live iso
Feel free to prepare those isos and submit them to Devuan for inclusion.
#3 2018-08-11 03:50:57
xe-non
what about installer and get-devuan page?
#4 2018-08-11 04:11:18
The desktop-live installer - refractainstaller - rsyncs the running live system.  It cannot add anything directly during installation.  You could install another init option in the live-environment and then install the modified version.  But if switching init requires a reboot that won't work.  This from the readme:
Refracta Installer will install the operating system to hard drive from
a running live-CD or live-USB session. The running system will be copied
exactly - any changes you make to the running system, including desktop
preferences, configuration changes, or added software will be copied to
the installed system.
As to the get-devuan page . . . there is no one-size-fits-all iso.  Devuan is about CHOICE.
#5 2018-08-12 19:30:48
There is a point in the installer, right before it installs the bootloader, where you could chroot into the installed system and make changes (such as installing openrc.) I haven't tried it, but it should work.
#6 2018-08-13 23:37:49
xe-non
Ok thankz i will try it.
