#1 2018-08-08 07:14:25
stroudmw
[Solved] MIYO and Seamonkey
I'm having issues trying to install the Seamonkey web browser in Miyo Awesome (Devuan GNU/Linux 2.0) . I like that browser because, not only is it lightweight, but it also comes with a pretty good email client.
I add the following to /etc/apt/sources.list:
deb http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt all main
...and then run this:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 2667CA5C
...and get this:
Executing: /tmp/apt-key-gpghome.3PmnrSXlye/gpg.1.sh --recv-keys --keyserver keyserver.ubuntu.com 2667CA5C
gpg: keyserver receive failed: Server indicated a failure
I've used this method with both Devuan Ascii and Debian Stretch without issues, but for some reason I can't get it to work with Miyo!
Linux hurricane 4.9.0-7-amd64 #1 SMP Debian 4.9.110-3+deb9u1 (2018-08-03) x86_64 GNU/Linux
Thanks.
edit: I have been using the instructions found here: https://wiki.debian.org/Seamonkey
#2 2018-08-08 08:55:54
MiyoLinux
Re: [Solved] MIYO and Seamonkey
Hi stroudwm,
You're using Awesome if I remember correctly?
Edited to add: yes, you're using Awesome...as you stated in the OP! tongue
I don't use Seamonkey, but to see what would happen, I just followed the instructions that you gave in your edit on my Miyo-Awesome installation; I also received an error message; however, there was more information given...
dan@miyolinux:~$ sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com 2667CA5C
Executing: /tmp/apt-key-gpghome.2rpRGMj9Dw/gpg.1.sh --recv-keys --keyserver keyserver.ubuntu.com 2667CA5C
gpg: failed to start the dirmngr '/usr/bin/dirmngr': No such file or directory
gpg: connecting dirmngr at '/tmp/apt-key-gpghome.2rpRGMj9Dw/S.dirmngr' failed: No such file or directory
gpg: keyserver receive failed: No dirmngr
So, I installed dirmngr...
sudo apt install dirmngr
After installing dirmngr, I ran the previous command again, and I received no errors that time. Went ahead and installed Seamonkey with the command given in the instructions, and Seamonkey installed.
Did you not receive that notification about dirmngr?
#3 2018-08-08 09:45:05
stroudmw
Yep smile I did install dirmngr. I should've mentioned that, sorry.
edit: perhaps I should reinstall dirmngr...
#4 2018-08-08 10:02:15
stroudmw
Reinstalled dirmngr and I still have the same problem.
#5 2018-08-08 10:31:18
stroudmw
Ok... I found the solution:
I changed:
to:
sudo apt-key adv --recv-keys --keyserver hkp://keyserver.ubuntu.com:80 2667CA5C
I don't understand why this worked... it wasn't my ufw firewall as 1) I've done this many times before and the firewall has never been an issue, and 2) I had thought of the firewall and had disabled it!
Anyhow, it works. It must be magic.
#6 2018-08-08 11:31:06
MiyoLinux
Strange...
I didn't touch the firewall...it was still enabled when I did everything.
Miyo-magic!
LOLOLOLOLOLOLOLOLOL!  tongue
#7 2018-08-08 11:35:58
stroudmw
yes... strangely strange, yet oddly normal!
Thanks (again) for your help. I've written a nice review in Sourceforge, as well as the "Linux for Older Computers" Facebook group.
#8 2018-08-08 12:54:05
Just curious . . . why are you letting anything ubuntu touch your setup?
#9 2018-08-08 12:56:34
stroudmw
Because I want Seamonkey to stay updated. I neither like nor dislike Ubuntu: I'm rather ambivalent.
Why do you care?
#10 2018-08-08 13:22:17
stroudmw wrote:
Why do you care?
Because Devuan users should be aware that packages installed from Ubuntu could have "unintended consequences" on their Devuan system.  It is a bit like Russian roulette.  But your box, your choice.
#11 2018-08-08 13:25:28
stroudmw
I've been using this for a few years, without issues. I got the instructions from the Debian wiki. If it breaks, I'll fix it. Or, in a worse case, spend a morning reinstalling.
#12 2018-08-08 14:56:22
OK.  That's good to know.
#13 2018-08-09 04:36:23
MiyoLinux
Thank you for the review. I'm not on Facebook, so I won't see that one, but thank you anyway. smile
#14 2018-10-26 15:59:17
James1138
This may help in staying up-to-date on your installed version of SeaMonkey without the need to add any repositories...
https://sourceforge.net/projects/ubuntu … lla-build/
I used SeaMonkey in the past but so far cannot use it to watch Netflix since it does not yet support DRM playback like Firefox does,
James
Indiana/USA
