#1 2018-08-04 06:51:32
Ozi
DIY - Kirk it's here now!
Hi All
I had a request for an updated version of DIY, which is now almost done.
It will include a DIY iso, and the build environment to customise it for your selves. There is a setup script which will install the live-build packages and then add the updated scripts for Devuan. And I'll also update the README of sourceforge.
https://sourceforge.net/projects/linnix/files/
Ozi
#2 2018-08-04 09:15:05
MiyoLinux
Re: DIY - Kirk it's here now!
Ozi, thank you!
...or as my insignificant mind says in "Down Under Australian"...
(: ¡¡¡no⅄ ʞuɐɥʇ ƃᴉq ∀
I'm really looking forward to this. Thank you for all that you did to produce it! smile
#3 2018-08-04 09:21:51
Ozi rocks!
You do too but this is Ozi's moment . . .
#4 2018-08-04 23:40:20
Ozi
I'm uploading a DIY image and the build environment in diy-devuan-2018-08-04.tar.gz now and I have updated the README.
This example uses Devuan Ascii as the build environment
Open a terminal window in your home directory and run the following commands:
$ wget -c "http://sourceforge.net/projects/linnix/files/diy-devuan-2018-08-04.tar.gz"
Copy diy-devuan-2018-08-04.tar.gz into your HOME folder the extract it
$ tar -zxvf diy-devuan-2018-08-04.tar.gz
This will install live-build and live-tools, then add the updates for Devuan Ascii
$ cd ~/diy-devuan/setup/
$ sudo setup
Suggestion: add these lines to .bash_aliases
alias diy='cd ~/diy-devuan'
alias menu='sudo ./menu'
To run the build
$ diy
$ menu
The live-build manuals are here:
      /usr/share/doc/live-manual/
#5 2018-08-05 12:26:27
MiyoLinux
Ozi, your work is not in vain...it's GREATLY appreciated! smile
#6 2018-08-05 19:53:53
Ozi
Thanks  Miyo! smile
I hope you get some useful information from it! wink
Enjoy!
