#1 2018-07-31 15:35:34
VH
How can I use Internet Relay Chat?
I am trying to get some help through IRC.  I tried to access ircs://irc.freenode.net/#devuan channel using https://freenode.net/.
I entered
Nickname:
Channels:
Username:
Password:
I also registered my username and password as well.
However, in the chat room, I can only see what I type and I cannot see anybody else's typing.  What should I do?
#2 2018-07-31 16:17:49
yeti
Re: How can I use Internet Relay Chat?
I see a V-H in my logs, so your configuration probably is correct.
Lots of IRCers stay connected to the chat(s) even while they are away or otherwise distracted. So sometimes a channel looks full while answers come with a huge delay... that's somehow normal... sometimes...
Give it a 2nd try with a bit more of patience...
#3 2018-07-31 16:38:47
Yes, just ask your question and stay logged for an answer.   You can read the logs here or here but if you are not logged in you may not receive a response.
#4 2018-07-31 23:15:34
VH
Ok, thanks.
I see my messages in the log.
Good to know!
#5 2018-07-31 23:30:47
sgage
I have had good results with HexChat (in the repos).
#6 2018-08-01 00:17:08
ChuangTzu
HexChat is quite useful.
