#1 2018-06-23 09:42:24
scar352
Support for Devuan Jessie
Hi all,
I am new here at the forum and apologies if this has been asked before or seems obvious, but I did not find an answer in the official Devuan website or in the documentation.
I was wondering now that ASCII has been released, how long will Jessie be still officially supported?
Is it now receiving updates in the same way as Debian Jessie through the LTS program?
Is any change needed in sources.list to receive the updates?
I am asking because I usually do not like to jump on upgrades on my machines and would still like to continue use Devuan Jessie for some time.
I would also like to take the opportunity to congratulate the Devuan community for the amazing work they have done.
It is a fantastic operating system! I could not be happier with it.
Thank you so much!
#2 2018-06-23 11:09:16
devuser
Re: Support for Devuan Jessie
I am guess Devuan Jessie will be supported as long as Debian Jessie is supported but i am not 100% sure. An actual developer will probably chime in soon and give you a definitive answer though.
Pretty sure you don't need to do anything.
#3 2018-06-23 11:28:13
Panopticon
From memory i think Debian Jessie support ends in 2020 for LTS?  Not sure with Devuan, but seeing as Devuan tracks debian i would say similar time frames?
https://wiki.debian.org/DebianReleases
LTS = https://wiki.debian.org/LTS
#4 2018-06-23 15:20:49
Welcome to Devuan!  The 'official' answer is in the second sentence on the index page of the https://devuan.org/ website.
#5 2018-06-23 18:00:26
scar352
Thank you.
I assume that you mean Devuan Jessie is now under oldstable status? Please, correct if I am wrong.
Debian Jessie oldstable support has now ended and it is now under the LTS program, not provided by Debian security team, but by third parties.
If possible, I'd just like a clarification on how this works currently for Devuan.
Is there a Devuan security team that provides security updates for Jessie currently under oldstable release? Or do the security updates come mirrored from the Debian LTS program?
Will there be an LTS program for Devuan Jessie too, which will extend beyond the Debian Jessie's LTS?
#6 2018-06-23 18:40:49
devuser
Yes, i guess thats (usually) the case.
Doubt it. It's unlikely Devuan currently has the spare resources needed to extend the life cycle beyond what's supported by Debian.
#7 2018-06-23 18:49:19
I wasn't aware of that but according to this page yes.
We follow the Debian LTS cycle as described on this page.  The LTS upgrades applied to Debian will be available in the Devuan Jessie repos as they have always been.
#8 2018-06-24 08:23:56
scar352
Thanks all.
It is clear now. Great to know I can still continue to enjoy the stability of Jessie for a while.
