#1 2018-06-22 04:55:35
ername
Wifi and HDMI upgrade issues
After updating from devuan Jessie to 2.0.0 ASCII, wifi stopped working and the computer stopped seeing HDMI TV, so it was during the update and also with the new installation. I had to put Jessie again.
#2 2018-06-22 05:03:03
Re: Wifi and HDMI upgrade issues
Did you study the Release Notes before trying to upgrade?
#3 2018-06-22 05:07:46
ername
No, I did not study, because I do not know English, I'm thinking about this stable release, so everything should work
#4 2018-06-22 05:15:01
It should work if you follow the upgrade instructions carefully and have the correct repos enabled.
