#1 2018-06-14 03:13:02
Llewellen
My Wallpaper
How to post an image from a folder on my computer?
It is not that I am mad; it's only that my head is different from yours - Diogenes of Sinope
#2 2018-06-14 04:02:55
Re: My Wallpaper
Here's the magic incantation.  Thought this early description of how amprolla works might be an interesting example:
[img=image-description]url-to-image[/img]
amprolla
Or if you want a thumbnail
[url=url-to-full-image][img=image-description]url-to-thumbnail[/img][/url]
amprolla
#3 2018-06-14 04:08:25
Llewellen
Re: My Wallpaper
@golinux:  Thank you but I can be quite thick sometimes.  What's the url to a .png image in a folder on my computer?
#4 2018-06-14 04:11:04
Re: My Wallpaper
You'll have to post it online somewhere if you don't have access to a server.
#5 2018-06-14 04:14:20
Llewellen
Re: My Wallpaper
OK thanks.  Let me see if I can share a note in Evernote or Zoho Notebook.
#6 2018-06-14 04:29:24
Llewellen
Re: My Wallpaper
This is a wallpaper I made for Devuan with Enlightenment22 DE/Window Manager.  As you can see, I'm not a graphic designer but it works for me on my system.
The Devuan script logo is from the site; the E22 design logo came from wikipedia where it was shiny black - I recoloured it to be sort of close to the blue colour of the default E22 theme.  Then I used a few basic, simple GIMP tools.
Ignore the panel at the top.  I made this on a laptop running Manjaro because that's where I have GIMP installed at the moment.
https://www.evernote.com/shard/s517/sh/ … 5bf2e1fefd
#7 2018-06-14 05:08:06
Re: My Wallpaper
Server not found
Firefox can’t find the server at deve22%20backgrouind.
Yada Yada
#8 2018-06-14 05:13:00
Llewellen
Re: My Wallpaper
golinux wrote:
Server not found
Yada Yada
Wonderful.  Evernote just went live with beta of an updated web app.  Maybe that's the problem, although it does have a toggle to test the web address it generates in response to the <share> command and that worked for me.  I'll mess with it tomorrow and then edit my post, either to post a revised, working url or to advise that I can't link to the background in question.
#9 2018-06-14 07:01:12
Re: My Wallpaper
I think you're using the url tag back-to-front; it takes the actual url in the begin tag, and the description between the tags. So if you swap those, it becomes a click-accessible url. As is, one has to copy that url that is seen and paste to follow, rather than clicking it.
#10 2018-06-14 14:44:35
Llewellen
Re: My Wallpaper
I double checked and I did have it listed as specified in tne <url> help section.  However, I deleted the description between the tags and the link now works.
