#1 2018-05-30 18:17:21
GNUser
what is the difference between ./ and ././ [SOLVED]
I've been hacking on GNU/Linux for a long time, so obviously I'm familiar with ./ and use it often. It seems that ././ is also sometimes used to mean "here" (for example, see the No hard-coded paths section here).
Have you ever encountered ././ before? I have only ever seen it in the AppImage guide in the link above. Please, what's the difference between ./ and ././? Internet searches have not turned up anything even remotely relevant this question.
#2 2018-05-30 18:36:47
Re: what is the difference between ./ and ././ [SOLVED]
I have often used something similar ../ or even .../ in web design to navigate to various files in the tree structure of a complicated site.  Is ././ in a path to a file?  Or within some code?
#3 2018-05-30 18:44:23
GNUser
Yes, ././ in the context of AppImage creation are the leading characters in a relative path and means "here". I can confirm that it works:
bruno@thinkpad:~$ cd /bin
bruno@thinkpad:/bin$ ././echo test
test
But for the life of me I can't figure out why someone wouldn't simply use plain ol' ./. Maybe the AppImage guys are unaware that the simpler form is equivalent? Maybe ././ also works in other OSes but ./ only works in GNU/Linux? I'm at a loss.
If none of my Devuan friends know, I may contact the AppImage guys to ask them.
#4 2018-05-30 19:19:50
GNUser
I asked the AppImage guys and they explained it to me: https://github.com/AppImage/AppImageKit … -393284213
In a word, ././ is redundant. It's a hack to convert absolute paths (e.g., /usr/bin/foo) to relative paths (e.g., ././/bin/foo) without changing the length of the string. Binaries have internal addresses, so if the length of a string inside a binary is changed when patching the binary to make it portable, the binary will no longer work because things will no longer be at the expected addresses.
#5 2018-05-30 20:13:43
It's not at all obvious to me . . .
