#1 2018-05-12 14:27:13
MiyoLinux
Input requested regarding Suspend
I've made a shutdown utility to use on future versions of Miyo. I'm using it now on the latest release instead of the default obsession utility... tongue
My question is, for those who use Suspend, do you prefer the screen to be locked when you Suspend? Yes, no...doesn't matter?
I'm not asking in regards to MiyoLinux users; I'm asking in regard to anyone who uses Suspend on any operating system. smile
Thank you for any input!
Click to enlarge...
miyo-exit.png?1526134678
#2 2018-05-13 23:15:47
msi
Re: Input requested regarding Suspend
I usually don't use suspend, so I can't say. But I'd like to have a look at the source of your utility if you don't mind. Can you put it up on GitHub? I suppose it's either written in Bash or Python. I'm working on something similar (in Bash, currently).
#3 2019-02-16 06:06:50
stanz
MiyoLinux wrote:
I've made a shutdown utility to use on future versions of Miyo.......
Just found this, and "No" - I don't want screen to be locked. But, isn't that an option in power manager?
Keeping the option, sounds good to keep smile
asta
miyoisomix.i2p
#4 2019-02-16 06:16:42
imhigh.today
I generally prefer systems to err on the side of being mistrusting. If I'm using suspend, I'm probably on a device with a battery. Devices on batteries can be picked up and moved away from the owner.
Lock screen, verify that the person in front of the computer is the owner before displaying any potentilaly sensitive data.
Devuan Ceres | Ryzen 2400G | RX560 | 32GB RAM | Samsung 850 Pro
#5 2019-02-16 12:48:27
xinomilo
Unknown
yes, always turn on a screen lock in screensaver/suspend.
but in general i agree with @stanz, that should be a choice, not a default smile
#6 2019-02-16 17:24:55
franko
I'm with imhigh.today and xinomilo, it should have at least the option to lock. I want my screen to be locked when resuming from either suspend or hibernate.
#7 2019-02-16 20:45:14
MiyoLinux
First...thanks for these latest replies. smile  I truly appreciate it.
Second, to msi...I don't know if you'll see this, but I promise that I wasn't avoiding your inquiry. I don't know how I missed it before. Please forgive me.
No...it's simply a basic YAD script...that I'm going to have to change since consolekit apparently will no longer be available beginning in beowulf. neutral  tongue
Here it is as it currently exists...
yad --form --center --undecorated --width=165 --borders=10 --height=320 --title="Exit" --skip-taskbar \
--image=/usr/share/miyolinux/miyo-exit.png --image-on-top \
--field="  Shutdown!gnome-shutdown!Shut Down":fbtn "dbus-send --system --print-reply --dest="org.freedesktop.ConsoleKit" /org/freedesktop/ConsoleKit/Manager org.freedesktop.ConsoleKit.Manager.Stop" \
--field="  Reboot!system-reboot!Restart":fbtn "dbus-send --system --print-reply --dest="org.freedesktop.ConsoleKit" /org/freedesktop/ConsoleKit/Manager org.freedesktop.ConsoleKit.Manager.Restart" \
--field="  Suspend!gnome-session-suspend!Suspend":fbtn "dbus-send --system --print-reply --dest="org.freedesktop.UPower" /org/freedesktop/UPower org.freedesktop.UPower.Suspend" \
--field="  Hibernate!gnome-session-hibernate!Hibernate":fbtn "dbus-send --system --print-reply --dest="org.freedesktop.UPower" /org/freedesktop/UPower org.freedesktop.UPower.Hibernate" \
--field="  Log Out!gnome-logout!Log Out":fbtn "openbox --exit" \
--button=gtk-cancel --buttons-layout=center \
#8 2019-02-16 21:01:49
Isn't there consolekit2.  There has been recent discussion. and also there are consolekit related packages in beowulf:
libpolkit-backend-1-0-consolekit
libpolkit-gobject-1-0-consolekit
etc.
You should probably be on the ML.
#9 2019-02-16 21:33:09
MiyoLinux
etc.
Oh...
tongue
The last time I tried a straight beowulf build, it was a no-go with consolekit. Perhaps I should try again. LOLOLOLOL! tongue
I've been too busy with the latest i3 versions to test things...
Thank you...I'll look into it when I have time. smile
#10 2019-02-18 01:28:11
MiyoLinux
etc.
Oh...
tongue
I'm the Ultra-Quoter! LOLOLOLOLOLOLOLOLOL!  tongue
Well, I tried a quick basic beowulf Openbox build this evening...there's good news and bad news.
The bad news: still no Consolekit.
The good news: the obsession utility (from the repositories) works with elogind! I can shutdown, reboot, etc with it. smile
Using lxpolkit (for the authentication agent), still works fantastic for opening things like synaptic too.
Now if I can figure out what commands obsession is using...
#11 2019-02-18 02:25:20
These packages may or may not be relevant but . . .  I leave it to you to sort . . .
#12 2019-02-18 02:58:57
MiyoLinux
Thank you, but I no longer need Consolekit since obsession works with elogind.
#13 2019-02-20 04:52:59
MiyoLinux
Hooray! I F...I...N...A...L...L...Y found the commands that work with elogind for my exit utility! tongue
loginctl poweroff
loginctl reboot
loginctl suspend
loginctl hibernate
So, if this may possibly help anyone else, here's the new code for the exit utility in upcoming MiyoLinux versions based on beowulf...
yad --form --center --undecorated --align=left --width=165 --borders=10 --height=320 --skip-taskbar \
--field="  Shutdown!gnome-shutdown!Shut Down":fbtn "loginctl poweroff" \
--field="  Reboot!system-reboot!Restart":fbtn "loginctl reboot" \
--field="  Suspend!gnome-session-suspend!Suspend":fbtn "loginctl suspend" \
--field="  Hibernate!gnome-session-hibernate!Hibernate":fbtn "loginctl hibernate" \
...it still looks the same...
#14 2019-02-20 06:47:59
Are you sure? loginctl is in the systemd package .. or rather, where did you get it from?
#15 2019-02-20 07:01:02
MiyoLinux
Ralph, I found it in an old manjaro forum from back when they still had an openrc version.
That loginctl part works on my Beowulf build for shutdown, reboot, and suspend. I haven't tried hibernate yet.
Have I stumbled upon a boo-boo? tongue
#16 2019-02-20 07:06:49
Well, I think one can say you are threading the boundary at least smile
MiyoLinux distribution = Devuan beowulf + ( some bits of systemd that happened to work today )
It doesn't bother me as such, but I might be special wink wink
#17 2019-02-20 07:18:44
MiyoLinux
LOL! big_smile
Dagnabit! Just when I thought I was onto something...
I'll see how it plays out...
#18 2019-02-20 11:00:30
MiyoLinux
Ah...this just registered with me (if I understand the question correctly).
I didn't get "it" anywhere. I just saw what someone was using on Manjaro OpenRC in their i3 config file; which was, loginctl ______ .
I didn't install anything extra; I simply tried the commands first from the terminal, and they worked. Now...whether that relates to it working now (in beowulf) as opposed to it continuing to work in the future...I don't know.
Just wanted to clarify that I didn't install anything to give me the ability to use loginctl.
#19 2019-02-20 12:00:45
mmm maybe a
dpkg -S loginctl
could shed some light on it. For me, as I don't have that program, I tried
apt-file find loginctl
which reported it as belonging to systemd. And as far as I can tell, there is no installation candidate for that package in any Devuan repository.
#20 2019-02-20 12:49:51
MiyoLinux
mmm maybe a
dpkg -S loginctl
Strange.
I'm using straight beowulf repositories. No outside packages installed other than the Refracta tools (which apparently aren't in beowulf yet?)...and my window themes and custom accessories (that use yad straight from the beowulf repos).
Just for kicks, I did another build on another computer that's even more stripped down (than my normal build) with only beowulf repos and no other additions at all...and loginctl works on it too.
Edited to add: I'm on my phone and can't check that command right now. I'll try it later. smile
#21 2019-02-20 13:31:02
xinomilo
Unknown
beowulf.
$ dpkg -S loginctl
elogind: /bin/loginctl
$ apt policy elogind
elogind:
  Installed: 239.3+20190131-1
  Candidate: 239.3+20190131-1
  Version table:
 *** 239.3+20190131-1 500
        500 http://gr.deb.devuan.org/merged testing/main amd64 Packages
        500 http://gr.deb.devuan.org/merged ceres/main amd64 Packages
        100 /var/lib/dpkg/status
#22 2019-02-20 20:59:32
Good. Apparently my use of apt-file leaves some to be desired.
#23 2019-02-20 22:13:56
MiyoLinux
LOL!
Here's what mine shows...
dan@miyolinux:~$ dpkg -S loginctl
elogind: /usr/share/bash-completion/completions/loginctl
elogind: /usr/share/man/man1/loginctl.1.gz
elogind: /usr/share/zsh/site-functions/_loginctl
...and available options...
dan@miyolinux:~$ loginctl -h
loginctl [OPTIONS...] {COMMAND} ...
Send control commands to or query the login manager.
  -h --help                Show this help
     --version             Show package version
     --no-pager            Do not pipe output into a pager
     --no-wall             Do not print any wall message
     --dry-run             Only print what would be done
  -q --quiet               Suppress output
     --no-legend           Do not show the headers and footers
     --no-ask-password     Don't prompt for password
  -H --host=[USER@]HOST    Operate on remote host
  -M --machine=CONTAINER   Operate on local container
  -p --property=NAME       Show only properties by this name
  -a --all                 Show all properties, including empty ones
     --value               When showing properties, only print the value
  -l --full                Do not ellipsize output
     --kill-who=WHO        Who to send signal to
  -s --signal=SIGNAL       Which signal to send
  -c                       Cancel a pending shutdown or reboot
  -i --ignore-inhibitors   When shutting down or sleeping, ignore inhibitors
Session Commands:
  list[-sessions]          List sessions (default command)
  session-status [ID...]   Show session status
  show-session [ID...]     Show properties of sessions or the manager
  activate [ID]            Activate a session
  lock-session [ID...]     Screen lock one or more sessions
  unlock-session [ID...]   Screen unlock one or more sessions
  lock-sessions            Screen lock all current sessions
  unlock-sessions          Screen unlock all current sessions
  terminate-session ID...  Terminate one or more sessions
  kill-session ID...       Send signal to processes of a session
User Commands:
  list-users               List users
  user-status [USER...]    Show user status
  show-user [USER...]      Show properties of users or the manager
  enable-linger [USER...]  Enable linger state of one or more users
  disable-linger [USER...] Disable linger state of one or more users
  terminate-user USER...   Terminate all sessions of one or more users
  kill-user USER...        Send signal to processes of a user
Seat Commands:
  list-seats               List seats
  seat-status [NAME...]    Show seat status
  show-seat [NAME...]      Show properties of seats or the manager
  attach NAME DEVICE...    Attach one or more devices to a seat
  flush-devices            Flush all device associations
  terminate-seat NAME...   Terminate all sessions on one or more seats
System Commands:
  poweroff [TIME] [WALL...] Turn off the machine
  reboot   [TIME] [WALL...] Reboot the machine
  suspend                   Suspend the machine to memory
  hibernate                 Suspend the machine to disk
  hybrid-sleep              Suspend the machine to memory and disk
  suspend-then-hibernate    Suspend the system, wake after a period of
                            time and put it into hibernate
