#1 2018-04-23 05:11:00
fanfoue70
ascii/raspberry 3 wifi problem
Hello,
I have no wlan0 appearing after a fresh ascii install in RPi3.
# iwlist scan
lo        Interface doesn't support scanning.
eth0      Interface doesn't support scanning.
# ifup wlan0
Cannot find device "wlan0"
ifup: failed to bring up wlan0
I added brcmfmac to /etc/modules.
# lsmod
Module                  Size  Used by
ipv6                  479232  24
brcmfmac              270336  0
brcmutil               16384  1 brcmfmac
cfg80211              688128  1 brcmfmac
rfkill                 32768  1 cfg80211
vc4                   184320  0
snd_soc_core          208896  1 vc4
snd_pcm_dmaengine      16384  1 snd_soc_core
drm_kms_helper        200704  1 vc4
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
drm                   438272  2 vc4,drm_kms_helper
joydev                 28672  0
snd_bcm2835            40960  1
hid_cherry             16384  0
snd_pcm               122880  4 vc4,snd_pcm_dmaengine,snd_bcm2835,snd_soc_core
snd_timer              36864  1 snd_pcm
snd                    86016  6 snd_timer,snd_bcm2835,snd_soc_core,snd_pcm
vchiq                 348160  1 snd_bcm2835
uio_pdrv_genirq        16384  0
uio                    24576  1 uio_pdrv_genirq
evdev                  24576  3
config :
Raspberry 3 model B Rev 1.2
devuan_ascii_2.0.0-beta_arm64_raspi3.img
A devuan jessie on the same hardware (updated firmware) ran wifi OK. I tested with the distributed and updated firmware on ascii.
Thanks for the help.
#2 2018-04-23 07:59:17
wdq
Re: ascii/raspberry 3 wifi problem
try ifconfig as root i have a wild guess that the name is not wlan0 but other
Just a simple man!
#3 2018-04-23 08:45:21
fanfoue70
Thanks for answering !
ifconfig as root only lists lo and eth0.
One funny thing is that when I remove/modprobe the brcmfmac module, syslog only says the module is registred, nothing about firmware.
#4 2018-04-23 10:27:12
wdq
iwconfig
post an output of   lspci -nn
Just a simple man!
#5 2018-04-23 14:43:42
fanfoue70
# iwconfig
eth0      no wireless extensions.
lo        no wireless extensions.
# lspci -nn
pcilib: Cannot open /proc/bus/pci
lspci: Cannot find any working access method.
(this is a rpi, no pci bus as far as I know)
#6 2018-04-23 15:02:18
wdq
because this is a forum and is hard to be always to look i suggest to you to join #devuan-arm on freenode irc chat
https://webchat.freenode.net
channel - #devuan-arm  where you will get an answer in real time
Just a simple man!
#7 2018-04-23 15:19:33
fanfoue70
don't worry I'm not in a hurry :-)
by the way, here the output of lshw :
# lshw -c net
  *-network
       description: Ethernet interface
       physical id: 1
       logical name: eth0
       serial: b8:27:eb:fc:81:5b
       capacity: 100Mbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=smsc95xx driverversion=22-Aug-2005 duplex=full firmware=smsc95xx USB 2.0 Ethernet ip=192.168.1.22 link=yes multicast=yes port=MII speed=100Mbit/s
#8 2018-04-23 15:21:04
fanfoue70
and lsusb :
# lsusb
Bus 001 Device 005: ID 413c:3016 Dell Computer Corp. Optical 5-Button Wheel Mouse
Bus 001 Device 004: ID 046a:0023 Cherry GmbH CyMotion Master Linux Keyboard G230
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
#9 2018-04-23 15:23:36
fanfoue70
syslog does not give very much info either :
# grep -i mac /var/log/syslog
Apr 23 07:11:39 raspi2 kernel: [    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
Apr 23 07:11:39 raspi2 kernel: [    0.095845] bcm2835-dma 3f007000.dma: DMA legacy API manager at ffffff800801d000, dmachans=0x1
Apr 23 07:11:39 raspi2 kernel: [    5.283902] usbcore: registered new interface driver brcmfmac
# grep -i 80211 /var/log/syslog
# grep -i wire /var/log/syslog
#10 2018-04-23 15:32:56
wdq
Do you have raspi-config installed ?
If yes
 elect item 9, Advanced Options
Select item A5, Device Tree
Choose Yes
Reboot
if not
download this script from github
https://github.com/snubbegbg/install_raspi-config
and run it in terminal as root like so
sh install.sh
and follow the steps above
Just a simple man!
#11 2018-04-24 19:25:47
fanfoue70
I could install raspi-config, but the procedure didn't work (I tried twice), still no wlan0 or anything wireless else (only eth0 & lo).
By the way, A5 is not labelled "Device Tree" but SPI. Is it the same thing ?
Anyway, a SPI module is loaded
# lsmod |grep spi
spi_bcm2835            20480  0
and the devices are created
# ls -al /dev/spidev0.*
crw------- 1 root root 153, 0 Apr 24 21:15 /dev/spidev0.0
crw------- 1 root root 153, 1 Apr 24 21:15 /dev/spidev0.1
#12 2018-04-25 10:17:33
fanfoue70
I tried a rpi-update; same problem.
#13 2018-04-25 10:22:25
yeti
Maybe the builder of the PI3 images just doesn't read the forum?
β€”β–Ά https://git.devuan.org/sdk/arm-sdk/issues/28
Add a help cry there?
I was told in Devuan's IRC channel #devuan-arm that a solution exists but I did not get details.
*sigh!*
My two PI3s are still waiting for a solution too...
<πš‹πš˜πšπš’ πš˜πš—πš•πš˜πšŠπš='πšπš˜πšŒπšžπš–πšŽπš—πš.πš‹πš˜πšπš’.πš’πš—πš—πšŽπš›π™·πšƒπ™Όπ™»="π™³πš’πšœπšŠπš‹πš•πšŽ π™Ήπš‚!";'>
π”“π”©π”’π”žπ”°π”’ π”©π”’π”žπ”³π”’ 𝔢𝔬𝔲𝔯 π”£π”žπ”²π”©π”±π”° 𝔦𝔫 𝔱π”₯𝔒 𝔰𝔒𝔠𝔱𝔦𝔬𝔫 π”Ÿπ”’π”©π”¬π”΄ π”žπ”«π”‘ 𝔑𝔬𝔫'𝔱 𝔣𝔬𝔯𝔀𝔒𝔱 𝔱𝔬 π”²π”«π”°π”²π”Ÿπ”°π” π”―π”¦π”Ÿπ”’!
#14 2018-04-25 16:01:38
Exactly.   #devuan-arm (ping parazyd) and https://git.devuan.org/sdk/arm-sdk/issues/ are excellent places to catch his attention.
#15 2018-04-29 12:40:59
fanfoue70
Here's a solution (found in https://git.devuan.org/sdk/arm-sdk/issues/28 and https://quantum2.xyz/2017/10/27/install … with-wifi/) :
get https://cs.wallawalla.edu/%7Estiltr/rpi3_4.14.26.tar.gz
extract archive, overwrite /boot with content of 4.14.26_boot.tar.gz
extract 4.14.26_modules.tar.gz into root partition (kernel modules)
get debian image from https://people.debian.org/~stapelberg/r … IEW.img.xz
mount image, copy firmware from root partition (/lib/firmware/brcm/*430*)
it should work :-)
