#1 2018-04-17 19:23:41
richard-tx
8812 driver for Devuan Jessie
I am attempting to build a driver for the 8812 USB wifi device.
Can anyone help with a quick how-to?
I found this link for the Raspberry Pi, but that does not work with Devuan for obvious reasons.
One of the reasons is /lib/modules/build.   It is a sym linked to /home/paralyzd/arm-sdk....
This is for the Raspberry Pi 2 (32 bit) Jessie release.
rich
#2 2018-04-17 20:17:03
bbatten
Re: 8812 driver for Devuan Jessie
There is a Linux kernel driver for the Realtek RTL8812AU USB device which you can pull from Github here and compile.
#3 2018-04-17 20:23:41
Surely this is a typo: /home/paralyzd/arm-sdk....
#4 2018-04-18 00:38:58
richard-tx
More of the same issue.
root@devuan:~/rtl8812AU_8821AU_linux# make
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/4.10.17-v7+/build M=/root/rtl8812AU_8821AU_linux  modules
make[1]: Entering directory '/home/parazyd/arm-sdk/tmp/kernels/raspi2/raspi2-linux'
make[1]: *** No rule to make target 'modules'.  Stop.
make[1]: Leaving directory '/home/parazyd/arm-sdk/tmp/kernels/raspi2/raspi2-linux'
Makefile:1584: recipe for target 'modules' failed
make: *** [modules] Error 2
[b]root@devuan:~/rtl8812AU_8821AU_linux# ls -l /lib/modules/4.6.3-gb48d47a/build
lrwxrwxrwx 1 root root 53 Oct 12  2016 /lib/modules/4.6.3-gb48d47a/build -> /home/parazyd/arm-sdk/tmp/kernels/raspi3/raspi3-linux[/b]
You can see the problem.  I just don't know how to fix it.  Well I do, but I have no idea where to get the correct file(s).
#5 2018-04-18 00:50:14
richard-tx
What do I know?  In any case, the sym link points to something that isn't there.  (:>)
#6 2018-04-18 01:05:29
This is what's in the script.
You might like to know that parazyd builds all of the arm stuff.
#7 2018-04-18 02:05:50
richard-tx
All that is in the dir is directories.  No files.
I guess I am going to have to email parazyd.
#8 2018-04-18 02:31:23
That or freenode #devuan-arm
#9 2018-04-18 13:54:29
Check the Makefile to see if there's a place to set that path so it corresponds to your own setup.
#10 2018-04-19 18:15:26
bbatten
richard-tx wrote:
... the sym link points to something that isn't there.
Your screen output doesn't seem to show a complaint about being unable to resolve a symlink. The line "No rule to make target 'modules'" means that target can't be found in a Makefile. The kernel Makefile has "modules:" as a target.
Have you installed a kernel header package? Alternatively, have you installed a kernel source tree?
Have you done a "make prepare"?
