#1 2018-02-23 01:39:52
GNUser
in ASCII, libpolkit-agent-1-0 and policykit-1 held back? [SOLVED]
I thought I'd give ASCII a try and installed it using the Miyo live desktop. Then I installed mate-desktop-environment-extras. Everything works well, but trying to upgrade the system leaves two packages behind:
bruno@thinkpad:~$ sudo apt-get dist-upgrade
[sudo] password for bruno:
Building dependency tree
Calculating upgrade... Done
  libpolkit-agent-1-0 policykit-1
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Does anybody know why? The two package versions are version 0.105-9+devuan1.
#2 2018-02-23 02:56:48
GNUser
Re: in ASCII, libpolkit-agent-1-0 and policykit-1 held back? [SOLVED]
I'm not sure about the answer to my question, but installing these two packages made the issue go away:
libpolkit-backend-1-0-elogind libpolkit-gobject-1-0-elogind
Also, I was having problems mounting/unmounting USB drives (little boxes pop up saying I didn't have permission) and shutdown/rebooting (would take me to login screen) via the GUI. These problems went away when I installed the two packages above.
#3 2018-02-23 04:20:15
This has been discussed on the dng mail list and the irc channels and even this forum.  Unfortunately I don't understand it well enough to explain it.   IIRC it only happens on an upgrade, not a new install.  The devs are working hard to sort things so that the needed files are deleted/delivered under every possible circumstance.
#4 2018-02-23 09:40:09
Geoff 42
Yes, if you follow golinux' link you will see that installing the elogind backends replaces the packages causing the problem. You will need to ignore some worrying looking warnings though...
Geoff
#5 2018-02-23 14:40:01
GNUser
Thank you both. I have not been following ASCII's development as closely as I should sad
