#1 2017-11-11 07:27:53
makh
(SOLVED) [Jessie] System keeping - how to undo package break of xfce4
Hi
I made a mistake trying to make my OS smaller. So I removed a few packages from the dependencies of meta package xfce4. But now I am getting this dependency issue, even though I reinstalled the earlier removed packages:
Calculating upgrade... The following packages were automatically installed and are no longer required:
  hddtemp libxfcegui4-4 ristretto xfce4-artwork xfce4-battery-plugin
  xfce4-clipman xfce4-clipman-plugin xfce4-cpufreq-plugin
  xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-diskperf-plugin
  xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-mailwatch-plugin
  xfce4-mount-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin
  xfce4-places-plugin xfce4-quicklauncher-plugin xfce4-screenshooter
  xfce4-sensors-plugin xfce4-smartbookmark-plugin xfce4-systemload-plugin
  xfce4-taskmanager xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin
  xfce4-weather-plugin xfce4-xkb-plugin
Use 'apt-get autoremove' to remove them.
But I want to keep these packages. ... Kindly guide.
Thankyou.
HP Probook 440 G2: Arch, Debian Stable
Others: Devuan, Centos, Ubuntu, Opensuse
GUI: Openbox, Xfce, Cinnamon
Chroot: Debian, Ubuntu, Fedora
#2 2017-11-11 08:02:24
Re: (SOLVED) [Jessie] System keeping - how to undo package break of xfce4
1.  Reinstall the meta package and you 'should' get everything back.
2.  Reinstall xfce without the meta package and just add the pkgs you want.
#3 2017-11-12 04:48:54
makh
Hi
cat /var/log/apt/history.log
My try:
Start-Date: 2017-11-07  21:00:37
Commandline: apt remove hplip hplip-data quodlibet xfburn xsane xsane-common
Remove: hplip:amd64 (3.14.6-1+deb8u1), xfburn:amd64 (0.5.2-1), xsane-common:amd64 (0.998-6), printer-driver-postscript-hp:amd64 (3.14.6-1+deb8u1), xsane:amd64 (0.998-6+b1), quodlibet:amd64 (3.2.2-1), hplip-data:amd64 (3.14.6-1+deb8u1), xfce4-goodies:amd64 (4.10)
End-Date: 2017-11-07  21:00:51
Start-Date: 2017-11-07  21:07:02
Commandline: apt install hplip hplip-data quodlibet xfburn xsane xsane-common
Install: hplip:amd64 (3.14.6-1+deb8u1), xfburn:amd64 (0.5.2-1), xsane-common:amd64 (0.998-6), printer-driver-postscript-hp:amd64 (3.14.6-1+deb8u1, automatic), xsane:amd64 (0.998-6+b1), quodlibet:amd64 (3.2.2-1), hplip-data:amd64 (3.14.6-1+deb8u1)
End-Date: 2017-11-07  21:07:12
Start-Date: 2017-11-11  23:39:37
Commandline: apt-get install --reinstall xfce4
Reinstall: xfce4:amd64 (4.10.1)
End-Date: 2017-11-11  23:39:40
Start-Date: 2017-11-12  09:43:56
Commandline: apt-get install --reinstall xfce4 hplip hplip-data quodlibet xfburn xsane xsane-common
Reinstall: hplip:amd64 (3.14.6-1+deb8u1), xfburn:amd64 (0.5.2-1), xsane-common:amd64 (0.998-6), xfce4:amd64 (4.10.1), xsane:amd64 (0.998-6+b1), quodlibet:amd64 (3.2.2-1), hplip-data:amd64 (3.14.6-1+deb8u1)
End-Date: 2017-11-12  09:44:08
But still I get:
# apt upgrade
Building dependency tree
#4 2017-11-12 12:28:58
apt-get install hddtemp libxfcegui4-4 ristretto xfce4-artwork xfce4-battery-plugin...
and any other packages from the autoremoval list that you want to keep. They will then be marked as manually installed.
#5 2017-11-13 11:50:44
makh
Thankyou Sir!
