#1 2017-11-01 05:43:30
makh
[Solved] Virtualbox guest additions - not working (Ascii)
Hi
I have installed the guest cd components, but they are not working in ascii: like shared folder.
I am having devuan ascii installed inside virtualbox 5.1.30
also I get for:
cat /etc/debian_version
9.2
cat /etc/devuan_version
jessie
Thankyou
HP Probook 440 G2: Arch, Debian Stable
Others: Devuan, Centos, Ubuntu, Opensuse
GUI: Openbox, Xfce, Cinnamon
Chroot: Debian, Ubuntu, Fedora
#2 2017-11-03 03:18:14
fog
Re: [Solved] Virtualbox guest additions - not working (Ascii)
makh wrote:
Hi
also I get for:
9.2
jessie
Thankyou
I have ASCII (VB 5.1.30) and CERES (VB 5.2.0) installed in virtual box. All components work including shared folders.
How are you creating shared folders?
I hope that you set shared folders while VM guest is turned off?
What is your VM host?
#3 2017-11-03 13:06:35
makh
Hi
I actually cloned the jessie, then upgraded to ascii. Then installed the guest cd after the upgrade.
I dont see any issue except that the guest addons arent working...
My folder creation was same as for jessie, no difference.
My host OS is Arch.
Edit 1: I reinstalled the guest additions:
# sh VBoxLinuxAdditions.run
Verifying archive integrity... All good.
Uncompressing VirtualBox 5.1.30 Guest Additions for Linux...........
VirtualBox Guest Additions installer
Removing installed version 5.1.30 of VirtualBox Guest Additions...
vboxadd.sh: Stopping VirtualBox Additions.
Copying additional installer modules ...
Installing additional modules ...
vboxadd.sh: Starting the VirtualBox Guest Additions.
Failed to set up service vboxadd, please check the log file
/var/log/VBoxGuestAdditions.log for details.
# cat /var/log/VBoxGuestAdditions.log
vboxadd.sh: failed: modprobe vboxguest failed.
Edit: Installing the dkms and the kernel header solved the issue.
Thankyou
#4 2017-11-03 18:57:12
fog
makh wrote:
Hi
My host OS is Arch.
Thankyou
your screenshot indicates that you have installed VB from Oracle. You can also try Devuan's version of VB with all needed components. This way you may avoid problems related to the future upgrades.
#5 2017-11-04 02:24:18
makh
Hi @fog
cat /etc/apt/sources.list
## package repositories
# Compatible Debian 9:
deb http://auto.mirror.devuan.org/merged ascii main contrib non-free
deb http://auto.mirror.devuan.org/merged ascii-updates main contrib non-free
deb http://auto.mirror.devuan.org/merged ascii-security main contrib non-free
# Devuan repositories
deb http://packages.devuan.org/merged ascii main non-free contrib
#deb-src http://packages.devuan.org/merged ascii main non-free contrib
apt search virtualbox
shows no package for virtual box
also see:
http://devuanpackages.viralds.it/search … virtualbox
No ascii package.
Thankyou
#6 2017-11-04 03:05:19
Try ascii backports.  It is in Debian stretch backports so should be in ascii's.
#7 2017-11-04 05:03:50
fog
yes:
Sorting... Done
Full Text Search... Done
virtualbox/ascii-backports,now 5.1.30-dfsg-1~bpo9+1 amd64 [installed]
  x86 virtualization solution - base binaries
virtualbox-dkms/ascii-backports,now 5.1.30-dfsg-1~bpo9+1 all [installed,automatic]
  x86 virtualization solution - kernel module sources for dkms
virtualbox-guest-dkms/ascii-backports,now 5.1.30-dfsg-1~bpo9+1 all [installed]
  x86 virtualization solution - guest addition module source for dkms
virtualbox-guest-source/ascii-backports 5.1.30-dfsg-1~bpo9+1 all
virtualbox-guest-utils/ascii-backports,now 5.1.30-dfsg-1~bpo9+1 amd64 [installed,automatic]
  x86 virtualization solution - non-X11 guest utilities
virtualbox-guest-x11/ascii-backports,now 5.1.30-dfsg-1~bpo9+1 amd64 [installed]
  x86 virtualization solution - X11 guest utilities
virtualbox-qt/ascii-backports,now 5.1.30-dfsg-1~bpo9+1 amd64 [installed,automatic]
  x86 virtualization solution - Qt based user interface
virtualbox-source/ascii-backports 5.1.30-dfsg-1~bpo9+1 all
hope this will help
#8 2017-11-04 07:42:57
makh
Hello
But the version is not compatible to virtualbox 5.2. Any ways ...
Thankyou all for your kind help.
#9 2017-11-04 15:34:45
fog
makh wrote:
Hello
Well ASCII comes with the VB version that you installed (see above) that is 5.1.30.
If you want to try VB 5.2 then get it from Oracle. While VB depends on kernel in terms of compatibility, I would think that VB 5.2 is compatible with kernel 4.9 that comes with ASCII.
If 5.2 is not compatible with linux 4.9 either build your own kernel and problem solved
.. or upgrade ASCII to CERES:
Sorting... Done
boinc-virtualbox/unstable 7.8.3+dfsg-2 amd64
  metapackage for virtualbox-savvy projects
virtualbox/unstable,now 5.2.0-dfsg-2 amd64 [installed]
virtualbox-dkms/unstable,now 5.2.0-dfsg-2 all [installed,automatic]
virtualbox-ext-pack/unstable 5.2.0-2 all
  extra capabilities for VirtualBox, downloader.
virtualbox-guest-additions-iso/unstable 5.2.1-118452-1 all
  guest additions iso image for VirtualBox
virtualbox-guest-dkms/unstable,now 5.2.0-dfsg-2 all [installed]
virtualbox-guest-source/unstable 5.2.0-dfsg-2 all
virtualbox-guest-utils/unstable,now 5.2.0-dfsg-2 amd64 [installed,automatic]
virtualbox-guest-x11/unstable,now 5.2.0-dfsg-2 amd64 [installed]
virtualbox-qt/unstable,now 5.2.0-dfsg-2 amd64 [installed,automatic]
virtualbox-source/unstable 5.2.0-dfsg-2 all
I am running both ASCII and CERES in VM and both are really stable. I have installed latest custom 4.13.11 kernels in both ASCII and CERES though.
Another option would be to temporary enable CERES sources in ASCII to install Devuan's VB 5.2 again with possible kernel upgrade.
#10 2017-11-04 17:38:58
makh
Thanks
