#1 2017-10-27 13:15:25
keos
Problems with the multimedia player VLC [Solved]
Every time that i change to the full screen with the reproduction system VLC, the video stop or brake the image, and i have noted too that the quality of the sound is ok but not like in Linuxmint.
I will like to know if i’m missing something, if there are some tools that I have to download in order to improve … Thanks!.
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#2 2017-10-29 17:56:55
keos
Re: Problems with the multimedia player VLC [Solved]
Well, i was looking yestarday for another multimedia player and i downloaded gmlive and mplayer but i don’t like it … so today i went back to VLC ... and i found that it is working 90% much better, just some times videos stop --very strange indeed!!.
#3 2017-10-29 18:14:52
I never could get the VLC that comes with jessie to work properly so I installed the wheezy version - Twoflower - and it works just fine.  If you're on ascii who knows.
#4 2017-10-30 15:07:11
cynwulf
I've not heard of "gmlive" before, but I just checked and it's an mplayer front end.
Also it looks like mplayer installs a lot more video codec packages than vlc does, so it's likely that installing missing codecs fixed your problem.
Might not be relevant to Devuan, but: I also suggest backporting ffmpeg, rather than using the libav fork which was released with Debian jessie (future Debian releases went back to ffmpeg).
#5 2017-10-31 12:32:32
keos
Well it happened again ...  and i don't know what to do now because the only multimedia that i like is vlc.
Edit: It looks like sometimes works and sometimes it doesn't.
#6 2017-10-31 20:40:04
cynwulf
Well maybe some more info on the hardware involved?
#7 2017-11-01 13:12:01
keos
Toshiba Satellitte
L855D-S5117
#8 2017-11-01 16:04:55
cynwulf
A dmesg and/or listing of PCI devices might be more useful.  Using code tags to keep it readable is a good idea.
#9 2017-11-02 12:25:41
keos
root@kaos:/home/keos# dmesg
[    0.000000] Linux version 4.9.0-3-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-3-amd64 root=UUID=3ae77ee2-8b75-4b07-8c79-83b3fd79701e ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] x86/fpu: Using 'eager' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f3ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f400-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ba87efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ba87f000-0x00000000bb07ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bb080000-0x00000000bf9befff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf9bf000-0x00000000bfabefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bfabf000-0x00000000bfbbefff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bfbbf000-0x00000000bfbfefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000bfbff000-0x00000000bfbfffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bfc00000-0x00000000dfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffc00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: TOSHIBA Satellite L855D/Portable PC, BIOS 6.40 01/14/2013
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x11f000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-FFFFF write-through
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000000 mask FFFF80000000 write-back
[    0.000000]   1 base 000080000000 mask FFFFC0000000 write-back
[    0.000000]   2 base 0000BFBBD000 mask FFFFFFFFF000 uncachable
[    0.000000]   3 base 0000FFC00000 mask FFFFFFC00000 write-protect
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] TOM2: 000000011f000000 aka 4592M
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: last_pfn = 0xbfc00 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fe1b0-0x000fe1bf] mapped at [ffff9270800fe1b0]
[    0.000000] Base memory trampoline at [ffff927080099000] 99000 size 24576
[    0.000000] Using GB pages for direct mapping
[    0.000000] BRK [0x10a72e000, 0x10a72efff] PGTABLE
[    0.000000] BRK [0x10a72f000, 0x10a72ffff] PGTABLE
[    0.000000] BRK [0x10a730000, 0x10a730fff] PGTABLE
[    0.000000] BRK [0x10a731000, 0x10a731fff] PGTABLE
[    0.000000] BRK [0x10a732000, 0x10a732fff] PGTABLE
[    0.000000] BRK [0x10a733000, 0x10a733fff] PGTABLE
[    0.000000] BRK [0x10a734000, 0x10a734fff] PGTABLE
[    0.000000] BRK [0x10a735000, 0x10a735fff] PGTABLE
[    0.000000] BRK [0x10a736000, 0x10a736fff] PGTABLE
[    0.000000] BRK [0x10a737000, 0x10a737fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x35d10000-0x36e7ffff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000FE020 000024 (v02 TOSINV)
[    0.000000] ACPI: XSDT 0x00000000BFBFE120 00009C (v01 TOSINV TOSINV00 00000001      01000013)
[    0.000000] ACPI: FACP 0x00000000BFBFC000 00010C (v05 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: DSDT 0x00000000BFBED000 00A362 (v01 TOSINV TOSINV00 F0000000 ACPI 00040000)
[    0.000000] ACPI: FACS 0x00000000BFB7B000 000040
[    0.000000] ACPI: UEFI 0x00000000BFBFD000 000236 (v01 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: HPET 0x00000000BFBFB000 000038 (v01 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: APIC 0x00000000BFBFA000 000084 (v03 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: MCFG 0x00000000BFBF9000 00003C (v01 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: ASF! 0x00000000BFBF8000 0000A5 (v32 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: BOOT 0x00000000BFBEC000 000028 (v01 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: SLIC 0x00000000BFBEB000 000176 (v01 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: WDRT 0x00000000BFBEA000 000047 (v01 TOSINV TOSINV00 00000000 ACPI 00040000)
[    0.000000] ACPI: WDAT 0x00000000BFBE9000 0001AC (v01 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBE2000 0065DB (v01 TOSINV TsbOdm   00001000 ACPI 00040000)
[    0.000000] ACPI: FPDT 0x00000000BFBE0000 000044 (v01 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: MSDM 0x00000000BFBDF000 000055 (v03 TOSINV TOSINV00 00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBDE000 000B98 (v01 INSYDE IS CRB   00000001 ACPI 00040000)
[    0.000000] ACPI: SSDT 0x00000000BFBDC000 001ECC (v02 INSYDE IS CRB   00000001 ACPI 00040000)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000011effffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x11effb000-0x11effffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000011effffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000ba87efff]
[    0.000000]   node   0: [mem 0x00000000bb080000-0x00000000bf9befff]
[    0.000000]   node   0: [mem 0x00000000bfbff000-0x00000000bfbfffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000011effffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000011effffff]
[    0.000000] On node 0 totalpages: 909661
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 12167 pages used for memmap
[    0.000000]   DMA32 zone: 778687 pages, LIFO batch:31
[    0.000000]   Normal zone: 1984 pages used for memmap
[    0.000000]   Normal zone: 126976 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 4, version 33, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x10228210 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0xba87f000-0xbb07ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xbf9bf000-0xbfabefff]
[    0.000000] PM: Registered nosave memory: [mem 0xbfabf000-0xbfbbefff]
[    0.000000] PM: Registered nosave memory: [mem 0xbfbbf000-0xbfbfefff]
[    0.000000] PM: Registered nosave memory: [mem 0xbfc00000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec11000-0xfed7ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed81000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffbfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xffc00000-0xffffffff]
[    0.000000] e820: [mem 0xe0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] percpu: Embedded 35 pages/cpu @ffff92719ec00000 s103512 r8192 d31656 u524288
[    0.000000] pcpu-alloc: s103512 r8192 d31656 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 895425
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-3-amd64 root=UUID=3ae77ee2-8b75-4b07-8c79-83b3fd79701e ro quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 3481172K/3638644K available (6187K kernel code, 1137K rwdata, 2856K rodata, 1392K init, 688K bss, 157472K reserved, 0K cma-reserved)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:33024 nr_irqs:456 16
[    0.000000] spurious 8259A interrupt: IRQ7.
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 1896.427 MHz processor
[    0.000027] Calibrating delay loop (skipped), value calculated using timer frequency.. 3792.85 BogoMIPS (lpj=7585708)
[    0.000030] pid_max: default: 32768 minimum: 301
[    0.000053] ACPI: Core revision 20160831
[    0.000055] TOSHIBA Satellite detected - force copy of DSDT to local memory
[    0.000151] ACPI: Forced DSDT copy: length 0x0A362 copied locally, original unmapped
[    0.013443] ACPI: 4 ACPI AML tables successfully acquired and loaded
[    0.013515] Security Framework initialized
[    0.013517] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.013524] AppArmor: AppArmor disabled by boot time parameter
[    0.013890] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.015285] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.015926] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.015935] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.016305] [Firmware Info]: CPU: Re-enabling disabled Topology Extensions Support.
[    0.016312] CPU: Physical Processor ID: 0
[    0.016312] CPU: Processor Core ID: 0
[    0.016314] mce: CPU supports 7 MCE banks
[    0.016330] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[    0.016331] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[    0.016679] Freeing SMP alternatives memory: 24K (ffffffff9667a000 - ffffffff96680000)
[    0.019126] ftrace: allocating 25178 entries in 99 pages
[    0.030783] smpboot: Max logical packages: 1
[    0.031153] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.178206] smpboot: CPU0: AMD A8-4500M APU with Radeon(tm) HD Graphics (family: 0x15, model: 0x10, stepping: 0x1)
[    0.178211] Performance Events: Fam15h core perfctr, AMD PMU driver.
[    0.178218] ... version:                0
[    0.178218] ... bit width:              48
[    0.178219] ... generic registers:      6
[    0.178220] ... value mask:             0000ffffffffffff
[    0.178221] ... max period:             00007fffffffffff
[    0.178221] ... fixed-purpose events:   0
[    0.178222] ... event mask:             000000000000003f
[    0.178959] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.179136] x86: Booting SMP configuration:
[    0.179138] .... node  #0, CPUs:      #1 #2 #3
[    0.420482] x86: Booted up 1 node, 4 CPUs
[    0.420484] smpboot: Total of 4 processors activated (15171.26 BogoMIPS)
[    0.422177] devtmpfs: initialized
[    0.422285] x86/mm: Memory block size: 128MB
[    0.426650] PM: Registering ACPI NVS region [mem 0xbfabf000-0xbfbbefff] (1048576 bytes)
[    0.426765] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.426780] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.426854] pinctrl core: initialized pinctrl subsystem
[    0.427025] NET: Registered protocol family 16
[    0.438315] cpuidle: using governor ladder
[    0.454314] cpuidle: using governor menu
[    0.454539] Simple Boot Flag at 0x44 set to 0x1
[    0.454581] ACPI: bus type PCI registered
[    0.454585] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.454955] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.454960] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.454979] PCI: Using configuration type 1 for base access
[    0.455957] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.455959] mtrr: probably your BIOS does not setup all CPUs.
[    0.455960] mtrr: corrected configuration.
[    0.475025] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[    0.475028] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.476063] ACPI: Added _OSI(Module Device)
[    0.476066] ACPI: Added _OSI(Processor Device)
[    0.476068] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.476071] ACPI: Added _OSI(Processor Aggregator Device)
[    0.476527] ACPI: Executed 1 blocks of module-level executable AML code
[    0.494269] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.506829] ACPI: Interpreter enabled
[    0.506852] ACPI: (supports S0 S3 S4 S5)
[    0.506853] ACPI: Using IOAPIC for interrupt routing
[    0.507074] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.524742] ACPI: Power Resource [PFA1] (off)
[    0.525151] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.525157] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.525162] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.525179] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.525279] acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000cf9ff])
[    0.525547] PCI host bridge to bus 0000:00
[    0.525550] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.525551] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.525553] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.525555] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.525557] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.525558] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.525560] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.525561] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.525563] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.525564] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.525566] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.525567] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.525569] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.525570] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.525572] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
[    0.525574] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
[    0.525575] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
[    0.525577] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.525586] pci 0000:00:00.0: [1022:1410] type 00 class 0x060000
[    0.525728] pci 0000:00:01.0: [1002:9903] type 00 class 0x030000
[    0.525737] pci 0000:00:01.0: reg 0x10: [mem 0xe0000000-0xefffffff pref]
[    0.525743] pci 0000:00:01.0: reg 0x14: [io  0x4000-0x40ff]
[    0.525748] pci 0000:00:01.0: reg 0x18: [mem 0xf0200000-0xf023ffff]
[    0.525788] pci 0000:00:01.0: supports D1 D2
[    0.525890] pci 0000:00:01.1: [1002:9902] type 00 class 0x040300
[    0.525899] pci 0000:00:01.1: reg 0x10: [mem 0xf0244000-0xf0247fff]
[    0.525946] pci 0000:00:01.1: supports D1 D2
[    0.526089] pci 0000:00:04.0: [1022:1414] type 01 class 0x060400
[    0.526134] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[    0.527196] pci 0000:00:04.0: System wakeup disabled by ACPI
[    0.527253] pci 0000:00:05.0: [1022:1415] type 01 class 0x060400
[    0.527298] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
[    0.527445] pci 0000:00:10.0: [1022:7812] type 00 class 0x0c0330
[    0.527467] pci 0000:00:10.0: reg 0x10: [mem 0xf0248000-0xf0249fff 64bit]
[    0.527564] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[    0.528972] pci 0000:00:10.0: System wakeup disabled by ACPI
[    0.529041] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[    0.529057] pci 0000:00:11.0: reg 0x10: [io  0x4118-0x411f]
[    0.529066] pci 0000:00:11.0: reg 0x14: [io  0x4124-0x4127]
[    0.529074] pci 0000:00:11.0: reg 0x18: [io  0x4110-0x4117]
[    0.529083] pci 0000:00:11.0: reg 0x1c: [io  0x4120-0x4123]
[    0.529091] pci 0000:00:11.0: reg 0x20: [io  0x4100-0x410f]
[    0.529100] pci 0000:00:11.0: reg 0x24: [mem 0xf0250000-0xf02507ff]
[    0.529253] pci 0000:00:12.0: [1022:7807] type 00 class 0x0c0310
[    0.529266] pci 0000:00:12.0: reg 0x10: [mem 0xf024f000-0xf024ffff]
[    0.530795] pci 0000:00:12.0: System wakeup disabled by ACPI
[    0.530858] pci 0000:00:12.2: [1022:7808] type 00 class 0x0c0320
[    0.531315] pci 0000:00:12.2: reg 0x10: [mem 0xf024e000-0xf024e0ff]
[    0.534049] pci 0000:00:12.2: supports D1 D2
[    0.534051] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[    0.535372] pci 0000:00:12.2: System wakeup disabled by ACPI
[    0.535436] pci 0000:00:13.0: [1022:7807] type 00 class 0x0c0310
[    0.535448] pci 0000:00:13.0: reg 0x10: [mem 0xf024d000-0xf024dfff]
[    0.535615] pci 0000:00:13.2: [1022:7808] type 00 class 0x0c0320
[    0.536136] pci 0000:00:13.2: reg 0x10: [mem 0xf024c000-0xf024c0ff]
[    0.538870] pci 0000:00:13.2: supports D1 D2
[    0.538871] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[    0.538987] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[    0.539164] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[    0.539183] pci 0000:00:14.2: reg 0x10: [mem 0xf0240000-0xf0243fff 64bit]
[    0.539244] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[    0.539363] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[    0.539524] pci 0000:00:14.4: [1022:780f] type 01 class 0x060400
[    0.539613] pci 0000:00:14.4: System wakeup disabled by ACPI
[    0.539681] pci 0000:00:14.5: [1022:7809] type 00 class 0x0c0310
[    0.539693] pci 0000:00:14.5: reg 0x10: [mem 0xf024b000-0xf024bfff]
[    0.539857] pci 0000:00:14.7: [1022:7806] type 00 class 0x080501
[    0.539873] pci 0000:00:14.7: reg 0x10: [mem 0xf024a000-0xf024a0ff 64bit]
[    0.540022] pci 0000:00:18.0: [1022:1400] type 00 class 0x060000
[    0.540128] pci 0000:00:18.1: [1022:1401] type 00 class 0x060000
[    0.540231] pci 0000:00:18.2: [1022:1402] type 00 class 0x060000
[    0.540347] pci 0000:00:18.3: [1022:1403] type 00 class 0x060000
[    0.540458] pci 0000:00:18.4: [1022:1404] type 00 class 0x060000
[    0.540562] pci 0000:00:18.5: [1022:1405] type 00 class 0x060000
[    0.540782] pci 0000:01:00.0: [1969:1090] type 00 class 0x020000
[    0.540803] pci 0000:01:00.0: reg 0x10: [mem 0xf0100000-0xf013ffff 64bit]
[    0.540813] pci 0000:01:00.0: reg 0x18: [io  0x3000-0x307f]
[    0.540903] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.552454] pci 0000:00:04.0: PCI bridge to [bus 01]
[    0.552460] pci 0000:00:04.0:   bridge window [io  0x3000-0x3fff]
[    0.552464] pci 0000:00:04.0:   bridge window [mem 0xf0100000-0xf01fffff]
[    0.552580] pci 0000:02:00.0: [10ec:8176] type 00 class 0x028000
[    0.552600] pci 0000:02:00.0: reg 0x10: [io  0x2000-0x20ff]
[    0.552626] pci 0000:02:00.0: reg 0x18: [mem 0xf0000000-0xf0003fff 64bit]
[    0.552729] pci 0000:02:00.0: supports D1 D2
[    0.552731] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.564453] pci 0000:00:05.0: PCI bridge to [bus 02]
[    0.564459] pci 0000:00:05.0:   bridge window [io  0x2000-0x2fff]
[    0.564463] pci 0000:00:05.0:   bridge window [mem 0xf0000000-0xf00fffff]
[    0.564590] pci 0000:00:14.4: PCI bridge to [bus 03]
[    0.565765] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.565847] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.565930] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.566013] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.566082] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.566137] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.566191] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.566248] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.566445] ACPI: Enabled 1 GPEs in block 00 to 1F
[    0.566682] vgaarb: setting as boot device: PCI:0000:00:01.0
[    0.566683] vgaarb: device added: PCI:0000:00:01.0,decodes=io+mem,owns=io+mem,locks=none
[    0.566691] vgaarb: loaded
[    0.566692] vgaarb: bridge control possible 0000:00:01.0
[    0.566820] PCI: Using ACPI for IRQ routing
[    0.568642] PCI: pci_cache_line_size set to 64 bytes
[    0.568706] e820: reserve RAM buffer [mem 0x0009f400-0x0009ffff]
[    0.568708] e820: reserve RAM buffer [mem 0xba87f000-0xbbffffff]
[    0.568709] e820: reserve RAM buffer [mem 0xbf9bf000-0xbfffffff]
[    0.568711] e820: reserve RAM buffer [mem 0xbfc00000-0xbfffffff]
[    0.568712] e820: reserve RAM buffer [mem 0x11f000000-0x11fffffff]
[    0.568998] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.569002] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.571137] clocksource: Switched to clocksource hpet
[    0.581907] VFS: Disk quotas dquot_6.6.0
[    0.581950] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.582096] pnp: PnP ACPI init
[    0.582322] system 00:00: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.582324] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.582328] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.582634] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.582678] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.582715] pnp 00:03: Plug and Play ACPI device, IDs TOS0310 SYN1900 SYN0002 PNP0f13 (active)
[    0.582788] system 00:04: [io  0x0400-0x04cf] has been reserved
[    0.582790] system 00:04: [io  0x04d0-0x04d1] has been reserved
[    0.582792] system 00:04: [io  0x04d6] has been reserved
[    0.582794] system 00:04: [io  0x0680-0x06ff] has been reserved
[    0.582796] system 00:04: [io  0x077a] has been reserved
[    0.582798] system 00:04: [io  0x0c00-0x0c01] has been reserved
[    0.582799] system 00:04: [io  0x0c14] has been reserved
[    0.582801] system 00:04: [io  0x0c50-0x0c52] has been reserved
[    0.582803] system 00:04: [io  0x0c6c] has been reserved
[    0.582805] system 00:04: [io  0x0c6f] has been reserved
[    0.582807] system 00:04: [io  0x0cd0-0x0cdb] has been reserved
[    0.582808] system 00:04: [io  0x0840-0x0847] has been reserved
[    0.582811] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.582916] system 00:05: [mem 0xff800000-0xff80ffff] has been reserved
[    0.582919] system 00:05: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.582921] system 00:05: [mem 0xffc00000-0xffffffff] has been reserved
[    0.582923] system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.583479] pnp: PnP ACPI: found 6 devices
[    0.591577] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.591600] pci 0000:00:04.0: PCI bridge to [bus 01]
[    0.591603] pci 0000:00:04.0:   bridge window [io  0x3000-0x3fff]
[    0.591607] pci 0000:00:04.0:   bridge window [mem 0xf0100000-0xf01fffff]
[    0.591612] pci 0000:00:05.0: PCI bridge to [bus 02]
[    0.591614] pci 0000:00:05.0:   bridge window [io  0x2000-0x2fff]
[    0.591617] pci 0000:00:05.0:   bridge window [mem 0xf0000000-0xf00fffff]
[    0.591622] pci 0000:00:14.4: PCI bridge to [bus 03]
[    0.591635] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.591637] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.591639] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.591641] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.591643] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.591644] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.591646] pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
[    0.591647] pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
[    0.591649] pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
[    0.591651] pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
[    0.591652] pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
[    0.591654] pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
[    0.591655] pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
[    0.591657] pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
[    0.591658] pci_bus 0000:00: resource 18 [mem 0xe0000000-0xf7ffffff window]
[    0.591660] pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfed3ffff window]
[    0.591661] pci_bus 0000:00: resource 20 [mem 0xfed45000-0xffffffff window]
[    0.591663] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.591665] pci_bus 0000:01: resource 1 [mem 0xf0100000-0xf01fffff]
[    0.591667] pci_bus 0000:02: resource 0 [io  0x2000-0x2fff]
[    0.591668] pci_bus 0000:02: resource 1 [mem 0xf0000000-0xf00fffff]
[    0.591914] NET: Registered protocol family 2
[    0.592174] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.592291] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.592448] TCP: Hash tables configured (established 32768 bind 32768)
[    0.592489] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.592513] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.592668] NET: Registered protocol family 1
[    0.592687] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.883475] pci 0000:01:00.0: set MSI_INTX_DISABLE_BUG flag
[    0.883483] PCI: CLS 64 bytes, default 64
[    0.883550] Unpacking initramfs...
[    1.301476] Freeing initrd memory: 17856K (ffff9270b5d10000 - ffff9270b6e80000)
[    1.301480] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.301483] software IO TLB [mem 0xbb9bf000-0xbf9bf000] (64MB) mapped at [ffff92713b9bf000-ffff92713f9befff]
[    1.301543] perf: AMD NB counters detected
[    1.301873] LVT offset 0 assigned for vector 0x400
[    1.301939] perf: AMD IBS detected (0x000000ff)
[    1.302540] audit: initializing netlink subsys (disabled)
[    1.302567] audit: type=2000 audit(1509610768.192:1): initialized
[    1.303368] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[    1.303452] zbud: loaded
[    1.304856] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.304931] io scheduler noop registered
[    1.304932] io scheduler deadline registered
[    1.304953] io scheduler cfq registered (default)
[    1.305349] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.305356] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.306346] GHES: HEST is not enabled!
[    1.306632] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.308237] Linux agpgart interface v0.103
[    1.308956] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.308957] AMD IOMMUv2 functionality not available on this system
[    1.310201] i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    1.313012] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.313025] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.313549] mousedev: PS/2 mouse device common for all mice
[    1.313705] rtc_cmos 00:01: RTC can wake from S4
[    1.313965] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.314006] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[    1.314268] ledtrig-cpu: registered to indicate activity on CPUs
[    1.315223] NET: Registered protocol family 10
[    1.315931] mip6: Mobile IPv6
[    1.315934] NET: Registered protocol family 17
[    1.315940] mpls_gso: MPLS GSO support
[    1.317005] microcode: CPU0: patch_level=0x06001116
[    1.317020] microcode: CPU1: patch_level=0x06001116
[    1.317044] microcode: CPU2: patch_level=0x06001116
[    1.317067] microcode: CPU3: patch_level=0x06001116
[    1.317195] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.317675] registered taskstats version 1
[    1.317717] zswap: loaded using pool lzo/zbud
[    1.318062] ima: No TPM chip found, activating TPM-bypass!
[    1.318866] rtc_cmos 00:01: setting system clock to 2017-11-02 08:19:28 UTC (1509610768)
[    1.319095] PM: Hibernation image not present or could not be loaded.
[    1.323541] Freeing unused kernel memory: 1392K (ffffffff9651e000 - ffffffff9667a000)
[    1.323544] Write protecting the kernel read-only data: 12288k
[    1.325627] Freeing unused kernel memory: 1988K (ffff927189e0f000 - ffff92718a000000)
[    1.330433] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.335074] Freeing unused kernel memory: 1240K (ffff92718a2ca000 - ffff92718a400000)
[    1.357230] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.413386] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.413646] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.413677] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.416929] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.417032] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.420831] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.421069] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.421121] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.422746] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.422966] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.536805] thermal LNXTHERM:00: registered as thermal_zone0
[    1.536810] ACPI: Thermal Zone [THZN] (55 C)
[    1.546324] ACPI: bus type USB registered
[    1.546430] usbcore: registered new interface driver usbfs
[    1.546481] usbcore: registered new interface driver hub
[    1.546591] usbcore: registered new device driver usb
[    1.548475] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.549599] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.549806] QUIRK: Enable AMD PLL fix
[    1.549830] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    1.549841] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
[    1.550055] xhci_hcd 0000:00:10.0: hcc params 0x014042c3 hci version 0x96 quirks 0x00000608
[    1.550085] ehci-pci: EHCI PCI platform driver
[    1.550594] SCSI subsystem initialized
[    1.551648] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.551652] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.551654] usb usb1: Product: xHCI Host Controller
[    1.551655] usb usb1: Manufacturer: Linux 4.9.0-3-amd64 xhci-hcd
[    1.551657] usb usb1: SerialNumber: 0000:00:10.0
[    1.551908] hub 1-0:1.0: USB hub found
[    1.551920] hub 1-0:1.0: 2 ports detected
[    1.552119] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    1.552127] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[    1.553468] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.553512] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.553516] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.553518] usb usb2: Product: xHCI Host Controller
[    1.553522] usb usb2: Manufacturer: Linux 4.9.0-3-amd64 xhci-hcd
[    1.553524] usb usb2: SerialNumber: 0000:00:10.0
[    1.553657] alx 0000:01:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [00:8c:fa:3f:01:bf]
[    1.553747] hub 2-0:1.0: USB hub found
[    1.553760] hub 2-0:1.0: 2 ports detected
[    1.554243] ehci-pci 0000:00:12.2: EHCI Host Controller
[    1.554252] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 3
[    1.554258] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    1.554268] ehci-pci 0000:00:12.2: debug port 1
[    1.554331] ehci-pci 0000:00:12.2: irq 17, io mem 0xf024e000
[    1.557520] libata version 3.00 loaded.
[    1.558570] sdhci: Secure Digital Host Controller Interface driver
[    1.558571] sdhci: Copyright(c) Pierre Ossman
[    1.562354] AVX version of gcm_enc/dec engaged.
[    1.562355] AES CTR mode by8 optimization enabled
[    1.567178] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[    1.567295] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.567298] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.567300] usb usb3: Product: EHCI Host Controller
[    1.567302] usb usb3: Manufacturer: Linux 4.9.0-3-amd64 ehci_hcd
[    1.567304] usb usb3: SerialNumber: 0000:00:12.2
[    1.567518] hub 3-0:1.0: USB hub found
[    1.567531] hub 3-0:1.0: 5 ports detected
[    1.568052] ehci-pci 0000:00:13.2: EHCI Host Controller
[    1.568061] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 4
[    1.568066] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    1.568076] ehci-pci 0000:00:13.2: debug port 1
[    1.568114] ehci-pci 0000:00:13.2: irq 17, io mem 0xf024c000
[    1.583193] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[    1.583472] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    1.583474] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.583475] usb usb4: Product: EHCI Host Controller
[    1.583477] usb usb4: Manufacturer: Linux 4.9.0-3-amd64 ehci_hcd
[    1.583478] usb usb4: SerialNumber: 0000:00:13.2
[    1.583715] hub 4-0:1.0: USB hub found
[    1.583753] hub 4-0:1.0: 5 ports detected
[    1.584170] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B07 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\_SB.PCI0.SMBS.SMB0) (20160831/utaddress-247)
[    1.584176] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    1.584212] ahci 0000:00:11.0: version 3.0
[    1.584586] ohci-pci: OHCI PCI platform driver
[    1.584599] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    1.584602] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[    1.585887] scsi host0: ahci
[    1.586066] scsi host1: ahci
[    1.586151] ata1: SATA max UDMA/133 abar m2048@0xf0250000 port 0xf0250100 irq 29
[    1.586154] ata2: SATA max UDMA/133 abar m2048@0xf0250000 port 0xf0250180 irq 29
[    1.586189] sdhci-pci 0000:00:14.7: SDHCI controller found [1022:7806] (rev 0)
[    1.587568] mmc0: SDHCI controller on PCI [0000:00:14.7] using ADMA
[    1.587757] ohci-pci 0000:00:12.0: OHCI PCI host controller
[    1.587765] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 5
[    1.587795] ohci-pci 0000:00:12.0: irq 18, io mem 0xf024f000
[    1.651365] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    1.651368] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.651370] usb usb5: Product: OHCI PCI host controller
[    1.651371] usb usb5: Manufacturer: Linux 4.9.0-3-amd64 ohci_hcd
[    1.651373] usb usb5: SerialNumber: 0000:00:12.0
[    1.651715] hub 5-0:1.0: USB hub found
[    1.651725] hub 5-0:1.0: 5 ports detected
[    1.652162] ohci-pci 0000:00:13.0: OHCI PCI host controller
[    1.652168] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 6
[    1.652200] ohci-pci 0000:00:13.0: irq 18, io mem 0xf024d000
[    1.715365] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    1.715368] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.715370] usb usb6: Product: OHCI PCI host controller
[    1.715371] usb usb6: Manufacturer: Linux 4.9.0-3-amd64 ohci_hcd
[    1.715373] usb usb6: SerialNumber: 0000:00:13.0
[    1.715722] hub 6-0:1.0: USB hub found
[    1.715732] hub 6-0:1.0: 5 ports detected
[    1.716173] ohci-pci 0000:00:14.5: OHCI PCI host controller
[    1.716181] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 7
[    1.716215] ohci-pci 0000:00:14.5: irq 18, io mem 0xf024b000
[    1.779367] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    1.779371] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.779372] usb usb7: Product: OHCI PCI host controller
[    1.779374] usb usb7: Manufacturer: Linux 4.9.0-3-amd64 ohci_hcd
[    1.779375] usb usb7: SerialNumber: 0000:00:14.5
[    1.779665] hub 7-0:1.0: USB hub found
[    1.779691] hub 7-0:1.0: 2 ports detected
[    1.879314] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[    1.895312] usb 3-5: new high-speed USB device number 2 using ehci-pci
[    1.911315] usb 4-4: new high-speed USB device number 2 using ehci-pci
[    2.044560] usb 3-5: New USB device found, idVendor=0bda, idProduct=0129
[    2.044563] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.044564] usb 3-5: Product: USB2.0-CRW
[    2.044565] usb 3-5: Manufacturer: Generic
[    2.044567] usb 3-5: SerialNumber: 20100201396000000
[    2.050811] usbcore: registered new interface driver rtsx_usb
[    2.052679] usb 1-2: New USB device found, idVendor=062a, idProduct=4102
[    2.052682] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.052685] usb 1-2: Product: 2.4G Wireless Mouse
[    2.052686] usb 1-2: Manufacturer: MOSART Semi.
[    2.056018] hidraw: raw HID events driver (C) Jiri Kosina
[    2.063282] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.063304] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.067314] ata2.00: ATAPI: TSSTcorp CDDVDW SN-208AB, TO04, max UDMA/100
[    2.075821] usbcore: registered new interface driver usbhid
[    2.075823] usbhid: USB HID core driver
[    2.076849] input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:10.0/usb1/1-2/1-2:1.0/0003:062A:4102.0001/input/input3
[    2.077045] hid-generic 0003:062A:4102.0001: input,hiddev0,hidraw0: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-0000:00:10.0-2/input0
[    2.077089] ata2.00: configured for UDMA/100
[    2.094555] ata1.00: ATA-8: TOSHIBA MQ01ABD064, AX0A3M, max UDMA/100
[    2.094558] ata1.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.096635] ata1.00: configured for UDMA/100
[    2.097007] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD0 3M   PQ: 0 ANSI: 5
[    2.136741] usb 4-4: New USB device found, idVendor=10f1, idProduct=1a43
[    2.136744] usb 4-4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    2.136746] usb 4-4: Product: TOSHIBA Web Camera - HD
[    2.136747] usb 4-4: Manufacturer: Importek
[    2.138068] scsi 1:0:0:0: CD-ROM            TSSTcorp CDDVDW SN-208AB  TO04 PQ: 0 ANSI: 5
[    2.156148] sd 0:0:0:0: [sda] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[    2.156285] sd 0:0:0:0: [sda] Write Protect is off
[    2.156287] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.156334] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.179393] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.179396] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.179710] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.199924] random: fast init done
[    2.241221] psmouse serio1: synaptics: queried max coordinates: x [..5634], y [..4598]
[    2.294848] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xd00073/0x240000/0xa0400/0x0, board id: 1680, fw id: 706145
[    2.294854] psmouse serio1: synaptics: Toshiba Satellite L855D detected, limiting rate to 40pps.
[    2.304663]  sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 >
[    2.305944] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.315313] tsc: Refined TSC clocksource calibration: 1896.455 MHz
[    2.315322] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x36ac2de5286, max_idle_ns: 881590444602 ns
[    2.329338] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input2
[    3.335530] clocksource: Switched to clocksource tsc
[    3.449413] PM: Starting manual resume from disk
[    3.449422] PM: Hibernation image partition 8:2 present
[    3.449424] PM: Looking for hibernation image.
[    3.449837] PM: Image not found (code -22)
[    3.449839] PM: Hibernation image not present or could not be loaded.
[    3.824838] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[    5.246751] random: crng init done
[    6.660717] acpi_cpufreq: overriding BIOS provided _PSD data
[    6.710336] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
[    6.710341] ACPI: Power Button [PWRB]
[    6.710936] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input5
[    6.710941] ACPI: Lid Switch [LID0]
[    6.711008] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[    6.711010] ACPI: Power Button [PWRF]
[    6.783752] [drm] Initialized
[    6.904957] wmi: Mapper loaded
[    7.034030] ACPI: Battery Slot [BAT0] (battery present)
[    7.034735] ACPI: Video Device [VGA] (multi-head: yes  rom: no  post: no)
[    7.036914] acpi device:00: registered as cooling_device5
[    7.037030] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
[    7.064260] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
[    7.064435] sp5100_tco: PCI Vendor ID: 0x1022, Device ID: 0x780b, Revision ID: 0x14
[    7.064542] sp5100_tco: Using 0xfed80b00 for watchdog MMIO address
[    7.064555] sp5100_tco: Last reboot was not triggered by watchdog.
[    7.064692] sp5100_tco: initialized (0xffffa5ba406c9b00). heartbeat=60 sec (nowayout=0)
[    7.108236] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    7.324582] ACPI: AC Adapter [ADP0] (on-line)
[    7.366397] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    7.366589] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    7.413564] input: PC Speaker as /devices/platform/pcspkr/input/input8
[    7.767409] kvm: Nested Virtualization enabled
[    7.767413] kvm: Nested Paging enabled
[    7.890449] [drm] radeon kernel modesetting enabled.
[    8.194334] EDAC MC: Ver: 3.0.0
[    8.242484] CRAT table not found
[    8.242487] Finished initializing topology ret=0
[    8.242507] kfd kfd: Initialized module
[    8.251429] [drm:radeon_pci_probe [radeon]] *ERROR* radeon kernel modesetting for R600 or later requires firmware-amd-graphics.
[    8.346724] MCE: In-kernel MCE decoding enabled.
[    8.655872] EDAC amd64: DRAM ECC disabled.
[    8.655883] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
                Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
                (Note that use of the override may cause unknown side effects.)
[    8.704233] EDAC amd64: DRAM ECC disabled.
[    8.704245] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    8.748100] EDAC amd64: DRAM ECC disabled.
[    8.748112] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    8.792539] EDAC amd64: DRAM ECC disabled.
[    8.792549] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    9.031232] rtl8192ce: Using firmware rtlwifi/rtl8192cfwU_B.bin
[    9.056479] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[    9.056943] rtlwifi: rtlwifi: wireless switch is on
[    9.151060] rtl8192ce 0000:02:00.0: firmware: direct-loading firmware rtlwifi/rtl8192cfwU_B.bin
[    9.284706] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[    9.328192] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input9
[    9.455456] media: Linux media interface: v0.10
[    9.513602] Linux video capture interface: v2.00
[    9.615208] uvcvideo: Found UVC 1.00 device TOSHIBA Web Camera - HD (10f1:1a43)
[    9.633182] uvcvideo 4-4:1.0: Entity type for entity Extension 3 was not initialized!
[    9.633187] uvcvideo 4-4:1.0: Entity type for entity Processing 2 was not initialized!
[    9.633191] uvcvideo 4-4:1.0: Entity type for entity Camera 1 was not initialized!
[    9.633364] input: TOSHIBA Web Camera - HD as /devices/pci0000:00/0000:00:13.2/usb4/4-4/4-4:1.0/input/input10
[    9.633494] usbcore: registered new interface driver uvcvideo
[    9.633495] USB Video Class driver (1.1.1)
[    9.819995] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC269VB: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    9.820006] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    9.820009] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    9.820011] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    9.820013] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    9.820016] snd_hda_codec_realtek hdaudioC1D0:      Mic=0x18
[    9.820019] snd_hda_codec_realtek hdaudioC1D0:      Internal Mic=0x12
[    9.829725] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/sound/card1/input11
[    9.830375] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input12
[    9.830552] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input13
[   12.951857] Adding 1126396k swap on /dev/sda2.  Priority:-1 extents:1 across:1126396k FS
[   13.032219] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[   13.625150] lp: driver loaded but no devices found
[   13.683679] ppdev: user-space parallel port driver
[   14.999144] RPC: Registered named UNIX socket transport module.
[   14.999146] RPC: Registered udp transport module.
[   14.999146] RPC: Registered tcp transport module.
[   14.999147] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   15.043130] FS-Cache: Loaded
[   15.089585] FS-Cache: Netfs 'nfs' registered for caching
[   15.209165] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   21.933074] Bluetooth: Core ver 2.22
[   21.933110] NET: Registered protocol family 31
[   21.933113] Bluetooth: HCI device and connection manager initialized
[   21.933121] Bluetooth: HCI socket layer initialized
[   21.933130] Bluetooth: L2CAP socket layer initialized
[   21.933155] Bluetooth: SCO socket layer initialized
[   22.582293] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   22.582295] Bluetooth: BNEP filters: protocol multicast
[   22.582301] Bluetooth: BNEP socket layer initialized
[   26.315657] NET: Registered protocol family 4
[   26.380093] NET: Registered protocol family 3
[   26.383799] NET: Registered protocol family 5
[   27.013509] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   32.158234] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   36.937617] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   37.098302] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   37.997253] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   42.064686] wlan0: authenticate with f8:2c:18:8a:a9:d3
[   42.097145] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[   42.105682] wlan0: authenticated
[   42.107926] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[   42.112552] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=2)
[   42.113155] wlan0: associated
[   42.113171] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
#10 2017-11-02 12:41:27
cynwulf
You need to install the radeon device firmware from the non-free repository (already enabled in your sources by the looks of it, as realtek device firmware is being loaded).
#11 2017-11-02 13:16:16
keos
i'm not sure if i understand this -- it's saying that there is not a candidate for the instalation ...
root@kaos:/home/keos# apt-get install firmware-amd-graphics
Leyendo lista de paquetes... Hecho
Creando árbol de dependencias
Leyendo la información de estado... Hecho
El paquete firmware-amd-graphics no está disponible, pero algún otro paquete hace referencia
a él. Esto puede significar que el paquete falta, está obsoleto o sólo se
encuentra disponible desde alguna otra fuente
E: El paquete «firmware-amd-graphics» no tiene un candidato para la instalación
#12 2017-11-02 13:26:13
keos
/etc/apt/sources.list
deb http://auto.mirror.devuan.org/merged/ ascii main
deb http://auto.mirror.devuan.org/merged/ ascii-updates main
deb http://auto.mirror.devuan.org/merged/ ascii-security main
deb http://kovacsoltvideo.hu/moonchildproductions/ ./
#13 2017-11-02 14:49:38
keos
I added the contrib non-free to the sources list ...
It looks like i did well ...
root@kaos:/home/keos# apt-get update
Obj:1 http://auto.mirror.devuan.org/merged ascii InRelease
Obj:2 http://auto.mirror.devuan.org/merged ascii-updates InRelease
Ign:4 http://kovacsoltvideo.hu/moonchildproductions ./ InRelease
Obj:5 http://kovacsoltvideo.hu/moonchildproductions ./ Release
Obj:3 http://amprolla.devuan.org/merged ascii-security InRelease
root@kaos:/home/keos# apt-cache search nonefree
root@kaos:/home/keos# apt-cache search non-free
libspin-java - transparent threading solution for non-freezing Swing applications
libspin-java-doc - transparent threading solution for non-freezing Swing applications (docs)
nvidia-xconfig - deprecated X configuration tool for non-free NVIDIA drivers
context-nonfree - Non-free items from the ConTeXt distribution
dahdi-firmware-nonfree - DAHDI non-free firmware
fonts-moe-standard-kai - Chinese TrueType font, standard Kaiti (non-free)
fonts-moe-standard-song - Chinese TrueType font, standard Song (non-free)
p7zip-rar - non-free rar module for p7zip
scribus-doc - non-free documentation for Scribus
sweethome3d-furniture-nonfree - Interior 2D design application with 3D preview (additional non-free furniture)
texinfo-doc-nonfree - texinfo and info documentation that is non-free
unace-nonfree - extract, test and view .ace archives (non-free version)
unrar - Unarchiver for .rar files (non-free version)
t1-xfree86-nonfree - non-free Postscript Type 1 fonts from XFree86
ttf-xfree86-nonfree - non-free TrueType fonts from XFree86
ttf-xfree86-nonfree-syriac - non-free syriac OpenType fonts from XFree86
root@kaos:/home/keos# root@kaos:/home/keos# apt-get install firmware-amd-graphics
Se instalarán los siguientes paquetes NUEVOS:
0 actualizados, 1 nuevos se instalarán, 0 para eliminar y 1 no actualizados.
Se necesita descargar 1,566 kB de archivos.
Se utilizarán 15.3 MB de espacio de disco adicional después de esta operación.
Des:1 http://auto.mirror.devuan.org/merged ascii/non-free amd64 firmware-amd-graphics all 20161130-3 [1,566 kB]
Descargados 1,566 kB en 25s (62.6 kB/s)
Seleccionando el paquete firmware-amd-graphics previamente no seleccionado.
(Leyendo la base de datos ... 141847 ficheros o directorios instalados actualmente.)
Preparando para desempaquetar .../firmware-amd-graphics_20161130-3_all.deb ...
Desempaquetando firmware-amd-graphics (20161130-3) ...
Configurando firmware-amd-graphics (20161130-3) ...
localepurge: Disk space freed in /usr/share/locale: 0 KiB
localepurge: Disk space freed in /usr/share/man: 0 KiB
localepurge: Disk space freed in /usr/share/gnome/help: 0 KiB
localepurge: Disk space freed in /usr/share/omf: 0 KiB
localepurge: Disk space freed in /usr/share/doc/kde/HTML: 0 KiB
Total disk space freed by localepurge: 0 KiB
root@kaos:/home/keos# apt-get dist upgrade
E: Operación inválida: dist
root@kaos:/home/keos# apt-get upgrade
Calculando la actualización... Hecho
Se actualizarán los siguientes paquetes:
  firmware-realtek
1 actualizados, 0 nuevos se instalarán, 0 para eliminar y 0 no actualizados.
Se necesita descargar 342 kB de archivos.
Se utilizarán 428 kB de espacio de disco adicional después de esta operación.
¿Desea continuar? [S/n]
Des:1 http://auto.mirror.devuan.org/merged ascii/non-free amd64 firmware-realtek all 20161130-3 [342 kB]
Descargados 342 kB en 7s (44.7 kB/s)
Leyendo lista de cambios... Hecho.
(Leyendo la base de datos ... 142183 ficheros o directorios instalados actualmente.)
Preparando para desempaquetar .../firmware-realtek_20161130-3_all.deb ...
Desempaquetando firmware-realtek (20161130-3) sobre (0.43) ...
Configurando firmware-realtek (20161130-3) ...
update-initramfs: deferring update (trigger activated)
Procesando disparadores para initramfs-tools (0.130) ...
update-initramfs: Generating /boot/initrd.img-4.9.0-4-amd64
Yes, it works!.
Thanks!!
#14 2017-11-02 15:00:30
cynwulf
Looks like the firmware is now installed.  Reboot and then check your dmesg again to see if that same error appears.
#15 2017-11-02 15:09:04
keos
[    0.000000] percpu: Embedded 35 pages/cpu @ffff981f9ec00000 s103512 r8192 d31656 u524288
[    0.000000] tsc: Detected 1896.628 MHz processor
[    0.000027] Calibrating delay loop (skipped), value calculated using timer frequency.. 3793.25 BogoMIPS (lpj=7586512)
[    0.000031] pid_max: default: 32768 minimum: 301
[    0.000056] ACPI: Core revision 20160831
[    0.000057] TOSHIBA Satellite detected - force copy of DSDT to local memory
[    0.000155] ACPI: Forced DSDT copy: length 0x0A362 copied locally, original unmapped
[    0.013689] ACPI: 4 ACPI AML tables successfully acquired and loaded
[    0.013768] Security Framework initialized
[    0.013769] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.013776] AppArmor: AppArmor disabled by boot time parameter
[    0.014141] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.015542] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.016181] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.016191] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.016573] [Firmware Info]: CPU: Re-enabling disabled Topology Extensions Support.
[    0.016580] CPU: Physical Processor ID: 0
[    0.016581] CPU: Processor Core ID: 0
[    0.016582] mce: CPU supports 7 MCE banks
[    0.016598] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[    0.016599] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[    0.018178] Freeing SMP alternatives memory: 24K (ffffffff85c7a000 - ffffffff85c80000)
[    0.020666] ftrace: allocating 25178 entries in 99 pages
[    0.032546] smpboot: Max logical packages: 1
[    0.032904] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.178186] smpboot: CPU0: AMD A8-4500M APU with Radeon(tm) HD Graphics (family: 0x15, model: 0x10, stepping: 0x1)
[    0.178191] Performance Events: Fam15h core perfctr, AMD PMU driver.
[    0.178197] ... version:                0
[    0.178198] ... bit width:              48
[    0.178198] ... generic registers:      6
[    0.178199] ... value mask:             0000ffffffffffff
[    0.178200] ... max period:             00007fffffffffff
[    0.178201] ... fixed-purpose events:   0
[    0.178201] ... event mask:             000000000000003f
[    0.178958] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.179146] x86: Booting SMP configuration:
[    0.179147] .... node  #0, CPUs:      #1 #2 #3
[    0.420453] x86: Booted up 1 node, 4 CPUs
[    0.420455] smpboot: Total of 4 processors activated (15171.76 BogoMIPS)
[    0.422080] devtmpfs: initialized
[    0.422189] x86/mm: Memory block size: 128MB
[    0.426570] PM: Registering ACPI NVS region [mem 0xbfabf000-0xbfbbefff] (1048576 bytes)
[    0.426679] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.426695] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.426782] pinctrl core: initialized pinctrl subsystem
[    0.426961] NET: Registered protocol family 16
[    0.440385] cpuidle: using governor ladder
[    0.456382] cpuidle: using governor menu
[    0.456610] Simple Boot Flag at 0x44 set to 0x1
[    0.456646] ACPI: bus type PCI registered
[    0.456649] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.456915] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.456920] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.456939] PCI: Using configuration type 1 for base access
[    0.457906] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.457908] mtrr: probably your BIOS does not setup all CPUs.
[    0.457909] mtrr: corrected configuration.
[    0.473083] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[    0.473086] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.474184] ACPI: Added _OSI(Module Device)
[    0.474186] ACPI: Added _OSI(Processor Device)
[    0.474188] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.474191] ACPI: Added _OSI(Processor Aggregator Device)
[    0.474629] ACPI: Executed 1 blocks of module-level executable AML code
[    0.492602] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.504616] ACPI: Interpreter enabled
[    0.504639] ACPI: (supports S0 S3 S4 S5)
[    0.504640] ACPI: Using IOAPIC for interrupt routing
[    0.504868] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.523450] ACPI: Power Resource [PFA1] (off)
[    0.523867] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.523873] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.523879] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.523896] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.523998] acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000cf9ff])
[    0.524329] PCI host bridge to bus 0000:00
[    0.524332] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.524334] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.524335] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.524337] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.524339] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.524340] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.524342] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.524343] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.524345] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.524348] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.524350] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.524352] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.524353] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.524355] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.524356] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xf7ffffff window]
[    0.524358] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
[    0.524359] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xffffffff window]
[    0.524361] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.524370] pci 0000:00:00.0: [1022:1410] type 00 class 0x060000
[    0.524546] pci 0000:00:01.0: [1002:9903] type 00 class 0x030000
[    0.524556] pci 0000:00:01.0: reg 0x10: [mem 0xe0000000-0xefffffff pref]
[    0.524561] pci 0000:00:01.0: reg 0x14: [io  0x4000-0x40ff]
[    0.524567] pci 0000:00:01.0: reg 0x18: [mem 0xf0200000-0xf023ffff]
[    0.524608] pci 0000:00:01.0: supports D1 D2
[    0.524711] pci 0000:00:01.1: [1002:9902] type 00 class 0x040300
[    0.524720] pci 0000:00:01.1: reg 0x10: [mem 0xf0244000-0xf0247fff]
[    0.524767] pci 0000:00:01.1: supports D1 D2
[    0.524877] pci 0000:00:04.0: [1022:1414] type 01 class 0x060400
[    0.524923] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[    0.525828] pci 0000:00:04.0: System wakeup disabled by ACPI
[    0.525884] pci 0000:00:05.0: [1022:1415] type 01 class 0x060400
[    0.525930] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
[    0.526074] pci 0000:00:10.0: [1022:7812] type 00 class 0x0c0330
[    0.526096] pci 0000:00:10.0: reg 0x10: [mem 0xf0248000-0xf0249fff 64bit]
[    0.526198] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[    0.527656] pci 0000:00:10.0: System wakeup disabled by ACPI
[    0.527724] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[    0.527739] pci 0000:00:11.0: reg 0x10: [io  0x4118-0x411f]
[    0.527748] pci 0000:00:11.0: reg 0x14: [io  0x4124-0x4127]
[    0.527757] pci 0000:00:11.0: reg 0x18: [io  0x4110-0x4117]
[    0.527765] pci 0000:00:11.0: reg 0x1c: [io  0x4120-0x4123]
[    0.527774] pci 0000:00:11.0: reg 0x20: [io  0x4100-0x410f]
[    0.527783] pci 0000:00:11.0: reg 0x24: [mem 0xf0250000-0xf02507ff]
[    0.527922] pci 0000:00:12.0: [1022:7807] type 00 class 0x0c0310
[    0.527934] pci 0000:00:12.0: reg 0x10: [mem 0xf024f000-0xf024ffff]
[    0.529485] pci 0000:00:12.0: System wakeup disabled by ACPI
[    0.529547] pci 0000:00:12.2: [1022:7808] type 00 class 0x0c0320
[    0.530008] pci 0000:00:12.2: reg 0x10: [mem 0xf024e000-0xf024e0ff]
[    0.532742] pci 0000:00:12.2: supports D1 D2
[    0.532744] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[    0.534063] pci 0000:00:12.2: System wakeup disabled by ACPI
[    0.534128] pci 0000:00:13.0: [1022:7807] type 00 class 0x0c0310
[    0.534145] pci 0000:00:13.0: reg 0x10: [mem 0xf024d000-0xf024dfff]
[    0.534319] pci 0000:00:13.2: [1022:7808] type 00 class 0x0c0320
[    0.534834] pci 0000:00:13.2: reg 0x10: [mem 0xf024c000-0xf024c0ff]
[    0.537561] pci 0000:00:13.2: supports D1 D2
[    0.537563] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[    0.537681] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[    0.537845] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[    0.537863] pci 0000:00:14.2: reg 0x10: [mem 0xf0240000-0xf0243fff 64bit]
[    0.537926] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[    0.538035] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[    0.538216] pci 0000:00:14.4: [1022:780f] type 01 class 0x060400
[    0.538307] pci 0000:00:14.4: System wakeup disabled by ACPI
[    0.538377] pci 0000:00:14.5: [1022:7809] type 00 class 0x0c0310
[    0.538389] pci 0000:00:14.5: reg 0x10: [mem 0xf024b000-0xf024bfff]
[    0.538552] pci 0000:00:14.7: [1022:7806] type 00 class 0x080501
[    0.538569] pci 0000:00:14.7: reg 0x10: [mem 0xf024a000-0xf024a0ff 64bit]
[    0.538719] pci 0000:00:18.0: [1022:1400] type 00 class 0x060000
[    0.538826] pci 0000:00:18.1: [1022:1401] type 00 class 0x060000
[    0.538929] pci 0000:00:18.2: [1022:1402] type 00 class 0x060000
[    0.539033] pci 0000:00:18.3: [1022:1403] type 00 class 0x060000
[    0.539140] pci 0000:00:18.4: [1022:1404] type 00 class 0x060000
[    0.539243] pci 0000:00:18.5: [1022:1405] type 00 class 0x060000
[    0.539419] pci 0000:01:00.0: [1969:1090] type 00 class 0x020000
[    0.539440] pci 0000:01:00.0: reg 0x10: [mem 0xf0100000-0xf013ffff 64bit]
[    0.539450] pci 0000:01:00.0: reg 0x18: [io  0x3000-0x307f]
[    0.539540] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.550244] pci 0000:00:04.0: PCI bridge to [bus 01]
[    0.550250] pci 0000:00:04.0:   bridge window [io  0x3000-0x3fff]
[    0.550253] pci 0000:00:04.0:   bridge window [mem 0xf0100000-0xf01fffff]
[    0.550368] pci 0000:02:00.0: [10ec:8176] type 00 class 0x028000
[    0.550388] pci 0000:02:00.0: reg 0x10: [io  0x2000-0x20ff]
[    0.550414] pci 0000:02:00.0: reg 0x18: [mem 0xf0000000-0xf0003fff 64bit]
[    0.550516] pci 0000:02:00.0: supports D1 D2
[    0.550518] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.562243] pci 0000:00:05.0: PCI bridge to [bus 02]
[    0.562249] pci 0000:00:05.0:   bridge window [io  0x2000-0x2fff]
[    0.562252] pci 0000:00:05.0:   bridge window [mem 0xf0000000-0xf00fffff]
[    0.562427] pci 0000:00:14.4: PCI bridge to [bus 03]
[    0.563605] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.563690] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.563779] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.563864] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.563936] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.563993] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.564050] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.564107] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0
[    0.564341] ACPI: Enabled 1 GPEs in block 00 to 1F
[    0.564596] vgaarb: setting as boot device: PCI:0000:00:01.0
[    0.564597] vgaarb: device added: PCI:0000:00:01.0,decodes=io+mem,owns=io+mem,locks=none
[    0.564605] vgaarb: loaded
[    0.564606] vgaarb: bridge control possible 0000:00:01.0
[    0.564727] PCI: Using ACPI for IRQ routing
[    0.566547] PCI: pci_cache_line_size set to 64 bytes
[    0.566611] e820: reserve RAM buffer [mem 0x0009f400-0x0009ffff]
[    0.566613] e820: reserve RAM buffer [mem 0xba87f000-0xbbffffff]
[    0.566614] e820: reserve RAM buffer [mem 0xbf9bf000-0xbfffffff]
[    0.566615] e820: reserve RAM buffer [mem 0xbfc00000-0xbfffffff]
[    0.566617] e820: reserve RAM buffer [mem 0x11f000000-0x11fffffff]
[    0.566840] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.566844] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.568969] clocksource: Switched to clocksource hpet
[    0.579525] VFS: Disk quotas dquot_6.6.0
[    0.579570] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.579731] pnp: PnP ACPI init
[    0.579959] system 00:00: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.579961] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.579966] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.580284] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.580328] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.580365] pnp 00:03: Plug and Play ACPI device, IDs TOS0310 SYN1900 SYN0002 PNP0f13 (active)
[    0.580438] system 00:04: [io  0x0400-0x04cf] has been reserved
[    0.580440] system 00:04: [io  0x04d0-0x04d1] has been reserved
[    0.580442] system 00:04: [io  0x04d6] has been reserved
[    0.580446] system 00:04: [io  0x0680-0x06ff] has been reserved
[    0.580448] system 00:04: [io  0x077a] has been reserved
[    0.580450] system 00:04: [io  0x0c00-0x0c01] has been reserved
[    0.580452] system 00:04: [io  0x0c14] has been reserved
[    0.580454] system 00:04: [io  0x0c50-0x0c52] has been reserved
[    0.580455] system 00:04: [io  0x0c6c] has been reserved
[    0.580457] system 00:04: [io  0x0c6f] has been reserved
[    0.580459] system 00:04: [io  0x0cd0-0x0cdb] has been reserved
[    0.580461] system 00:04: [io  0x0840-0x0847] has been reserved
[    0.580464] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.580571] system 00:05: [mem 0xff800000-0xff80ffff] has been reserved
[    0.580573] system 00:05: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.580575] system 00:05: [mem 0xffc00000-0xffffffff] has been reserved
[    0.580578] system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.581118] pnp: PnP ACPI: found 6 devices
[    0.589329] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.589353] pci 0000:00:04.0: PCI bridge to [bus 01]
[    0.589356] pci 0000:00:04.0:   bridge window [io  0x3000-0x3fff]
[    0.589360] pci 0000:00:04.0:   bridge window [mem 0xf0100000-0xf01fffff]
[    0.589365] pci 0000:00:05.0: PCI bridge to [bus 02]
[    0.589367] pci 0000:00:05.0:   bridge window [io  0x2000-0x2fff]
[    0.589370] pci 0000:00:05.0:   bridge window [mem 0xf0000000-0xf00fffff]
[    0.589375] pci 0000:00:14.4: PCI bridge to [bus 03]
[    0.589389] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.589391] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.589392] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.589394] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.589396] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.589398] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.589399] pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
[    0.589401] pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
[    0.589403] pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
[    0.589404] pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
[    0.589406] pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
[    0.589407] pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
[    0.589409] pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
[    0.589410] pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
[    0.589412] pci_bus 0000:00: resource 18 [mem 0xe0000000-0xf7ffffff window]
[    0.589414] pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfed3ffff window]
[    0.589415] pci_bus 0000:00: resource 20 [mem 0xfed45000-0xffffffff window]
[    0.589417] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.589419] pci_bus 0000:01: resource 1 [mem 0xf0100000-0xf01fffff]
[    0.589421] pci_bus 0000:02: resource 0 [io  0x2000-0x2fff]
[    0.589423] pci_bus 0000:02: resource 1 [mem 0xf0000000-0xf00fffff]
[    0.589669] NET: Registered protocol family 2
[    0.589929] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.590044] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.590199] TCP: Hash tables configured (established 32768 bind 32768)
[    0.590241] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.590265] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.590409] NET: Registered protocol family 1
[    0.590428] pci 0000:00:01.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.885275] pci 0000:01:00.0: set MSI_INTX_DISABLE_BUG flag
[    0.885283] PCI: CLS 64 bytes, default 64
[    0.885353] Unpacking initramfs...
[    1.304654] Freeing initrd memory: 17856K (ffff981eb5d10000 - ffff981eb6e80000)
[    1.304658] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.304661] software IO TLB [mem 0xbb9bf000-0xbf9bf000] (64MB) mapped at [ffff981f3b9bf000-ffff981f3f9befff]
[    1.304698] perf: AMD NB counters detected
[    1.305124] LVT offset 0 assigned for vector 0x400
[    1.305250] perf: AMD IBS detected (0x000000ff)
[    1.306557] audit: initializing netlink subsys (disabled)
[    1.306607] audit: type=2000 audit(1509619386.200:1): initialized
[    1.308100] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[    1.308244] zbud: loaded
[    1.310914] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.311031] io scheduler noop registered
[    1.311033] io scheduler deadline registered
[    1.311073] io scheduler cfq registered (default)
[    1.311948] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.311967] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.313432] GHES: HEST is not enabled!
[    1.313687] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.315300] Linux agpgart interface v0.103
[    1.316023] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.316025] AMD IOMMUv2 functionality not available on this system
[    1.317346] i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    1.320162] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.320176] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.320702] mousedev: PS/2 mouse device common for all mice
[    1.320825] rtc_cmos 00:01: RTC can wake from S4
[    1.321100] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.321135] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[    1.321299] ledtrig-cpu: registered to indicate activity on CPUs
[    1.322240] NET: Registered protocol family 10
[    1.323006] mip6: Mobile IPv6
[    1.323010] NET: Registered protocol family 17
[    1.323017] mpls_gso: MPLS GSO support
[    1.324095] microcode: CPU0: patch_level=0x06001116
[    1.324116] microcode: CPU1: patch_level=0x06001116
[    1.324137] microcode: CPU2: patch_level=0x06001116
[    1.324152] microcode: CPU3: patch_level=0x06001116
[    1.324286] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.324809] registered taskstats version 1
[    1.324851] zswap: loaded using pool lzo/zbud
[    1.325220] ima: No TPM chip found, activating TPM-bypass!
[    1.325984] rtc_cmos 00:01: setting system clock to 2017-11-02 10:43:06 UTC (1509619386)
[    1.326185] PM: Hibernation image not present or could not be loaded.
[    1.330611] Freeing unused kernel memory: 1392K (ffffffff85b1e000 - ffffffff85c7a000)
[    1.330614] Write protecting the kernel read-only data: 12288k
[    1.332715] Freeing unused kernel memory: 1988K (ffff981ef100f000 - ffff981ef1200000)
[    1.342191] Freeing unused kernel memory: 1240K (ffff981ef14ca000 - ffff981ef1600000)
[    1.363935] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.367792] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.420348] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.420618] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.420650] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.423916] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.424022] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.428038] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.428290] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.428339] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.430178] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.430418] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.549666] thermal LNXTHERM:00: registered as thermal_zone0
[    1.549668] ACPI: Thermal Zone [THZN] (67 C)
[    1.552482] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B07 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\_SB.PCI0.SMBS.SMB0) (20160831/utaddress-247)
[    1.552492] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    1.553495] SCSI subsystem initialized
[    1.554427] ACPI: bus type USB registered
[    1.554468] usbcore: registered new interface driver usbfs
[    1.554490] usbcore: registered new interface driver hub
[    1.554525] usbcore: registered new device driver usb
[    1.555495] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.556417] ehci-pci: EHCI PCI platform driver
[    1.556423] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.556798] QUIRK: Enable AMD PLL fix
[    1.556844] ehci-pci 0000:00:12.2: EHCI Host Controller
[    1.556858] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[    1.556875] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    1.556952] ehci-pci 0000:00:12.2: debug port 1
[    1.557018] ehci-pci 0000:00:12.2: irq 17, io mem 0xf024e000
[    1.560244] libata version 3.00 loaded.
[    1.561054] sdhci: Secure Digital Host Controller Interface driver
[    1.561054] sdhci: Copyright(c) Pierre Ossman
[    1.568717] alx 0000:01:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [00:8c:fa:3f:01:bf]
[    1.573062] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[    1.573167] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.573169] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.573172] usb usb1: Product: EHCI Host Controller
[    1.573173] usb usb1: Manufacturer: Linux 4.9.0-3-amd64 ehci_hcd
[    1.573175] usb usb1: SerialNumber: 0000:00:12.2
[    1.573494] hub 1-0:1.0: USB hub found
[    1.573513] hub 1-0:1.0: 5 ports detected
[    1.574156] ehci-pci 0000:00:13.2: EHCI Host Controller
[    1.574170] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 2
[    1.574175] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    1.574186] ehci-pci 0000:00:13.2: debug port 1
[    1.574227] ehci-pci 0000:00:13.2: irq 17, io mem 0xf024c000
[    1.575255] AVX version of gcm_enc/dec engaged.
[    1.575257] AES CTR mode by8 optimization enabled
[    1.593036] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[    1.593242] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.593244] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.593245] usb usb2: Product: EHCI Host Controller
[    1.593247] usb usb2: Manufacturer: Linux 4.9.0-3-amd64 ehci_hcd
[    1.593248] usb usb2: SerialNumber: 0000:00:13.2
[    1.593511] hub 2-0:1.0: USB hub found
[    1.593551] hub 2-0:1.0: 5 ports detected
[    1.594187] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    1.594194] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 3
[    1.594407] xhci_hcd 0000:00:10.0: hcc params 0x014042c3 hci version 0x96 quirks 0x00000608
[    1.594419] ohci-pci: OHCI PCI platform driver
[    1.594721] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.594723] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.594725] usb usb3: Product: xHCI Host Controller
[    1.594727] usb usb3: Manufacturer: Linux 4.9.0-3-amd64 xhci-hcd
[    1.594729] usb usb3: SerialNumber: 0000:00:10.0
[    1.595479] hub 3-0:1.0: USB hub found
[    1.595493] hub 3-0:1.0: 2 ports detected
[    1.595724] xhci_hcd 0000:00:10.0: xHCI Host Controller
[    1.595728] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
[    1.597811] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.597841] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    1.597843] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.597845] usb usb4: Product: xHCI Host Controller
[    1.597846] usb usb4: Manufacturer: Linux 4.9.0-3-amd64 xhci-hcd
[    1.597848] usb usb4: SerialNumber: 0000:00:10.0
[    1.598053] hub 4-0:1.0: USB hub found
[    1.598063] hub 4-0:1.0: 2 ports detected
[    1.598253] sdhci-pci 0000:00:14.7: SDHCI controller found [1022:7806] (rev 0)
[    1.599745] mmc0: SDHCI controller on PCI [0000:00:14.7] using ADMA
[    1.599820] ahci 0000:00:11.0: version 3.0
[    1.600096] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    1.600099] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[    1.600783] scsi host0: ahci
[    1.601080] scsi host1: ahci
[    1.601161] ata1: SATA max UDMA/133 abar m2048@0xf0250000 port 0xf0250100 irq 29
[    1.601164] ata2: SATA max UDMA/133 abar m2048@0xf0250000 port 0xf0250180 irq 29
[    1.601301] ohci-pci 0000:00:12.0: OHCI PCI host controller
[    1.601308] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 5
[    1.601341] ohci-pci 0000:00:12.0: irq 18, io mem 0xf024f000
[    1.665080] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    1.665083] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.665085] usb usb5: Product: OHCI PCI host controller
[    1.665086] usb usb5: Manufacturer: Linux 4.9.0-3-amd64 ohci_hcd
[    1.665087] usb usb5: SerialNumber: 0000:00:12.0
[    1.665431] hub 5-0:1.0: USB hub found
[    1.665442] hub 5-0:1.0: 5 ports detected
[    1.665884] ohci-pci 0000:00:13.0: OHCI PCI host controller
[    1.665891] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 6
[    1.665920] ohci-pci 0000:00:13.0: irq 18, io mem 0xf024d000
[    1.729077] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    1.729080] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.729081] usb usb6: Product: OHCI PCI host controller
[    1.729083] usb usb6: Manufacturer: Linux 4.9.0-3-amd64 ohci_hcd
[    1.729084] usb usb6: SerialNumber: 0000:00:13.0
[    1.729460] hub 6-0:1.0: USB hub found
[    1.729472] hub 6-0:1.0: 5 ports detected
[    1.729901] ohci-pci 0000:00:14.5: OHCI PCI host controller
[    1.729908] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 7
[    1.729940] ohci-pci 0000:00:14.5: irq 18, io mem 0xf024b000
[    1.793068] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    1.793071] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.793072] usb usb7: Product: OHCI PCI host controller
[    1.793074] usb usb7: Manufacturer: Linux 4.9.0-3-amd64 ohci_hcd
[    1.793075] usb usb7: SerialNumber: 0000:00:14.5
[    1.793458] hub 7-0:1.0: USB hub found
[    1.793483] hub 7-0:1.0: 2 ports detected
[    1.901010] usb 1-5: new high-speed USB device number 2 using ehci-pci
[    1.921004] usb 3-2: new full-speed USB device number 2 using xhci_hcd
[    1.925006] usb 2-4: new high-speed USB device number 2 using ehci-pci
[    2.050063] usb 1-5: New USB device found, idVendor=0bda, idProduct=0129
[    2.050066] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.050068] usb 1-5: Product: USB2.0-CRW
[    2.050069] usb 1-5: Manufacturer: Generic
[    2.050070] usb 1-5: SerialNumber: 20100201396000000
[    2.056325] usbcore: registered new interface driver rtsx_usb
[    2.076927] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.076968] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    2.080953] ata2.00: ATAPI: TSSTcorp CDDVDW SN-208AB, TO04, max UDMA/100
[    2.087525] ata2.00: configured for UDMA/100
[    2.093874] usb 3-2: New USB device found, idVendor=062a, idProduct=4102
[    2.093877] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.093878] usb 3-2: Product: 2.4G Wireless Mouse
[    2.093880] usb 3-2: Manufacturer: MOSART Semi.
[    2.097547] hidraw: raw HID events driver (C) Jiri Kosina
[    2.104571] ata1.00: ATA-8: TOSHIBA MQ01ABD064, AX0A3M, max UDMA/100
[    2.104574] ata1.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.106610] ata1.00: configured for UDMA/100
[    2.106965] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD0 3M   PQ: 0 ANSI: 5
[    2.117237] usbcore: registered new interface driver usbhid
[    2.117239] usbhid: USB HID core driver
[    2.118278] input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:10.0/usb3/3-2/3-2:1.0/0003:062A:4102.0001/input/input3
[    2.118460] hid-generic 0003:062A:4102.0001: input,hiddev0,hidraw0: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-0000:00:10.0-2/input0
[    2.147641] scsi 1:0:0:0: CD-ROM            TSSTcorp CDDVDW SN-208AB  TO04 PQ: 0 ANSI: 5
[    2.150825] usb 2-4: New USB device found, idVendor=10f1, idProduct=1a43
[    2.150828] usb 2-4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    2.150830] usb 2-4: Product: TOSHIBA Web Camera - HD
[    2.150831] usb 2-4: Manufacturer: Importek
[    2.165914] sd 0:0:0:0: [sda] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[    2.166008] sd 0:0:0:0: [sda] Write Protect is off
[    2.166011] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.166048] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.185061] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.185064] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.185323] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.221836] random: fast init done
[    2.251606] psmouse serio1: synaptics: queried max coordinates: x [..5634], y [..4598]
[    2.305546] psmouse serio1: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xd00073/0x240000/0xa0400/0x0, board id: 1680, fw id: 706145
[    2.305556] psmouse serio1: synaptics: Toshiba Satellite L855D detected, limiting rate to 40pps.
[    2.313029] tsc: Refined TSC clocksource calibration: 1896.480 MHz
[    2.313046] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x36ac5e0f526, max_idle_ns: 881590650387 ns
[    2.325904]  sda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 sda8 >
[    2.326905] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.339778] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input2
[    3.337077] clocksource: Switched to clocksource tsc
[    3.503837] PM: Starting manual resume from disk
[    3.503846] PM: Hibernation image partition 8:2 present
[    3.503848] PM: Looking for hibernation image.
[    3.504159] PM: Image not found (code -22)
[    3.504162] PM: Hibernation image not present or could not be loaded.
[    3.857070] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[    5.186907] random: crng init done
[    6.593600] acpi_cpufreq: overriding BIOS provided _PSD data
[    6.708949] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
[    6.708955] ACPI: Power Button [PWRB]
[    6.709557] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input5
[    6.709562] ACPI: Lid Switch [LID0]
[    6.709635] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[    6.709637] ACPI: Power Button [PWRF]
[    6.771089] [drm] Initialized
[    6.877130] ACPI: Battery Slot [BAT0] (battery present)
[    6.877624] ACPI: Video Device [VGA] (multi-head: yes  rom: no  post: no)
[    6.880072] acpi device:00: registered as cooling_device5
[    6.880211] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
[    6.922673] ACPI: AC Adapter [ADP0] (on-line)
[    7.003532] wmi: Mapper loaded
[    7.009352] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    7.009433] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    7.040345] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    7.073926] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
[    7.074066] sp5100_tco: PCI Vendor ID: 0x1022, Device ID: 0x780b, Revision ID: 0x14
[    7.074159] sp5100_tco: Using 0xfed80b00 for watchdog MMIO address
[    7.074171] sp5100_tco: Last reboot was not triggered by watchdog.
[    7.074360] sp5100_tco: initialized (0xffffb308806c9b00). heartbeat=60 sec (nowayout=0)
[    7.467608] input: PC Speaker as /devices/platform/pcspkr/input/input8
[    7.504712] snd_hda_intel 0000:00:01.1: Force to non-snoop mode
[    7.915464] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/sound/card0/input9
[    7.917877] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC269VB: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    7.917881] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.917884] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    7.917886] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    7.917888] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    7.917892] snd_hda_codec_realtek hdaudioC1D0:      Mic=0x18
[    7.917894] snd_hda_codec_realtek hdaudioC1D0:      Internal Mic=0x12
[    7.927444] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/sound/card1/input10
[    7.927792] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:14.2/sound/card1/input11
[    7.927856] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:14.2/sound/card1/input12
[    7.977173] [drm] radeon kernel modesetting enabled.
[    8.596284] rtl8192ce: Using firmware rtlwifi/rtl8192cfwU_B.bin
[    8.651755] rtl8192ce 0000:02:00.0: firmware: direct-loading firmware rtlwifi/rtl8192cfwU_B.bin
[    8.666076] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[    8.666504] rtlwifi: rtlwifi: wireless switch is on
[    8.763822] CRAT table not found
[    8.763824] Finished initializing topology ret=0
[    8.763844] kfd kfd: Initialized module
[    8.764859] [drm] initializing kernel modesetting (ARUBA 0x1002:0x9903 0x1179:0xFB28 0x00).
[    8.764881] [drm] register mmio base: 0xF0200000
[    8.764882] [drm] register mmio size: 262144
[    8.766033] ATOM BIOS: 113
[    8.766106] radeon 0000:00:01.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[    8.766110] radeon 0000:00:01.0: GTT: 1024M 0x0000000020000000 - 0x000000005FFFFFFF
[    8.766117] [drm] Detected VRAM RAM=512M, BAR=256M
[    8.766118] [drm] RAM width 32bits DDR
[    8.766293] [TTM] Zone  kernel: Available graphics memory: 1751836 kiB
[    8.766296] [TTM] Initializing pool allocator
[    8.766310] [TTM] Initializing DMA pool allocator
[    8.766354] [drm] radeon: 512M of VRAM memory ready
[    8.766356] [drm] radeon: 1024M of GTT memory ready.
[    8.766390] [drm] Loading ARUBA Microcode
[    8.807771] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/ARUBA_pfp.bin
[    9.029923] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/ARUBA_me.bin
[    9.074575] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/ARUBA_rlc.bin
[    9.074588] [drm] Internal thermal controller without fan control
[    9.074910] [drm] radeon: dpm initialized
[    9.095482] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/TAHITI_uvd.bin
[    9.141706] radeon 0000:00:01.0: firmware: direct-loading firmware radeon/TAHITI_vce.bin
[    9.143506] [drm] Found VCE firmware/feedback version 50.0.1 / 17!
[    9.143535] [drm] GART: num cpu pages 262144, num gpu pages 262144
[    9.187300] [drm] PCIE GART of 1024M enabled (table at 0x00000000001D6000).
[    9.187472] radeon 0000:00:01.0: WB enabled
[    9.187477] radeon 0000:00:01.0: fence driver on ring 0 use gpu addr 0x0000000020000c00 and cpu addr 0xffff981f97ee7c00
[    9.187857] radeon 0000:00:01.0: fence driver on ring 5 use gpu addr 0x0000000000075a18 and cpu addr 0xffffb30881835a18
[    9.207895] radeon 0000:00:01.0: fence driver on ring 6 use gpu addr 0x0000000020000c18 and cpu addr 0xffff981f97ee7c18
[    9.207898] radeon 0000:00:01.0: fence driver on ring 7 use gpu addr 0x0000000020000c1c and cpu addr 0xffff981f97ee7c1c
[    9.207901] radeon 0000:00:01.0: fence driver on ring 1 use gpu addr 0x0000000020000c04 and cpu addr 0xffff981f97ee7c04
[    9.207904] radeon 0000:00:01.0: fence driver on ring 2 use gpu addr 0x0000000020000c08 and cpu addr 0xffff981f97ee7c08
[    9.207907] radeon 0000:00:01.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c and cpu addr 0xffff981f97ee7c0c
[    9.207909] radeon 0000:00:01.0: fence driver on ring 4 use gpu addr 0x0000000020000c10 and cpu addr 0xffff981f97ee7c10
[    9.208066] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    9.208068] [drm] Driver supports precise vblank timestamp query.
[    9.208075] radeon 0000:00:01.0: radeon: MSI limited to 32-bit
[    9.208146] radeon 0000:00:01.0: radeon: using MSI.
[    9.208180] [drm] radeon: irq initialized.
[    9.227118] [drm] ring test on 0 succeeded in 2 usecs
[    9.227143] [drm] ring test on 3 succeeded in 2 usecs
[    9.227144] kvm: Nested Virtualization enabled
[    9.227147] kvm: Nested Paging enabled
[    9.227151] [drm] ring test on 4 succeeded in 3 usecs
[    9.272911] [drm] ring test on 5 succeeded in 1 usecs
[    9.281856] EDAC MC: Ver: 3.0.0
[    9.292791] [drm] UVD initialized successfully.
[    9.300439] MCE: In-kernel MCE decoding enabled.
[    9.353989] EDAC amd64: DRAM ECC disabled.
[    9.353999] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    9.402094] [drm] ring test on 6 succeeded in 16 usecs
[    9.402104] [drm] ring test on 7 succeeded in 3 usecs
[    9.402105] [drm] VCE initialized successfully.
[    9.402605] [drm] ib test on ring 0 succeeded in 0 usecs
[    9.402643] [drm] ib test on ring 3 succeeded in 0 usecs
[    9.402677] [drm] ib test on ring 4 succeeded in 0 usecs
[    9.449382] EDAC amd64: DRAM ECC disabled.
[    9.449393] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    9.485476] EDAC amd64: DRAM ECC disabled.
[    9.485487] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    9.865021] media: Linux media interface: v0.10
[    9.928733] [drm] ib test on ring 5 succeeded
[    9.991497] Linux video capture interface: v2.00
[   10.124838] uvcvideo: Found UVC 1.00 device TOSHIBA Web Camera - HD (10f1:1a43)
[   10.143080] uvcvideo 2-4:1.0: Entity type for entity Extension 3 was not initialized!
[   10.143086] uvcvideo 2-4:1.0: Entity type for entity Processing 2 was not initialized!
[   10.143089] uvcvideo 2-4:1.0: Entity type for entity Camera 1 was not initialized!
[   10.143279] input: TOSHIBA Web Camera - HD as /devices/pci0000:00/0000:00:13.2/usb2/2-4/2-4:1.0/input/input13
[   10.143463] usbcore: registered new interface driver uvcvideo
[   10.143464] USB Video Class driver (1.1.1)
[   10.472573] [drm] ib test on ring 6 succeeded
[   10.984241] [drm] ib test on ring 7 succeeded
[   10.986729] [drm] radeon atom DIG backlight initialized
[   10.986731] [drm] Radeon Display Connectors
[   10.986732] [drm] Connector 0:
[   10.986733] [drm]   LVDS-1
[   10.986734] [drm]   HPD1
[   10.986737] [drm]   DDC: 0x6530 0x6530 0x6534 0x6534 0x6538 0x6538 0x653c 0x653c
[   10.986738] [drm]   Encoders:
[   10.986739] [drm]     LCD1: INTERNAL_UNIPHY2
[   10.986740] [drm]     LCD1: TRAVIS
[   10.986741] [drm] Connector 1:
[   10.986742] [drm]   VGA-1
[   10.986743] [drm]   HPD2
[   10.986745] [drm]   DDC: 0x6540 0x6540 0x6544 0x6544 0x6548 0x6548 0x654c 0x654c
[   10.986746] [drm]   Encoders:
[   10.986747] [drm]     CRT1: INTERNAL_UNIPHY2
[   10.986748] [drm]     CRT1: NUTMEG
[   10.986749] [drm] Connector 2:
[   10.986750] [drm]   HDMI-A-1
[   10.986751] [drm]   HPD3
[   10.986753] [drm]   DDC: 0x6550 0x6550 0x6554 0x6554 0x6558 0x6558 0x655c 0x655c
[   10.986753] [drm]   Encoders:
[   10.986755] [drm]     DFP1: INTERNAL_UNIPHY
[   11.249329] [drm] fb mappable at 0xE03DA000
[   11.249331] [drm] vram apper at 0xE0000000
[   11.249333] [drm] size 4325376
[   11.249334] [drm] fb depth is 24
[   11.249335] [drm]    pitch is 5632
[   11.249638] fbcon: radeondrmfb (fb0) is primary device
[   11.397420] Console: switching to colour frame buffer device 170x48
[   11.401117] radeon 0000:00:01.0: fb0: radeondrmfb frame buffer device
[   11.425306] [drm] Initialized radeon 2.48.0 20080528 for 0000:00:01.0 on minor 0
[   13.127908] Adding 1126396k swap on /dev/sda2.  Priority:-1 extents:1 across:1126396k FS
[   13.196921] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[   13.790019] lp: driver loaded but no devices found
[   13.803709] ppdev: user-space parallel port driver
[   15.252481] RPC: Registered named UNIX socket transport module.
[   15.252483] RPC: Registered udp transport module.
[   15.252484] RPC: Registered tcp transport module.
[   15.252485] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   15.296567] FS-Cache: Loaded
[   15.343263] FS-Cache: Netfs 'nfs' registered for caching
[   15.451498] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   21.505110] Bluetooth: Core ver 2.22
[   21.505137] NET: Registered protocol family 31
[   21.505138] Bluetooth: HCI device and connection manager initialized
[   21.505145] Bluetooth: HCI socket layer initialized
[   21.505148] Bluetooth: L2CAP socket layer initialized
[   21.505158] Bluetooth: SCO socket layer initialized
[   22.468290] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   22.468292] Bluetooth: BNEP filters: protocol multicast
[   22.468298] Bluetooth: BNEP socket layer initialized
[   26.090171] NET: Registered protocol family 4
[   26.121101] NET: Registered protocol family 3
[   26.125019] NET: Registered protocol family 5
[   28.428060] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   34.148961] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   38.878918] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   39.051654] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   39.932815] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   43.954625] wlan0: authenticate with f8:2c:18:8a:a9:d3
[   43.987022] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[   43.996628] wlan0: authenticated
[   43.997850] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[   44.005805] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[   44.006330] wlan0: associated
[   44.006448] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  101.445520] wlan0: deauthenticated from f8:2c:18:8a:a9:d3 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[  102.681891] wlan0: authenticate with f8:2c:18:8a:a9:d3
[  102.714488] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[  102.726879] wlan0: authenticated
[  102.729284] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[  102.733030] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[  102.733975] wlan0: associated
[  281.094414] wlan0: deauthenticated from f8:2c:18:8a:a9:d3 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[  282.331868] wlan0: authenticate with f8:2c:18:8a:a9:d3
[  282.364521] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[  282.373029] wlan0: authenticated
[  282.379216] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[  282.382691] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[  282.383321] wlan0: associated
[  343.450857] wlan0: deauthenticated from f8:2c:18:8a:a9:d3 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[  344.686861] wlan0: authenticate with f8:2c:18:8a:a9:d3
[  344.719619] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[  344.736330] wlan0: authenticated
[  344.738456] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[  344.743961] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[  344.744522] wlan0: associated
[  529.080524] wlan0: deauthenticated from f8:2c:18:8a:a9:d3 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[  530.328650] wlan0: authenticate with f8:2c:18:8a:a9:d3
[  530.361323] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[  530.370975] wlan0: authenticated
[  530.371956] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[  530.375619] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[  530.376276] wlan0: associated
[  531.249110] wlan0: deauthenticating from f8:2c:18:8a:a9:d3 by local choice (Reason: 3=DEAUTH_LEAVING)
[  531.645500] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  531.756865] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  535.465829] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  537.550657] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  537.681322] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  538.564645] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  541.099704] wlan0: authenticate with f8:2c:18:8a:a9:d3
[  541.116233] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[  541.125705] wlan0: authenticated
[  541.127052] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[  541.133069] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[  541.133589] wlan0: associated
[  541.133661] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  940.477247] wlan0: deauthenticated from f8:2c:18:8a:a9:d3 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[  941.712438] wlan0: authenticate with f8:2c:18:8a:a9:d3
[  941.747737] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[  941.757507] wlan0: authenticated
[  941.759716] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[  941.765099] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[  941.765675] wlan0: associated
[ 1126.006194] wlan0: deauthenticated from f8:2c:18:8a:a9:d3 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[ 1127.241757] wlan0: authenticate with f8:2c:18:8a:a9:d3
[ 1127.274200] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[ 1127.284176] wlan0: authenticated
[ 1127.285374] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[ 1127.293909] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[ 1127.294480] wlan0: associated
[ 1188.770718] wlan0: deauthenticated from f8:2c:18:8a:a9:d3 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[ 1190.008839] wlan0: authenticate with f8:2c:18:8a:a9:d3
[ 1190.041391] wlan0: send auth to f8:2c:18:8a:a9:d3 (try 1/3)
[ 1190.050228] wlan0: authenticated
[ 1190.052496] wlan0: associate with f8:2c:18:8a:a9:d3 (try 1/3)
[ 1190.060239] wlan0: RX AssocResp from f8:2c:18:8a:a9:d3 (capab=0x411 status=0 aid=1)
[ 1190.060823] wlan0: associated
[ 1190.189030] wlan0: deauthenticating from f8:2c:18:8a:a9:d3 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1190.584765] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1190.730025] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#16 2017-11-02 15:13:58
cynwulf
Re: Problems with the multimedia player VLC [Solved]
All looking good there.  Looks like it's all sorted?  You would have had horrible performance before due to software rendering being used.
#17 2017-11-02 15:26:19
keos
No ... it was an illusion ... everything was fine till one video finished then the next video comes with a black images, only audio works.
If i start another video (manualy) it works fine, the image comes, but automatic doesn't work, i means when the next video comes by itself there is not images.
#18 2017-11-02 15:50:13
cynwulf
Any warnings or errors in your Xorg log file? (/var/log/Xorg.0.log)
Also have a look at ~/.xsession-errors
And finally, run VLC from a terminal emulator and see if it spits any errors when it happens...
#19 2017-11-02 16:02:14
keos
[    23.713]
X.Org X Server 1.19.3
Release Date: 2017-03-15
[    23.713] X Protocol Version 11, Revision 0
[    23.713] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[    23.713] Current Operating System: Linux kaos 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64
[    23.713] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-3-amd64 root=UUID=3ae77ee2-8b75-4b07-8c79-83b3fd79701e ro quiet
[    23.713] Build Date: 15 March 2017  09:21:41PM
[    23.713] xorg-server 2:1.19.3-1 (https://www.debian.org/support)
[    23.713] Current version of pixman: 0.34.0
[    23.713] 	Before reporting problems, check http://wiki.x.org
[    23.713] Markers: (--) probed, (**) from config file, (==) default setting,
[    23.713] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov  2 11:35:07 2017
[    23.815] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    24.050] (==) No Layout section.  Using the first Screen section.
[    24.050] (==) No screen section available. Using defaults.
[    24.050] (**) |-->Screen "Default Screen Section" (0)
[    24.050] (**) |   |-->Monitor "<default monitor>"
[    24.078] (==) No monitor specified for screen "Default Screen Section".
[    24.078] (==) Automatically adding devices
[    24.078] (==) Automatically enabling devices
[    24.078] (==) Automatically adding GPU devices
[    24.078] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    24.146] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    24.146] 	Entry deleted from font path.
[    24.244] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    24.244] (==) ModulePath set to "/usr/lib/xorg/modules"
[    24.244] (II) The server relies on udev to provide the list of input devices.
[    24.244] (II) Loader magic: 0x55a6ea85be00
[    24.244] (II) Module ABI versions:
[    24.244] 	X.Org ANSI C Emulation: 0.4
[    24.244] 	X.Org Video Driver: 23.0
[    24.244] 	X.Org XInput driver : 24.1
[    24.244] 	X.Org Server Extension : 10.0
[    24.245] (++) using VT number 7
[    24.245] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    24.247] (II) xfree86: Adding drm device (/dev/dri/card0)
[    24.288] (--) PCI:*(0:0:1:0) 1002:9903:1179:fb28 rev 0, Mem @ 0xe0000000/268435456, 0xf0200000/262144, I/O @ 0x00004000/256, BIOS @ 0x????????/131072
[    24.288] (II) LoadModule: "glx"
[    24.341] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    24.673] (II) Module glx: vendor="X.Org Foundation"
[    24.673] 	compiled for 1.19.3, module version = 1.0.0
[    24.674] 	ABI class: X.Org Server Extension, version 10.0
[    24.674] (==) Matched ati as autoconfigured driver 0
[    24.674] (==) Matched ati as autoconfigured driver 1
[    24.674] (==) Matched modesetting as autoconfigured driver 2
[    24.674] (==) Matched fbdev as autoconfigured driver 3
[    24.674] (==) Matched vesa as autoconfigured driver 4
[    24.674] (==) Assigned the driver to the xf86ConfigLayout
[    24.674] (II) LoadModule: "ati"
[    24.867] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    24.873] (II) Module ati: vendor="X.Org Foundation"
[    24.873] 	compiled for 1.19.0, module version = 7.8.0
[    24.873] 	Module class: X.Org Video Driver
[    24.873] 	ABI class: X.Org Video Driver, version 23.0
[    24.873] (II) LoadModule: "radeon"
[    24.873] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[    24.981] (II) Module radeon: vendor="X.Org Foundation"
[    24.981] 	compiled for 1.19.0, module version = 7.8.0
[    24.981] 	Module class: X.Org Video Driver
[    24.981] 	ABI class: X.Org Video Driver, version 23.0
[    24.981] (II) LoadModule: "modesetting"
[    24.981] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    25.004] (II) Module modesetting: vendor="X.Org Foundation"
[    25.004] 	compiled for 1.19.3, module version = 1.19.3
[    25.004] 	Module class: X.Org Video Driver
[    25.004] 	ABI class: X.Org Video Driver, version 23.0
[    25.004] (II) LoadModule: "fbdev"
[    25.004] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    25.021] (II) Module fbdev: vendor="X.Org Foundation"
[    25.021] 	compiled for 1.19.0, module version = 0.4.4
[    25.021] 	Module class: X.Org Video Driver
[    25.021] 	ABI class: X.Org Video Driver, version 23.0
[    25.021] (II) LoadModule: "vesa"
[    25.022] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    25.045] (II) Module vesa: vendor="X.Org Foundation"
[    25.045] 	compiled for 1.19.0, module version = 2.3.4
[    25.045] 	Module class: X.Org Video Driver
[    25.045] 	ABI class: X.Org Video Driver, version 23.0
[    25.045] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[    25.049] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    25.049] (II) FBDEV: driver for framebuffer: fbdev
[    25.049] (II) VESA: driver for VESA chipsets: vesa
[    25.085] (II) [KMS] Kernel modesetting enabled.
[    25.085] (WW) Falling back to old probe method for modesetting
[    25.121] (WW) Falling back to old probe method for fbdev
[    25.121] (II) Loading sub module "fbdevhw"
[    25.121] (II) LoadModule: "fbdevhw"
[    25.121] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    25.122] (II) Module fbdevhw: vendor="X.Org Foundation"
[    25.122] 	compiled for 1.19.3, module version = 0.0.2
[    25.122] 	ABI class: X.Org Video Driver, version 23.0
[    25.122] (WW) Falling back to old probe method for vesa
[    25.122] (II) RADEON(0): Creating default Display subsection in Screen section
[    25.122] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[    25.122] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    25.122] (==) RADEON(0): Default visual is TrueColor
[    25.122] (==) RADEON(0): RGB weight 888
[    25.122] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[    25.122] (--) RADEON(0): Chipset: "ARUBA" (ChipID = 0x9903)
[    25.159] (II) Loading sub module "fb"
[    25.159] (II) LoadModule: "fb"
[    25.159] (II) Loading /usr/lib/xorg/modules/libfb.so
[    25.180] (II) Module fb: vendor="X.Org Foundation"
[    25.180] 	compiled for 1.19.3, module version = 1.0.0
[    25.180] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    25.180] (II) Loading sub module "dri2"
[    25.180] (II) LoadModule: "dri2"
[    25.180] (II) Module "dri2" already built-in
[    25.180] (II) Loading sub module "exa"
[    25.180] (II) LoadModule: "exa"
[    25.181] (II) Loading /usr/lib/xorg/modules/libexa.so
[    25.218] (II) Module exa: vendor="X.Org Foundation"
[    25.218] 	compiled for 1.19.3, module version = 2.6.0
[    25.218] 	ABI class: X.Org Video Driver, version 23.0
[    25.218] (II) RADEON(0): KMS Color Tiling: enabled
[    25.218] (II) RADEON(0): KMS Color Tiling 2D: enabled
[    25.218] (II) RADEON(0): KMS Pageflipping: enabled
[    25.218] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[    25.229] (II) RADEON(0): Output LVDS has no monitor section
[    25.363] (II) RADEON(0): Output VGA-0 has no monitor section
[    25.364] (II) RADEON(0): Output HDMI-0 has no monitor section
[    25.375] (II) RADEON(0): EDID for output LVDS
[    25.375] (II) RADEON(0): Manufacturer: SEC  Model: 3150  Serial#: 0
[    25.375] (II) RADEON(0): Year: 2011  Week: 0
[    25.375] (II) RADEON(0): EDID Version: 1.3
[    25.375] (II) RADEON(0): Digital Display Input
[    25.375] (II) RADEON(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    25.375] (II) RADEON(0): Gamma: 2.20
[    25.375] (II) RADEON(0): No DPMS capabilities specified
[    25.375] (II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    25.375] (II) RADEON(0): First detailed timing is preferred mode
[    25.375] (II) RADEON(0): redX: 0.615 redY: 0.355   greenX: 0.335 greenY: 0.610
[    25.375] (II) RADEON(0): blueX: 0.150 blueY: 0.100   whiteX: 0.313 whiteY: 0.329
[    25.375] (II) RADEON(0): Manufacturer's mask: 0
[    25.375] (II) RADEON(0): Supported detailed timing:
[    25.375] (II) RADEON(0): clock: 72.3 MHz   Image Size:  344 x 193 mm
[    25.375] (II) RADEON(0): h_active: 1366  h_sync: 1414  h_sync_end 1446 h_blank_end 1526 h_border: 0
[    25.375] (II) RADEON(0): v_active: 768  v_sync: 770  v_sync_end 775 v_blanking: 790 v_border: 0
[    25.375] (II) RADEON(0): Unknown vendor-specific block f
[    25.375] (II) RADEON(0):  SAMSUNG
[    25.375] (II) RADEON(0):  156AT24-T01
[    25.375] (II) RADEON(0): EDID (in hex):
[    25.375] (II) RADEON(0): 	00ffffffffffff004ca3503100000000
[    25.375] (II) RADEON(0): 	00150103802213780a8da59d5b559c26
[    25.375] (II) RADEON(0): 	19505400000001010101010101010101
[    25.375] (II) RADEON(0): 	010101010101411c56a0500016303020
[    25.375] (II) RADEON(0): 	250058c1100000190000000f00000000
[    25.375] (II) RADEON(0): 	00000000001eb4021500000000fe0053
[    25.375] (II) RADEON(0): 	414d53554e470a2020202020000000fe
[    25.375] (II) RADEON(0): 	00313536415432342d5430310a200039
[    25.375] (II) RADEON(0): Printing probed modes for output LVDS
[    25.375] (II) RADEON(0): Modeline "1366x768"x60.0   72.33  1366 1414 1446 1526  768 770 775 790 -hsync -vsync (47.4 kHz eP)
[    25.375] (II) RADEON(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz)
[    25.375] (II) RADEON(0): Modeline "1152x768"x59.8   71.75  1152 1216 1328 1504  768 771 781 798 -hsync +vsync (47.7 kHz)
[    25.375] (II) RADEON(0): Modeline "1024x768"x59.9   63.50  1024 1072 1176 1328  768 771 775 798 -hsync +vsync (47.8 kHz)
[    25.375] (II) RADEON(0): Modeline "800x600"x59.9   38.25  800 832 912 1024  600 603 607 624 -hsync +vsync (37.4 kHz)
[    25.375] (II) RADEON(0): Modeline "848x480"x59.7   31.50  848 872 952 1056  480 483 493 500 -hsync +vsync (29.8 kHz)
[    25.375] (II) RADEON(0): Modeline "720x480"x59.7   26.75  720 744 808 896  480 483 493 500 -hsync +vsync (29.9 kHz)
[    25.375] (II) RADEON(0): Modeline "640x480"x59.4   23.75  640 664 720 800  480 483 487 500 -hsync +vsync (29.7 kHz)
[    25.515] (II) RADEON(0): EDID for output VGA-0
[    25.516] (II) RADEON(0): EDID for output HDMI-0
[    25.516] (II) RADEON(0): Output LVDS connected
[    25.516] (II) RADEON(0): Output VGA-0 disconnected
[    25.516] (II) RADEON(0): Output HDMI-0 disconnected
[    25.516] (II) RADEON(0): Using exact sizes for initial modes
[    25.516] (II) RADEON(0): Output LVDS using initial mode 1366x768 +0+0
[    25.516] (II) RADEON(0): mem size init: gart size :3fdcc000 vram size: s:20000000 visible:1f806000
[    25.516] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[    25.516] (==) RADEON(0): DPI set to (96, 96)
[    25.516] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
[    25.516] (II) Loading sub module "ramdac"
[    25.516] (II) LoadModule: "ramdac"
[    25.516] (II) Module "ramdac" already built-in
[    25.516] (II) UnloadModule: "modesetting"
[    25.516] (II) Unloading modesetting
[    25.516] (II) UnloadModule: "fbdev"
[    25.516] (II) Unloading fbdev
[    25.516] (II) UnloadSubModule: "fbdevhw"
[    25.516] (II) Unloading fbdevhw
[    25.516] (II) UnloadModule: "vesa"
[    25.516] (II) Unloading vesa
[    25.516] (--) Depth 24 pixmap format is 32 bpp
[    25.517] (II) RADEON(0): [DRI2] Setup complete
[    25.517] (II) RADEON(0): [DRI2]   DRI driver: r600
[    25.517] (II) RADEON(0): [DRI2]   VDPAU driver: r600
[    25.517] (II) RADEON(0): Front buffer size: 4128K
[    25.517] (II) RADEON(0): VRAM usage limit set to 460735K
[    25.581] (==) RADEON(0): DRI3 disabled
[    25.581] (==) RADEON(0): Backing store enabled
[    25.581] (II) RADEON(0): Direct rendering enabled
[    25.581] (II) EXA(0): Driver allocated offscreen pixmaps
[    25.581] (II) EXA(0): Driver registered support for the following operations:
[    25.581] (II)         Solid
[    25.581] (II)         Copy
[    25.581] (II)         Composite (RENDER acceleration)
[    25.581] (II)         UploadToScreen
[    25.581] (II)         DownloadFromScreen
[    25.591] (II) RADEON(0): Acceleration enabled
[    25.591] (==) RADEON(0): DPMS enabled
[    25.591] (==) RADEON(0): Silken mouse enabled
[    25.592] (II) RADEON(0): Set up textured video
[    25.592] (II) RADEON(0): [XvMC] Associated with Radeon Textured Video.
[    25.592] (II) RADEON(0): [XvMC] Extension initialized.
[    25.592] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    25.603] (--) RandR disabled
[    25.612] (II) SELinux: Disabled on system
[    27.480] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[    27.480] (II) AIGLX: enabled GLX_ARB_create_context
[    27.480] (II) AIGLX: enabled GLX_ARB_create_context_profile
[    27.480] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[    27.480] (II) AIGLX: enabled GLX_INTEL_swap_event
[    27.480] (II) AIGLX: enabled GLX_SGI_swap_control
[    27.480] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[    27.480] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[    27.480] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[    27.480] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[    27.480] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[    27.483] (II) AIGLX: Loaded and initialized r600
[    27.483] (II) GLX: Initialized DRI2 GL provider for screen 0
[    27.484] (II) RADEON(0): Setting screen physical size to 361 x 203
[    27.979] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[    27.979] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    27.979] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    27.979] (II) LoadModule: "libinput"
[    27.979] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    28.436] (II) Module libinput: vendor="X.Org Foundation"
[    28.437] 	compiled for 1.19.0, module version = 0.23.0
[    28.437] 	Module class: X.Org XInput Driver
[    28.437] 	ABI class: X.Org XInput driver, version 24.1
[    28.437] (II) Using input driver 'libinput' for 'Power Button'
[    28.437] (**) Power Button: always reports core events
[    28.437] (**) Option "Device" "/dev/input/event5"
[    28.437] (**) Option "_source" "server/udev"
[    28.437] (II) event5  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    28.437] (II) event5  - (II) Power Button: (II) device is a keyboard
[    28.437] (II) event5  - (II) Power Button: (II) device removed
[    28.456] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event5"
[    28.456] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    28.456] (**) Option "xkb_model" "pc105"
[    28.456] (**) Option "xkb_layout" "us"
[    28.457] (II) event5  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    28.457] (II) event5  - (II) Power Button: (II) device is a keyboard
[    28.458] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[    28.458] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    28.458] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    28.458] (II) Using input driver 'libinput' for 'Video Bus'
[    28.458] (**) Video Bus: always reports core events
[    28.458] (**) Option "Device" "/dev/input/event6"
[    28.458] (**) Option "_source" "server/udev"
[    28.459] (II) event6  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[    28.459] (II) event6  - (II) Video Bus: (II) device is a keyboard
[    28.459] (II) event6  - (II) Video Bus: (II) device removed
[    28.480] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7/event6"
[    28.480] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    28.480] (**) Option "xkb_model" "pc105"
[    28.480] (**) Option "xkb_layout" "us"
[    28.481] (II) event6  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[    28.481] (II) event6  - (II) Video Bus: (II) device is a keyboard
[    28.482] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    28.482] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    28.482] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    28.482] (II) Using input driver 'libinput' for 'Power Button'
[    28.482] (**) Power Button: always reports core events
[    28.482] (**) Option "Device" "/dev/input/event3"
[    28.482] (**) Option "_source" "server/udev"
[    28.483] (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    28.483] (II) event3  - (II) Power Button: (II) device is a keyboard
[    28.483] (II) event3  - (II) Power Button: (II) device removed
[    28.512] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4/event3"
[    28.512] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    28.512] (**) Option "xkb_model" "pc105"
[    28.512] (**) Option "xkb_layout" "us"
[    28.513] (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    28.513] (II) event3  - (II) Power Button: (II) device is a keyboard
[    28.514] (II) config/udev: Adding input device Lid Switch (/dev/input/event4)
[    28.514] (II) No input driver specified, ignoring this device.
[    28.514] (II) This device may have been added with another device file.
[    28.515] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[    28.515] (II) No input driver specified, ignoring this device.
[    28.515] (II) This device may have been added with another device file.
[    28.516] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse (/dev/input/event1)
[    28.516] (**) MOSART Semi. 2.4G Wireless Mouse: Applying InputClass "evdev pointer catchall"
[    28.516] (**) MOSART Semi. 2.4G Wireless Mouse: Applying InputClass "libinput pointer catchall"
[    28.516] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Wireless Mouse'
[    28.516] (**) MOSART Semi. 2.4G Wireless Mouse: always reports core events
[    28.516] (**) Option "Device" "/dev/input/event1"
[    28.516] (**) Option "_source" "server/udev"
[    28.576] (II) event1  - (II) MOSART Semi. 2.4G Wireless Mouse: (II) is tagged by udev as: Mouse
[    28.576] (II) event1  - (II) MOSART Semi. 2.4G Wireless Mouse: (II) device is a pointer
[    28.576] (II) event1  - (II) MOSART Semi. 2.4G Wireless Mouse: (II) device removed
[    28.608] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:10.0/usb1/1-2/1-2:1.0/0003:062A:4102.0001/input/input3/event1"
[    28.608] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Wireless Mouse" (type: MOUSE, id 9)
[    28.608] (**) Option "AccelerationScheme" "none"
[    28.608] (**) MOSART Semi. 2.4G Wireless Mouse: (accel) selected scheme none/0
[    28.608] (**) MOSART Semi. 2.4G Wireless Mouse: (accel) acceleration factor: 2.000
[    28.608] (**) MOSART Semi. 2.4G Wireless Mouse: (accel) acceleration threshold: 4
[    28.672] (II) event1  - (II) MOSART Semi. 2.4G Wireless Mouse: (II) is tagged by udev as: Mouse
[    28.672] (II) event1  - (II) MOSART Semi. 2.4G Wireless Mouse: (II) device is a pointer
[    28.673] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse (/dev/input/mouse0)
[    28.673] (II) No input driver specified, ignoring this device.
[    28.673] (II) This device may have been added with another device file.
[    28.674] (II) config/udev: Adding input device TOSHIBA Web Camera - HD (/dev/input/event8)
[    28.674] (**) TOSHIBA Web Camera - HD: Applying InputClass "evdev keyboard catchall"
[    28.674] (**) TOSHIBA Web Camera - HD: Applying InputClass "libinput keyboard catchall"
[    28.675] (II) Using input driver 'libinput' for 'TOSHIBA Web Camera - HD'
[    28.675] (**) TOSHIBA Web Camera - HD: always reports core events
[    28.675] (**) Option "Device" "/dev/input/event8"
[    28.675] (**) Option "_source" "server/udev"
[    28.675] (II) event8  - (II) TOSHIBA Web Camera - HD: (II) is tagged by udev as: Keyboard
[    28.675] (II) event8  - (II) TOSHIBA Web Camera - HD: (II) device is a keyboard
[    28.676] (II) event8  - (II) TOSHIBA Web Camera - HD: (II) device removed
[    28.736] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:13.2/usb4/4-4/4-4:1.0/input/input9/event8"
[    28.736] (II) XINPUT: Adding extended input device "TOSHIBA Web Camera - HD" (type: KEYBOARD, id 10)
[    28.736] (**) Option "xkb_model" "pc105"
[    28.736] (**) Option "xkb_layout" "us"
[    28.737] (II) event8  - (II) TOSHIBA Web Camera - HD: (II) is tagged by udev as: Keyboard
[    28.737] (II) event8  - (II) TOSHIBA Web Camera - HD: (II) device is a keyboard
[    28.738] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event10)
[    28.738] (II) No input driver specified, ignoring this device.
[    28.738] (II) This device may have been added with another device file.
[    28.738] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event11)
[    28.739] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event12)
[    28.739] (II) No input driver specified, ignoring this device.
[    28.739] (II) This device may have been added with another device file.
[    28.740] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    28.740] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    28.740] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    28.740] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    28.740] (**) AT Translated Set 2 keyboard: always reports core events
[    28.740] (**) Option "Device" "/dev/input/event0"
[    28.740] (**) Option "_source" "server/udev"
[    28.741] (II) event0  - (II) AT Translated Set 2 keyboard: (II) is tagged by udev as: Keyboard
[    28.741] (II) event0  - (II) AT Translated Set 2 keyboard: (II) device is a keyboard
[    28.741] (II) event0  - (II) AT Translated Set 2 keyboard: (II) device removed
[    28.764] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    28.764] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[    28.764] (**) Option "xkb_model" "pc105"
[    28.764] (**) Option "xkb_layout" "us"
[    28.765] (II) event0  - (II) AT Translated Set 2 keyboard: (II) is tagged by udev as: Keyboard
[    28.765] (II) event0  - (II) AT Translated Set 2 keyboard: (II) device is a keyboard
[    28.765] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event2)
[    28.765] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    28.765] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[    28.765] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[    28.765] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[    28.765] (II) LoadModule: "synaptics"
[    28.765] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    28.785] (II) Module synaptics: vendor="X.Org Foundation"
[    28.785] 	compiled for 1.19.0, module version = 1.9.0
[    28.785] 	Module class: X.Org XInput Driver
[    28.785] 	ABI class: X.Org XInput driver, version 24.1
[    28.785] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[    28.785] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    28.785] (**) Option "Device" "/dev/input/event2"
[    28.828] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
[    28.828] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5634 (res 51)
[    28.828] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4598 (res 76)
[    28.828] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[    28.828] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[    28.828] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[    28.828] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[    28.828] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    28.828] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    28.868] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input2/event2"
[    28.868] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 12)
[    28.868] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[    28.868] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[    28.868] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.038
[    28.869] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[    28.869] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[    28.869] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    28.869] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    28.869] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    28.870] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[    28.870] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[    28.870] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[    28.870] (II) No input driver specified, ignoring this device.
[    28.870] (II) This device may have been added with another device file.
[    48.343] (II) RADEON(0): EDID vendor "SEC", prod id 12624
[    48.343] (II) RADEON(0): Printing DDC gathered Modelines:
[    48.343] (II) RADEON(0): Modeline "1366x768"x0.0   72.33  1366 1414 1446 1526  768 770 775 790 -hsync -vsync (47.4 kHz eP)
[    48.491] (II) RADEON(0): EDID vendor "SEC", prod id 12624
[    48.491] (II) RADEON(0): Printing DDC gathered Modelines:
[    48.491] (II) RADEON(0): Modeline "1366x768"x0.0   72.33  1366 1414 1446 1526  768 770 775 790 -hsync -vsync (47.4 kHz eP)
[    48.956] (II) RADEON(0): EDID vendor "SEC", prod id 12624
[    48.956] (II) RADEON(0): Printing DDC gathered Modelines:
[    48.956] (II) RADEON(0): Modeline "1366x768"x0.0   72.33  1366 1414 1446 1526  768 770 775 790 -hsync -vsync (47.4 kHz eP)
#20 2017-11-02 16:19:05
cynwulf
Nothing wrong there.  Your X.org and video driver setup seems ok to the best of my knowledge.
If running VLC from a terminal emulator doesn't show up anything when the problem occurs, then I'm pretty much out of ideas on that one.
See if another media player such as one which uses mplayer as a back end has the same issue.
#21 2017-11-02 17:13:57
keos
Mplayer/Gmlive were uninstalled. Now after install again these programs i went back to vlc and everything looks perfect – i will continuing checking vlc till tomorrow before to give the subject by solved.
Thank for everything!.
#22 2017-11-02 17:47:04
keos
No. it was not necessary to wait till tomorrow, it went back to  the blackness ...
--- i don't like mplayer i can't run the videos automatically.
#23 2017-11-02 17:51:01
I suggested trying the wheezy version - Twoflower.   Might be worth a try since it seems you're kind of at the end of the road . . .
#24 2017-11-02 18:54:01
keos
it is not free ... i think that i'm going to uninstall devuan ...
#25 2017-11-02 20:52:49
If it's not "free", it's because of what you've added to it.  wink   A default Devuan install is indeed free software.
