#1 2017-10-05 15:24:54
boycottsystemd
[SOLVED] wine32 in Devuan 1.0 Jessie 64 bit ?
Is it possible to install wine32 in Devuan 1.0 Jessie 64 bit ?
# apt-get install wine32
Building dependency tree
 wine32:i386 : Depends: libwine:i386 but it is not going to be installed
               Depends: libgl1-mesa-dri:i386 but it is not going to be installed
#2 2017-10-05 16:17:14
debdog
Re: [SOLVED] wine32 in Devuan 1.0 Jessie 64 bit ?
You probably have to enable multiarch: https://wiki.debian.org/Multiarch/HOWTO#Usage
The wine packages shipped with Jessie are ancient, though. Preferably use the ones provided by the wine project:
https://wiki.winehq.org/Debian
#3 2017-10-05 16:47:21
boycottsystemd
I've run
# dpkg --add-architecture i386 && apt-get update
before trying to install wine32.
Is it officialy recommended and safe to use debian version of wine ?
#4 2017-10-05 17:24:17
All compatible Debian packages are in the Devuan merged repos.  Do not use Debian pkgs directly.
Have you installed the multiarch packages?
#5 2017-10-05 21:08:33
Racoton
I have uninstall wine last week, but still I can see one packet installed: wine32:i386. It necessary was for wine installation. I think answer is yes.
#6 2017-10-06 08:14:10
debdog
Ok, on second glance, there's something odd about that error. Could you run it again but with aptitude instead of apt-get? It usually returns more useful messages.
Nothing is safe. From what officials do you need approval?
Let's put it this way: depends on what you want to run. Some old software runs fine with the ancient wine version provided by Jessie. Most modern ones just won't. And, if you show up at winehq asking for help, the first advice you'll get is to update to latest version.
Which GPU and driver do you use and how did you install the driver?
#7 2017-10-06 11:58:43
boycottsystemd
I've installed multiarch-support and binutils-multiarch
#8 2017-10-06 12:12:20
boycottsystemd
I've broken my system by debian updates (https://dev1galaxy.org/viewtopic.php?id=1609)
I downgraded packages mentioned in aptitude error message and it has solved problem described in first post.
I would expect it from someone who has good knowledge of Devuan, probably from developers.
I want to run WarThunder in wine because linux version is not working: https://dev1galaxy.org/viewtopic.php?id=1615
see link above.
I've default driver if I remember correctly.
#9 2017-10-06 14:51:18
MiyoLinux
Here's a quick rundown of what I do to install 32 bit Wine...
First, make sure that you have 32 bit architecture enabled on the 64 bit...
Open your terminal, and enter the following commands one at a time.
Followed by...
apt-get update
Then, open Synaptic, and "mark" the packages for installation in the order given in the link below...
https://sourceforge.net/p/miyolinux/wiki/Wine%20/
To install a program with Wine, use the "Custom Command" --> wine
#10 2017-10-06 15:08:45
That's a handy howto, Myio.  Hopefully I'll remember it when I finally get on ascii.
And an OT note . . . on your wiki page you say:
There is also an "unofficial" Devuan forum which may be used.
We've been 'official' for many months now.  wink
#11 2017-10-06 15:30:03
MiyoLinux
DOH! yikes
I'll fix that now. Thank you golinux.
#12 2017-10-06 16:32:03
MiyoLinux
In addition to my response above...
I'm currently running KDE-Plasma on Devuan Ascii. The instructions vary slightly for Ascii at this point. Whether it changes in the future when Ascii becomes Stable...I'm not sure.
In Synaptic...
1. Install wine32-preloader:i386 (don't install the development version; it will break)...this will also install "wine".
2. Install winetricks
Then, to install a Wine program, use the custom command --> wine32
#13 2017-10-07 09:42:00
boycottsystemd
Followed by...
apt-get update
Thank you for reply and for Miyo distro smile
#14 2017-10-07 14:09:43
MiyoLinux
Glad to help if I can. Good luck! Hey, if you're wanting to run War Thunder, have you considered trying PlayOnLinux? It's in the repos. I've never used it myself, but many people say that PlayOnLinux works wonders for them.
I also tried Steam some time back to see how it would do in Miyo. Maybe I was lucky, but I just installed it through Synaptic, and it worked out of the box. I do remember trying War Thunder on Steam, but I guess my graphics couldn't handle it. I tried a few other games, and they worked great. War Thunder was free on Steam back when I tried it.
https://youtu.be/IPWHuI_dTq4
#15 2017-10-07 16:44:42
boycottsystemd
Thank you, WT is running fine now. Maybe I'll try PlayOnLinux and Steam some day.
#16 2017-10-07 17:10:41
MiyoLinux
As we say here in the US, if it ain't broke, don't fix it! wink
Take care!
#17 2017-10-08 16:16:28
boycottsystemd
Thank you smile
We say "Why change something what is ok ?"   smile
