#1 2017-08-20 22:11:22
catprints
ascii/lxqt wifi address change
Playing with ascii/lxqt install and for my use it's pretty good. So I decided to install eudev and the install went smoothly using synaptic with experimental repo temporarily enabled. ON reboot all appeared normal. A few more reboots and wifi was not connecting.
Short story is address was no longer wlan0. Now wlxc83a35c261fd. (used ip list command someone helpful mentioned somewhere to get address) I don't know what does this or why it did'nt happen immediately on eudev install. Just thought I would share in case someone could enlighten me or be enlightened with the information.
"The obstacle is the path."
#2 2017-08-20 22:41:03
Re: ascii/lxqt wifi address change
Guess you're not 0n the dng mail list . . .
https://lists.dyne.org/lurker/message/2 … 3f.en.html
That should give you some clues about what's going on.
#3 2017-08-21 00:09:34
catprints
Very much to the point of my issue. I do follow the mailing list- just a little after the fact in this case. I still wonder why it was not an immediate problem but took several reboots to show up.
* thanks for the link.
#4 2017-08-21 02:11:33
Yeah, that's weird. I have one ascii install that I've been running without adding net.ifnames=0 to the boot command except for one morning when I did need it for a few reboots. It was when I was playing with policykit/pkexec/synaptic. Doesn't make sense.
