#1 2017-08-04 14:47:05
viverna
Scanner and sane-utils
Hello folks,
I'm a new Devuan user (from Debian) from few week.
In Debian world I had a problem with my scanner, the script (run by user root) in /usr/local/bin/sanato solves the problem assigning group 'scanner' to device:
line=`sane-find-scanner | grep 'found USB scanner' | sed -e 's/.*libusb://'`
if [ "$line" = "" ]; then
        echo not found
else
        line=`echo $line | sed -e 's;:;/;'`
        chgrp scanner /dev/bus/usb/$line
fi
With devuan remained the problem. Sane-utils is systemd infected and so I wrote a new script:
line=`lsusb|grep "Your model"|sed -e 's/Bus \([0-9]\+\) Device \([0-9]\+\).\+/\1\/\2/'`
        echo not found
else
fi
Change "Your model" with your scanner.
Udev rules that run script:
# /etc/udev/rules.d/42-usb-permissions.rules
SUBSYSTEM!="usb", GOTO="end_skip_usb"
ACTION=="add", RUN+="/usr/local/bin/sanato"
LABEL="end_skip_usb"
It can serve someone.
#2 2017-08-04 15:52:19
Re: Scanner and sane-utils
Thanks and welcome, viverna.
#3 2017-09-23 14:05:25
viverna
Thanks golinux.
