Hi All. Found a minor installer issue. The problem described in the title occurs with "devuan_excalibur_6.1.1_amd64_netinstall.iso". This boot menu is NOT the grub boot menu. On this thin client PC, I have to press the letter 'p' during the BIOS startup to get to the BIOS's Boot Menu.
It does not occur with Jessie "devuan_jessie_1.0.0_amd64_NETINST.iso". When I installed Jessie, the BIOS boot menu correctly showed "devuan".
The problem does not occur when I installed using legacy boot. Actually, nothing is added to the BIOS boot menu when in legacy mode.
A quick search shows that UEFI boot entries are stored in NVRAM somewhere on the motherboard. So I assume that the Devuan installer writes to this location using the command "efibootmgr". But somewhere between Jessie and Excalibur, this command was changed and wrote "Debian" instead of "Devuan".
Your finding isn't astonishing for me. it applies to installations in efi mode. This is the case since ASCII. grub-install is 1:1 a Debian package.
I am solving this topic for me by doing another grub-install past the installation, here an example for Excalibur and w/o Secure Boot:
# grub-install --bootloader-id=devuan6 --no-uefi-secure-boot When there are major updates of grub packages that trigger a grub-install it can happen that debian is appearing again. Then you have to repeat the fix.
