My next test in a VBox VM. My setup: efi, German language, keyboard, timezone, expert install to cli with sysvinit, luks encrypted. Manual installation of Lightdm/X11 and Cinnamon DE w/o recommends to reduce the usual bloat and to get a system with that sw I like and need. I am using my notes so the result is mostly reproduceable.
The installer works as usual, no comments.
The problem I am facing now: when I try to login into the DE, after 2 seconds LightDM comes back with the login mask. The same symptoms you face when your /home is full. The language setting in LightDM is on German, my special characters are correct.
I managed to look at the VM from the installer in rescue mode. Enough disk space available according df -h. My /home/$USER is nearly empty, just 8 or 9 . files like .XAuthority are present, no trace of the XDG folders like Documents ... or .config.
What is going on here? Is it possible that due to changed dependencies my installation with --no-install-recommends suddenly lacks an important package? How do I troubleshoot this?
Could be related to the .XAuthority file
https://wiki.archlinux.org/title/LightD … login_loop
Re-examine all that you have been told. Dismiss that which insults your soul. - Walt Whitman
Dump shampoo and hair dye
Global Skywatch・Subliminal Manipulation
