Hello ,
i have transfered an SSD from gifted workstation onto a newly found sff-pc.
it seems to function just fine (devuan 6)
but it seems there is some issue involved since was invoking
"ufw enable" and getting this response.
WARN: uid is 0 but '/lib' is owned by 1000
WARN: /lib is group writable!
WARN: uid is 0 but '/usr' is owned by 1000
WARN: /usr is group writable!
Firewall is active and enabled on system startupis there a proper way to recover from this "issue" or should be considered botched and hence a new install be undertaken.
thank you very much.
