#1 Yesterday 23:17:36
vi.joe
RTL9210 quirks
hi there !
you know those little enclosures to have ssd or nvme storage attached via usb ?
some are great ... some fail ...
long story, short ending ...
most times it's the RTL9210 built in firmware doing AUTOSUSPEND ... wtf ...
so .. keep that thingee alive ... ;-)
my solution:
# SysVinit
cat << 'EOF' > /etc/init.d/rtl9210-fix
### BEGIN INIT INFO
# Provides:          rtl9210-fix
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Prevent autosuspend for Realtek RTL9210 adapters
# Description:       Read SMART every 10 seconds to prevent autosuspend
### END INIT INFO
DAEMON=/usr/local/sbin/rtl9210-fix.sh
INTERVAL=10
case "$1" in
  start)
    echo "Starting RTL9210 Autosuspend Fix ..."
    # Background Loop
    nohup /bin/bash -c \
      "while true; do $DAEMON; sleep $INTERVAL; done" >/dev/null 2>&1 &
    # remember PID
    echo $! > /var/run/rtl9210-fix.pid
    PID=$(cat /var/run/rtl9210-fix.pid 2>/dev/null)
    echo "Service rtl9210-fix active, PID: $PID"
  stop)
    echo "Stopping RTL9210 Autosuspend Fix ..."
    if [ -n "$PID" ]; then
      echo "Service rtl9210-fix PID: $PID stopping"
      kill $PID
      rm -f /var/run/rtl9210-fix.pid
    fi
  status)
    echo "Status RTL9210 Autosuspend Fix ..."
    if [ -z "$PID" ]; then
      echo "Service rtl9210-fix not active, no PID found"
    else
      echo "Service rtl9210-fix active, PID: $PID "
      smartctl --scan 2>/dev/null | grep -i realtek
    fi
  restart)
    $0 stop
    $0 start
    echo "Usage: $0 {start|stop|restart}"
    exit 1
esac
exit 0
# eof
EOF
chmod +x /etc/init.d/rtl9210-fix
# DAEMON
cat << 'EOF' > /usr/local/sbin/rtl9210-fix.sh
#!/bin/bash
# get all Storage Devices with Realtek Controller
disks=$(sudo smartctl --scan 2>/dev/null | grep -i realtek | sed 's/ .*$//')
if [ -z "$disks" ]; then
    exit 0
fi
for disk in $disks; do
    # read SMART Data to keep Realtek Device(s) "alive"
    smartctl -a $disk >/dev/null 2>&1
done
# eof
EOF
chmod +x /usr/local/sbin/rtl9210-fix.sh
# activate Service for all Runlevels
update-rc.d rtl9210-fix defaults
any reactions are welcome ... ;-)
greets
