Pages: 1
I've uploaded umnt which is an awk script to mount network drives based on an fstab-like configuration file: <https://codeberg.org/awk-scripting/umnt>. It does not use gvfs but mount (to make a late reply to https://dev1galaxy.org/viewtopic.php?id=7851). Something like
<your-user> ALL=(ALL) NOPASSWD: /usr/bin/mount *
<your-user> ALL=(ALL) NOPASSWD: /usr/bin/umount *in /etc/sudoers is recommended. umnt supports smb, sftp and dav filesystems. It's a kind of beta release but good enough for use.
Now the (perhaps) interesting point: umnt does not do the mount itself. Instead, it creates the shell code to make the mount which must be piped to /bin/sh. To illustrate, here is one of the two example scripts.
$ cat net-mount
# Must be run in tty window.
dir=$(umnt --list |
dmenu |
umnt --stdin --verbose |
sh)
[ "$dir" != "" ] && open "$dir" &Why do I post that here? Of course, you might want to use that thing. My use case is simply "no gvfsd". But I would also like to get some feedback on the approach and suggestions for the next thing I would like to implement that way: network configuration, that is, have a script that reads configuration information and creates the shell script to configure the network. But I already understand that this is more difficult.
Pages: 1
