#1 2026-10-04 19:53:54
kapqa
[SOLVED] error report - kernel excalibur-backports
Hello ,
have accidentally shot down my partition so it took me some time to recover
have noticed that on another partition the kernel is already above 7 (for excalibur, via bpo)
now on this new install, the kernel via backports does not seem wanna install;
maybe i did something wrong, otherwise please consider it as an "error bugreport" posted here instead of official bugreport.
getting this
sudo apt -t excalibur-backports install linux-image-amd64
Solving dependencies... Error!
Unsatisfied dependencies:
 linux-base-amd64 : Depends: linux-base-7.1.13+deb13-amd64 (= 7.1.13-1~bpo13+1) but it is not installable
 linux-image-7.1.13+deb13-amd64 : Depends: linux-base-7.1.13+deb13-amd64 (= 7.1.13-1~bpo13+1) but it is not installable
                                  Depends: linux-binary-7.1.13+deb13-amd64 (= 7.1.13-1~bpo13+1) but it is not going to be installed
                                  Depends: linux-modules-7.1.13+deb13-amd64 (= 7.1.13-1~bpo13+1) but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
   Unable to satisfy dependencies. Reached two conflicting decisions:
   1. linux-base-amd64:amd64 is selected for install because:
      1. linux-image-amd64:amd64=7.1.13-1~bpo13+1 is selected as an upgrade
      2. linux-image-amd64:amd64=7.1.13-1~bpo13+1 Depends linux-base-amd64 (= 7.1.13-1~bpo13+1)
   2. linux-base-amd64:amd64 Depends linux-base-7.1.13+deb13-amd64 (= 7.1.13-1~bpo13+1)
      but none of the choices are installable:
      [no choices]
#2 2026-10-05 10:11:08
kapqa
Re: [SOLVED] error report - kernel excalibur-backports
thanks, it fucntioned after applieing
sudo apt modernize-sources
The following files need modernizing:
  - /etc/apt/sources.list
  - /etc/apt/sources.list.d/boinc.list
Modernizing will replace .list files with the new .sources format,
add Signed-By values where they can be determined automatically,
and save the old files into .list.bak files.
This command supports the 'signed-by' and 'trusted' options. If you
have specified other options inside [] brackets, please transfer them
manually to the output files; see sources.list(5) for a mapping.
For a simulation, respond N in the following prompt.
Rewrite 2 sources? [Y/n]
Modernizing /etc/apt/sources.list...
- Writing /etc/apt/sources.list.d/devuan.sources
- Writing /etc/apt/sources.list.d/devuan-backports.sources
Warning: Could not determine Signed-By for URIs: http://deb.devuan.org/merged/, Suites: excalibur-backports
sudo apt update
Hit:1 http://deb.devuan.org/merged excalibur-backports InRelease
Hit:2 http://deb.devuan.org/merged excalibur InRelease
Hit:3 http://deb.devuan.org/merged excalibur-security InRelease
Hit:4 http://deb.devuan.org/merged excalibur-updates InRelease
Hit:5 https://boinc.berkeley.edu/dl/linux/alpha/trixie trixie InRelease
All packages are up to date.
Notice: Missing Signed-By in the sources.list(5) entry for 'http://deb.devuan.org/merged'
Upgrading:
  linux-base  linux-headers-amd64  linux-image-amd64  linux-libc-dev  linux-sysctl-defaults
Installing dependencies:
  cpp-14-for-host               linux-binary-7.2.6+deb13-amd64    linux-kbuild-7.2.6+deb13
  gcc-14-for-host               linux-headers-7.2.6+deb13-amd64   linux-modules-7.2.6+deb13-amd64
  linux-base-7.2.6+deb13-amd64  linux-headers-7.2.6+deb13-common
  linux-base-amd64              linux-image-7.2.6+deb13-amd64
Suggested packages:
  debian-kernel-handbook  firmware-linux-free  linux-doc-7.2
Summary:
  Upgrading: 5, Installing: 10, Removing: 0, Not Upgrading: 129
  Download size: 191 MB
  Space needed: 290 MB / 739 GB available
