#1 Today 08:15:55
bai4Iej2need
grafana
I wanted to test grafana.
After the last update aptitude reported that it was broken because of a missing dependency from systemd.
https://grafana.com/docs/grafana/latest … tallation/
But the website reports, that start is also possible with sysvinit.
Now I removed grafana again, because I did not use it.
Does anyone know more ?
broken by design :
#2 Today 11:36:35
Re: grafana
bai4Iej2need wrote:
... aptitude reported that it was broken because of a missing dependency from systemd.
Well ...
I think the [aptitude] printout says it all.
ie: missing dependency from [systemd].
If my memory serves me right, three or four years ago I read that the devs at Debian decided that packages containing [sysvinit] scripts would no longer be accepted in their repositories.*
That decision eventually bore fruit:
Boyuan Yang @bugs.debian.org wrote:
    Since sysvinit is not enabled by default in Debian, I do not consider this bug as release-critical.
    Downgrading the bug severity to "normal".
See:
https://bugs.debian.org/cgi-bin/bugrepo … ug=1034328
https://dev1galaxy.org/viewtopic.php?pid=44938#p44938
But it could well be (?) that the package you need is still in the process of being sanitised by the Devuan packagers.
Give it time.
* sorry, cannot find the link to that.
