#1 Yesterday 23:37:22
mlxdy
[SOLVED] Waydroid don't working on Devuan
[01:17:21] Starting waydroid session
[01:17:21] ERROR: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout e
xpired, or the network connection was broken.
[01:17:21] See also: <[url]https://github.com/waydroid[/url]>
[01:17:21] Traceback (most recent call last):
  File "/usr/lib/waydroid/tools/actions/app_manager.py", line 64, in maybeLaunchLater
    tools.helpers.ipc.DBusSessionService()
  File "/usr/lib/waydroid/tools/helpers/ipc.py", line 12, in DBusSessionService
    return dbus.Interface(dbus.SessionBus().get_object("id.waydro.Session", object_path), intf)
  File "/usr/lib/python3/dist-packages/dbus/_dbus.py", line 209, in __new__
    return Bus.__new__(cls, Bus.TYPE_SESSION, private=private,
                       mainloop=mainloop)
  File "/usr/lib/python3/dist-packages/dbus/_dbus.py", line 99, in __new__
    bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop)
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 120, in __new__
    bus = cls._new_for_bus(address_or_type, mainloop=mainloop)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the re
ply timeout expired, or the network connection was broken.
During handling of the above exception, another exception occurred:
  File "/usr/lib/waydroid/tools/__init__.py", line 123, in main
    actions.app_manager.showFullUI(args)
  File "/usr/lib/waydroid/tools/actions/app_manager.py", line 132, in showFullUI
    maybeLaunchLater(args, justShow)
  File "/usr/lib/waydroid/tools/actions/app_manager.py", line 72, in maybeLaunchLater
    tools.actions.session_manager.start(args, launchNow, background=False)
  File "/usr/lib/waydroid/tools/actions/session_manager.py", line 42, in start
    _name = dbus.service.BusName("id.waydro.Session", dbus.SessionBus(), do_not_queue=True)
                       mainloop=mainloop)
Any ideas how to fix this? It worked in the past on Devuan as I remember, but since they moved Waydroid to backports it stopped hmm
I use OpenBox WM with Slim if it's related to problem.
#2 Today 00:17:59
mlxdy
Re: [SOLVED] Waydroid don't working on Devuan
Don't run Waydroid as root! Run waydroid container start as root, then waydroid as user
This is solution smile
